PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Possible 575 HP w/ some changes?
  2. Electric water pump wiring question.
  3. LS1 Steering column in LT1??
  4. What are the odds? My luck...
  5. IAC tests good, yet doesnt move. Idle is fubar
  6. new PB at the track.
  7. Who's got the best prices on Qa1 / Strange
  8. New LE TrickFlow 21 deg heads/ported intake
  9. help! oil leaking from driver side header xp
  10. 1 7/8 header ?
  11. 1997 ta
  12. supercharged 355 plan
  13. Anyone ever see a sparkplug do this?
  14. tune issues
  15. New exhaust plans
  16. questions about single plane intakes
  17. Knock Count Cycling on Datamaster
  18. LT1 Single plane intake porn! pics inside!
  19. I'm so close, one more issue.
  20. Flexplate bolt torque spec
  21. waterpump
  22. windage tray
  23. backfire under load please help!!
  24. Part # for M6 polyurathane mount?
  25. Outlaw radial tire championship coverge
  26. Windage issue?
  27. Spark Plug Boots Within 1/8" Of Collectors - Plug Wrap?
  28. how do you test fuel pressure on the street
  29. New PR at KCIR last night!
  30. 96 motor with 95 comp
  31. compstar vs scat
  32. should i go with this header/exhaust set up
  33. funniest ricer comment...
  34. Wtf Le2 heads installed and failure!
  35. Firebird Formula HID fog lights
  36. Camaro Factory Cam Specs
  37. 97 lt1 rpms issues...Maybe need new plugs/wires
  38. Oil filter mount leak?
  39. % converter slip with a SS3600?
  40. Fuel line adapter part#'s. Need help.
  41. lt1 balacing
  42. 3:73 Gears Question
  43. How much is my motor worth?
  44. Test opti off the car
  45. Car takes awhile to rev down
  46. quick lt1 to ls1 airbox?
  47. 4L60e electronics
  48. 58mm TB worth it for the money?
  49. Power Steering
  50. Battery Not Charging After Relocation
  51. Valvestem Seals
  52. need a part from a corvette AC compressor
  53. SES light
  54. The Mysterious Miss
  55. clutch fork
  56. '95 LT1 Head Gasket
  57. how many people have a spool?
  58. Bullet VS2700 spring install=not working
  59. Ok WTF NOW!
  60. aftermarket valve cover pics
  61. timing retard for nitrous
  62. more 292xfi cam questions
  63. my old motor
  64. LT1's?
  65. Oil filter tests
  66. Finishing Le2 head build: where does this go?
  67. Any feedback on these?
  68. Stall help
  69. Interesting Track Video - 11.04 @ 122
  70. Race header install starts today info help
  71. Any real performance gain from 1.6 to 1.65 rockers?
  72. newbie that needs help
  73. hose help
  74. Finally the car is close to being back on the road!!
  75. need help from some experts!
  76. Anyone else go from HVAC to VAC? Any issues?
  77. Pull heads with cam?
  78. ses light comes on when fans come on
  79. Engine light comes on then goes off-vac leak?
  80. Halo LED - HID - Angel Eye Mod 93-97
  81. Monster transmission Dead with pics
  82. Do I even need this part??
  83. Double roller
  84. Anyone using LE 223/230 112lsa Cam?
  85. high fuel pressure?
  86. Opti replacement gone wrong
  87. cam/heads question?
  88. Griffin rad users ?
  89. LT4 cam stock valve springs
  90. LS1 Brakes...
  91. Need Help with my 97 LT1
  92. Summit 1.6 RR's
  93. Edelbrock AirGap port work before and after plus random LT1 intakes that we ported
  94. Will these lifters work?
  95. th350
  96. 95 Trans Am Startup problem
  97. Professional Products 58mm TB?
  98. Mystery Metal in the Oil Pickup
  99. Catch Can?
  100. Another New Best (with video)
  101. Hood scoop idea
  102. Speed density tuners an users come inside! looking for a tune
  103. what will it run??? cam and very minor home headwork
  104. Stripped oil pump drive gear and the motors died. Questions.
  105. Looking at this lt1
  106. what replacement o2s
  107. 93 to 94-97 lt1 differences
  108. 1994 LT1 Opti Question
  109. What size nuts do I need?
  110. The LT1 Oil Pan Thread
  111. nitrous or not??
  112. xfi 292
  113. What oil R u running with 383/forceinduction?
  114. 1997 Camaro Lt1
  115. SN93 on a b-body
  116. best $15 i've spent on my car in a while.... made it feel 10 years newer
  117. Starter question
  118. What Is This Plug Telling Me
  119. Just picked up a Wolfe 6pt :)
  120. Quick question about door glass
  121. Is It Even POSSIBLE To Install Hooker Shorties???
  122. looking for the right heads
  123. Pics of current Optispark I from thepartsladi
  124. Belt squeaking like hell but only when cold
  125. HELP! Need engine pics for reassemble...
  126. Throttle body is in!
  127. Getting no oil pressure only on start-up
  128. 13,000 miles original Ws6 formula. Needs HP
  129. egr ?
