PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 [133] 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Help Please. ;/
  2. 93 myth?
  3. AFR 180cc lt1 heads
  4. high idle ses light on/off
  5. Radiator Replacement
  6. ok for your blower folks...
  7. Need some help here. Headers + Y pipe
  8. So, who wants to be the first Hydrogen-Hybrid LT1?
  9. Cam
  10. Fuel Injector ?
  11. wont start no spark
  12. quick question on a 383 rod length
  13. high flow cat
  14. H/C/I how much did u guys pay
  15. Opti Problems
  16. gm 847 w hotcam roller rockers
  17. F-Body Install (130+ Install Guides)
  18. Octane Boosters??
  19. Lt1
  20. I Need Instructions On How To Wire My CutOut
  21. car falls on its face
  22. Detonation?? new prob!
  23. Check out this SS hood. Looks to work with LS1 lid.
  24. beaten to death topic here but could use some help
  25. most power?
  26. Early Early christmas present!
  27. need some things answerd on the eagle kits..
  28. stock installed heights on lt1 head with stock retainer
  29. What do u guys think about this....
  30. LE1 or LE2 questions..
  31. Ltx Hub Pull Video
  32. Front Sway Bar question??
  33. Exhaust Pop
  34. Cam and Head Questions????
  35. What Blower/Cam set up?
  36. my 383 lt1 build... should be fun.
  37. Bad hesitation leading to car shutting off
  38. Help Oil temp
  39. need help with freescan/vemaster
  40. How much can I make off this?
  41. Which Short Blocks?
  42. lt1 crank pulley help
  43. Spark Plug Wire Wrap
  44. Revised Phatkops single plane 383...
  45. RAM Powergrip HD vs. ZOOM Dual sided Kevlar
  46. LS7 Lifters
  47. 2009 LTX Shootout date has been set
  48. New cam, and tune and what not...help.
  49. going to track next week guess times
  50. oil pan gasket
  51. Fuel Pump For Blower
  52. lq1 and lq4 diff ??
  53. This can't be kosher..
  54. Lt1 Hub Need to be lined up?
  55. how much is my mids holding me back?
  56. compression?
  57. got a problem
  58. so i blew the motor now i need to figure out what to sell it for
  59. factory head cc specs
  60. Edelbrock's Semi-CNC LT4 heads
  61. Nitrous and Timing Retard
  62. newbie is curious
  63. rear end out of a LS1??
  64. i think im down 1 cylinder...
  65. How Aggressive is your build
  66. Cheapest place to get ac delcos
  67. A4 ls1 over M6 lt1
  68. PRE heads/cam upgrade
  69. Fix your broken opti for $29.99!!!
  70. LTCC complete cost
  71. Best way to Find out which cam
  72. Is This Optispark Ok?
  73. Going to track later, guess my times
  74. How much for shell?
  75. blower setup hp question
  76. what you guys think about this cam for my set up?
  77. wtf ?????HELP ASAP
  78. Optispark Fitment
  79. back firing problem
  80. lt1 rods and crank
  81. LT1 intake, wrinkle black or red?
  82. what is needed to build a daily driveable 400hp lt1
  83. Chassis Dyno
  84. oil change soon
  85. What times do you think
  86. which gear set?
  87. Is TPIparts.net selling AC Delco opti now?
  88. nitrous set up (what are you guys running)
  89. Which weight oil would you recommend with the cc306?
  90. Attention All_ignition Buyers!!!!!
  91. project nightmare
  92. Shift Points
  93. how much hp/tq is made with full bolt ons
  94. fuel problems
  95. Slotted And Drilled Rotors
  96. Pics of my car...
  97. Head and Intake Porting
  98. stock rotating assemblies
  99. Supercharger
  100. 2 bolt or 4 bolt
  101. Full throttle runs rough
  102. next mode
  103. Larger oil filter
  104. Need Some advice
  105. weird problem after a/c compressor R/R
  106. Samco Sport hoses, but no clips?
  107. powerdyne blower plate
  108. weird problems after replacing starter
  109. 1.6 RR's
  110. NapaAutoParts Flywheel, good or bad?
  111. code P1371
  112. Car won't turn over
  113. Got my car tuned - still a shaky idle
  114. LTX Tech, problem....
  115. Look what came in the mail
  116. Finally Made a Decision!
  117. ls6 valve springs
  118. Blocking AIR
  119. Under Drive Pullies?
  120. plz identify this module... abs computer?
  121. Why isn't shbox's website linked in the LTX section??
  122. Where to unbolt the stearing rod?
  123. Went back to the "stock" tune &...
  124. Putting Pacesetter LT's in?
  125. Emissions....Again
  126. need help
  127. Remove stock headers??????????
  128. BeCool, Griffen, or Entropy Corp. Help me decide!
  129. Repeated instances of P0420
  130. Will it run?
  131. ls1 h-pipe on my lt1?
