View Full Version : LT1-LT4 Modifications
- Programmer 96-97 LT1???
- wierd cooling problem
- 12 second pass
- Any other boltons??
- Wires ona college budget
- Edlebrock Intake question
- springs
- which is better?
- Which clutch
- intake question
- Can a LT1 f-body run 9's for $10000 bumper to bumper build?
- oxygen sensor
- Thermostat question
- lt1 hard to get started
- 94 LT1, Need advice on Upgrades
- battery draining. NEED HELP PLEASE!
- borlamouth
- i think i figured it out...
- Intake Question???
- cowl hood.. where to get
- Halp: Car no spark, convoluted
- ls1 throtle body on an lt1 car
- what can i do besides FI?
- wtb LT headers for 97ss
- Car Vibrates At Drag When High Rpm???
- Which cam has more under the curve power? cc503 or hotcam?
- 1.6rr??
- MSD ignition question
- ls1 springs for the smaller cam guys?
- here you go
- Help
- cold fusion nitrous
- supercharger cam
- 383 supercharged + spray??
- Coolant level sensor question
- Track times with AI 200cc heads and AI Trick Flows
- Need help with fuel line mod
- Opinion on power output
- Stroker kits
- Gas Gauge Problem
- Parts ?
- ignition box for nitrous use - digital 6 or hyfire VI
- Bought a 94 Z28 has LT4 intake on it causing me to fail emmissions?
- Would turning motor over by flexplate cause spun bearing ???
- Track results...
- Oil smell after heavy throttle?
- Check out this lt1 on ebay 500HP
- little help about n2o
- what are some good springs for a cc503 cam
- LT1 help
- Flywheel noise? clank clank clank click :(
- For a Bolt on LT1 which stall?
- 383 almost done what do u think?
- My winter work thread. 95 TA, lots of pics!
- lt1 Malibu
- What's up guys..
- Need help w RR.
- guys that have done a lsx swap
- Gauging interest, the ultimate street/strip rolling chassis 94 Z28
- NEEDED.. Your old stock OPTI dist. caps (for a good cause)
- Hey guys, cold start, cold outside, pig rich and wants to foul plugs?
- Ltx Party???
- OMG!!! Tranny wont shift! its on teh trailer! HELP!!
- Solid roller Lifters ???'s
- Front seal leaking!!
- Urgent!! Driveshaft!
- 400 hp goal n/a
- REALLY Silly stock cam question...
- Car runs like crap in the cold?
- Car runs rich as a pig before harvest!
- Limp Mode What Is It?
- 10-80 in a bolt on lt1
- weight of a convertable formula?
- Miss fire???
- What next?
- Which muffler with mufflex?
- Part # MCLEOD master cylinder???
- help with full lengths
- Stalling Problem-Cant Figure It Out?? Help Please!!
- Mids. Help constructing a y pipe
- Input with making a stock headed cam guide
- Rear end
- stall
- Weak Lt1
- Rear distributor questions
- LT1 to LT4 upgrade
- Any GOOD lt1 shops in DFW?
- f/s stock intake w/
- Lift limit for LT1 head flow?
- Walbro Fuel Pump Problem
- Milled Heads, what pushrods and gaskets?
- LT1 bearings
- question on a part...
- Items needed for a cam swap...
- ls1 brake question
- What is the best brand in HEAD GASKETS?
- Project LT-GUN
- Who says you can't make an LT1 fast?
- help
- dyno tune
- quick nitrous question
- 3.73 will take how many 10th off 13.4 run
- 94-96 LT1 manifold Tech question ? PICS?
- How much would an actual dyno tune help?
- LTx Shootout Road Trip Meet-Up Points
- High capacity oil pan ?'s
- Header Flanges
- Cant spin the tires
- Will this work for my hawk?
- early christmas presents for me!
- Patriot dbl springs
- need a master/slave cylinder hose!
- 100k Long Block Tranny and 2.73 rear
- Does my new engine need to be taken apart and rebuilt?
- ltx shootout questions
- exhaust dilemma
- open headers?
- Lt1 4l60e $2000
- Installed a cutout... Question
- Setting up fuel system for 383ci LT1
- water pump went out!!
