PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 [160] 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. few new pics of hood and exhaust
  2. fuel rails
  3. resurfaced Heads.. do i need after a blow head gasket
  4. shift point
  5. MSD Pro Billet Question?
  6. Weird tumbling sound from my rearend?
  7. Block Almost Finished (Pics)
  8. Head Gaskets Blow???? Need help before i buy.
  9. are my rockers to tight?
  10. weight vs power difference between CB to TD's
  11. brakes
  12. poll: muffler with dual setup?
  13. (m6 bolton/hotcam dyno graphs)
  14. Can ignition go bad?
  15. Lifter noise at start up??
  16. Key fob isnt communicating with the car.
  17. feels like throttle sticking...
  18. 97 WS.6 Formula build (help wanted)
  19. New PB 1/8th For Light Bolt On LT1!!!!
  20. gmmg questions
  21. front brakes
  22. best lt,s for lowered car
  23. small cam with good power from 1500+
  24. Looking for head suggestions
  25. Cel
  26. Does anybody have
  27. 95 problems
  28. Engine Knocking Problems
  29. anyone have pics of lt1 ta in maroon color?
  30. 97 Opti/waterpump/timing belt help
  31. Inconsistent vibration from 1500-2500 RPM ???
  32. when is a head too big?
  33. What studs and guideplates to use?
  34. Looks like i'm missing something? (Pics)
  35. Will an OBD1 Hypertech work with an OBD2 cable so long as the right cable was used?
  36. new pacesetter LT headers smoke
  37. Last update for the SB2.2 LT1...
  38. cam and heads, now i cant get it to idle. help
  39. weird problem... once i thought i was done
  40. Need to buy some things to finish the project, where is the best place/places?
  41. Oil pressure sensor
  42. i am really stumped
  43. Having a couple of problems.
  44. hot to remove the egr valve
  45. few small problems
  46. Better or worse gas mileage with Lts
  47. Help with Oil pump
  48. H/C/I LT1 alive and running (vid)
  49. Why is my fuel gauge is stuck on a full tank???
  50. Code 84, 3-2 Control Solenoid Circuit
  51. What are the most common coolant leak spots?
  52. Best Rockers Arms to Buy?
  53. First time at the track!!! Times inside
  54. Link to Opti Install
  55. What gives the 96-97 F-Body +10hp?
  56. tryin to figure some stuff out about my new car
  57. How do i fix stall wall? Big stall shifts 1-3
  58. lt1 vs. lt4 knock module for juice use
  59. Hot cam question...
  60. thinking about ditching the lt1
  61. Took it to the beaver today
  62. WTF, my balancer just fell off!!!
  63. Do they make?
  64. 97 Z28 ticking :( ??? video inside
  65. Quick Help Please
  66. Removing Cruise Control, Help?
  67. Looking For Some LT1 Heads/Intakes
  68. Is it ok?
  69. Why is my 30th SS so strong?
  70. Help, water in headers:(
  71. TPS sensor percentage issues. Check it out.
  72. Vibration
  73. Readjusted the roller rockers after 114k, what a difference!
  74. o2's
  75. super 44's
  76. Interesting video
  77. Dropped my motor in today (tons of pics not dialup friendly)
  78. painted my intake today
  79. BBK or Summit Throttle Body
  80. I love my new exhaust!
  81. I want a custom cam! Who?
  82. LT headers o2 sensors
  83. which cam and where
  84. suspension packages???
  85. help please.....fuel....i think???
  86. who lives near jacksonville nc, i need help lt1
  87. Battery volts at 11...starter solenoid clicks...but won't start.....
  88. flames coming out of my headers
  89. Emergency Brake cable snapped! OH NO
  90. need help fast!!! cranks but doesnt start
  91. 151k and iffy...
  92. Major oil leak
  93. Nitrous help
  94. New PB light bolt on LT1
  95. need help starting my 95 caprice with no key
  96. Machine shop Raped me again. Banjo bolt hole stripped.
  97. Favorite Tune
  98. what is this guage
  99. Delteq VS Opti
  100. What size injectors?
  101. intake question?
  102. massive ticking
  103. can you clear up the "over camming" issues
  104. lt1 crank
  105. PTV clearance question... and a few others
  106. where does the grounding strap go? lt1
  107. Posting a for sale link...
  108. how do our lt1s match up to a 350z?
  109. Figuring out my shift rpm by mph?
  110. Cams. Shift Points and Peak RPMs
  111. false knock?
  112. im trying to help a buddy of mine with a budget build lt1
  113. cc306 question
  114. a few questions about the lt4
  115. 93 LT1 w/M6 I need to transfer to another Fbody..plz help..
  116. Few Valve Spring Questions
  117. harmonic balancer fell off
  118. Cleaning the Engine Bay?
  119. is my vacuum to low?
