View Full Version : LT1-LT4 Modifications
- what is this tranny's problem?
- lt1engine please help>>>>>>>
- 94 25th weird idle
- what transmissions can be put in a 93 firebird lt1??
- tunning for LT1..?
- SBC Milodon steel splayed main caps
- Tunning for LT1..?
- tunerpro v5 dash
- Happy B-Day Mr. Tony Shepherd
- I think I found my next new toy...
- Ideas???
- P0101
- efi connection people step inside
- Quick LT1 vs LS1 rack and pinion question
- 1996 LT1 engine stalling/bogging
- SES light....HELLLLLP
- '93-'94 coolant hose 'upgrade'
- 96-97 trans harness for efi connection people
- 1.5/1.6 split on the rocker's
- What is this?
- FML! bent 8 rods today
- The inevitable finally happened! 10-bolt Fail twice w/ NEW VIDEO!
- Exhaust Flange V Band
- Where to get this size plug?
- wat kind of brake pad that originally came with ourvehicle.
- Tranny dipstick tube
- 93 Trans am Help/opinion
- Catalytic converter ?'s for a swap guy
- Best cam for Daily Driver?
- Ls1 brakes
- Electric wp relay wiring
- Horrible gas mileage after cam install...
- nhra cage build help
- I found another Bowtie Block (GM Race Shop)
- Fuel pressure bouncing when car is running?
- slow to start
- Slp 2otl w/ cutout
- ebay roller rockers - good buy?
- kooks gaskets
- Chassis mount torque arm??
- lt1 Parts for sale, TPIS HEADS, LONGTUBES, INTAKE, INJECTORS- GO FAST PARTS
- Timing chaing questions
- 400+ rwhp from stock bottom end
- Long tube headers
- LT1 intake
- Can i see pics of dumped exhaust puhhleezz:D
- 94 Camaro headlight springs?
- Low horsepower draw AC compressor?
- Slow to start
- '69 Camaro swapped with '95 LT1 Vette motor question?
- Got my Formula up and running!!
- went through 4 starters in 2 days!?help!
- LT1 383 for sale
- Swapping in a 96 LT1 into my thirdgen, cam selection help
- Gauges for a 1997 Z28???
- people with ignition boxes
- LT1 question. please help..
- Need lt1 parts? Huge part out!!
- Traction bar help
- Lt1 Slave Rod
- LT4 questions... Please help
- Quick Lifter Q??
- Chandler Opti
- LT1 squeking noise
- Injectors
- 25 anniversary TA...Rare?
- Finally got some pistons now what rings
- Stock Flywheel limits?
- MBA style Fuel Rail Covers?
- Coolant fan Problem....
- color code
- car will not stay running after cc306 install!
- lt1 interior wiring. ignition
- Car missing after header install.
- Cam Advice
- slightly rough idle, slight hesitation
- Codes and Exhaust
- How to check injectors?
- Operation fix it
- bog at high rpm
- a few e85 questions
- close to solving opti issue!
- cooling fan issue
- ebay fabbed valve covers
- Rocker arm fracture? Pics inside
- Cam/bolt on + nitrous guys....
- oil pressure to high???
- 3.8 lid
- Any Gains with an underdrive pulley setup?
- ported lt1 intake manifold
- 4" y pipe...is it too much for a street car?
- How Should I Kill My Resonation?
- Milky Oil
- code help????
- No Spark? Randomly dies. Please Help!
- New Opti...Still Wont Start!!!
- 383 is finished up
- Part # or size for PHR bolts?
- backfiring
- Rear end swap
- Engine Coolant overflow
- timing code
- HELP! Flooding Out!
- guys any ideas of what this means?
- Hood Insulator Info
- Idea to help control blowby N/A?
- Dash Swap into 96 Camaro
- 13sec
- Oil filler neck
- hesitate to accelerate?
- Procharger Install - Couple Q's
- LTX Cylinder Heads
- New LSM Valve Event Controller on the way
- yikes!! cant read codes
- Alternator pigtail
- 2000 miles after 355 rebuild
- whats the deal with knock sensors?
- My new Turbo LT1, **Pics Inside** have a few questions.
- EFI Users...question for ya.
- Oil pressure problem, any help?
- Could an exhaust leak cause...
- Back in the game...
- SLP Speedometer correction box. Need a part # or instructions.
