PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 [217] 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. comp 918 valve springs
  2. what gears for my '92 Vette?
  3. 30lb injector hp limit?
  4. high idle?
  5. LT1 Direct Port
  6. Question about cats..
  7. OPSU Leak
  8. Side exhaust
  9. custom grind?
  10. Block off plates.
  11. Headers: Shorties vs LT, basics (+ cats and emissions)
  12. Fleetwood LT1 question
  13. new setup
  14. Cheap HP?
  15. Need help please, trying to diagnose whats wrong with the car.
  16. Cam only record?
  17. 383 shortblock
  18. what could i expect with this combo
  19. hooker tips not fitting?
  20. A new crank kit...
  21. A couple ?'s For those with KOOKS
  22. Basic LT1 questions
  23. rear gear and speedo
  24. Check my math plz
  25. 500-600hp
  26. aftermarket maf
  27. Stage 3 heads
  28. Whats the word on SB2.2 HEADS?
  29. Knock retard at wot
  30. What Afr Heads To Get??
  31. LT1 performance
  32. biggest cam?
  33. lt4 valve springs
  34. XR282HR-10 cam in a LT1
  35. Long Tube install, AFTERMATH!
  36. edelbrock catback
  37. car wont run
  38. How much HP can a LT1 bottom end handle?
  39. Welcome Port Pros..our newest sponsor!!
  40. Clutch
  41. CC305 vs. GM 846
  42. Headers for a 94 trans-am
  43. 93 Formula Lt1 need engine mods??
  44. Performance Rebuild Kit
  45. joe overton cam question
  46. Air fuses?
  47. 11sec on LT1 ,what is needed?
  48. curious
  49. h/c or s/c
  50. Power Guesses
  51. What size injectors?
  52. Holy moly unexpected high dyno batman!! 300/341!
  53. horsepower vs 1/4
  54. Valvesprings
  55. M6 Bolt On Record
  56. Oil Pressure Unit Relocation or 90 deg. steel boot?
  57. advice on mufflers
  58. New times :)
  59. Weight confusion question?
  60. glowing header tubes
  61. delteq and arcing wires
  62. Hotcam to CC306
  63. fuel pressure
  64. Electric exhaust cutout
  65. RARE 1996 Pontiac Firebird Formula WS.6
  66. Tpi Help
  67. Lloyd Ellliott or AI Sound Clips
  68. Whats Next?? for mods
  69. Manifold gaskets???
  70. need help, replacing optispark,LT1
  71. 1995 transmission
  72. Changing Valve Seals
  73. Cam Install
  74. I need specs
  75. ls1 heads and ls4 intake on LT1
  76. Aftermarket Elbow & Airfoil Worth It???
  77. Who's running Joe Overton (sp?) head/cam combo only?
  78. turbocharger
  79. Autometer Tach with shiftlight
  80. track time?
  81. Miss Fire
  82. new here lt1 questions.
  83. I need an education on proper stall speed for a converter... trying to pick one
  84. rev limiter problems????
  85. Lt1 383
  86. Another problem. (Sigh)
  87. local machine shop? or loyd elliot?
  88. what do u guys think??
  89. Heads and cam
  90. lt1 into v6 car?
  91. Where to get LT1 style radiator cover / shroud
  92. A new noise
  93. end gears
  94. Estimation of hp/tq & Et
  95. Finally some pics of the coil-overs installed..
  96. CraneCams HI6R Ignition box for 93 Z28
  97. Pulling motor
  98. wanting to build a 355 (help needed)
  99. Using LT1 Edit, how do you turn off the knock sensor?
  100. nines or faster?
  101. 383 Specs
  102. Might Sell Car At End Of Year - Gauging Interest?
  103. Best Rotating Assembly for 383ci
  104. what else?
  105. what size is a stock 96 z28 cam?
  106. Strange Misfire
  107. What's it take to build a 396?
  108. LE vs AI
  109. New mph at the track yesterday for my cam only LT1...
  110. SS Impalas
  111. Flowmaster 10 series
  112. New Dyno Numbers
  113. compression test
  114. Head/cam Pkg Ai Or Le
  115. Long tubes
  116. 4bolt or girdle?
  117. I found out my car is a 93... Is this a major drawback?
  118. Tuning a LT1???
  119. is it my opti?
  120. Longblock and Shortblock
  121. completly removing A/C and air bags for 94 Z28
  122. Any opinions about Golen longblocks?
  123. engine breather
  124. Hitting the rev limiter??
  125. 396/Super Vic/Front End Conversion/Daily Driver
  126. Rear End noise changing to 4*10's?
  127. A4 questions
  128. camshafts
  129. 4.10's
  130. Lt1 which year?
  131. roller rockers
  132. how to take out crank?