  120. belt to use with asp pulley? i searched
  121. LT4 Hot Cam Kit????
  122. Is it possible to screw up a nonvent opti install?
  123. LT1 install Tips or Tricks?
  124. 350 LT1's in the 11's?
  125. 2005 G35 Vs LT1?
  126. opti spark
  127. Looking For Stuff To Do To My Car Today...
  128. Cranking, i think no spark
  129. intake elbow for 58mm tb???
  130. I'm removing my 2" Drop...
  131. few turbo LT-1 questions
  132. hypertech programer question
  133. opti or sensor or fuelpump
  134. Good deal on ford 9'' rear???
  135. Port Velocity, shape of ports, etc
  136. What are good street/strip tires
  137. Help.......Someone tell me whats wrong
  138. Wiring Harness...
  139. HELP!!!!!!!!!!! Car won't start..
  140. t56?
  141. car stalled in reverse why?
  142. Need some help!!
  143. damn this low coolant sensor!!
  144. LE1 LE2 guys, ive got a ???
  145. random question
  146. How to tell if your car came with a stall??
  147. Magnaflow!!
  148. Part number for the Dynomax bullet?
  149. I have made my decision...
  150. lt1 dart heads
  151. opti cap and rotor
  152. Opti Question
  153. Reccomended Oil Pump, Pan, Filter?
  154. AC Delete
  155. spiral flow duals
  156. High HP guys, will this PCV setup work?
  157. Need some help
  158. 4.10
  159. Simple LT and tune?
  160. Yet another opti question
  161. When I hit the gas I hear a clunk
  162. Rebuild
  163. 11's possible,stall and 3.73 gears?
  164. Obd1 Obd2
  165. car won't start
  166. Nitrous users need advice
  167. AFR 227's what headers?
  168. Lost to my Nephew. ?
  169. Electrical
  170. 2 options..which one?
  171. difficlutly with timing chain and reluctor
  172. clutch master cylinder movement
  173. Go Figure....
  174. New LT1 Owner Need Rocker Arm Help!
  175. OBD I (#11-Malfunction Ind. Lamp) issue
  176. cam help comparison
  177. Stupid K&N FIPK question.
  178. Anyone else have a 95 OBD1?
  179. cddd
  180. 95 LT1...I NEED HELP!!! (kinda long)
  181. **VID** FASTFATBOY on the local 600ft track
  182. hydra rev kit?
  183. What year is my LT1 ??
  184. I'm Freezing My ASS off!
  185. Review this kit please
  186. Replacing injectors
  187. Lt1 coolant lines?
  188. Kooks Y-pipe
  189. Single Digit Guys Inside
  190. Turbo on Long Tubes?
  191. Header question
  192. Walbro keeps making noise?
  193. sportlines with lt's
  194. LSX swap or wait and get an LS1 car?
  195. 40 series with longtubes
  196. What do you guys think?
  197. White Trash needs your help
  198. waterpump housing tubes
  199. Jacobs ignition box and nitrous mastermind.. on a LT1??
  200. I'm looking for pics of lt1 firebirds painted in Orange
  201. recharging your A/C?
  202. 96LT1 Help!
  203. Headers???
  204. A/C evaporator box delete
  205. Accel DFI
  206. Broken heater box
  207. Help please
  208. CAI Install.... throw code?
  209. CC306 cam only guys ???
  210. What do you guys think?
  211. who's from jacksonville nc
  212. relocating PS fluid resivoir
  213. Oldest opti?
  214. Whats the name?
  215. oil leak!
  216. Tracked the Z on spray.... questions about 150 shot?
  217. Most HP for the least amount of $$$$$$$$
  218. Some new times for my 396 LT-4
  219. New to Lt1's
  220. LTX's In Stock Eliminator At Rockingham
  221. Hot cam
  222. What are the differences in the TB cables?
  223. what are the differnce between casts on lt1 heads
  224. headers "looking for the caps to block the air system"
  225. valve springs and rockers??
  226. Tune ?
  227. Rerouting the belt
  228. thinking about selling my car, details inside
  229. H/C/I LT1 almost done, cast your predictions!
  230. tight fit with headers
  231. Mail order or custom tune??
  232. What the best 383 twin turbo heads/cam
  233. How much are ya'll spraying on stock internals?
  234. brake peddal is hard as hell to push
  235. V6 & Z28 rear ends. R they the same?
  236. Edelbrock intake...
  237. Timing Question
  238. I Need Help Please
  239. 12's finally!!
  240. A Sneak Peek...
  241. lt1 swap
  242. Who here has non-coated pacesetters?
  243. EGR Delte Ques.???
  244. Sweet Thunder Flow
  245. X-Pipe w/Bullets
  246. 96 LT1 worth buying? Your input needed!
  247. LT1 Turbo - Optimum Setups
  248. 4L60E lockup problem...
  249. Chrome Radiator hold down where to buy ?
  250. Power Steering Delete
