PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Fuel Enable Malfunction?!?! Code 46 - also IAC, completely stumped
  2. Where to find stock valve cover bolts.
  3. Tune issue? Keep fouling out 02s
  4. red plug???
  5. LT1 to LS1 T56 Conversion
  6. My junk.
  7. Fix or replace SLP's 2 on the left muffler?
  8. Optispark Vacuum Harness
  9. Anyone know the size of the trans crossmember bolts?
  10. Lt1 wont crank after opti install
  11. Stall questions for the new procharged 383 Build?
  12. Which cam is better for a blower....112lsa or 114lsa?
  13. 95 scanning woes
  14. timing chain
  15. wire harness delima!
  16. Body Grounds
  17. CSR Electric Waterpump Wiring
  18. HORRIBLE gas mileage. 10-15 highway, 5-8 in town. D:
  19. Question about heads.
  20. carbing a 97 lt1 motor, hub question
  21. lt1-427
  22. Car Won't Stay Running !!!
  23. New tune question!
  24. .1" offset rockers on cammed LT1? Valvetrain guys come in.
  25. Pcm
  26. 96 LT1 Starter
  27. Zex nitrous kit yay or nay?
  28. Too much cam for 6-speed?
  29. Code Reader Suggestions?
  30. LT1 gone Optiless "it Lives"
  31. stupid question...
  32. bilstein hd's or KYB AGX's??? HELP
  33. Getting WOT knock on E85?
  34. LT1 Street cam suggestions
  35. Cant get it to Lean out (Help Please)
  36. SLP Loudmouth on 1996 Trans Am
  37. Help! Starter wont line up
  38. LT1 runs then dies
  39. Manual brakes
  40. temp gauge.. need help!
  41. harness??
  42. 93-97 98-02 Exhaust???
  43. Smh
  44. sbc 400/lt gen
  45. whhhhhyyyy?
  46. What will fit?
  47. Couple of questions
  48. From personal experience, how hard is a heater core swap on the lt1?
  49. ls1 heads on a lt1
  50. Solid motor mounts
  51. A little help needed.....
  52. LT1 would'nt start,...loose coil connector?!
  53. How do you secure the radiator without the condensor?
  54. 95 LT1 acting up
  55. Started my LTCC conversion
  56. Car will not run at temp
  57. Intake Question
  58. Racetronix walbro 255 pump install question
  59. header gaskets
  60. Supercharged Stroker Q's
  61. Starting problems
  62. Car died on the road
  63. 1995 Camaro LT1/T56 high idle!
  64. 12s finally
  65. lt1 startup issues
  66. How much Gain with UDP & EWP
  67. Heads "MILLED" .030
  68. 355 build with lots of questions
  69. My how things change, the car is for sale.....
  70. Cammed LT1 track #'s & Nitrous #'s
  71. How much slack is too much?
  72. need stall advice..
  73. Any ideas on a stuck head dowel pin?
  74. when is rains it pours
  75. Very Confused!
  76. WS6 Ram Air Box, with 85mm Opening conversion
  77. Steering link swap question
  78. Gm846
  79. Help with new 396 top end!!
  80. Ls1 ??
  81. On the front
  82. short block needed
  83. 1995 Z-28 A.I.R pump bad
  84. Hotcam goes 10's...
  85. Anyone make 2inch headers
  86. lt1 24x convertion
  87. Rear gears for auto. 3.73?
  88. Throttle Cable
  89. LTCC install experience
  90. Hard Start on Fresh Rebuild
  91. Permanent Tranny Mount
  92. driver side cat replacement cost?
  93. Rough idle at times, stumble @4500+, oil gauge bouncing around. Ideas?
  94. Dipstick tube
  95. LT1 Advice please.
  96. Ignition timing for cruising?
  97. Check Gauge Question
  98. car is falling apart, rear shaking now.
  99. LT1 Motor stumbles only when driving in traffic!
  100. Gears and stall? For a high 12?
  101. Black c6 zo6 rims
  102. New Concept
  103. Battery Relocation
  104. Transmission leaking :(
  105. Dyno blues
  106. So what are these "free mods" I am always hearing about?
  107. Heater Hose
  108. Need Some Help Plz....
  109. Engine Hours Gauge?
  110. Quick AC question
  111. Can I Break Into 12's
  112. Which of these hoses is NOT for the cooling? (pic)
  113. Moroso oil pan leaking from one of the plugs. (pic)
  114. Which side does these wire looms go on? (pics)
  115. ignition misfire?
  116. Seals and Bolts
  117. looking at 95 z28 what to look for....
  118. thinking about building a street strip car
  119. A little more progress on GTP AFR/LE SR 383
  120. Weird Header Question....
  121. can we put LS1 MAF on LT1?
  122. torq thrust
  123. cps reluctor wheel?
