PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Oil Pressure issue
  2. dealer license
  3. what is this?
  4. lingenfelter valve springs
  5. Running Like Crap
  6. Wiring issue with installing pacesetter long tubes
  7. 97 z28 wont start
  8. Changing alot of stuff. OPTI related
  9. True LT1 Guys, NEED YOUR HELP OIL LEAK.
  10. Stroker Oil Pressure Issue. Plz Help !
  11. Oil Temp Gauge Install
  12. Converter question
  13. Loose oil
  14. Another opti question!
  15. opti ?
  16. Y pipe install question
  17. quick injector question
  18. Removing Oil pan
  19. need advice on inspecting coil/opti
  20. student on a budget build (could use tips)
  21. Lt1 huge problem when warmed up
  22. Emissions Delete / Head bolts Question
  23. What's the gayest LS1 cam name?
  24. LT1 into a v6?
  25. 355 vs 383 vs 396
  26. Injector Question
  27. Vid of my E-cut out.
  28. should i buy?
  29. Help Please... Big power problem
  30. How difficult is it to put in a BMR k-member and A-arms?
  31. Oil Plugs
  32. Ticking Valvetrain?
  33. Need emission legal - are mid tubes worth it
  34. Would I win?
  35. Gauges
  36. solid roller vs hydraulic
  37. 9 inch rear
  38. whats wrong with my car?
  39. Where is the cheapest place to buy Jet hot or Hooker ORY?
  40. Check Twice, Cut Once
  41. LTX , So who is ready to go???
  42. Will an LS1 Hooker Y-pipe fit on LT1 Jet Hot Long Tubes?
  43. LT1 cooling problems
  44. What ORY fits on Jet Hot Long tubes?
  45. What cam to use?
  46. 96 misfire partially fixed...not all the way tho...depressing....
  47. LT1 Miss fire
  48. Valve Spring Compressor
  49. Band clamps
  50. Ignition Break-up at High Rpms
  51. SAW THIS ON CRAIGLIST "Ford 302 Mexican Block - $350 "
  52. Ported heads and intake, plus cam.
  53. o2 sensors are frustratin
  54. Lt-1 Wth Omg
  55. o2 extension's, home made
  56. Where the hell can i rent or buy a Rear main seal installer tool????
  57. e brake
  58. 02 extensions
  59. Spohn Sway Bars
  60. Headers: Coated or Painted
  61. Stalling. HELP!!!
  62. PCM - MADZ28 (Madtuner) or PCMforless?
  63. need exhaust advice, please chime in
  64. Comp cams XFI 467 / Converter question?
  65. Finally Got Some New Parts!!
  66. new motor dyno cc503
  67. NEED HELP!!! My z wont shift
  68. What convinced you to buy your car?
  69. LT1 cooling problems
  70. lost brakes
  71. '93-97 Camaro Wide "Sunoco Style
  72. MAF code
  73. Long Tube Headers vs Spark Plug Wires
  74. Exhaust Options
  75. Finally I Have An Exhaust Video!!!!
  76. Throttle Body Q
  77. DTC 24 (Vehicle Speed Sensor)
  78. A/C not cold, fans won't turn on. Same problem?
  79. What is FUSE #2 Actuators for?
  80. Whats wrong with my car???
  81. TUNE/nn THROTTLE BODY
  82. 2 bolt blocks
  83. FINALLY got on a dyno....
  84. Cost and Info on LT1 A4 To M6 Swap?
  85. Looking for plug wire ideas.
  86. where can i order some reducers......
  87. True Duals?
  88. Timing Chain Questions
  89. LT1 what's it worth
  90. 383 question!
  91. Started plumbing up the motor
  92. Corvette wheels?
  93. No codes any ideas??
  94. SBC balancer/pulley work on LT1??
  95. cylinders 5 and 6 misfire
  96. Blowing Off Tb Elbow.....fixed
  97. Shot in the dark
  98. proper way to port intake for monoblade?(pics)
  99. Cutout Question
  100. Upper tower strut bar PROBLEMS!!
  101. Cam or headers?
  102. hot start "click"
  103. Still looking for answers. V6 rear into V8
  104. Where to buy new IAC Controller?
  105. rear o2 sensor type?
  106. Hot cam
  107. Starting to look like an engine
  108. NEVER underestimate your own work!
  109. Piston to valve clearance
  110. Lets See Them True Dual Pics
  111. o2 sensor
  112. OTVC Wires
  113. Racer in need of a Vic Jr. Converted for LT1 - Carbed.
  114. Electric Water Pump
  115. Time for a change??
  116. Selecting proper springs
  117. SRP vs JE for YSI vortech?
  118. my turbo lt1 vs stroker supra
  119. Stock Fbody LT1 combustion chamber size
  120. Pacesetter to good to be true?
  121. Help me I'm confused!!! Plug wires/Smog Question
  122. not sure what to do
  123. I got my Z28!
  124. for the guys who dont frequent cz28.com
  125. Oil Temperature Gauge
  126. 96 motor in a 94
  127. PCM Bad?
  128. Nos vs Supercharger
  129. bad rings. what should I do?
