View Full Version : LT1-LT4 Modifications
- cam help
- How hot is your car??
- What Dyno's More???
- LT1 Electronic Nitrous TPS Switch
- Well this sucks!!!
- fuel system for lt1 with h/c
- What is average LT1 idle Oil Pressure?
- the exhaust heat shroud
- Guys with pacesetters
- Bolt broke off in manifold!!
- Where does this go
- Tuning question
- What fuel/ignition to go with?
- SBC internals work in LT1's right?
- MSD 6AL - car wont run with it! 93-95 coil
- transmission question
- longtubes leak... how do i fix it?
- From where can I buy LE head?
- waterpump recommendation
- Whatcha Think
- What I'm getting
- Used cam and springs?
- my new lt1
- bolt ons
- new times
- hooker lts on street car w/ full exhaust = EWW
- T56 setup, cam/springs, other lt1 stuff for sale
- lt1 for ls1
- BMR or Spohn?
- BARE Casting LT4 heads
- lopy cams
- Stock lt1 lifters?
- does anyone know were to buy a rock bottom price LT4 intake?
- Oil Leak at top of throttle body?
- Head Gasket Options
- slight misfire
- K&N FIPK - Filter won't stay on!
- help me choose a motor.
- air fuel ratio
- 94+ TB on a 93
- what kind of gains could be expected from porting stock LT1 heads?
- Messed with my throttle body and...
- help! taking out cat
- cam to use with obd-2
- Just a little more power
- Lets guess horsepower
- edelbrock lt1 kit
- bypass AC?
- temperature
- Valvetrain noise?
- Sick new setup, ET estimates?
- Cam ? for a buddy's 96 LT1
- Question For Those Using Victor Series Intake On Lt1??
- Anybody have these headers?
- 383 Lt1 + D1sc
- couple of exhaust questions
- Removed abs, air pump, cruise, etc; can I just cut off plugs and put in factory loom?
- shorties for long tubes...
- where to get an opti?
- need a tranny!!
- What do ya think? I saw something that dosent seem right when i pulled off my heads
- Quick Mac header question
- Cut out help
- Granatelli vs MAF Ends vs Descreened Stock vs Bone Stock
- cam question
- how do you indentify a hotcam?
- are these heads any good?
- NEW 383 almost in woohoo
- flywheel question
- Will a holley TB for a 93 work 94+ car???
- Roots Blower For LT1?
- 400ci , 396ci
- Dyno #s: Is this healthy???
- Cutouts??
- Im New and Have a Question
- LT4 valvesprings
- Pulley Removal - Holy cow! Please Help
- 3:73 gears
- Best cam & heads for a STS Turbo?
- how does the gm847 do on boost
- What do all of you think of this 383 LT1??
- Does any one know how to set up a LT1 intake for direct nitrious?
- lt4 hotcam on l09 lsa
- 383 lt1
- header questions
- Which one?
- Terrible Stuttering In Second Gear At Low RPM
- EGR and AIR
- CC 306 questions....
- Wanna hear something nice ?
- Can you get 400+ rwhp out of an lt1 n/a?
- Q's On Edelbrock Cam 2108
- CFM from a 1.940" intake valve?
- granatelli MAF
- Gained .6 tenths and 5mph from Kooks LT's..
- Advanced Engine Building Questions
- Which headers??
- Cam opinions
- off road y pipe for lt's off an ls1 on a lt1 car?
- air induction
- electric fuel gauge install
- LT1 cams rounding off the lobes?
- 1996 Vortec compatible with LT1?
- engine temp
- True Duals??
- Trans mount
- cut-out question
- balancer options
- valves - which is the intake and which is the exhaust?
- Catted y for pacesetters?
- Looking to buy hotcam kit.
- what to buy for stock 97 TA?
- Part number for cat off a 95
- Rev Limiter
- automatic trans slipping can anyone tell me whats wrong?
- Video from last sunday's outing.
- LT1 pulley install
- Code PO113 - INtake air temp sensor 1 circuit
- Advanced Induction?
- Kook's LT's through cutout... vids inside
- blown head gasket
- Do All M6 Stock LT1's Have No Traction?
- help car won't start!!
- Temp...