  124. will i pass e check
  125. Question!!
  126. solid roller 383 12.5to1 le2
  127. Cam suggestions with TFS 195's 23*heads
  128. Ordered parts for cam/boltons.
  129. Pulling engine...HELP!!
  130. The Blue Beast LT1
  131. The Blue Beast
  132. LT1 Fuel Cooler?
  133. Got my 4th f body, what mods should i do next??
  134. missing but not
  135. Motor torn down !!
  136. 10.13 @ 136! New PB!
  137. How hard is it or am i crazy
  138. need help with a mcloed twin disc
  139. Wiring gurus - electric water pump warning light help please
  140. Puzzling LT1 problem
  141. Throttle Body Spacer and a ?
  142. Lt1 a4 shift mph?
  143. 6LE front bumper
  144. 10% summit discount cupons..
  145. back firing
  146. SCAT Rotating Assembly
  147. 95 t/a died while driving last night
  148. Low Coolant Sensor
  149. difference of cutout with my exhaust?
  150. abs inop & brake light...
  151. Car died on the highway..help!
  152. lt1 tuneing help "rev limiter"
  153. a4 to m6 issues
  154. opti question
  155. I has oil pressure!??
  156. head gasket for boost
  157. 93-97 e-brake weights, are they necessary?
  158. holley dual plane 300-36 on an lt1
  159. Re pinning harness for 24x
  160. lt1 power loss.. too much/too little fuel, possibly spark issue?
  161. oil on plugs?
  162. Ram air help
  163. Gauging Interest....Help me price it
  164. trans cable ball/socket end
  165. icm or maf problem?? (Not iac or maf still same problem)
  166. Engine Vacuum??
  167. Throttle Body Plates - Evil Opti is back!
  168. Price of LT1 F-Bods beginning to rise?
  169. Street Motor LT1
  170. I need a roller
  171. How to post pics
  172. Carbon Fiber Sail Panel
  173. sometimes my car makes me look stupid....starter dead spot?
  174. My 25th Anniversary Trans am
  175. What Coverters are you guys using?
  176. Brakemotive....Thank You.
  177. LT1 tune advice - dfco
  178. SES and AIR removal
  179. Voltage regulator going bad?
  180. Intake Mod for Injectors?
  181. not starting, any help plz
  182. cam package help for 96 impala
  183. Muffler
  184. hey i had some questions about cams for the lt1 96 impala
  185. How do I know if it is an LT1 or LT4 KM?
  186. Trend PR's arrived today
  187. Rear end shift?
  188. Front brake wear
  189. Odd starting problem
  190. Slp cai
  191. Fuel Gauge Install Line
  192. '96 B-Body LT1 Cooling System Questions
  193. 95 T/A freshly rebuilt AC system keeps shutting down.
  194. Motor removal
  195. Amsoil?
  196. 1995 camaro z28 vented opti spark qestion
  197. Is it worth putting a cam in?
  198. O2 bungs and senors on hooker long tube headers
  199. Why does my car knock so much in the 2-4k range?!
  200. timing chain 24x conversion
  201. Another rich thread
  202. Where are you guys mounting crank trigger pick-ups?? Where should I put the 0'magnet?
  203. 1.6 rr ?
  204. what direction to go now????
  205. Steel MLS or Mr gasket .026 gaskets?
  206. Back to my roots, 1996 Camaro SS...
  207. What is the QUIETEST muffler I can buy?
  208. Checking LT1 heads and deck for warp
  209. tree huggers
  210. stock re-ring and now with no oil pressure
  211. stock timing chain replacement
  212. Getting Speed Inc PS pulley. What tool? Tensioner? (pic)
  213. engine wont fire... dont know the problem
  214. Replacing the Motor Mounts
  215. catted y pipe cutout question
  216. Weird New Humming Sound
  217. Question?
  218. Epic Burnout!
  219. need help on buildin 94 camaro z28 lt1
  220. carburated fbody
  221. why is my motor pulling vacuum at high rpm?
  222. LT1 died on the road.
  223. C5 brake upgrade. Need help
  224. Just finished my first engine romoval out the bottom
  225. intake manifold
  226. my new toy
  227. lt1 timing chain sugestions
  228. My Cruiser
  229. 1995 camaro Z-28 what is the right code scanner to use?
  230. Header Questions!
  231. just got my cars motor back together and got a few issues.. help?
  232. Totally picked the wrong bolts for header install!
  233. LT1 tuner in Arkansas
  234. Anybody running a window net?? Whats the best latch style you like??
  235. Will D1SC @ 10psi work with Ai 200cc heads?
  236. Stock LT4 cam
  237. steel headgasskets
  238. 4L60e wont shift out of park
  239. Car woudl't start....
  240. Next Step Fuel Pressure?
  241. engine removal ?
  242. Aftermarket fuel system.
  243. What fuel system for my 427ci
  244. pulling the tranny
  245. Clutch dragging?
  246. ideas on 383 build
  247. 93 lt1 and m6 worth?
  248. whats it worth ????
  249. 1993 and 1995 O2 Sensor Question
  250. V6 shifter cable
