View Full Version : LT1-LT4 Modifications
- best valves
- Cc 503
- Obd ?
- True Dual Muffler Suggestions
- 355 (LE2 head/LE1.5 cam) valve float solution found. Dyno graph inside
- my cars finally getting fixed!
- LT1 swap
- valve springs
- Track times!
- Need a dipstick that is made for headers...
- Any way to bypass O2's on OBD2?
- Ported Heads Pictures and weight reduction progress pics
- This is why you weld the pickup tube...PICS
- Got my CPT 4l60 installed last night
- Couple of questions ...
- rev limit of stock bottom end
- cold start idle
- Anyone run a custom Advanced induction cam
- Got this car for $1525.00
- Another exhaust question
- Anyone drop the front of there LT1 with springs? pics?
- Header Problem!!!
- fuel pressure issues and no start
- need help with opti
- Install time for LT'S???
- M6 guys... parts info needed
- lt1 just died.
- 18 mpg hwy with head and cam swap.
- Which plug wires...
- What all is needed to put 98+ Brakes on a 97 or below?
- Just go car....gas pedal?
- 100 shot & tune?
- choosing LT's. need some info
- what size tach fits in the air vent on a 96bird
- Can't break the LT1
- another tuning ? obd1
- EGR Question
- Crashed my camaro, so what should my next car be ?, To be lt1 powered :-D
- Clutch Swap
- Cubic Inches and block power
- Which Torque converter, unsure on decision
- Locking Plate behind the steering wheel... do I need it?
- overhating please please help asap!
- Low Coolant Light
- TPS sensor bad
- STEP IN >>>>> lets see your true dual pictures
- ? about new track times
- LT1 Tuning
- What am i doing wrong?
- Roller Rockers
- car will not hold idle, please help.
- LT1 to gen1 conversion
- Advantages of splayed 4 bolt.
- To those with Aftermarket Steering wheels.
- ran at the track
- Help!
- Which Mechanical Water Pump?
- biggest noob question ever. sorry
- 1st time I raced
- quick 95' TA question
- VOTE: Best clutch for $$
- Help, I Cant Figure This Out, Need Help.
- Convertor?
- To all who are SPRAYING regularly...
- trickflow pushrods
- cc503?
- Cats and Motor mounts
- Cluster wire access
- breathers what do they do
- Help On Throtle Body
- ABS INOP and BRAKE light on
- Recirculating radiator catch can question
- Idle issues need help!!
- Questions?? ( Aquired 98-02 center console)
- Raising LT1 rev limiter
- going to replace spark plugs, and brands to look out for?
- coolant issues!! HELP
- what do i do?
- Swappin' plugs
- Head Bolts or Studs?
- HELP lt1 keeps poppin fuses
- Are These EBAY Remanf. TB's Legit?
- compression question???
- Blown Motor?
- will a 12bolt from a 71 camaro fit my 96t/a
- Hooker LT Install
- Picking up new project this weekend..
- help with some oil burning
- i need facts on a 383 build
- KYB AGXs at the track
- thinking about getting the tailpipes tucked. opinions please
- Major charging problems
- So... some bitch hit my beautiful car on tuesday...
- How much abuse can a Centerforce take?
- NEW PICS of my car!!
- Last egr/ air delete question i swear.
- What can i expect?
- throttle body bypass size tube
- Fuel Pump and Fuel Gauge Sending Unit
- People Running Nitrous Come IN!!!
- Superchargers ATI vs. Vortech??
- FS: 1995 LT4 Formula
- What is this part?
- breathers
- update on mods so far
- New 383!
- I need vaccum...
- XE, XE-high lift, XE-R, XFI Cam Lobes. Who knows the difference?
- PLZ help me ID this cam
- Still getting Smoke at Higher RPMS and Full Throttle
- Bad opti??
- best oil for a new cam install
- Question About A Sway Bar
- Riddle For The LT1 Guys
- Back fire
- Opinon on Rims for my 96 Z28
- 1.7 Rocker Arm Question PLEAE HELP!!!
- Ever feel like you just don't know what to do next??
- Question about optispark
- cam is in so whats next?
- LT4 Motor... Question about Vacuum and PCV
- RPM VS Speed question..
