PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235
  1. M6 swap results
  2. 96 TA cats and O2 sensors?
  3. free mods?
  4. LT1 to LT4??
  5. came across new block! what do do now??
  6. how accurate is g tech
  7. How fast have you gone with your 10bolt? Times inside
  8. True duals with Spohn Torque Arm
  9. Afr 215 Raised Runner
  10. Does This Sound Right
  11. internally balanced?
  12. 4L60E Inspection cover
  13. *video* 224/230 cam on 93 firehawk
  14. 95 Opti Wire Harness
  15. Opti??
  16. balancing
  17. Beat an 05 GT, then i broke down!
  18. 1994 trans am hooker header dilemma
  19. Intake fluttering
  20. times
  21. oxygen sensor questions
  22. 1.6 RR Clearance
  23. 195cc or 210cc Any suggestion?
  24. Best cam for unported heads for Lt1?
  25. dual cat to single cat
  26. 2/3 wot shift prob.
  27. Supercharging my Lt1
  28. car problems please help
  29. 383 lt1 only 13.23 at 105??
  30. nitrous and Delteq
  31. Just bought a Delteq
  32. 1.6 RR's
  33. I need help for this questions...
  34. Not Bad... stock Lt1! Dyno
  35. Rerouting belt
  36. crank casting numbers 1995 lt1
  37. Track Times
  38. jet hot sucks
  39. Its Alive
  40. cheapest opti?
  41. LT1's quieter than LS1's?
  42. Cam swap+springs Issues?? @HELP thnx
  43. Crank Gear Install - Not Going On
  44. Tried LS1 DS swap..didnt fit? Help
  45. fuel pump??
  46. stock flow #'s
  47. cam help
  48. high-flow cat that will bolt right up to a '95 Z28?
  49. LT1 Dyno Archive
  50. Drove an M6 TA today
  51. Exhaust Bracket question
  52. EGR and AIR removal
  53. BBK shorties fit w/ mac y-pipe?
  54. opti conversion/protection
  55. Nitrous shot?
  56. Will It Hold UP??
  57. Safe boost for lt1
  58. LT4 hotcam?
  59. home porting throttle body
  60. bolt on are there any more for me?
  61. header bolt question???
  62. About to order a clutch for my Z
  63. Dyno info for my mods
  64. lt1 tuner program suggestion?
  65. Need advice on gears for my setup..
  66. going to dyno again tommorrow.
  67. awsome opti article!!!
  68. O2 sensor interchangability?
  69. carbed lt1
  70. Roller Rockers
  71. Very Slow H/C car and Intermittent Miss- I'm stumped
  72. Air Intake
  73. aggressive cam for stroker engine?
  74. Header Disaster!!!
  75. quick question about a code
  76. Afr Rev Kit
  77. anybody solve the bad misfire problems?
  78. What will I need for the LT's?
  79. Lt4 Km?
  80. Torque convertor ??
  81. I want to do a cam swap on my lt1.
  82. talk about a short throw
  83. Pissed Off
  84. shaft mount or regular rockers?
  85. Anybody Know About The New SLP Dual-Dual Exhaust?
  86. Dyno session went badly
  87. jet hot long tubes
  88. 94z28 blew white smoke through intake now wont start
  89. who converts SBC heads to LT1
  90. 15 degree heads for only $1,300!!
  91. Need help LT1 randomly stalls, then starts up fine?
  92. Header Question
  93. Next Mods.....
  94. Question about HPP3 programing.
  95. shortblock options...
  96. oxygen sensor
  97. What SFCs do you have?
  98. Is it worth it??
  99. Custom Air intakes
  100. LT1 Question
  101. installed the delteq and car only ran good for a few days!
  102. lloyd elliot
  103. Symptoms of bad O2 sensors?
  104. after hot cam install car is not running right
  105. Pacesetter LT's (pics)
  106. high flow cats, SES?
  107. piston ring help
  108. whats next
  109. whats next
  110. ET guesses for tonight?
  111. Advice on ebay 425hp Trans Am mods wanted.
  112. Does an Aftermarket PCM still require the use of the ICM?
  113. Stock ignition coil limits....
  114. gmmg chambered exhuast
  115. Funny...
  116. where to get LT1 engine with warranty for decent price?
  117. hp/ quarter mile with these mods
  118. estamated Hp and e/t for my mods?
  119. crazy dyno = bad opti ???
  120. opinions needed
  121. questionable advice
  122. Looking for ORY
  123. A4 pros/cons?
  124. What ever happend to the Coil system, "Del-Tech" for LT1?
  125. transmission problems
  126. what fuel pump should i get?
