PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Can an LT4 with these mods handle this Comp Cam?
  2. Installing Longtubes this weekend
  3. msd question?
  4. Can't seem to find the numbers in google etc for the Crane 831 Cam.
  5. ANyone using the Hedman Long Tube 65180 Headers? I have questions
  6. Spark Plugs Ngk G-power Any Good
  7. 3" to 4" Mufflex ypipe
  8. 1.7 Rocker Arms
  9. Where does this go? *pics*(no 56k)
  10. can i change my pcm to a newer one?
  11. Milky oil and clean coolant
  12. You'll never guess what happened to the Z today
  13. crane roller rockers
  14. Shootout Carnage
  15. Some 383 Questions
  16. cooling question
  17. msd cap and rotor question
  18. The difference that HID's made on my 95 Z28...
  19. using a 700r4
  20. 95z with 94 lt1 problem please help
  21. lt1 questions?
  22. 2008 LTx Shootout Results!
  23. Na H/c/i Setups
  24. Which Nitrous System for the Lt1
  25. Need stock head specs ASAP....
  26. Help Me figure this out ><
  27. Gran MAF issue
  28. spring kits
  29. boosted LE engine
  30. Q's about longtubes and ORY
  31. Pulling oil pan???? please help
  32. WHY is my temp going to 210 or above ? fan problem???
  33. What the heck is this.
  34. cut springs?
  35. Cylinder bore vs piston marking
  36. throttle body bypass pros VS cons
  37. A4 Guys what is your MPH and RPM through the 1/4.
  38. You know what sucks?
  39. Hood/Decal Question 93-97 WS6
  40. So what are the pros/cons of deleted the A.I.R system?
  41. bullets
  42. FI Heads
  43. help me make a choice
  44. lt1 help
  45. tune up ?
  46. F-body week in myrtle beach
  47. how to test opti when off motor?????
  48. CB handle
  49. finally, pics/video of cali's baddest LT1 :D
  50. production numbers
  51. weird dyno graph...suggestions?
  52. OMG - Check this out!!!!
  53. Need help selecting a top end package
  54. an idea from last night...
  55. 94 LT1 will not go above 3k or so.
  56. losing water
  57. Header Gasket
  58. miss-fire and stall out, at specific RPM range
  59. Vote on best Catback Exhaust
  60. The famous Optispark
  61. fuel problem
  62. big problems with my daily please help quick!!!!
  63. give me some free mods
  64. Curious about possible roller rocker noise
  65. Buying LT1 Tuning Software and Cables
  66. installed new battery box and car is dying
  67. Need some LT4 Help, Smoking oil leak... supposedly 1000 miles...
  68. Having a strange oil pressure problem!
  69. LT4 Hotcam kit
  70. Damn LT1 wont start!
  71. Oil Pressure problems
  72. Quick spark plug question
  73. Possible Header leak?
  74. where can i buy a motorad thermostat
  75. Underdrive Pulley
  76. Gears question
  77. emissions block off
  78. RPM Rev on Stock Block...
  79. Is this possible?
  80. What a waste of a car!!!
  81. EXCELLANT DEALS ON 18 BFGoodrich Drag Radial Tires 275/35/18
  82. Still having some issues
  83. slp 2otl
  84. How would I do against a 95 katana 600 ?
  85. Nitrous with KB pistons...
  86. do spintech baffles really help scavenge?
  87. Ever wanted to turbo your Lt1???
  88. lt1 engine dress up
  89. what is the bolt pattern size on a 96t/a
  90. 18-10.5 Rim Looks Like It Wants To Rub
  91. Another opti questin
  92. Read these plugs.
  93. possible LT1 race in August or early Sept
  94. burnt wire. need help
  95. Stumbles at idle when in closed loop
  96. '95 LT1 starting issues
  97. Alternator Question
  98. "Fast Chip" tune vs.??
  99. What other mods?
  100. Sleeper Cam
  101. 305/45r-18 Will These Fit In A 93 T/a Wheel Wells
  102. Hoods
  103. 160 stat vs 190?? tune difference? please read
  104. Why stock rears are no fun!
  105. help me decide, 383 or 355
  106. Taking apart stock rear end... need some help
  107. Question about tuning
  108. opti spark question
  109. Another Idle Problem
  110. swapping front brakes
  111. What about this opti?
  112. New best at the Shootout
  113. Open Header Question
  114. Hot Cam...
  115. A Big Thank You
  116. Pics of the Car..
  117. Ls7 Lifters
  118. Rear end question...
  119. Closed loop issues
  120. Exhaust video.
  121. What color should I powder coat with???
  122. 97 formula throwing codes like crazy!!! HELP!!