  130. Need a part number! Help!
  131. random misfire because of front o2 sensors?
  132. Speed limiter????
  133. Cam to work with LE2 heads?
  134. Is the 2 otl exhaust 3"??
  135. Removed the air cond compressor, ps, and bracket
  136. Problem with fan turning on
  137. Gotta sick 'bird...?'s
  138. What next?
  139. Tranny Temp gage
  140. OBDII tuning info needed
  141. who would win
  142. need some help
  143. egr delete question!!
  144. 1.6 rockers/springs
  145. What sponsor for o2 extentions and AC sensors?
  146. Spark Plugs Black and Smelling like Fuel? Pic Inside
  147. misfire because of a p0100 code?
  148. Help me get my car to pass inspection!
  149. Timing Chain Cover Help!!!
  150. does hooker make a mid length headers?
  151. my waterpump weep hole mod
  152. how do i connect a 2.5" exhaust to a 3" collector?
  153. im stumped
  154. Are new bearings required w/ cam install?
  155. starting problems and more
  156. will 11in wheels fit without any modifications?
  157. Best oil for supercharged lt1? Royal Purple?
  158. My Life.
  159. What color is my new car!?
  160. Headers
  161. lt4 falling on its face above 5000rpm
  162. New LT1
  163. Sputtering and popping.
  164. A.I.R. stands for
  165. Chossing coil pack
  166. NGK Platinum or Autolite Platinum.
  167. how soon should MAF be upgraded
  168. Is there a best CAI?
  169. Piston to head clearance
  170. Coated or un-coated PS LTs ?
  171. What's an Ultra-z hood sell for? Pics please.
  172. changing control arms
  173. Ses light goes off again
  174. Question about heads!
  175. feul filters
  176. WTB: LT1 in Texas, Arkansas, or Oklahoma.
  177. Stock GM timing chain
  178. Exhaust Help
  179. LS7 Lifters in an LTx motor
  180. Where is that two tone red & black t/a at??
  181. How much boost can speed density handle?
  182. Those in the extreme street class come inside!
  183. Need A Lt1 Tuner After I Get My Cam Installed
  184. I Live In Chicago And Looking For A Cam Installer For My Lt1
  185. lt1 t56
  186. Gasket Kit?
  187. Picked up a new ss hood
  188. cam help
  189. powersteering to manual rack?
  190. Window washer bottle thing...
  191. Exhaust Fumes?
  192. front strut bar
  193. Lazer cams
  194. Granettelli MAF ??
  195. LT Caprice motor vs. F-body LT1?
  196. LCA Relo's + Adj. T.A. + Torque = CARRRNAAAAGGGGEEE!!!! *PICS*
  197. throttle body ?s
  198. find the MAF sensor in the pic an other thing
  199. The Z is in pieces...
  200. Want to Polish My Manifold Need Help
  201. mufflex 4 inch catback?
  202. Tune or Not?????
  203. OTVC wires
  204. I need a list of components for a A4 to M6 swap.
  205. o2 change
  206. Is My Z A Freak?
  207. Anyone have a dual gauge pod?
  208. got a question for yall need opinions
  209. Help!!!
  210. Any board sponsors want to help me get to the LTx shootout?
  211. A4 is poop right now!
  212. LT1 No start
  213. Question about 94-95 compared to 96-97
  214. how much oil
  215. protecting spark plug wired from heat?
  216. optispark disassemble?
  217. Pic request! calling all LT1s
  218. 02 extensions. Which ones?
  219. Tune/hp
  220. O2 sensor faulty?
  221. MSD wiring harness
  222. P1 on LT1
  223. O2 Simulator Help!!!
  224. how many miles are to many? already searched, turned up nothing
  225. stock clutch limits?
  226. Need Main Engine Wire Harness!!!!!
  227. shorty headers...
  228. Which Model Motor Should I Convert My
  229. I Have A 98 Z28 Ls1 A4
  230. bad optispark maybe?
  231. headliner sagging need help!!
  232. MSD box mounting ideas
  233. anybody mod the stock fuel cup?
  234. GMHTP magazine will be covering the LTX Shootout!
  235. Sounds of mufflers
  236. Header gaskets
  237. Modifying camaro hood to fit Firebird
  238. $$$$$$$$$ Money ? $$$$$$
  239. Choppy Idle when cold
  240. took the DoD off
  241. LT1 Edit...? Tuner Cat?
  242. 10K Budget 1996 Z-28 Camaro
  243. Wide Band O2 owners
  244. 355 LE dyno tune this Friday...Guess my numbers
  245. LT1 Short blocks and long blocks
  246. Lt1 injectors
  247. help car struggles to start
  248. Put motor in Car today (pics)
  249. LT-1 Head gasket questions
  250. air and egr
