PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Can not Get LT1Edit to work/Connect
  2. 93 intake on lt4 heads
  3. wire problems....
  4. Dirty intake PICS
  5. Temp question, concerned and need answers.
  6. lt1 computer swap
  7. R.I.P Micheal Jackson
  8. I datalog, you tell me whats wrong
  9. what exhaust manufactor is best
  10. what kind of intake ?
  11. Want my Roadmaster to spin em' both under WOT... any ideas?
  12. Starter
  13. 93 383 into a 95
  14. Building power curve at WOT with A/F tuning
  15. Tuner question
  16. ls1 breaks
  17. Some goodies came today :)
  18. 1 7/8" headers?
  19. hid headlight kit
  20. Taking off the opti.....
  21. Have any of you done this?
  22. is this cam ok?
  23. OBDI or OBDII computer
  24. LT headers question
  25. Which opti distributor do I need?
  26. Carb or EFI
  27. Adding Mechanical Coolant Temp Gauge...HELP
  28. Gauge lights do not work
  29. anyone interested in accel gen 7 DFI?
  30. Slave Cylinder help
  31. LT1 gettin too damn HOT! Help!
  32. 93 LT1 Computer Question
  33. Best T/A headlights conversion kit?
  34. what size headers should I get??
  35. Coolant Shooting Out Radiator
  36. quad driver 1 failure ?????
  37. LTs this weekend
  38. Help tap broke off in crank snout
  39. Unbelievable!!
  40. Please help !!!!!!!
  41. Now my car is acting up...need help
  42. borla exhaust problems...
  43. what do you guys think about the dart heads
  44. performance MAFs?
  45. Fuel pump relay? where is it?
  46. GM header gasket doesn't make Pacesetter hole
  47. Ordering LT's...good idea?
  48. gears for my TA?
  49. Oil leaking somewhere?
  50. timing chain problem
  51. Open loop to closed loop switching after header install
  52. Removed Wiring to power windows, I'm Lost
  53. Which way to hang eagle rods in 383
  54. LE2 Dyno results.
  55. car running hot
  56. what would you do?
  57. best for the buck 9.5" converter
  58. Running Rich??
  59. Max whp 383 with ported stock heads and 847 cam?
  60. Cai
  61. i just got a level 6 trans rated at 800hp what kind of cooler should i get
  62. Anyone know how to reprogram ECM??
  63. Cars to loud
  64. Fuel line ?
  65. LS1 1.7 rr's on a LT1.
  66. proformance question
  67. which alternator w/ an F1 Procharger???
  68. 1996 Procharged Trans Am OVERHEATING FAST&BAD
  69. Correctly Aligning Crank/Hub and Pulley
  70. LS1 Lid Conversion or Ram Air
  71. Swapping LT1 from 95 Z28 into a 93- Question
  72. between intakes need opinions
  73. LM1 with LTs sound clip needed
  74. pvc bypass
  75. electrical problems
  76. New motor backfires and wont run!?! HELP
  77. Any good machineshops in Maryland?
  78. What to bolt on my LT?
  79. what is 3-channel/4-channel?
  80. what to do w/ EGR Solenoid when eliminating EGR
  81. ID on a BBK tb?
  82. Best Nitrous Kit
  83. camaro bottom end and caprice bottom end???
  84. Lock up converter question?
  85. Lca?
  86. oil pressure gauge pined out
  87. help me decide!
  88. Intial Startup issues
  89. Oil pressure problem
  90. Tune ups/future plans.
  91. missfire at high rpm/WOT
  92. LT1 Opti question...
  93. stuck lifters ?????
  94. I should probubly know this
  95. hooker header question
  96. gauge install
  97. LT1 diagnostic help...
  98. Video of my 1/4 run!
  99. High Rev/idle on my Trans Am
  100. after market starter
  101. Tips on Removing/cleaning EGR
  102. 10 Sec Club
  103. New track times! New best in 1/8th
  104. New guy in here, project pics included.
  105. old question new 58mm body
  106. my old setup..
  107. Kooks LT?
  108. Low Res Pulse Circuit Failure
  109. Intake manifold oil leak symptoms..
  110. Yes, another cam sound video
  111. Clutch Disks from Gripforce on ebay
  112. AC Problems
  113. IAC didn't fix the problem with my idle
  114. Ac control broken!?
  115. lt1 valves????
  116. Flywheel Chatter
  117. Mpg
  118. At WOT on an NA car whats your AF?
  119. Exhaust, Tune up questions
  120. First 1/8 mile times...
  121. Budget Minded 500whp
  122. Slave Cylinder Rebuild
  123. Need master tech advise
  124. Temp
  125. My LT1 today..
  126. Couple of Questions...Help please!
  127. Elliott (Not Lloyd Elliott)
  128. who has the comp269 in there lt1?
  129. help me diagnose plz!