  133. my 95 LT1 beat a stock LS1
  134. SLP LT-1 fuel injectors
  135. lt1 problems
  136. Can an LT1 be bored and stroked to a 427?
  137. Opinions on this H/C setup. Please
  138. 99 GT Vs 94 LT1
  139. Pace Setter LT install
  140. Engine Missing
  141. Breather filter for LT1
  142. Shorties Vs Long tubes
  143. Spoiler High, Low?
  144. Did I mess up my harmonic balancer??
  145. Injector Advice Please
  146. Bolt On Record-still 12.29?
  147. What Cam to Get?
  148. do you think this cam is to big for a stock LT1 short block?
  149. Question on Flow Numbers?
  150. Troubleshooting help needed!
  151. LT1- limits? RPM? Parts? LOTS of ??'s
  152. roller rockers
  153. LE1,2,3 VS AFR VS Stock Ported
  154. problems with new car, bogging down
  155. rebuild - 383 kit vs 355?
  156. Electric Water Pump
  157. break-in 383 and dyno tune
  158. is this normal?
  159. 97 SS air filter??
  160. Lloyd Elliot, 11s....
  161. how high of dynamic compression can you run on pump fuel?
  162. valve train questions
  163. Posi
  164. o2 Sims
  165. Anybody else run this cam?
  166. Nitrous Cam List what your using and how you like it.
  167. plans for winter cam, Lt's
  168. lt5?
  169. Can I stuff a LT4 in my Chevy Pick Up?
  170. Is 41mm Too Big For A Front Sway Bar?
  171. I need some kinda direction here
  172. cam
  173. mod LT1, or sell it and get LS1?
  174. How should I get the tired LT1 rebuilt?
  175. sway bar fitment questions
  176. Vid of my LT1 RX-7
  177. Timing question
  178. LT1 Blower results
  179. my first trans am
  180. OK so I got an idea of what I wanna build the engine to except for a cam???
  181. 160 Degree thermo too low for winter??
  182. Sold my dirtbike now I have 3 grand what should I get
  183. cam smartfolks
  184. how is your ground clearance with longtubes and the factory Eibach springs?
  185. Getting ready for LE2 H/C swap, need pointers!
  186. best heads/ cam combo
  187. .BIN files for a 93
  188. Please help with a miss. New opti bad possibly?
  189. question about th-350 swaps
  190. what clutch to get?
  191. What emmissions stuff can I take off?
  192. What kind of rwhp and times does a good-running CC305 cam car get?
  193. Stock cubed record?
  194. Vacuum Canister install?
  195. fuel check valve?
  196. tps circuit high
  197. engine revs up when at a complete stop
  198. help with injector size
  199. Anyone run purple hornies off of long tube hookers straight pipe back?
  200. 383 Stroker and Stock Throttle Body?
  201. the baddest lt4 direct port on ebay
  202. Budget valvetrain for CC306?
  203. I'm new, need clutch help
  204. cam with 150,000 miles
  205. more streetable?
  206. fuel pump or regulator?
  207. what type of racing clutch?
  208. Running the LT1 without a serpentine belt?
  209. What is the most common Engine Problems of Camaro Z28??
  210. LT1 vs. LS1, what do you think?
  211. the old lt-1 having some fun
  212. pics of my heads
  213. Which electric water pump?
  214. does the Trans Am rear bumper hang lower than the Formula's?
  215. new here and got a cheap project 94 z28 :-) want some advice
  216. Me vs. this Mustang?
  217. I don't know what I did.
  218. 97 up gauges swap into 96
  219. Lt1 CAI?
  220. New Best (NA)
  221. V6 K member same as LT1?
  222. easiest way to drop a set of headers in an f-body?
  223. Throttle body porting? Also, fan question.
  224. timing troubles
  225. A4 to M6 swap
  226. good fuel pump to use for about 550 HP?
  227. What plugs RU running?
  228. New best
  229. Long Tubes
  230. LT1 Heads?
  231. New to the f-body and got questions
  232. what are the o2's ?
  233. My First Camaro?
  234. How fast is your CAM only LT1?
  235. 58mm throttle body
  236. Dyno Guess
  237. What else do I need for my cam swap?
  238. heads & cam questions
  239. 1993 Corvette question
  240. How Much Can they flow?
  241. 2 questions: mini tubs, baileys ignition?
  242. My 1995 Z28 (CC306, No Cat, Shortys)
  243. 98+ brakes
  244. LT1 free mods?
  245. when is it time for fuel upgrade?
  246. Racing with Stock Stall and 3.73s
  247. cam
  248. low LE3 383 dyno
  249. Tims LT1 Valve Spring Compressor
  250. What valve springs for the gm 847 cam
