View Full Version : LT1-LT4 Modifications
- LT1 nOOb, Hard start problems
- Help!!!!!!!!!!!!!!!!!!!!!
- Oil pressure ?
- Highest rwhp and rwtq #'s for bolton LT1?
- 292 Valvetrain
- need opinion.
- Few more things from jegs and summit today
- auto shift knob options
- Help me ID this part!
- LT1 with slp 90mm LS1 maf?
- Need to run on a dyno
- Check my wheel size
- Steering column
- Stumped...
- 96 LT1 6 Speed VSS Question
- Need opinion on power with this engine build
- Spent some money..
- 95 lt1 problems
- Best o2 sensors to use??
- Breaking Points on an lt1/m6 z28
- Victor JR intakes
- Xmm Throttle Body
- note to self! *optis ftl!*
- Lower Octane = Rougher Start?
- Killer Deals On LT1 Plate Systems.
- Finally took pic
- with stock pistons and 58cc chamber what is the CR
- harness relocation
- stage 8 or breslin style ?
- Knock at 4200-4500 @WOT
- New to site, have 94 LT1
- trans and other things for sale
- New freebie for the build!
- Looking cam size help for LT1
- Check out this sweet 4x4
- cam 2 big?
- M6 Shifter Knbos
- which electric water pump?
- cam installation
- Tick towards the bttom end
- Cam?
- Wheres a good place to buy new fogs for my 95 t/a?
- crane 10308-1 springs
- Top end/nitrous questions
- 918 springs or pro mag 1.6 rr?
- Newbie Question?
- hot cam kit?
- changed a few 14 year old parts
- turbo/supercharged lt1 firebird/formula body style pics...
- Post up pics of your aftermarket hood
- milky oil!
- 2OTL Exhaust size?
- valve float with crane 227?
- True dual exhaust question
- 1995 z28 long tubes
- Hello there. Little advice with dyno results.
- Removing EVAP, !EVAP
- Remember my ticking noise thread? The one with the video.
- Rear seatbelts?
- obd-1 and obd-2 differences
- missing or dropping out at wot!!?
- Heater core question
- Ehh- crap messed up now I think I have to pull the engine
- Actual power?
- Whats wrong with my oil pressure???
- Need Help W/ Power Programmer
- Lifter
- newbie ? about LT1
- Different LT1s??
- how much cam are you run in a DD's?
- Don't forget to register for the SHOOTOUT
- New z28
- flow#s for stock intake?
- skip shift
- Header Bolts
- Big Problem, need help!
- I love it when people try and sell L99's as LT1's! LOL
- Thinking about doing an m6 swap, help inside please...
- Question about Cloyes timing chain
- Does my LT1 have little men that drink my coolant?
- About to start the LT1 need some Help!!!!
- Max compression on a street car?
- grind welding flash and welds down on pacesetters?
- Stock Car - Weight Reduction Question
- LT1 Ignition Idea???
- Help!! Car won't pass smog
- need some help?
- buyer beware!
- About to pull heads.
- Shootout Road Construction Info!
- What MPH will i top out at w/th400 and 4.10
- Oil Leak Around Timing Cover HELP
- problem worse than imagined
- Idle rpm problem when coasting in neutral
- Warbird (lt1) People Need Your Help!
- What to do/change when baught a used car??
- lt1 mod?
- Finally Got Pics Of Ovc Wires And Headers
- Crane Cams HI 6R ?
- Delteq Missing
- Relocate or Lightweight???
- Some pics of the teardown/ new build
- what size?
- profab k member??
- 97 ss ram air system question
- How do i tell if ECM is toast?
- has anyone noticed
- Engine Building Questions
- High Idle?
- vibrations at high rpm
- Idle adjustment after cam swap - again
- 1993 Tuning/metering system?
- Why is my car not loud?
- rockers
- oil pressure slowly dropping??
- LT1 Valvetrain Questions
- deleting cats 97 ss
- D u all think my stock 10 bolt will last me this season?
- Intake Gasket Install
- oil pan to work with hooker long tubes
- ls1 driveshaft
- intake question
- intake question
- Windage tray
- Why isnt there more SBC swaps?
- Let's see your nitrous setups
- Pics of the new heads!
- Header Panel Replacement?
- Replace cat with cut-out, or leave cat?