- Questions about RR's
- My Intro & 355/th350 project
- New tuning site
- cutting stock coil springs
- Cam choice for A4, stock heads, 6500 shifts
- Engine Rebuild/Conversion
- Engine Rebuild/Conversion?
- Timing Chain Question.
- spring / summer project rebuild
- trans dont shift at wot?
- Maf ends
- whats a cutout worth on a stock lt1
- scanmaster install Q's
- base timing....
- He's got problems!!!
- Torque Specs
- Miss at high RPM
- whats the cheapest you could pick up an LT1 crate motor for?
- Ready for headers, what's needed?
- O2 sensors
- Clutch suggestions
- oil pump broke down in my transmission
- pls heeeeeelp me ?
- Just like Tanner. My car is now up and running
- Another Ignorant Owner of an LS1
- ideas for lt1 setup
- it is alive again!! :)
- Stock Pipe Size
- Hotcam Kit or Vigilante 2600?
- EGR and Itake manifold question and a tune up question
- I want head!
- 94Z with 97 engine
- Whats with the LT1 hate?
- Are headers beneficial?
- help 1/6 roller rock. ticking
- exhaust rattles
- 1996 WS6 TA my Ramair is Sealed!!! how do i drill
- burn plug wires
- 1.5/1.6 rocker question
- Porting And Polishing Heads
- 1996 WS6 Trans Am A4 stats?
- lt4 knock module?
- how to get high 11's?
- 10 sec recipe?
- Any one has LT4 kit on his Camaro?
- 911 heads coming off sunday! help!!
- Preliminary numbers from my ported LT1 heads
- Question on High stall (3000-3500) on Stock Heads/cam
- how do you know if your lifters are good?
- What do you need for 350 rwhp?
- boom tubes
- Quote on instaling headers
- Is this right...
- Intake Manifold Oil Leak Fix
- 95 z28 LT1 Headers 4-1 or TriY
- head bolt torque spec's...
- auto conversion
- MSD Opti Spark
- Recent Dyno Results
- 3500 Stall
- O2s and AIT part#
- upper RPM Coughing and power loss
- Valve Question
- lt4 hot cam installation
- Will an LS1 Cat-Back Fit LT1?
- Who has a good rep for converting old school heads to work on the LT1
- Does anyone know how to adjust 1.6 RR???
- Need assistance adjusting rockers.
- A good car? How much power does it have?
- Wtf?
- a4 to m6 swap question.
- Explain this...
- Not having an F-Body sucks...
- My 396 LT1 shortblock just about finished - Pictures
- Throttle body Size?
- help gutting dual cats on LT1?
- spark plug wire heat shielding?
- What time should I run???
- shorty header plugs?
- Just got heads and cam installed
- Car is still running rough, datafiles inside.
- Exhaust is too loud???
- monoblade tb
- 396 LT1 shortblock - does this cost seem reasonable?
- porting the throttle body and intake question
- Anyone know what the difference is
- What do u think of these headers and lowering springs?
- Mods needed for Turbo???
- ram air hood question
- BBK Shorties
- Getting rid of EGR
- Delteq question regarding msd
- Anybody run Isky cams in their LT1?
- crankshaft bearing problem
- '95 Z28 383 engine issues, help
- Super low budget 377?
- new guy needs some help bad
- About the new MSD cap and rotor for the Opti-spark
- stock intake 90
- tranny swap
- does the comp cams distributor gear fit
- LS1/LS6 lifters in LT1??
- Need Borla Sound Clip
- NASCAR Boom Tube with LT's
- Are LT1's internally ballanced?
- Perimeter Bolt Valve covers for AFRs
- Golen Engine Service??
- LTX Intake??
- To All Turbo LT1's
- A major problem???
- 96 and up coil conversion
- Venom 400
- good clutch for LT1
- gutting out cat
- Offset Stud Girdles for AFR's
- Converter and Gears?
- Is this a good deal for an alum ds?
- Deleting A/C
- where can i get a oil pump driveshaft?
- pacesetter and y pipe
- Why do you guys modify your lt1s?
- AFR 220's requiring Shaftmount rockers?
- mods i am doin this weekend!
- "homemade" cold air intake
- 93 wiring harness
- I Need An Exhaust Sound Clip