- more about the pcm performance
- LT headers
- Anyone running 15x10 prostars with 6.5" bs?
- Canton Valve Covers and OTVC Wires
- Power Steering Pump relocation bracket??
- 1995 Impala SS fuel pump same as Camaro?
- which way do the header gaskets go?
- My progress
- Key thingy
- Antiseeze Question!! Need Answer Quick
- What bolt ons am i missing?
- Wanna save money? Consider this...
- Balancing.
- cnc cylinder heads
- YSI blower brackets for 94 LT1 Z28?
- Do new ls7 lifters work in lt1 cars?
- Misfire problems
- Slow Start w/ New battery = starter?
- mod t/a or get gto or corvette
- Bad MPG's
- Rocker Arms ?
- 2 or 4 bolt
- need a set of 30over 6in forged pistons
- Urgent need Help on Timing Cover
- mods!!!
- Air Fuel help!
- carbed lt1 intakes?
- How Do I Install The Front Shocks Without Blowing The Springs In My Face
- So does anyone need their cylinder heads rebuilt?
- question on 4L60E .... enter!!
- plus of descreening the NAF??!!
- Need help after changing plug wires
- yes ANOTHER cam question thread
- whats a LT1 and tranny worth?
- other plug wire ideas?
- Slp Lm
- shaft mount rocker arms
- Can i remove the air silenoid?
- Roller Rocker Question
- Waterproofing an Opti
- More weight reduction pics and carnage
- Home Ported Intake Pictures
- Installing Headers-what all do i need
- Zero deck the block or not?
- Question 4 Ray@Nitrous Outlet
- exhaust swapage!!!
- cam swap grocery list
- 4:10 swap from 3:42
- how to beef up ur 10bolt
- crappy battery = perf problems?
- Big Fn Problem!!!
- 12bolt Or Ford 9" Which Is Easyier To Install
- need some knowledge here...
- Stumble at mid-throttle or higher, idle RPM erratic
- Quick Opti question
- I blew up my spider gears in my stock posi unit...
- Loud Knocking Noice
- Broken starter nose?
- Antenna mounting
- LPP stainless LT1 headers slots or no slots?
- Throttle body bypass attempt
- rod bearing clearances....
- Missing and rich after cam swap
- anybody seen the new slp powerflo catback?
- where do you shift your bolt on car (m6 guys with 3.42s)
- Swapping to a LS1
- N2o plug Gap???
- Removing this piece help plz
- Injector swap question...
- bad vibration?????
- Accelerator stop scew
- MAP sensor seal?????
- Ram air conversion
- engine rebuild
- Which Ground wire is this?
- would this work
- How long should my stock clutch last?
- Can a built tranny kill power?
- upgrading from S trim to YSI on 1994 LT1??
- Plug wires next to headers...Anyone have pics?
- HyperTech Programer
- when my fans turn on
- fuel pump bucket
- wires next to headers
- lt1 shiftpoint
- whats everyones timing/spark advance?
- Trans Am VS Camaro ur fav
- "Stock Internals" Build
- What do i need to do to delete air?
- What Are The Best Head/cam Package For A 2k Budget Or Even 1400
- check engine light please help
- Alignment off after putting on LS1 front brake swap.
- Step In If U Got Work On Your Stock Rearend
- MALF 16: Lo-Res Fail
- Cam decision...
- Rear Caliper question
- 95 vs. 00
- CB mounting
- Headlight Mods
- OBD1 issues... wtfbbq!?
- Questions About Custom Cams---------
- dart t4p heads
- Tps
- Tp
- Best Headers(poll)
- LT1 won't start
- 406 or lt1?
- Connecting Rods
- 95 TA NEED HELP quick...
- Help On Torque Converter!!
- 305, 503, and the stoc 10 bolt
- Lt1 Head Question
- need muffler ideas
- Racetronix's 42's...witch ones?
- Possible Optispark, LT1 newbie here.
- lt1 balancer postion
- f(*^ing @$$holes
- plug gap??
- heads ?
- 95 TA fuel tank/fuel pump?
- crane rockers
- Acting funny
- Quick valve spring question.
- OBD I SES light question-1995 Z28
- help with headers and ORY
- Spark Plug wires question?
- 1993 Z28 trouble codes
- LT1 Rotating assembly