- 11.0's to 9.90 with the touch of a button!!
- Who has the cheapest 3 inch catback for our cars?
- 262 engine question
- You've got to see this Vortech listing !!
- Brake Pads
- Datamaster Dyno
- Cam Question
- annoying problem
- Anyone use these pistons
- hooker longtubes leak where slip fit
- Hood Intake or K&N CAI?
- Anyone passing through Wyoming on way to LTx Shootout??
- Pictures of Hooker Exhaust Tips
- Looking for a shift knob
- How to start engine with out key
- c4 vette exhaust
- folks with A-PILLER guage pods (come on in)
- partial N20 set up
- Header bolt sizes
- 10's w/Ai 355 pump gas VIDEO
- weight reduction...roling chassis
- Chamber Size LT1 Heads???
- weld draglight prob.
- whats the avg 500rwhp build cost!!!
- 93 guys got ?
- Cylinder head ?s
- Just bought race style LT's, now what do i do about air/egr?
- Lets see some pictures of Ltx's with aftermarket wheels...
- lt1 guy's
- What is the limit of a stock 10 bolt rearend ?
- 58mm throttle body on stock engine
- gmmg and longtubes?
- Headers installed now the car redlines like mad...
- cc306?????????
- How can I get into the 11's?
- 1994 m6 tune on a 1993 auto computer?
- RPM/oil pressure.. weird problem
- Time for a rebuild....
- opti vaccum lines??
- Cruise Control on a 94z
- 383/396
- Can I do this or will I die?
- OPTI replacement write-up
- Stock rockers okay with small cam?
- Oil Leak
- -24 Below Zero!! Did the Z28 Fire?
- put 180 thermostat
- Cammed cars with ory and dumped bullets inside
- Show me them aftermarket steering wheels..
- LT4 350/355 Piston Question
- Torque arm opinions needed.
- bottomed out, hit oil pan
- Bought Parts Today
- headliner job :)
- lt1 mods for a buddy
- ? about MAF
- Hit a snow bank and now misfires/pops
- Key FOB issues....
- SplitFires . . . ?
- Video from Rockingham yesterday
- Is an N/A forged 355 a waste of time/money?
- lt1 383 Question
- Lingenfelter Cam for sale
- LS1 lid with sunoco hood.... WILL IT WORK?
- runs fine, then acts like bad gas, backfires chugs. dies throws check engine light
- Is this right??
- WTF! how do i tell if my LT4 hotcam is legit?
- tune shop in north alabama
- LT4 hotcam/ Supercharger???
- Starting to button up the motor. Pics!!!
- Winter work
- Edelbrock head and valvetrain ?s
- Coated vs. Uncoated Headers
- temperature gauge on instrument cluster not working after taken out and replaced
- O2 change help!!
- The car overheated...pics inside
- QUESTION regarding cam...
- Help with Relay install part #15-8719 #12193601
- headlights
- 12 bolt or 9IN"
- Meziere Electric Water pumps
- got my car started!
- Help With Glasspack on Std. Catback.
- You all know whats next!
- lt4 intake
- instructions for ls1 air box conversion, will i need a ls1 rad support
- What's involved in putting on a Grant Steering Wheel?
- HV oil pump with stock pan
- Vibration at high speeds?
- wut to do with 94 forumla
- Not sure what the problem is...ignition maybe
- curious of estimated hp output...
- i have a problem with my car
- rear main seal
- How much would an exhaust leak hurt me?
- Salad Shooters
- Sugest A Cam
- Massive Drop in MPG
- LT1 for daily driver?
- A little video I made.
- Help Please!! Fuel Leaking everywhere
- Tuner software?
- afr heads
- Location of Fuel Pump Relay...
- Its A Girl!!
- gm847 guys...
- Thinking about dumping the Camaro for a Corvette
- Coil pack conversion kit
- thinking about putting a carb. on my LT1
- What makes an LTX an LTX?
- BIG PROBLEM.... oil pressure go bye bye??
- 1.7 int./1.6 exh. RRs ?s
- Switching mufflers on true duals
- Anyone have the AutoTrend Photo CD and Password?
- High idle problems
- heads
- Are all stock LT1 intakes the same???
- My New 1993 Z28 Project
- Holley Commander 950 on a LT1
- How Plauseable Is This?
- Need help installing Walbro fuel pump!!!
