PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Oil Pan and Rear Main Seal
  2. car is missing when i give it gas
  3. quick question about o2 sensor
  4. car is almost done
  5. Long start up on LT1
  6. Mr gasket 5716 head gaskets fubared out of the box?
  7. Which driveshaft should I use?
  8. 93-96 corvette air box
  9. 93-96 corvette air box
  10. What route to go with my LT1
  11. Burning antifreeze, best way to go about fixing?
  12. GEAR HELP!?!?!? 2.73 to 3.73???
  13. 3.42 or 3.73 or 3.90
  14. Similar Setup What Did You Run?? 1/4
  15. o2
  16. should i do it myself or take it to a mechanic?
  17. 2 Part LT4 Knock Sensor Module Question
  18. Jesel shaft mounts / Valve Cover issue
  19. "thepartsladi" is GONE...next best place for an Opti?
  20. apm air box for 93 -97 firebird
  21. what to expect to pay for an lt1 SS?
  22. Erase codes from Scanmaster?
  23. 388 head gasket will this work?
  24. fuel pressure questions
  25. 96-97 4l60e in a 94 lt1
  26. Lt4
  27. LT1 longtube problems
  28. Flowmaster drones too bad
  29. milling heads
  30. Mallory 685 users
  31. damn coolant lines!
  32. Fastest lt convertbile
  33. Need help? Trouble code?
  34. Rod and mains question
  35. So what kind of Timing sets are good for over 6-700 HP
  36. no start after cam install...
  37. Awful vibration 80mph+
  38. Put on my new exhaust today.
  39. Does AFR offer a 210cc head for LT1?
  40. What headers are these??
  41. looking to buy an lt1 what should i look for
  42. Lt1 rotating assemblies?
  43. Racetronix FP harness with Boost-a-pump
  44. 95 z28, new cam and torque converter
  45. what torque converter should i get...
  46. No spark!!!
  47. 58mm TB
  48. relocated battery, now having trouble with alternator
  49. LT4 Hot Cam/AFR 195 Competition port heads
  50. EGR Block Off Plates
  51. time for an opti
  52. Going to be dyno testing some exhaust setups, input seeked.
  53. Back in the LT1 world
  54. '97 formula wheels on a '94 Trans am
  55. So does anyone else have????
  56. Custom throttle body plate?
  57. help!!!!!!!!!!!!!!!!!!!!! please..:)
  58. Codes 36 and 42
  59. O2 sensor bung stripped...Help/Advice
  60. Flat or square O2 extensions?
  61. Not passing emissions.....wtf.
  62. OBD1 PCM in 97 SS Camaro...
  63. Kooks aluminum header gaskets
  64. Fuel Line Leak - Intake Hot
  65. Scanner questions for idle checking
  66. SLP "Axelback"?
  67. Trying to scan code
  68. help!!!
  69. Finally fixed my LT1. With pics!
  70. how to read 02s dyno prep
  71. Few questions dealing with cats
  72. Where to go?
  73. what company torque converter are the bolt on guys running?
  74. Tranny slipping
  75. Does my LE2 set up will work with this 383 Short block ?
  76. Service Engine light problem
  77. what mod should i do next that will give me the most cut in et
  78. PITA pacesetter issues
  79. GM846 cam
  80. Battery/Alterntor problem?
  81. Intake Mod Question.
  82. 383 cam
  83. My first 1995 z28, current issue..
  84. Who makes the best drive shaft
  85. Collector Hitting Floor!
  86. would these work alright?
  87. Changed the exhaust to Kooks and here's a video!
  88. clutch fork
  89. '95 Caprice LT1 problems- HELP!
  90. first start up after cam swap, water pump driveshaft bearing toasted, wtf?
  91. High idle and trans shifting issues
  92. brake lights not working
  93. For sale- Lt1 Msd Distributor 1992-1994 with msd coil
  94. Goin to the track.
  95. Its finally together! Idle clip! LE2 383
  96. New best on street tires Bolt on lt1
  97. Multi-Layered Stainless Header Gaskets
  98. LT1 PCM question.
  99. been awhile
  100. few questions / problem with pics
  101. LT1 after converting to th350 from m6, the transmission sits so high that...
  102. Off road y pipe
  103. the mistery oil leak help(pictures)
  104. I am done with Lt1/Camaros/Chevrolet
  105. High idle
  106. 383 lt issue
  107. Scanmaster Hook -up OBD2 PLUG?
  108. TCS Delete Question
  109. headbolt mixup
  110. Miss in certain RPM range?
  111. She Lives!! *Pics & Vids*
  112. Flushing the coolant system..How?
  113. Another project going on at my house, 70 Chevelle
  114. How do you tell an automatic starter from a manual one?
  115. PO335 Code nightmare
  116. I just got my first car...well real one
  117. Emission legal LT headers & y-pipe.
  118. Even MORE intake **PORN**
  119. Questions about modding a 94 Z28
  120. dyno numbers FINALLY!!!
