View Full Version : LT1-LT4 Modifications
- Pics of Magnaflow catbacks?
- Dynatech LT headers - Which Y pipe fits?
- quick question about opti
- Advice for water on car?
- Almost done!!
- 95 z problems ..help please
- 6 sp flywheel questions
- Speed INC - Alt and PS Bracket
- Do i need to prime my motor again?
- what cam would b perfect for stock block and heads
- anybody selling cme valance
- Lt1 performance upgrades.
- Lpp headers
- Getting a Miss Under a Load
- Minimum length for exhaust?
- ?'s about Cam surge
- Got a bone to pic!!!!
- Limp Mode on 24x 383
- Dowel @ 3 o'clock, is this right? (pics)
- 1.6 rockers
- Slicks overkill?
- LTXShootout ES PA
- Need help with my new z28
- Coolant Cross over tube
- LT1 to LS1 air box convert.
- 24X problem?
- Great Deal On An LT1 Firehawk
- long tubes and ground clearance
- sbc 400?
- LT 1 Guru's please enter
- Just making sure, heater core flush....
- Balancer ?
- A/C problems compressor wont turn on
- I just cant win.
- where to cut weight?
- Need some A/C Help??
- Cam only guys... 60' times
- Drove My First 6-Speed LT1 Today
- Anyone replaced their LT1 factory harness?
- LG motorsports CAI
- Lt1 temp?
- Nitrous and NAno refills at the shootout???
- 24X ignition runnig; but 1 small issue
- Birthday present
- LT1 Ram Air box on LS1 conversion for 85mm MAF
- craigslist find
- car is cutting out at 3k rpm
- Are these the correct rod and main bolts?
- where can i get my lt1 tuned
- I will have my old Camaro with me next weekend at LTx Shootout!
- Is this guy giving me crap or not.
- What's going on, codes after my exhaust swap.
- recomend top end
- LT1 Build
- LT1 Steering Question (Rack and Pinion)
- LT1 going in limp mode
- High idle
- HIGH RES Failure
- 93-97 mcnord front bumper
- Cc306 cam
- Back to thinking possible blown head gasket....
- Z28/ trans am lt1 casting #'s???
- Yes this has been asked before... haha
- Getting ready to swap clutch... few questions
- 2011 LTX Shootout Schedule and Call Out Order Have Been Posted
- 24X Kit for the Street Car / WS6
- is milling necessary?
- PCV Oil Catch Can. Is this correct??? picture inside
- can anyone tell me why my trip meter doesnt work?
- tuning help
- Errr, was this suppose to go back on?
- fuel problems
- Soft clutch pedal?
- difference between crane 227 and LE 218/224
- Supercharged Street car Big Novi
- Eng dia plug
- Is an ATI balancer REALLY worth doing?
- Lt1 tuner
- EGR blockoff plates. Where does the last one go?
- 94 z28 a4 wont shift till 2800 rpms
- LT1 Injectors No Steady Pulsing
- LT1 malibu a/c questions
- A mirror problem
- Source for Water Pump Seal tool?
- 94 caprice stand alone wiring harness
- breather that replaces oil cap
- ZL1LT1 In Camaro Performers
- TURBO guys?
- AC delete pulley
- My cut outs are in!!! Questions before the install.
- 3rd Generation 101
- aftermarket oil pans
- valve springs?
- tuning assistance elavorate
- LS1 Rear swap question
- High fuel pressure. Idle 50-51 psi..........
- Help missing water pumps bolts
- 396 guys
- P1361?
- k F*ckkkk dzus. where should i mount my pins?
- LT1 surging no power at take off
- LT1 Engine Dress Up??
- best headers for 94 Trans am
- Cam ideas?
- code 43. icm problem, cant figure out
- Keyed hub?
- tunercats cable drivers
- Casting Number on right side?
- Head Gasket?
- Edelbrock or Trick Flow?
- Sweat 96 impala SS for sale
- SBC heads on LT1
- Help!!
- My brother's gas tank is spewing fluid from the fill...
- what spark plus to get??
- LPP Headers?
- New to LT1 world
- Exhaust
- LT1 shutting off like someone cut the power
- What is needed to make this work?
- prep on lt1 for s10
- How high can you torque pressure plate bolts?