  127. Torque Specs
  128. need help, car not running right
  129. 7100rpm
  130. Rebuilding an LT1, need some prices
  131. Some changes in the forum...
  132. Newbie Mistakes
  133. Favorite User Mods
  134. The Ultimate LT1-Newbie FAQ
  135. Finaly got some decent times
  136. Some 383 Insite
  137. who makes a good balancer install tool! super dampner hub and callies crank
  138. Pushrod Help
  139. how much for rear main seal
  140. LT5?
  141. What size stall should I run.
  142. Installed wrong coil on my car, sort of.
  143. failing opti symptoms maybe?
  144. quietest / least expensive / best performing muffler?
  145. Bought these on EBAY last night.
  146. what next?
  147. opinions on what hp this setup will net (i know... dumb question)
  148. Heads and Cam is in!!!!
  149. What Time?
  150. Joe O. I want DFI!! Help
  151. Car tugs and kinda sputters when I am WOT?
  152. Just wanting an estimated guess
  153. The Official LT1 Multimedia Thread
  154. anyone running LE3 package from Lloyd Elliott?
  155. n2o guru's need help
  156. CARB legal headers
  157. Will 98+ z06 clutch fil in lt1 tranny?
  158. BMR questions
  159. Edelbrock headers
  160. max psi on stock injectors?
  161. Heads and cam specifics- how much power?
  162. trickflow heads vs ported stock heads
  163. rotor disintegrated AGAIN on opti!!! WTF!!!
  164. LT Header write up?
  165. Built LT1 355 vs. 383 questions
  166. What timing chain?
  167. new opti in.. now i have idle problems
  168. New setup complete!! but car wont start!?
  169. injectors
  170. big problem
  171. Are 37# Injectors to big?
  172. surging idle/clipping during acceleration
  173. y pipe question
  174. scanmaster=awesome! now code 36....
  175. Headers?
  176. I must have another LT1...
  177. Cam swap steps??
  178. Dynoed LE1 today with alittle problem
  179. Behold, The Return of the King
  180. water pump drive seal
  181. Opti Spark, options???
  182. Pacesetter vs. Hooker headers
  183. I need a part #
  184. Lt1 Off Road Pipe
  185. please help
  186. low cr pistons
  187. LT-1 heads and cam
  188. 383 Stroker Build, any thoughts?
  189. Need Help Choosing Clutch
  190. re-ring kit
  191. it must be a street car!
  192. is a dual cat setup on a 95 really worth it?
  193. loudmouth or hooker
  194. Heads and Cam swap question
  195. 3000 or 3500 converter?
  196. Cylinder Heads
  197. Jet hot y-pipe
  198. 12.5 cr and 13 lbs of boost!
  199. Compression Ratio
  200. f'in opti crap
  201. which cam and which pushrod length?
  202. CNC porting VS. Hand porting
  203. you all are modding useless cars
  204. Valve Cover Breathers.
  205. SLP shorty owners.
  206. relationship of fuel pressure, tuning, and nitrous
  207. Check out the GMHTP!!!
  208. Oil pan gasket keeps comeing out
  209. Help! Transmission Problem
  210. Opti swap
  211. 210cc or 195cc ?
  212. difference between the lt4 and the lt1?
  213. tb bypass
  214. LT1 Head gasket
  215. pulley swap
  216. Need some help with getting mods
  217. cam buildup
  218. EGR question
  219. torque arms?
  220. vigilante converter
  221. F.S. LT1 Heads, short block, and power programmer
  222. BAD misfire on delteq and new autolite plugs - help!
  223. help! what is this i think i broke it
  224. Spark plug wire loom kit
  225. Who else does the over the valve cover wire kit?
  226. OOPS Bought another LT1
  227. lt1 shorty plugs
  228. True duals.
  229. clutch fork
  230. Cam question?
  231. water pump drive gear
  232. Why do i need forged?
  233. racing question???
  234. A4 to M6 swap
  235. Random Miss... something bad happened
  236. Intake Torque Spec?
  237. carbed lt1
  238. cc306 with stock heads
  239. Nitrous = boom! uh oh...!?!
  240. 1.6 rockers on stock cam
  241. timing cover gasket
  242. battery relocation info?
  243. header programming
  244. Need a parts list for Solid Roller cam swap.
  245. how to remove the cam and crank gear?
  246. Need Help Service engine light
  247. carbed lt1
  248. pcm masters needed
  249. Install LT4 hot cam kit in a 94 Z
  250. 355 Lt1 Build
