View Full Version : LT1-LT4 Modifications
- Rarest of the rare (?) LT1/LT4 4th Gen F-body on Ebay
- obd2 Lt1 Datalogging!!!
- intake swap
- Engine/Transmission Problems
- Lt4 knock module PCM
- Intermediate shaft removal
- ? 95 TA headlight question
- Car smoking at idle
- head bolts? Which get thread sealant?
- turbo oil return questions
- Stock y pipe and cats
- HALP! Trouble setting up shift points
- Low MPH with Hotcam
- The 1994 Trans am GT thread to end all questions
- 1 5/8 long tube headers
- MAF sensor cleaning
- wrong fuel pump hose connected
- head gasket inventory? Need to make sure all parts are here
- lt1 smells like coolant under the hood
- Loose CPS Reluctor Wheel?!?! W/Video
- supercharged lt1 guys??
- Drilling the throttle body for IAC/BLM?
- turbowerx scavenge pump wiring
- Question plus Help
- Speed inc. steam pipe kit
- Best Mods for $1000 or Less???
- LT1 F-Body engine drop
- 97z keeps blowing cooling fan fuse
- 94 Z28 stalls/stops running when warmed up
- keyway and windage tray
- Do I need a bigger tb?
- Could this be why my car batt drains out?
- EWP going out?
- lt1 running bad after opti replaced
- My '95 firebird wont start!
- Any ideas on what '96 SLP Shorties and 2 OTL catback are worth?
- Ultra Z hood
- Help with my fourth gen Camaro
- Need some wireing help before i part this project out.
- IAT Sensor issues? Ideas?
- Air Conditioning Removal
- Valve spring ?
- Stubborn pan gasket leak
- Anyone using the 6.75" ATI aluminum damper?
- Unbelievable. Code 36.
- need some window wiring help
- Opti Spark Choices
- OBD1 LT1 TUNE NEEDED IN LA (Rebuilt Motor)
- pcm program
- lt1 part out houston tx
- Issues after clutch install
- 94 lt1 carbed setup help
- 1994 LT1 350 4L60E problems
- Tranny options
- Help with ideas on build or if I should sell??
- New cam now trans prob
- Help! I can't get my fuel lines disconnected!
- clutch suddenly won't disengage
- engine swap
- Need some opinions on cylinder heads...
- What's that noise?? Also known as I'm going crazy. NOW HAS VIDEO
- Throttle body cleaning
- 95 Z Residual Fuel Pressure Spec
- Talked With my machinist
- Got this 92 Vette 6 speed, now what?
- Temperature (sending unit?) Issue
- 94 lt1 swaped to 97 lt1 and running problems
- gen 1 vs gen 2
- Tail light issues
- Overheating
- ADS Super Chip
- LT1 Issues, any thoughts?
- Seeking vortec help from the pros
- small oil leak & smell on lt1
- Swapping fuel pump. What sealant to seal bucket?
- 24x base tune
- Hot Cam finally in the 12s
- LT1 cam & rocker question
- Need stck fuel pump pigtail. Where to get one?
- LT1 runs rich after open loop
- 1994 LT1 high idle problem
- 95' LT1 Loses all power on key turn
- Hard Start LT1 with SES- Runs Fine
- Wide band help
- Nitrous nozzle question.
- How do you stop false knock or prevent it?
- Should I change head gaskets now?
- bolts for catalytic converter flange.
- newly rebuilt Lt1 runs hot
- Blown headgasket?
- LT1 with an S trim supercharger, will 4L60E live?
- AFR195's
- No Limit Drag Racing out for Android
- Converter kicking in and out
- can i put a obd2 pcm in my 95 lt1 car
- Best Site for Seats
- What should I be asking?
- LT1 Exhaust Manifold.
- LT1 build ideas
- Data logged w/TunerPro -Flooring from a dead stop causes severe hesitation or misfire
- How to turn off ABS dash light?
- Anybody in the process of building a turbo or blower car?
- LT1 won’t start… quite a few tests done…
- 95 lt1 firebird missfiring
- Gutting the cat while on the car
- SES light on. To care or not to care?
- 96 LT1 Reluctor/washer.
- N.O.S fuel line problem
- LT1 swap
- 255 lph fuel pump install
- Help with strange tapping/ticking
- LT1 Engine Temp/advice on tsat & tune
- egr and exhaust emissions question
- LT1 fuel pressure drops to 0 psi
- Is my WOT timing not enough?
- CC503 Cam
- LT1 Wiring Harness Minimum
- Can i change to ls7 lifters, 1.6 rr's, and pshrds with no problem?
- Bad Headgasket leading to Cam swap. Need your input.
- weather stripping
- Alright - spark / fueling / mis&backfires.
- Cam swap help
- LT1 Squealing scraping sound?
