View Full Version : LT1-LT4 Modifications
- valve cover spacers
- Jet Hots
- long tube question
- Why build/keep an LT1?
- Cat Back Question
- Pics of stainless steel Ram Air inserts, chrome filler bird & Strano front 35mm
- Failed Emissions - Need Help
- Does this work - or is it a scam? Hypertech programmer?
- fuel filter location?
- Problems with 95 LT1 T/A
- Any trick on changing spark plug wires LT1
- do you know.............
- Radiator & Low Coolant light PROBLEM!!
- Are these any good.
- Tran am LT1 O2 sensor questions
- How much Power should I have?? What Gears??
- Le2
- who does single plane EFI intakes
- Aluminum Driveshaft For Sale
- Steering Wheel Adaptation?
- can you use a 400 sbc block with an LT1 topend
- 1st Time @ Strip
- CC306 & springs question ---->
- AC compressor, Quick Question?
- camaro death
- OMG people are soo funny!
- biggest lt1 cam
- How do Cam bushings work?
- Little hesitation...I smell a problem afoot!
- Low Res Code... Once again..
- TSP True Duals
- Single Plain w/ IntakeElbows.com set-up
- Washers for head bolts???
- F/S: Aftermarket LT1 Parts
- Lt5?
- rearend question
- lt1 weight?
- Meanest looking LT1 Z28 Hood?
- Having an issue with Ford Injectors
- ABS INOP Light..
- Need Help ASAP, Tow Truck coming
- 160* thermostat question
- Bad opti?
- maf ends. any good?
- 2 Questions
- Why is my BRAKE light on?
- troubleshooting waterpump
- Rear Gear sets
- Guages acting weird??????????
- need a recall number
- What is this and what does it do?
- ASR question
- A bad Miss at WOT in 3rd...
- 93-97 firebird headlight question
- Anyone running LE2 heads with a cc306
- MSD ignition Question!!
- Y-pipe ?
- Coolant?
- Started it up today!
- Changing Headlights 94 Bird..
- Injectors - what size, brand and where? and input on issue
- 1 Month to get an MSD Distributor
- Gauge lights??
- Best Spark Plugs for me?
- MSD help please
- distributor
- proud ex chevy owner
- "HELP PACESETTER LONG TUBE INSTALL"
- timing cover
- LT4 cam/head combo advice.
- HELLLLP! Harmonic Balancer woes....
- Need Cheap Headers! Even Used!
- New LT1 owner
- Best place for tune at this point??
- short block vs. long block
- hedaer bolt length?
- Help Me Out
- LT's and ORY Next.
- Fuel tank vent issue??
- LE1+N20+Stock A4
- Gear whine just part of the deal??
- LT1 with LS1 Heads
- 1.6 OEM Rockers
- Header ET drop What did you Get???
- Help
- TA headlights
- Enternals still the same?
- Trick flow with slp cai???
- What motor in my 96 Impala SS
- What is this? The wires are burnt off!
- Anyone use pacesetter headers?
- 1.6 Crane Rocker Clearance
- header bolts?
- Luk Clutch
- My bucket
- Something we can all do
- Installed new ignition switch: Is it bad too?
- will these 02 extensions be suffifient???
- LT1 Coolant Hose HELP!!
- LT1 intake height
- Custom cold air intake ? ? ?
- lt1 IN late second gen camaro
- help with 1.6 nsa and sa --experts in here
- Help me find the right gaskets.
- Shops that tune LT1's in Ny,Nj,Pa,Ct
- lt1 @ 6psi stock
- Few electric WP questions
- problems after longtube install... help me =(
- LT1 balncer bolt, what purpose does it really serve?
- 1993 Firebird w/ a Major problem
- 93 owners who tune their cars
- Car wont start - At wits end
- Those who turned their cars in to race cars....
- LE2 Install tips!
- 1993 Obd1
- valve covers
- does this sound right? elevation calculator
- alum. vette heads vs stock z28 heads
- Which sounds better
- Where to get the chrome LT1 elbow??
- LT1 and Accusump
- Clueless to whats wrong....
- Bad Whining Out Of The New Rear End!!!
- does anybody know
- Need some opinions
- 10 amp ignition fuse popping (dead in the water)
- Need some opinions on mufflers ASAP!!!!!!!!