  123. BFG Drag Radials ARE THEY ANY GOOD CAUSE I LIKE M/T
  124. SLP Flow Booster
  125. Ran Car this weekend!
  126. Tune
  127. Tune before the last bolton is done...
  128. 98-02 taillight conversion
  129. Bent Dipstick
  130. Shifting
  131. Anyway I can lower the front?
  132. lt1 backfireing!!!!!!!!!!!!!!!! HELP!!!!!!!!!
  133. cc306 cam only guys step in.
  134. runs like crap need help
  135. 25.5 x 11.5 x 18 will they fit on z06 10.5rims
  136. would these work??
  137. Which opti-spark do u prefer???
  138. First Camaro Z28 pics of spring 2008
  139. 3.23 to 3.73 ET question....
  140. I am a traitor to the lt1
  141. silly me
  142. Scorpion Roller Rockers
  143. Who loves their LT1 F-body
  144. Picked up my new 94 z28
  145. misfiring when warm only?
  146. WTT......LT's for shorties..
  147. how much loss?
  148. which oil pump part#
  149. my first lt1 need advice,on the cars
  150. Bad optispark, timing?
  151. good mods for low budget
  152. Wide Band O2
  153. Buying a assembled block. What to look for?
  154. dyno max bullet(1) installed!
  155. 2008 LTX Shootout Results
  156. after replacing parts, still missing/bogging/low idle
  157. Transmission problem?
  158. lt1 or ls1 question
  159. No fuel pressure
  160. Optispark Wiring and Plug
  161. Datamaster question...
  162. Weighed car today!!
  163. First Time To The Track.....go 19.55.....
  164. New Temp sensor and spark plug question.
  165. Going to the track tonight!!
  166. Best way to remove LT1 knock sensor?
  167. Good Lt1 tuner in Indianapolis?
  168. Was reading an article on cobalts
  169. Hooker muffler sound
  170. New here and not suppose to post in the for sale section
  171. Is it bad to only put one new motor mount on?
  172. SLP thermostat
  173. Lt1 pistons
  174. Glasspacks on an LT1
  175. Well, my waterpump went
  176. Car won't idle?
  177. LT1 Low mount alt & PS kit, custom CAI
  178. Draglites on the Rear, Brake clearance..
  179. Anyone on wannahelp with opti problems
  180. water pump bearing seal install?
  181. Need some help guys...No Start
  182. can't remove crankshaft balancer from the hub
  183. Just starting to polish the Corsa muffler, Pics
  184. 3.73 or 4.11
  185. Electric windows to manual windows what do I need?
  186. Procharger FMU - Advice Needed!
  187. 02 sensor causing backfire??
  188. Abs Inop???
  189. 400cid+ genII block
  190. which muffler with the mufflex?
  191. exhaust leak issue
  192. best option?
  193. Coated pacesetters?
  194. Header Install Help!!!!
  195. Thinking of the strip - Advise?
  196. HELP ASAP WILL 265's FIT A 10.5 INCH RIM
  197. Small Tranny leak on a T56, causes?
  198. lt4 top end project
  199. Any Ideas?
  200. Biggest and best
  201. Does this look like spit to you?
  202. Cheap, But Good, Roller Rockers
  203. Just want to say thanks
  204. Is it too close?
  205. Piston Selection Help
  206. New HOOD!
  207. 2.5" or 3" true duals
  208. pre 03 cobra? and how much of a difference will i notice :)
  209. In KC for LT1 Shootout!
  210. MALF 16: Lo-Res Fail
  211. flowmaster muffler swap?
  212. fuel pump question?
  213. feul filter install
  214. Stock Internals Opinions Wanted
  215. Afr Lt4 eliminator heads
  216. will it hurt to drive like this?
  217. how much hp for a cutout??
  218. 98-02 tail lights in a 94?????
  219. Pinion angle help, please.
  220. Anyone have this Intake? Looks like a good deal
  221. cadillac cam!
  222. LT1 Alternator/PS kit
  223. less than a tenth...
  224. While the Tranny is in Gear it sounds like a rear caliper is dragging... Also Rear
  225. tire pressure?
  226. Heard a noise while adjusting roller rocker, what is it?
  227. slip yoke
  228. Spring question.
  229. hp gain with loudmouth???
  230. Another new PB
  231. Piston selection...
  232. IAC values
  233. Is it bad for the VC's to have Breathers instead of Oil Caps?
  234. Check ut my Z!
  235. 1st pic of #502
  236. carbon fiber driveshaft?
  237. 383 regrets??
  238. cam selection?
  239. part number plz
  240. LT1 Identification?
  241. Electric Water pump history
  242. Buddy has an issue with car dying...
  243. Cam Only times..
  244. Manual vs. Auto
  245. Exhaust setup question
  246. ? before heading to the machine shop
  247. Fuel Pressure Gauge reads 0
  248. Anyone run true dual exhaust on 4th gen?
  249. Nitrous or Gears
  250. Car Dies!!
