View Full Version : LT1-LT4 Modifications
- Intake is off now what?
- Lt4 springs on iron lt1 heads?
- Gear drive in an lt1.
- Advice on Build Plans
- starting probelm
- Speed Inc cadillac cam .....
- LPPs for sale?
- 25th Trans Am Engine Bay
- Anyone ever used this setup?
- lt-1 compression loss??????
- Bore increase
- E-Bay "shorty" headers...
- cc305 and cc503
- 1.6 rockers..question
- Can someone help identify this hose?
- question for mustang guys out there?
- Question about headers
- Where can I find 02 sensors?
- cam help
- 1993 z28 converted 383 stroker
- Pacesetter Headers ??
- Any documented gains from ported intake manifold
- 1993 Z28 converted 383 stroker
- Need to buy Schrader Valve Cap...
- Time to go all out!!
- 383 lt1 hp?
- A4 with 4.10 or 4.11s come in
- First real HP mods: Thunder Racing Performance Pack
- Front Mount Distributor , teaser pic
- ARP bolts/studs for splayed caps
- High Idle? Hard Shifting?
- Pics of my wheelie bars and new trunk mods!!!!
- Is PCMforless.com my best bet?
- another stock head cam recommendation thread
- Different oil pressure question
- madtuner....
- best place for top end engine parts
- new goodies, need some advice!
- 93 formula fuel problems
- pulling motor and need some help
- Finally, pics of my custom NastyCamd93 CAI
- Fastest street legal car... and it has an LT1!!!
- Best LT1 mod ever for less than 40 bucks????
- need some help putting in guages
- Bumper drag on a 150 shot!
- LE's 223/230 @ 112
- New car off ls1tech sales thread
- Best way to flush and clean out engine gunk/carbon buildup?
- Roller Rockers
- lt1 running low 11's???
- intake eblow help
- 4l60E tranny issue????
- Disconnected o2 sensors for leaded fuel to check if I have false knock, ok???
- Lpp headers update !
- which heads
- Attn: Those who did the LS1 Lid swap...
- Need manifold pics
- Whats normal fuel pressure?
- Poly mount problems?!?!
- are roller rockers noisier then stock rockers?
- Rear End Gears ?'s
- What kind of power will this make?
- 242/250 112, stockish heads dyno
- Need help picking the right parts for performance or crate engine
- What year??
- What kid of headers?
- What is this?
- LT1 clutch fluid
- Big vs Small heads debate
- PORT AND POLISH HEADS Do it no????
- 93-97 hatch
- 94 LT1 P/S pump issues
- HSW Micro Controller
- OTVC and CCPerformance....
- High Altitude LT1
- 8.55 at 169.9 mph
- cc503 vs cc306…
- valve springs
- Anybody here from kansas
- Exhaust leak...Causing bad o2 readings?
- Lt1 Carbed 'Style" intake question.
- And please identify thes two parts???
- LT1/LT4 manifold ???
- im looking for a twin turbo kit for my 94 lt1 camaro
- Question about fuel octane.
- Is this true
- What kind of headers are these?
- Oil Cooler
- Little black box
- Wierd Oil Pressure?
- 4l60e ?
- Few cylinder head questions
- Cutout Install Prices
- How hard is the 1st nitrous install?
- How to completely drain the cooling system
- decided on my rr set up , have a few q's.....
- ignition help
- Need help asap!!!!
- where is the stock amp
- Shifting Wierd!!!! HELP!!!
- problems with parking lock on shifter
- Any issues with relocating the computer into the interior?
- WTB!!! This Hood!!
- Piston rings
- New pics and cc306 idle vid!
- Comp custom grind
- mods for spring
- True duals: pros and cons ?
- Stall and road racing
- stock exhaust manifolds
- rebuilding lt1
- Need some pics and help!
- putting 1.6 rockers on stock springs?
- header install question????
- I have a question about LT1 Computers.
- Need help finding hood inserts and ram air box
- LT1 intake runner holes??
- Cam help?
- stock air intake on a built engine?
- will a granetelli ls1 maf work on a lt1?