  121. anybody with AS&M Midlength headers
  122. Slightly confused...pacesetter headers
  123. Clutch issues!!!!
  124. coolent system bleed
  125. injectors for a stock lt1
  126. What is this part.
  127. Monster trans with pics part 2
  128. What size plug to close off EGR hole in header?
  129. Does anybody know of any company's that have a Mcleod twin disc in stock??
  130. Question about AC Delco Cap and Rotor Kit
  131. Figuring out liters on a stroker
  132. LS1 lifters?!
  133. Finished my first mod!!!!
  134. ROCKER ARM Questions
  135. LT1 to WS6 LS1 air box
  136. Should I go with this?
  137. Do warped blocks happen often? question pertaining to cometic or copper gasket
  138. EGR Delete and Trouble Starting
  139. 93 lt1 scan software and cable?
  140. Do you still have your stock heater hoses?
  141. stock or ported LT1 heads(not aftermarket) what amount of boost and/or rwhp?
  142. Overheating problem now that she is back on the road
  143. Fuel Filters
  144. 96 Impala 355 blueprinted and balanced, heads and cam build
  145. Fel-Pro Headbolts or ARP?
  146. Fuel pump???
  147. Flowmaster 4in Merge W/ Chassis mount TA?
  148. Home porters, come in
  149. Buying optispark from "thepartsladi"
  150. Starting problem
  151. pacesetter header hits bell housing
  152. 383 C.R. and Injector size Question.
  153. question?
  154. Opinions: Should I redo my 1st attempt at rear main seal install?
  155. How can I tell if my dropped 160 degree thermostat is broken?
  156. how bad will stock intake hurt me?
  157. weird fuel problem
  158. Recommend me a tune
  159. optispark install
  160. LT1 year ID
  161. exhaust kits?
  162. rr's
  163. speedinc open house, anyone going?
  164. tranny line, which is which
  165. Rear braided brake line only...
  166. thinking of buy'in a lt1
  167. Is this Opti bad? (Pics inside)
  168. gaskets?
  169. TPI/LT1 cam?
  170. Trick flow elbow missing gromet
  171. Ebay speeddaddy headers, got a problem
  172. should i do it myself? (valve cover *pics) help
  173. thermostat
  174. Rod knock, maybe
  175. AI Cam with Le2 Heads now...Move to a bigger cam?
  176. Headers - Do I lose my Oil Cooler?
  177. had pcm tuned by lt1pcmtuning, failed IL emissions
  178. Fuel system questions. Intake swap Victor EFI
  179. Problem(s) with 1995 Trans Am
  180. Anybody that converted from a m6 to a th350 or th400 come in here....
  181. PCM problem
  182. Rod knock or wrist pin. Suggested purchase complete used engine? Help Advice Please!
  183. 3.4 to LT1 swap questions
  184. track for the 1st time now questions
  185. VP MS109 Fuel Question
  186. header install steering knuckle
  187. need help finding info on this Mahle piston
  188. How's your LT1 run when its humid?
  189. Look at these DYNO graphs
  190. Which timing set to get for cam swap?
  191. Another LT1 together
  192. Video of the new 385 LT1 in action
  193. Does anybody make turbo kits for LT1's except sts?
  194. AC FAILED... need help
  195. Drivability issues
  196. Which spark plug wires?
  197. What head gasket to use?
  198. 2001 Z28 vs. 1996 Z28 *videos inside*
  199. (Almost) Free Opti Mods for us 92-94 folks
  200. Aftermarket Head Owners - Need Your Opinion
  201. any way to reset a hypertech programmer w/o spending $225?
  202. madman alt bracket--squealing
  203. My t-56 is locking up after clutch replacement????
  204. where to get tune??
  205. Looking to buy Injectors????
  206. Topend Rebuild Issue
  207. Crank Recommendations
  208. Piston ring and valve seals
  209. what injectors?
  210. low profile cutout question..
  211. the problems will never end, trans died, t-56 rebuild questions
  212. New summer job equals new summer plans
  213. Procharger with LE1 heads, how much boost......and more questions?
  214. Wanted: Y-pipe and catback for LT1 w/ hooker LT
  215. MY Ebay LT Header Install...
  216. rear end size
  217. PN for ac compressor 94 Z28?
  218. Are UMI LCA Relocation brakets the same for a 10 as for a 12bolt
  219. 96 OBD2 into 95 obd1 car
  220. Calling All Opti Experts!!!!
  221. Need Schematics - No power to C230 G - pink
  222. please help!!!!
  223. changing a rear main?? what tool?
  224. can you put the green on the negative side of the coil?
  225. Intake is back from Bret
  226. FS 8 lucas delphi 42.5lb fuel injectors
  227. LT1 Surges at Idle after Tune Up?????
  228. Car runs like crap.
  229. Rocker Questions
  230. Opti problems
  231. LE2 Top end, do I need to refresh bottom end?
  232. Gains from LE2 Setups?
  233. LT1 Security / PCM issues?
  234. What changes should I make when using a 350 shot?
  235. 12.7s?
  236. How much is my TC worth?
  237. Need pics
  238. guideplates
  239. First Dyno numbers
  240. CAI mod or stick with SS Air Intake System?
  241. something is knocking up under my trans am!!!! need help guys
  242. 95 z wont start
  243. clutch release point
  244. Endurex lifters with 8500 miles, run em or rebuild em?
  245. lt1 water pump question ( please answer ASAP)
  246. Where to Jack on an engine
  247. Possible 575 HP w/ some changes?
  248. Electric water pump wiring question.
  249. LS1 Steering column in LT1??
  250. What are the odds? My luck...
