PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 [127] 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. high rpm wot cracking noises
  2. Proliance Radiators
  3. can a ls1 SS spoiler fit a lt1
  4. Bolt On LT1 Times Inside
  5. Stock lt1 injectors are rated @ X PSI?
  6. Anyone running these???
  7. TEA 220cc vs AI 200cc on a 383
  8. over the valve cover spark plug wires?
  9. LT1 heads ?
  10. 02 sensors bad already?
  11. Bumper Support
  12. Looking into true duals
  13. can someone look at me datamaster files and tune?
  14. How to tell
  15. Popping noise while turning
  16. What's this worth?
  17. Dyno'd my turd.... :)
  18. tuning questions
  19. What sponsor sells EGR blockoffs cheap?
  20. AIR delete quesion
  21. header bolt help
  22. front needs raising
  23. K&N CAI Problem
  24. The Big Suck
  25. Anyone else have this issue with Hot Cam
  26. auto tap who likes/dislikes it and why?
  27. 383 need cam , some advice
  28. What a great night...
  29. Help
  30. 388 LT1 guys in here
  31. Will this X-Pipe fit my 1996 lt1?
  32. lt1 into a 1995 v6 camaro
  33. new setup, question about injectors?!?!?!?
  34. Another LT1 tuned by PCMForLess...
  35. lets hear how much power you stock 4l60e can handle
  36. Lt-4 km
  37. T56 dust cover bolts
  38. chiltons manual...
  39. gm847??
  40. Occasional misfire in High RPM under load
  41. Injectors
  42. Is this typical?
  43. Please help,my g-body failed smog,high Co and HC with pic of report!
  44. What's this worth?
  45. Should I buy?
  46. Are the Vortec 4.3l V6the only ones?
  47. true duals or stick wit cat back?
  48. Griffin Radiator for stand up
  49. Who all has removed the bracket that connects the alternator to the intake?
  50. GMHTP LT1 Build...
  51. New PB AGAIN!! 10.84@124
  52. Next mod before headers?
  53. Lt1 Question
  54. LTX VS Stang on PINKS NOW
  55. New Best - 11.18 @ 120.33 N/A
  56. gm847
  57. help
  58. Whats a good transcooler?
  59. Odometer??
  60. auto shifting early and wont down shift after manifold swap
  61. LS1 rockers
  62. Trick Flow Gen X Heads
  63. Need help...please..
  64. 1le a/c delete pulley
  65. What Ignition Box
  66. AFS105 = AC Delco???
  67. Car is surging at low rpms
  68. Any difference
  69. How long can i drive wit o2's unplugged?
  70. Small head unit problem...
  71. Where and how much?
  72. Mids w/ a cam okay?
  73. AFR head / piston valve relief question
  74. 99 s10 transmission into 97 camaro
  75. Can a stock LT1 motor hang a wheel?
  76. Ford owners... lol
  77. unplugged o2's= high oil pressure??
  78. what head?
  79. best place to purchase hooker lt y pipe
  80. Y-Pipe struggle and questions!!! pics
  81. ls1 steering shaft
  82. Pattern and Dimensions for Fuel Rail Covers
  83. Sorry Guys I went to a LS1
  84. Good experiences with MSD opti???
  85. Rod and Piston suggestions?
  86. rear end out of line?
  87. Great now I think they are really noisy
  88. shop told me the problem, the opti is shot.....
  89. 3rd gen steering wheel adapter on 4th gen t/a
  90. Subframe Connectors What do you have??
  91. Stock 1/4 time for 96-97 ws6/SS
  92. Whats Size Pushrods For 383 w gm 847
  93. misfire at high rpms?
  94. best place to buy optispark
  95. FBody LT1 Compression Ratio
  96. How restrictive is the stock Camaro exhaust?
  97. 700r4 swap
  98. good LT1 turbo topend?
  99. u-joints 1le aluminum driveshaft
  100. How to clear codes on OBDII TA?
  101. Sell, or not to sell?
  102. Where to find NGK TR6 plugs?
  103. TB question
  104. stock bottom end-nitrous-cam
  105. Who is a guy who Cuts Custom Grind Blower Cams
  106. Second time at track w/ Cadillac Cam!!!!
  107. 355 Rebuild
  108. 383 or 396
  109. Problems with my sons 94 z28
  110. neen some help what is it worth
  111. trans question
  112. Engine Removal 94 LT1 (PICS INSIDE)
  113. New PB 1/4 mile this time!!
  114. Whoa is me
  115. Z doesnt wanna start! need input!
  116. flowtech vs magnaflow?
  117. head gasket/ stumble
  118. line locks?
  119. gm847 open headers...vid
  120. Kooks LT what oil filter to use?
  121. DMH Low Profile E-CutOuts...
  122. Hilarious
  123. park neutral safety switch wire
  124. ac delete writeup?