  130. Operation modifications underway
  131. Turbo Setup
  132. What do you think about 4.56 with a t56?
  133. air bags the same?
  134. LS6 block with LT1 heads???
  135. Pic of a pic of my old 97 Formula
  136. Cruise Control Lever
  137. Got hit with a monsoon .....
  138. Header Question
  139. Gears!! Gears!! Gears!!
  140. Comp 503 Cam Question
  141. security light
  142. Jet hot coated headers and smokes and stinks
  143. Just look at the link it's funny and sad...
  144. 3.42 gear
  145. Edelbrock Shorties Review
  146. timing chain
  147. Spark plug wire?s
  148. 92 vette
  149. Power Steering Hose Question
  150. Opti got wet, now what???
  151. Thinking of boring out my thottle body...
  152. Trufiber WS6 Hoods
  153. Building another 355. Will this meet my goal?
  154. I need a lift ?
  155. Golen CNC Heads
  156. radio and power window turn off while driving.
  157. opti spark question
  158. Maf help!
  159. getting my butt kicked
  160. I need parts!!
  161. How do I remove this?
  162. Chinese Opti: What's the longest one has lasted?
  163. what do i need for rebuild
  164. buick lt1 vs f-body lt1
  165. need brake help on 95 TA
  166. hot misfire new ICM cooling mod
  167. lt1 tuner
  168. Almost ready for the track. And no more granny shifting for me.
  169. Cam Gear and Crank Gear question! :)
  170. crazy problem i need help please
  171. Car seems to be breaking up at 4200rpm...help
  172. Cutout issue
  173. What Bearings to use for a stroker
  174. What kind of glue did you use on your fuel pump bucket?
  175. Thanks GMMG...
  176. Front timing cover and water pump bolt pattern drawings
  177. How-to mod an opti?
  178. got a few things!
  179. Changed spark plugs now car runs like crap...?
  180. HELP!!!! over heating
  181. picking up lt1 compression
  182. My Air Conditioner stinks BAAAADD!!
  183. Grinding at WOT
  184. vented opti question/rough idle
  185. What to do with the camaro...
  186. Fog Lights, what aftermarket ones could i use
  187. ? for all about temp sensor and temp switch????
  188. is this window motor problem ?
  189. Ai Cam
  190. Mild cam and 1.6's stock valve cover?
  191. Normal LT1 operating temps??
  192. PLEASE help, Weird idle issue
  193. Parking brake
  194. LT1 LE or AI....??
  195. Oil leak.. need ideas
  196. 58mm TB swap progress
  197. Not running right..need a lt1 guru
  198. Anybody ever break off the crank bolt into the crank on LT1?
  199. AFR 227 LT4's, single plane......etc.
  200. big difference in 28" from 30" tires
  201. New heads, TPI, or LSx?
  202. port matching gaskets?
  203. thinking of changing mufflers...
  204. 383 or 396 for my 1996 impala SS?
  205. Is this the right gasket maker?
  206. Header Increase ???
  207. Thinking about Going to DUals with an X Pipe how about these?
  208. What do I need for installing headers?
  209. CC502, stock LS1 rockers, and stock LS2 valve springs...
  210. What the Hell?
  211. plug wires
  212. Oh Crap, might have frigged up my hard fuel lines. Need help.
  213. Back from the track - Advanced Induction 383
  214. What did I do wrong? - Clutch Problems - HELP
  215. Build Thread for "Grn Dragon"
  216. Could anyone tell me what i have?
  217. What pistons should i go with?
  218. Made some progress.
  219. water in intake
  220. about to switch to synthetic. what weight for texas heat?
  221. 4l60e with 383 cid?
  222. ls1 brake upgrade
  223. How do i repair a heater hose?
  224. Missing coolant from radatior and its filling the resivor
  225. Wiring Question
  226. backfire!!!
  227. Any LT1 running AI come in !!
  228. What is the minimum safe distance that exhust pipes should be from steel fuel lines?
  229. k member a-arm bolts??
  230. LT1 X pipe
  231. Popping and Missing in high RPM's
  232. What do you guys think of the new setup?
  233. New Drag rims Greg Welds all around :)!!!
  234. Mod Questions
  235. Where do I fine the least expensive bilt in roll cage?
  236. How do I make the low coolant light go off?
  237. LT1/4 ARP rod bolt TQ-ing & Piston Ring ?'s
  238. can't believe i sold it
  239. Pulley installer/ puller for our lt1 ?
  240. monoblade flow
  241. Oil Pump
  242. What to do know?
  243. gear ?
  244. If you want a set of Brodix heads on your LT1
  245. LT4 intake....sort of
  246. Moroso problem with pick up tube wtf...
  247. Best way to set idle after H/C swap
  248. Caddy Lifters
  249. HELP?? CODE 36 -High RES Failure
  250. angle management