  130. sts?
  131. Help with tunning LT1 94 M6
  132. Best piston rings?
  133. Freeze plug size for water pump
  134. Sob oil leak! Again
  135. Anyones else car cursed????
  136. 95 M6 PCM in 97 M6 car??
  137. cam swap?
  138. will a ls1 pcm run a lt1 motor?
  139. LT1 6speed bolt on to ls1??
  140. Quick Head gasket question.
  141. LT1 6-Speed
  142. AFR LT1 heads Question
  143. This should make the heap a little quicker
  144. horrible clutch sounds
  145. Motor mounts header and plugs
  146. I guess im getting old
  147. Oil leak help(picture)
  148. ignitors problem ????? hlp me pls
  149. Machine shop issues
  150. How much does this hood wiegh?
  151. Thoughts on this cam?
  152. 9:7.1 compression How many pounds of boost?
  153. my stainless ebay headers
  154. 94 CAMARO 11.91...306 cam
  155. high compression
  156. A/C delete question
  157. Want to build a 500 HP LT1
  158. Clearance issues with Milodon 30909 oil pan?
  159. lt1 issue
  160. part number for bearings
  161. waterpump sleeve touching top of opti..
  162. Can't stop the engine from turning over...
  163. How to make sure its head gaskets?
  164. Some clarification about the cc306...
  165. ALDL Question
  166. 306 guys, where are you shifting your car at?
  167. What vehicals have a 4L60E that will bolt up to my 94 LTX?
  168. calling all you high mileage cam guys
  169. Are LT1 and LS1 MAF's the same?
  170. Big Ends?
  171. Which hood?
  172. trouble starting warm
  173. running car with no maf ?s
  174. Guide to installing an LT1 Help?!
  175. Rock crusher 4 speed
  176. Finally got the headers on...Opti quits
  177. Steering Wheel Swap
  178. A Long Time Coming...
  179. anybody have a step by step on dyi pr length check?
  180. header gasket fitment and street lites wheel studs
  181. Throttle cable
  182. lt1 pacesetters with y pipe for sale
  183. Is there a place to go to get PLUGS not CAPS for LT1 Intake Manifolds?
  184. Can't find head gaskets
  185. After market head lamps?
  186. Advanced Induction 383 Dyno Tune - Results Inside
  187. How do I correct my speedometer after 3.73s?
  188. Nitrous guys
  189. Single plane guys
  190. can i use these pistons
  191. Anybody changed the heater hose assembly?
  192. shbox come on in...
  193. High idle problem, drill and tubing modded 58mm bbk IAC counts at zero???
  194. What can my car run?
  195. fuel regulator
  196. someone please help me diagnose this
  197. I need gears!
  198. Why does this cam look Funny ???? Pic
  199. 94 TA LT1 Header install EGR Delete question
  200. To air condition, or not to air condition
  201. Does anyone have the LE3 package?
  202. I have a question
  203. Intake Bolt Torque Specs???
  204. first time at track not to impressed
  205. help pick turbo cam choose inside
  206. Some Questions about 96 camaro steering column
  207. How hard are you turning your 383
  208. Hurst Body Kit
  209. Three easy questions...
  210. Internal motor questions
  211. Alot of Water coming from the exhaust
  212. 93 intake manifold on 94
  213. putting the 383 on the dyno today
  214. how much is a 4l60e worth?
  215. Speedi Sleeve
  216. cam and head question
  217. Stock Shortblock Build
  218. Can someone try to explain me this clearly
  219. lt1 with or without mufflers
  220. help! pls
  221. lt1 problem guys.
  222. Time for new plugs
  223. Knock Sensor help...
  224. Sexy sounding LT1/D1SC Videos
  225. Update- Engine Knock (video) Thread Rocker Arm Hitting The Valve Cover... Help
  226. Idle issues on fresh rebuild
  227. 95 lt1 problem... again...
  228. Cam swap, first start up procedure
  229. could this cause a knocking noise?
  230. #2 plug removal
  231. Copper Gaskets leak after Header install?
  232. Morel (High Pressure Pin Oiling) Solid Roller Lifters
  233. maf reading
  234. Who has the fastest stock heads ported lt1?
  235. Oil pressure gauge =no reading
  236. ls1 lid on lt1 car
  237. trying to find a recent lt1 Thread
  238. tune up/oil pan
  239. Does this piece go under timing cover?
  240. CC306 Cam only dyno
  241. need a nice alternator now!
  242. Re-Torquing Bottom End Bolts/Studs
  243. Questions about oil pressure gauge.
  244. Missing/Backfire Issue
  245. How many people are running stock throttle bodies
  246. LT1 SS Spoiler Question
  247. Anyone use AP1AP2 automotive racing performance parts
  248. what do do about oil pressure sensor
  249. car runs rough when it heats up
  250. Crank hub stuck!