- 4th Gen fuel tanks.
- If a lt1 can run on as low as 6psi, how would i be able to tell if my oil pump is bad
- what does BFH stand for?
- Dies at Idle when cold
- hypertech
- 24x pinout questions
- Throtle Body Bypass
- Building a new shortblock, what parts do you suggest?
- Lt1 stumbling and rough idle
- How much will shifting to soon hurt times
- is a 96 trans am faster than a 95 formula.?
- Aftermarket Cat
- 96 LT1 emissions
- Is Oewheels.com a legit website..?
- quick question about ewp wiring!
- Lsx swap
- Aftermarket Seats
- what is M6 and A4 ?
- what's the biggest mm throttle body i can put on a stock LT1 intake
- misfire and other problems after 24x
- Vortech V1 T-Trim install
- LT1 gap after cylinder heads installed?
- Where do I run my oil line
- exhaust manifold bolt GRR
- ean when shifting
- lt1 oil pressure switch
- 96 Lt1 M6 rear end oil???
- i don't think anyone can help me..
- Breaking in the new engine (Procharged F1A LTx)
- Car dies when ideling
- post your gauge setups other then A pillar
- ram air hood, intake and maf
- What's up the expensive intake gasket???
- Question about head room
- single plane intake
- Code 26??
- Misfires
- My Discount opti experience
- lt1 spring locator ?
- 1996 z28 exhaust cutout!
- What kind of Exhaust is this? (brand?) *PICS*
- 1994 LT1 350 fuel problem
- Guys whats this motor look like for sale?
- Trying to go fast with a stock bottom end, advice?
- dash harness in v6 to lt1 swap
- random problem at 5k rpms?!?
- A4-- Aftermarket Shifter
- Exhaust Question.
- New Member, Old Car, Lots of Problems
- XFI 280 383 stroker
- Still For Sale
- Need help with Compression Ratio calculations
- standard roller cam in an LT1
- Single cat with ORY
- Down...but def. not out.
- Balancer problem
- Having fuel problems! New pump still no pressure. . .
- Fuel pressure spiking- turbo car
- Bs3 lt1
- Backfiring from Left side exhaust
- running rich
- running rich
- LT1 exhaust
- Hooker or magnaflow catback?
- Stock Bottom ends.
- IAC isn't working; need suggestions, help...
- New cam came with short dowel... anyone know how to pull the dowels out of cams?
- Thoughts and opinions on this 383 short block
- Ugh, another one of THESE threads
- Recommended build list
- Third time's the charm
- Do these plugs look too cold? TR6
- misfire!
- 11's stock bottom end w cc306 cam
- Vacuum lines locations
- Can anyone give me any feed back on the ebay clutch rand Bahnhof?
- Reluctant cold start
- LT1 knock sensor
- 24x swap, coil mount locations.
- Vacuum leak
- Oil pump and related parts questions?
- steering wheel adapter
- Flexplate question
- Chicago area cruise nights
- LT1 Carb conversion question
- Aeromotive Adjustable Fuel Pressure Regulator
- guys from okc area.
- Cheap ICM
- Is it a good buy?: 1995 Camaro Z28 w/ 194k
- $30 bucks composite valve covers junkyard find!!
- Wont idle after HG swap.
- Seems like the drivability is a bit better with the AC turned on.
- 95 Lt1 Intake Manifold Vacuum Ports question
- Slow starter
- Thoughts on this dual exhaust idea?
- LT4 knock module
- 1994 camaro lt1 grinding when starting
- Anyone ever have the water pump drive gear break?
- 241 heads on a lt1 short block?
- Internal Noise? Never heard this before.
- Left & right bank upstream o2 sensors reading inactive
- who is running pusher fans?
- Super Misfire Problem
- In YOUR OPINION: best sounding exhaust for LT1
- trans?
- Help...
- Service Engine Soon Light
- OD or D for 1/4mile racing??
- What kind of cat back exhaust?
- Steel Braided Fuel lines from drivers area to rail with AN fittings question LT1
- Anyone want to tell me what would cause this kind of damage to a head gasket?
- quick question, heater hose leak at wp.
- Help a brother out! (93 LT1)
- B&M Transcooler
- Is anyone available to look at my tune (pulled from Tunercats)
- stroker kit
- 96 lt1 no start with fuel and spark
- Help Please, in middle of project! Bell housing wont serperate
- Low oil pressure problem I believe to be solved.
- Ltx total timing at WOT
- 94 Camaro Z28 & OBD1 with 383 Stroker
- Cc503 timing
- Coolant turning brown after repeated flushs
- 355 H/C with F-1R @ 18 pounds, problem lifting heads??
- anyone have an idea what kind of oil pressure I should have when priming new engine
- Need cylinder head info, built YSI setup
- electric fans not kicking on
