View Full Version : LT1-LT4 Modifications
- Automatic Tranny Fluid Flush?
- 5k to play
- c5 air intake on lt1 vette
- where do i buy new o2 sensors
- Question.....
- 94 z28 stock rear end
- ABS delete double flare tool
- le2 only heads hp gain?
- HP guessimate
- Stainless air dam, Emblem Pros
- Wiring in Narrow Band air/fuel
- driving me crazy
- help choosing an afr head
- bad miss after header install
- longtube install
- Line lock, two step ?
- Finishing up the swap
- What do you guys think
- Engine Wiring harness question
- question about my pistons
- How Much Does One Knock Retard Equal In Horsepower loss ??
- Anyone running this SPECIFIC exhaust?
- Random dying
- lt1 head question
- Start up problem
- Absolute limit of stock rockers.
- mph gauge off and fuel level off
- Tunerpro file
- Header Help Please!
- solid roller lifters
- CLUTCH ADVISE for built lt1
- headers?
- %$%#&&*% aftermarket fan...new setup track results.
- Properly bleeding your coolant system
- pistons/compression
- keyed hub
- LT1 Oil Pressure Problem
- Cammed Guys Lets see your timing tables
- The project
- LT1 Bird BLS projector light kit installed! pics
- LS1 FIPK conversion done
- Adding some more pimp factor to the wifes ride!
- le3 corvette pics and video
- Lt1 Main Caps..
- !A.I.R., now check engine light.
- Supercharging my 95 lt1
- LT1 Head Question Iron Verses Aluminum
- what posi or locker to go with for a daily driver??
- Weighed my 94 1LE
- Lt4 gaskets
- Datalog software for 96 obd II?
- Misfiring...tried everything
- Beefy Single roller Vs Double roller ??
- Taking off supercharger, what do I need to be stock again?
- which fuel pump
- Fitment of Hedman 65386 Stepped Headers
- Need a part # / application quick for steam pipe
- gtp supercharger on v6 camaro 1997?
- ATI harmonic damper installation questions
- Track Results
- help me id this cam
- best spark plug?
- detriot locker diff, any good?
- what timing set to get? best one?
- wich of these optisparks do i need?
- finally got dynod...
- need some advice
- LT-1 from a Caddy a good donor??
- Some CAM questions....
- room for improvement?
- lt1 cam?
- speed daddy headers
- exhaust mounts on magnaflow
- is this a good rebuild kit for my transission?
- Preferred Intake Gasket for Stock LT1
- Coolant Crossover AN Conversion, Part List and Pictures.
- bad 10 bolt?
- $20 intake elbow.
- looking for a certain post/build
- help
- 4l60e shift kits
- How can I tell? 1.5's or 1.6's
- Im confused
- CAn anyone help me with this missfires?
- Dyno tuning
- Not enough power to fuel pump?
- New Build Wont Start, NOT OPTI!!
- I need opinions AI cam or Nitrous
- Question about putting LS1 Brakes on LT1
- Is My Fuel Pump Bad ???
- Lets see some aftermarket 4l60e shifter with stock consoles
- What's this radiator hole for?
- Help with Mods
- powerdyne supercharger
- is this a good cam kit and rebuild kit?
- can someone in sc help me solve this
- HP issue?
- Finally got some 1/4 Times for my setup!
- 94z28 i think my tranny is done. need advice on options
- LT1 Rockcrawler Won't Start
- Motor Mount to Kmember bolt size
- 94 lt1 Pontiac Trans Am, 97 engine swap need help.
- lpp header install issues? need advice.
- couple questions...
- 94 Steering Column - What Years Work?
- evap canister question
- head gasket help!!!!!
- egr block off question
- roller rocker ajustment
- Overheating issue dyno only,what gives?
- Another question about heads?
- Strange S60 rearend fitment ?????
- Car problems again
- might be running rich?
- Procharged LT1 Breakin Up....No Check Engine Light
- cluch spec stage 2+
- where do buy complete kit for EGR block off
- heads questions with pics
- drill the thermostat ?