- hickups?
- some more EGR??
- installed headers/have new problem
- rebuilding my 383
- converstion pics
- Firebird/ Trans Am question
- throwin codes
- 1997 Owners Check In Here
- Gas Prices?
- 99 Z28, worth the buy?
- anyone swap an lt1 with an ls2 or ls6?
- LT1 fuel pressure
- Help Save My Opti
- i need..........i need............
- 4l60e for lt1 for sale
- Bad valve springs/old opti?
- Break lights wont turn on!
- Throttle body
- CC305 vs. CC503 with stock heads...
- Quick Question?
- Pushrod guideplate HELL....
- Sleeving Lt1
- check engine light
- Heeeelp, Please Help!!
- New TB for me or not??
- got a hella deal on a 58mm tb
- IRS With Large Pics
- help
- Aftermarket valve covers.......
- i have camshaft i want to know ??
- What is wrong with my car? 10 bucks to whoever diagnoses.
- Where can I get one of these? *pic included*
- LT1 Intake Manifold
- 58mm tb cheap 200.00
- help install MAC Midlength headers on my 95 z28
- I found another company that makes billet HVAC/Headlight knobs!!!!
- Anyone know how much horse a stock bottom end can hold??
- I think I broke the rear end
- 2 bolt vs 4 bolt?
- Cloyes double roller
- Kind of a n00b LT1 owner...
- Combo ????
- Bent pushrod, worn guideplates, pictures attached...Need help quick.
- Best priced cowl hoods
- Doing a custom grind cam, need help designing cam!
- DIY Head Porting
- Did seafoam, now high rpm miss??
- opinions on M/T et streets?
- Direct Port for sale.
- LT1 pulley diagram
- injector questions.....
- need high torque starter, where and what kind?
- hot cam kit
- someone make lt4 intakes please
- Front bumper(NEED ONE) 97' Trans Am
- What size bolt do I need?
- hood
- Cleanest LT1
- Anyone know where to order a decent 355 rotating assy??
- Banjo Bolt in the back of the heads. Help!
- What oil?
- Cam/Spring Question
- rear main seal adaptor
- opinons on lt1 383
- Springs question!!
- Fastes h/c cam lt1?
- Some cam install pics
- Valve spring lift?
- Got my first ticket...
- victor jr single plane in the works!!!
- Hyda REV KIT Installation.
- LT4 Intake worth the money?
- Why can't LT1's use the crank gear to advance or retard a cam?
- Motive 3.90 Gears for 7.5
- Opinions needed...
- UMI Tubular K-Member
- LT1 f-body setup car needed for turbo
- Plug Wires?
- lack of power?
- Gears or Headers???????
- Pic of my LT1 motor
- What's Your opinion?
- How is it possible?
- valve train help...
- Custom Grind lift for stock heads?
- cc503
- I want some suggestions
- Animal Associations...
- For those who havn't done the TB bypass
- idle problem since new engine install. video inside.
- LT1 supercharger?
- lt1 running rich???
- pushrods: come in
- Blinking SES Light
- Seafoaming LT1(yes, I Searched, but need more)
- ss hood on z28.com for 93-97 camaros oem gm slp
- Stock TB good for?
- problems with adjusting the valves???
- vortech s trim for sale
- lt1 vavle covers
- How many LT1 owners are serious about buying Carbon Fiber FRC's?
- wings west body kit!
- fuel pump??
- Header queston
- i need a motor rebuilt!!!!!!!!!!!!!!!!!!!
- TURBO OR SuperCharger
- Benitfits of having 6.0'' rods over 5.7'' rods
- who makes the best opti??
- LT4 or CC 503
- Oil Filter Problem....help needed.
- Endine died help plz
- LT1 fuel pumps
- do I need pullies?
- Thermistat What temp. should I use?
- Car wont roll over??? HELP!!!!!!!!!
- cam,headers,new engine and not running how it should!
- question for tubular k-member guys
- Advice request: E-W/P and front cover re-seal.
- Fuel pressure - Help here plz
- LT1 Harland Shift Light Install!
- LT4 Hot Cam Shift points..... Help!
- Electrical problem
- need nitrous and cam help