- Power struggle
- Help me to keep from burning electrical wires after header install
- Stock clutch durability
- Speedo
- Lt1 block Q's 2 bolt vs 4 bolt
- intake redue
- shortie headers
- push rod 503
- seperate feul system for n20?
- Ticking, What is it?
- Simple firebird ?
- Where did you guys mount your Moroso kill switch?
- Ignition coil for LT1
- LM1 with Electric cutout?
- I have aftermarket oil pan what about level sensor?
- Help choose mail order tuner
- Freshly Rebuilt Tranny Amazed!
- Roller Rockers
- Which OIL will leak LESS 5W-30 or 10W-40??
- Complete A4 to M6 conversion
- Nasty Vibration
- LT1 Turbo intake manifolds?
- Talk me into a cam
- LT1 power help..
- Sound diagnosis, knocking?
- My Dart 200s back from LME
- Entropy Radiators??
- Bilsteins or AGX
- Side exhaust?
- Handling with heater hose mod?
- Valvetrain Setup - What do you think?
- 373 gear ?s
- Help Me Spend My Tax Return. :D
- LT1 Engine Weight
- LT1 opinion
- Cam only rebuild
- Clutch studder and shake
- Need input in road race 383 build
- Aftermarket/Pillar gauges?
- Oil Pan Torque??
- Where to buy schrader valve cap?
- where do i find lt1 turbo kit
- average price of a rebuild
- 3,000 tax refund to spend
- What do you think it will make???
- We need to get someone to manufacture these so we can have Direct Injection LT1s!
- how much can my motor take?
- $500 budget
- a few quick pics after tint and black wheels
- Project 96 build recommendations
- $1000 to spend
- LT1 build...need opinions...
- Injector?
- OK I bought it now what
- cam ?
- Cat-back Performance
- Best cam with stock Heads that would net be the best E.T.
- update on my car
- 1.6 nsa vs. S/a
- weird miss....any ideas???
- what viscosity of oil are people running out there
- TPI air foil not work in lt1?
- Suggestions wanted: next mod?
- Abs removal
- looking for a seat
- Got the cam and headers installed take a look
- Any difference between an LT1 and LT4 block?
- Any sponsors sell AC delco o2's
- Eecs?
- Cap and rotor question
- v6 to v8 swap
- Typical Question
- Diag time... Average manifold temp? (little long bare with)
- cutout questions
- Project LT1 Camaro Build....
- i need help with wiring
- 94 vette, what shot is OK
- ever feel you went the wrong route?
- Need a diagnosis.
- key ignition problem
- Anyone use a Summit/jegs brand EWP?
- what size stall?
- A.I.R. pump question
- 96 lt1 exhaust
- what size cam is too BIG
- pictures of the face lift
- Finally have some track results for my Ai 200cc heads/cam combo
- Car turned a code
- cc306 question
- Does anyone have a LT1 throw out bearing they can spare? TOB project underway.
- When it Hits Close Loop
- Edelbrock Air Gap Intake Manifold
- Mail order tunes for cammed cars?
- Rod knock/spun bearing?
- cam grind questions
- TB Question
- Solid roller 383 engine dyno numbers
- What harmonic balancer should I buy?
- 1st GEN headers on an LT1
- What else should I install while my car is getting a cam installed?
- thinkin about ordering my cat back
- tune question
- Spun 6800
- Replaced opti, now car just cranks till battery is dead? WTF
- whatduyado for your tachometer in your cammed 93-97 (pic please!)
- think 3500 is worth it????
- Vibration??
- Susp. upgrade???
- What heads to use on 396 stroker?
- need injector feedback
- Dual belt conversion
- NEED HELP with sensor
- ram air intake
- Seen these?
- Need some advice
- Concept LT5 + Concept Northstar in Concept Banshee = W...T...F...?!
- need advice please post, thanks
- Tell Me What You Think?!?!?!?!
- $1200 Budget on stock LT1. What to buy?
- Motor Install Help
- Stock intake manifold
- Timing setup?
- anyone with pacesetters and duals come in.
- any one run a d-pic guage
- turn signal help!
- lt1 hub vs ls1 hub
- Will a carb run OK on a LTx cam?
- ls6 valve springs
- I got me a Vette
- i need a good diy link for lt1 clutch replacemnt