- motor mounts
- Keeping the Trans Am! Story Inside
- arp head bolt torque specs
- 383 Stroker kits
- What a crappy night :( with the wifes camaro
- Dual fans in 96 LT1 not turning on
- WoW! 3rd gen and LT1 Firehawk, others, Garage Auction Info
- last post on this topic
- Water pump watchdog, quick ?
- Nothing with a relay is working!!
- LT1 engine upgrade any performance suggestions?
- need help!!!
- wow parts for the LT-1 are $$$$$
- GMMG Badge Ebay Scam
- Fuel Pressue Issue
- possible vapor lock
- impact of too short pushrods?
- carbed lt1 post up your pics
- Lt1 questions
- Solid roller question
- looking to see what people have for supercharger set ups
- Why just meth/water? Could race fuel(c16)/water have some benefits as well?
- dual 255 pump question
- LT1 aftermarket power steering pulley or cover?
- Current Technology and Solid Roller cams
- temperature sensor question
- 10 second lt1 cars come in
- Wiring harness.
- Bleeding Clutch, power bleeder?
- Water pump watchdog, question ?
- Is 82% injector duty cycle to much?
- lt1 383
- I need help please
- Proud moment !
- LT1 newbie help me with this Demon possessed car
- got the ss spoiler put on now i have a problem
- New Shocks Settings
- how important is this?
- used hooker LTs
- Some pics of my intake set up
- Help estimating what my car should have made on the dyno
- Did my clutch die?
- cam with stock rockers
- Help with replacing fuel line
- Brake Fluid
- what plugs
- 400rwtq daily driver. possible? how ? being reliable
- New Best N/A and Nitrous Numbers
- Custom LE cam
- New dyno #'s. Track times coming soon
- who's running 120mph+ and daily driving
- LTX shootout CARTECh
- Injector confusion
- catback?
- E3 Spark Plug and LT1
- K&N Cold Air Intake
- Cam Question
- Crazy Backwards Question LS1 K-Member w LT1
- need some rebuild help.. cant find the correct part
- Anyone have any idea ??
- Smart Shoppers
- braking up in high rpms
- LT1 1994 Z28 Runs a little hot, is this normal?
- cam question
- Help, suggestions
- cam ???
- connection c105
- new opti now TA wont run right
- How much can/would you spray?
- Alignments.
- loudest exhaust on fbody
- msd ignition q?
- lt1 block?
- Shuting off while driving
- fuel pump access panel
- TRAck tODAY HERES WHAT IT RAN
- Have two issues after sitting for a month!!
- headers for my lt1
- Questions for a show build............
- Speed help
- Tune nitrous by amount of torque the shot gives not by the amount of nitrous shot?
- Left-overs
- Car won't start,I think it's a fuel issue.
- porting?
- intake gasket ???
- Identification time.. what is this?
- question about plug and header install
- Tbi lt1?
- can 93 computer/harness be converted to 94
- 94 LT1 in a 95 F-body
- LT1 Cooling Help
- LT1 intake manifold removal/swap
- LS1 on LT1
- Another Bad Day At The Track! Help Please!!!
- I think i have found the issue!
- Who has the QUICKEST STOCK SHORTBLOCK N/A??????
- 1000 miles trip
- MSD dist.
- My old whip is up for sale!
- Can someone take a look a my datamaster file
- LT1 Swap ????
- help wirh ebay polished valve covers
- holley 12-914 - anyone using
- Ignition problem
- A/C not as cold as it should be
- LT guage cluster questions
- Let me try this here...
- optispark question?
- Water Meth kit
- Here's what I've been up to...56k nO WaY!!
- seriously dude?
- does this sound like a dirty fuel filter?
- still having problems.
- 96 Camaro ss Evap issue please help
- Stock length LT1 driveshaft measurements?
- hard to start all of a sudden ???
- fuel issues
- What is going on with my brakes? They really suck.
- '93 LT1 with boost
- valve clank with video help
- LT1 Stall Converter
- What's an LT1 worth?
- MSD box mounting question
- Header Gasket Help???!!!
- before i redo the exhaust.. borla and classic chambered?
- Headders for LT1 in a Volvo
- need help clanking sound
- valve spring question?
- *****SOME ONE PLEASE GIVE ME SOME TIPS ON THESE 93 camaro DOOR LOCKS******
- CC503 LT1 Dyno graphs