  132. need help please
  133. read this a bit off topic but what do u think?
  134. best place to buy pa racing fromt suspension?
  135. Need Lt1 help
  136. high rpm miss, ignition???
  137. Not Sure What This Is???
  138. Opti Options??
  139. 2nd opinion on opti problem?
  140. Ported Throttle Body?
  141. lt1 heads intake question
  142. Tune
  143. What Parts Are Needed For H/C Swap
  144. alternative intake manifold?
  145. How do I fix code p0441-- Evaporative Emission Control System Incorrect Purge Flow
  146. so...i have a wrecked lt1 f-body to play with...hmmm?
  147. Stock Throttle Body HELP--Disassembling
  148. Very Nice LT1 Clutch+Flywheel
  149. Oil Filter Adapter
  150. Is Vapor Canister the same as Charcoal Canister?
  151. pacesetter install
  152. i want to go with this AI package. what do you all think?
  153. Oil Leaking From Everywhere
  154. 2001 Camaro SS?
  155. crank hub and ignition problem
  156. HELP! Which Waterpump? OEM, Reman????
  157. A/C on an LT1
  158. PCM Help
  159. Dart intake for single plane conversion?
  160. wanting to go with LE1 kit, but not sure what all is needed
  161. T-trim and Opti???
  162. LM1 or LM2?
  163. Anyone working on LS swaps into their LT
  164. Header and 02 Question
  165. Any good exhaust gaskets for ported heads?
  166. Quick Question about exhaust
  167. 383 Running Rich
  168. car is back togther and has a weird hesitation occasonaly
  169. quick question about GM rockers
  170. Fans not coming on..
  171. who will port LT1 heads better? LE or AI?
  172. rear end
  173. Dropping Motor
  174. 58mm TB?
  175. Thread sealant?
  176. optisparked it up?
  177. 10 sec lt1 part out
  178. cc306,gm847,xfi280
  179. building a TT Lt5 in a 1983 corvette. what oil for breakin?
  180. 350-400 hp lt1
  181. LT1 swap into my dezert race truck
  182. valve springs
  183. Window switch help
  184. OPTI pigtail bad??
  185. car dies.
  186. torque arm bolt lost
  187. Diagnose this PLEASE!
  188. Welcome BizZzatch350 as our newest LT1 Moderator!
  189. replaced opti, coil, and ignition mod. what else?
  190. LT-1 intake on LT-4 heads?
  191. Emissions Free
  192. Cpe Engines
  193. rocker arm studs too long
  194. Nitrous guys please help
  195. zero to 1 mile?
  196. Lt1 le1 questions
  197. Antifreeze has it out for me
  198. brake pad recommendation
  199. Lucas Oil in...
  200. Shaft Mount - Valve Covers
  201. Summit vs. BBK TB, whats the difference?
  202. help me pick my mods for my 94 z
  203. help please need a file for tune
  204. LT4 cam and headers???
  205. Granatelli fuel pumps
  206. Battery Relocation..Progress Thread
  207. Need Help with the Water Temp. Sensor.
  208. It's Alive
  209. yank 3600 with a 100 shot
  210. 93 ta???
  211. Oil psi drops to 5 psi under hard braking - help
  212. Backfire during high rpm shifts?
  213. computer tuning
  214. Need header / exhaust advise
  215. ignition problem
  216. AC Delete Pulley
  217. 1.7rr?
  218. Need HELP!
  219. Lean Code. Need Help
  220. Which nitrous kit
  221. Battery Relocation
  222. crane energizer
  223. Exhaust banging
  224. what is this????
  225. 2009 LTX Shootout........volunteers needed
  226. A/F gauge reading right?
  227. another vid to watch
  228. Somone please show me a dyno sheet!!
  229. threw a code today P1371 help please!
  230. Putting Nitrous On My Car Tomorrow...
  231. Belt # for March 2 Piece Pulley
  232. Lt1 engine might be going bye bye...
  233. Lt1 electrical mechanic in DFW texas ??
  234. LT1 harness question
  235. Pacesetter Lt Y Pipe Fix
  236. Back from Pinks All Out Sonoma!!!!
  237. Mail order tune????
  238. oil leak and resealing the block?
  239. Got tuned!
  240. MAP and MAF readings
  241. GM part number for 847 cam???????
  242. Blower Questions
  243. swaping a Carb and turbo350 Trany in a 94Z28
  244. just a vid for all to watch
  245. help need a tune file bad
  246. LT1 stumbles badly under light/moderate acceleration..
  247. Pacesetter LT's?
  248. Header bolts: A correction
  249. Master/Slave cylinders
  250. Header Install