  125. TH-350/400 guys come on in
  126. So what is the T56 worth out of a LTx F-Body?
  127. Differential Cover... Help me decide
  128. turn signals
  129. More misfire woes
  130. ss lt1 intake
  131. need some help
  132. th 400
  133. electric water pump?
  134. emissions!!!!!!
  135. Rewiring '95 TCS switch harness for'97+ TCS switch
  136. Is this a blown head gasket??
  137. Cap & Rotor install ?
  138. Where to buy.....?
  139. my "where does this go" thread
  140. 98-02 brake conversion?
  141. please help me!friends head is swelling
  142. Rough Day and need to vent!
  143. eliminating accessories
  144. LT1 Canfield heads - Which Guide plates?
  145. Pro Mag valve lash
  146. New brakes, right rear caliper sticking
  147. what header wrap?
  148. 4.3 LT1 external parts the same as a 5.7?
  149. What exhaust to run?
  150. Sparkplugs
  151. 97 Trans am running a bit rough...
  152. suspension
  153. Which type supercharger for an LT1?
  154. Those using MSD Opti's, I have a question
  155. Help with cam choice...
  156. Lt1 cam
  157. please help wont start
  158. bad cold start problem
  159. By_pass fans on car...
  160. Broke sypder plate, which lifters?
  161. Which clutch??
  162. Check Gages Light
  163. PS removal?? How to?
  164. EVAP with a Monoblade
  165. New Vlavetrain = burning oil
  166. Comp Cams XFI 268 cam...
  167. My LE2 Swap and Before/After True Duals *Videos*
  168. lt1 in a s10 performance upgrade
  169. Pulling SES Codes Manually without a scanner?
  170. What do you think of this Tuner?
  171. SES comes on at idle
  172. Aftermarket steering wheel?
  173. New best but broke trans
  174. Shakedown runs with cc306 + full bolt-ons
  175. Help with ALDL cable
  176. No real street time on my cam, lmk what you think
  177. In the market for headers..
  178. brake issue.
  179. YEEEEHAH! I made it on all outtakes
  180. AI 200cc H/C Track Times UPDATE!!
  181. I have a question about the mass air flow sensor
  182. Thanksgiving Present II - Install! with pics
  183. does cutting off a turndown tip help with resonance???
  184. LS1 radiator in to LT1
  185. Tuning Question.. please help
  186. IAC valve---95/96 different???
  187. lightweight battery
  188. Finished up the Dyno Tune.
  189. vigilante 2800 9.5 converter
  190. oil pressure sending unit
  191. Best shorty headers?
  192. EV6 injectors on a LT1...
  193. symptoms of a bad pcm?
  194. Blower install on a LT1
  195. cut thumb open need advise
  196. Best place for these parts?
  197. lca sfc fab
  198. Cuts out or off whenever it wants to..no codes??HELP
  199. Lunati Voodoo 270/278
  200. Check out my CME I created.
  201. Pushrods?
  202. cam packages?
  203. Heavy braking = stall?
  204. where to buy a good oil pan foir lt1
  205. tuner cats
  206. In need of a cam
  207. Cam question
  208. first time out at track
  209. Question On Muffler
  210. Got a new optispark, few questions
  211. black rims
  212. Cutout HP Gains??
  213. Mr Gasket 5716 headgasket with alu heads
  214. Help me decide on a cheap rear...
  215. What do you think?
  216. ls1 driveshaft swap???
  217. Power loss from incorrect valve train geometry?
  218. Bolt on/Stalled guys what kinda times are u turning?
  219. thermostat ??
  220. a4 dyno ?
  221. Best way to get low 10s?? Plans call for NOS btw
  222. what do yall think
  223. What lifters do i need???
  224. Anybody ever done this to their crankshaft?
  225. LT's or Shorties?
  226. My afternoon Project
  227. Ordering headers this week and need help deciding between my two choices
  228. ehaust ?
  229. y pipe suggestions
  230. Muffler Choice on Dumped Y-Pipe
  231. Oil leak on passenger side? What to check?
  232. trans help
  233. LT1 won't start..HELP!!!
  234. New PB at local 600 foot track
  235. Switching from a 4L60e to TH400
  236. Car running bad
  237. Ported LT1 intake ?????'s
  238. Mail order or Dyno tune for basic bolt ons?
  239. Cc503
  240. Suspension noise?.... and upgrade.
  241. SS3600 vs PY3400???
  242. 3.73's or 4.10's for my M6
  243. magnapacks vs. bullets
  244. Date with a dyno (first time ever)
  245. o2 extensions
  246. head/ flow question need answers
  247. Help w/OBDII plug please
  248. stock lt1 block?
  249. AFR 195cc, 383 which cam cc306 or xfi292
  250. LT1 Bronze Cam gear - How long do they last?