- any good shops around PA
- Crane Gold 1.6 RR...which springs?
- So the 96Z had 2.73's and a 6-speed, WTF???
- What are the gains with oversized valves?
- Forged Pistons for LT1
- Is a 3600 vig too much of a stall for a bolt on LT1?
- Think she's got a lil' more in her?
- 97 WS.6 build. question about an xfi cam
- 30lbs Injectors
- Hydraulic Cam for 396!!
- lt1 choppy-idle and choppy-accelerate
- Stock LT1 specs
- Dash - 96 vs 99 - Diff?
- High end miss, lets solve the problem.
- Ny Performance Mechanic Shop
- Another what will it run thread...
- CC306 vs. CC467
- Still no start....
- steering wheel swap
- changing exhaust... any gains???
- LT1 LS7 clutch
- Steering Wheel Controls
- door panels are a bitch!!
- 94 tail lights... changing to 97-02 quick question
- Heater not working
- Need help building a bottem end.
- Ebay Opti???
- more bolt ons?
- sold the trans am
- at what point is an ignition box needed?
- It is time for me to sale!
- pn for spintech & flowmaster mufflers in mufflex cb
- LT1 Turbo Camshaft
- starter problems!!!
- cam dowel pin removal
- LT1 water pump rebuild? Has it been done here?
- Is it possible to use a 168 tooth flywheel on the LT1?
- Lt1 vs evo
- quick question about starting
- LongTube Install questions
- rearend soot
- LT1 swap
- header install help about to go crazy!!!!
- po100
- Header gasket
- Convert SBC heads and keep Fuel Injection?
- WTB: TCI Internal Flexpate - One piece seal
- walbro 255 lph ?'s
- side pipes?
- Hey guys I was wondering what yall think a fair asking price for my car info inside
- A4 removal and reinstall?
- Winter Storage?
- WRONG FLEXPLATE - Do I have to have my rotating assembly rebalanced???!!!
- Formula front end
- what will it take?
- Pictures of my stock 100k mile oil pump
- ebay 383 kits
- What Do You Think?
- starter promblem please help lt1
- LT! intake question
- Power adder decision?
- Possible Opti-spark issues
- Right Bank O2 sensor problem !
- 2 holes on head??
- My custom OTA true duals w/ X pipe. (pics and vid)
- cam laying around- opinion of specs
- first time in rain with LTs
- What would a 383 LT4 Put out?
- Exhaust advice
- should i get it or is it worthless?
- No shift under WOT
- Aftermarket Oil Pressure Gauges
- how many HP i will get from LTCC
- lmao just another cam question
- Is it worth it ??? opinions
- check this out haha
- lt1 swap help
- lt1 swap help
- th-400 speedo hookup
- New clutch installed, now I have a VERY LOUD whinning noise
- benefits of 1.6rr's on stock motor?
- Granatelli sub frame connectors
- Fidanza Flywheel
- Injectors?
- i think its the o2's!!
- 4LE80 Swap Help
- Just bought a Corvette block!
- Picking up a 93 LT1 Camaro
- my ses light comes on....
- oil pump pickup
- LT1 to carb, going in a truck already have the motor
- Help me with valve springs
- Check it out
- MSD 6A (or AL)
- thermostat
- Slave and master cylinders???T56 guys.....
- Corsa catback on a cammed LT1?
- New Cam...Old Motor... Shift Point???
- XFI Cam
- strange miss
- Running a blower/n2o cam with out a blower?
- 10 second LT1 for sale
- let's hear your custom LT1 cams!!!
- New to lt1, need help
- need help
- Help! Knock after opti install?
- Melling 10554 Select Pump
- Company's that make governors
- cd ignition box
- lt1 swap help?(harness config.)
- lol newb ??
- winter time blues.. heres some pics
- Water pump
- hey! another cam thread!
- Why lifter noise????
- Running rich but PCM says lean.
- 11 sec cam only come inside
- Ram clutch???? T56 guys come inside....
- things are unhooked
- Found a chassis shop by Peoria IL that I thought I would let you know about.
- Adjusting the valves
- crank hub
- exahust manifold bolt screwed up
- 2 Engine shots
- cam question?
- self aligning vs. non self aligning
- help
- tuner programs