- LT4 Starter Issues
- Vacuum leak
- locators?
- very weird???
- What is the best Valve Spring Compressor for a rookie?
- How to Swap Door Handles
- Should I do anything with these pistons? PICS
- Need A Tune Flash before this week end
- CAI kits
- Stock tune big injectors
- Need some good light weight pistions for my 355?
- looking for best AN prices.
- doin a little exhaust research
- Correct Sealant or Loc-Tite for Rocker Studs
- Valve job and port & polish stock
- misfire?
- MAC Header help
- runs great but misses at 4500?
- Recomend me some rear suspension parts..
- quick clip of my car
- intake elbow boots/clamps?
- oil drip
- LT1 Procharger
- Thinking about converting over to E10
- help with a 95 z28?
- Powerwashed engine bay, now no start
- Descreening MAF
- My '96 LT1 T/A build
- valve clearance ?'s
- Spec 3+ Users...
- Missfire in 96 TA
- lt1 cam swap??
- exhaust vid request
- another o2 thread. Wtf is happening here
- Upper rad hose Diameter
- LS1 Lid with a stock Firebird hood
- Fuel problem maybe?
- lt1 304 comp cam questions
- oil pump
- Where to buy
- Update on old car part 2...
- lt1 top end rebuild
- Could the engine sucking moisture through the MAF cause this?
- Fuel Pumps & Wiring Harness
- Which O2 Sensors?
- hotchkis strut tower brace
- Are Mahle 101p18 Good Pistons? Compressioin?
- Airfoil?
- vented opti
- That knocking/ticking problem video
- LTX/Callies Question
- I need an lt1 specialist
- 97 firebird formula
- Single plane Vic Jr set up questions
- car feels powerless
- Plug wire sleeves
- where to install speed inc FL reloc.?
- OK Who was it?.........Impala guys
- PICS Need help figuring this out Head and intake
- Ac delete, how hard is this?
- car vibrates real bad
- Whats needed to run e85?
- lt1 assembly question
- Security light, keeps locking starter out.
- 97' LT1 Camaro running lean on bank A & B
- Quick question about a thingy...
- Happy Birthday to Me/ Ebay Headers
- aNYONE SELLING AN EXHUAST FOR lt1?
- 4th gen 3rd gen clean out possible
- Keying Crank
- How much for exhaust install?
- Cometic Gaskets on Trick Flow Heads....
- Cam Suggestions!
- wiring help needed badly
- running rich
- Non-sponsor thanks and appreciation
- Cam Question
- rev limiter ?'s
- Direct Port is ready to go...
- torque converter
- Where to Mount the Solenoid?
- Need help 93 formula WAY underpowered
- Coolant leak?
- Any ideas?
- Low nitrous results with plate?
- LT1 camaro bolt-ons
- Opti-spark magnetic pickup sensor replacement part?
- Stock......Not so stock!!!!!!!!!!!!
- need help completing my 383
- Anyone running stock cube lt1 with 210 heads or larger?
- Formula Track Results...
- rpms drop
- LT4 Cam and rear gears question
- Edelbrock super victor or super hurricane single plane intake?
- where to buy pa racing k member?
- loss of power + high rpm
- Podcasts
- 2011 LTxShootout CALLOUTS!!!!!! See if you are inside!
- 97 LT1 is stumbling/misfiring/detonating in a load condition
- in the need of front drag shocks...
- 95 lt1 computer
- 5/64in vs 1/16in piston rings.
- need info on data logging my 95 z28
- Front Strut Problem...
- Prothane poly bushings won't fit into the bushing shell...
- checking a water pump
- Canton Oil Pan Question
- door hinges
- Tune help?
- Bent 2 Rods in my LT1 Stroker.. WHY
- 95 trans am injectors not pulsing...
- what springs for this solid roller cam
- Inside of intake coated with oil
- Hi-power, SMOG legal LT1/LT4
- Question on these headers
- Anti-Freeze Leak ... Dripping off Oil Filter?
- Engine Install problems!
- Fuel problem?
- no block off on intake mani
- recap of my cam swap
- LT1 wont be going to the dyno anytime soon.....
- lingenfelter 100mm maf?
- 95 z28 turns over wont start!?!
- TB size and port
- Looking to buy full exhaust
- Seems that rain and LT1's don't mix.