- aftermarket oil temp gauge
- LTx Shootout stickers
- LS1 lid?
- 96 LT1 emissions components, need help
- Trans Cooler?
- air condition question
- 95 Z-28 security light on
- De-leafed my blower motor
- Turbo LT1 whp estimate
- Email tune
- engine removal
- Bake light on
- I didn't know they made 0.021" head gaskets!
- Tuning & the lt4 knock module
- Hmmmmm
- Clunk coming to full stop?
- F'd up bad, need some advice..
- broke my ten bolt need help finding traction
- Emission style LT Pics...
- wont start
- 97 TA options
- What can I use to clean the block threads out?
- P0100 and P0300 code problems now what?
- Can someone help me out with links for what I need
- Lt4 hot cam
- Good way to build 96 lt1 up???!
- No problem but question about the radiator and coolant level.
- Daughters Surgery done.
- Car overheating bad need help!
- Did not pass smog check. Help!
- Starting issues
- Fuel leak at fuel pump quick connect, FIRE HAZARD
- Cooling issue but not over heating /O2 code question
- Clutch chatter!!!
- Lt1 with zero spark
- KR at idle?
- Considering 4.10s
- A/C Hookup + Heater Core ?
- ICM Heatsoak... Still Good or Replace?
- Underdrive Pullies: The real story
- WTH is This...
- 1993 camaro z28
- water system ? LT1 95 corvette
- 94 and 95 pcm?
- rounded off head bolts
- iv got a few tuning questions
- My homeade backlit radio delete panel with Trans Am logo progress pics
- How important is 1 7/8 headers
- New 355LT1 sets P300 periodically
- New leather seats - company ideas?
- So when winter comes around....
- m6 to auto conversion
- Built 4l60e
- LT1 Help needed
- 4.10's and nitrous
- spiral flow q?s
- just wondering???
- LM1 wideband with DELTEQ rpm help
- Damn opti!!!
- So, I didn't put any thread sealant on the head bolts.....
- 1/4 mile time for 405rwhp
- PCM I.d. ?
- th400
- 93 lt1 into a 95
- LT1 vs 392 SRT8
- Camshaft Retainer Plate
- resetting fuel trims
- Basic Maintainence w/Dyno Sheet
- is this real?
- Oil cooler delete. Am I missing something here? (pic)
- Steering wheel advice???
- Head Bolt thread Sealant, whats recommended??
- oil pump pickup ?
- 24x conversion question
- P/S Pump Bolt Hole Threads Stripped...input?
- Suspension mod
- lets discuss DFCO
- will welding a crack in headers hold?
- Rear seal impossible to get off, new one not the same.
- Hi temp
- Just Curious....what happen too....
- Anyone wanna double check a tune for me?
- Hurst shifter
- how much hp is left?
- M6 guys. need advise
- Pickup bolted to oil pump (pic), still tack weld?
- ALDL cable to laptop
- 97 Formula
- Don't have to sell....Yet lol
- Moroso oil pan sensor plug M20-1.5?
- 24X harness repin?
- Corvette Water Pump in Fbody?
- LT1 PCM TUNING MODS "Need Suggestions"
- EGR and 24x
- Problem with gauges
- V6 to V8 swap
- opinions needed for built
- Cruise Control box...
- Car feels slower than I should be
- P/N for coolant temp sensor?
- Heavy load miss.
- I might just make the Shootout
- Opti and high RPM miss/hesitation?
- Overheating a bit
- OBD2 back to OBD1 swap
- m6 to a4 mph loss
- Messing around with the ol LT1
- school me on speed density cars
- Gotta Make A Decision... 24x or Partout?
- Injectors
- Crossed Plug wires
- carb my 95 LT1 advice???
- can this be a fuel problem?
- crankshaft turned counter clockwise
- Can I Win?
- Check it out
- Can I get a little help from you guys?
- lt1 less power than normal and vibration
- Removing PCM to go XFI... BCM still work?
- Perfect timing ... FML
- Maybe silly but can you tell if your tune is good?
- Texas Speed True Duals clip on my LT1
- HArd to start
- Is this a Detroit Locker? If not what is it??
- lt1 noise with video
- Torque arm ??
- That didn't go well...
