PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Ctsv
  2. 96 LT-4 Build Dyno results
  3. Lt1 350 has me distraught, engine noise
  4. 1995 Trans Am ABS channel issue
  5. Couple of issues and questions with my new build.
  6. Lt1 smells rich after doing a tune up.
  7. Lt1 weird issues
  8. LT1 surging.
  9. We have AIP Optisparks if you need one.
  10. Testing Intake Manifold Gaskets with Smoke Machine
  11. EVAP lines backwards
  12. New member 6 speed guys. Got something for ya
  13. LT Headers and Y-Pipe
  14. Need help with flexplate
  15. Transmission swap
  16. Header gasket leak
  17. Looking for info on the LT1 for an E30 BMW swap
  18. Low Fuel Pressure
  19. engine build with my 15yo
  20. Dash pad
  21. Cam break in question
  22. Broken waterpump drive shaft?
  23. Tuning suggestions intermittent WOT and rich idle.
  24. Overheating - new guy
  25. Cheap 42lb injectors
  26. 93 z28
  27. Coolant coming out of reservoir neck
  28. New noise from T56
  29. Almost had it....
  30. Do I Have All The Bolt On’s and Free Mods?
  31. Brake bleeding help
  32. Torqhead valve cover coil mount question.
  33. Going from T56 to 4L60
  34. What headers are California legal for a 1997 Camaro SS slp lt1 pls answer
  35. Electric pump conversion signal wire?
  36. Starting over soon
  37. The SRZ Reborn 4.0
  38. How bad did I mess up...
  39. Can someone give a brotha a hand?
  40. 97 lt1 keeps turning off
  41. Lt1 97 keeps turning off
  42. Lt1 Turns off while running
  43. What Is The Next Logical Step (Modifications)
  44. Baffled with '96 LT1 running rough
  45. Startup issue
  46. Priming motor with oil
  47. Pushrod lenght
  48. 24x conversion oxygen sensor.
  49. 95 lt1 no spark at the coil
  50. Fuel Rail and regulator seals?
  51. Canton Oil Pan WTF?!
  52. Gen 2 LT-4 plug recommendations please!
  53. Transmission help!!
  54. ls3
  55. Goodies from Lloyd!!
  56. My stock lt1
  57. 94 cat - gain from removal
  58. Bolt on estimate
  59. Water Pump O-ring
  60. Anyone making 1000+ with unfilled block
  61. LT-4 intake gaskets DISCONTINUED?
  62. Low oil pressure?
  63. Cooling fan issue
  64. Cooling System Overhaul LT1
  65. Looking for Torque Build Input
  66. Wanting to convert to E85
  67. LT-4 timing set, UH OH!
  68. Gtp
  69. Timing Set for LT1
  70. LT-4 Opti cleaning?
  71. Crankshaft identification?
  72. Engine swap
  73. Tuning question LT1
  74. Is my set up good enough for 400whp?
  75. Fuel Injectors
  76. Bad pre-det knock
  77. Solid roller guys come in please
  78. LT1-LM7 swap. Swap questions
  79. LT1-LQ9 Swap questions
  80. Gaskets/parts for cam package
  81. Lt1 into 83 jag xj6 progress to date
  82. Evil opti throttle body cover plate
  83. 96 LT-4 Vette Optispark cap/rotor/wires/plugs
  84. Pacesetter Long Tube Y pipe
  85. What Injectors Are You Running?
  86. 1996 z28
  87. wiring a bench LT1 cable ODB1
  88. LT1 Fuel crossover tube.
  89. 10s - think I can do it?
  90. Scraping block deck
  91. Need Help Picking Which Stall
  92. Procharger on high compression
  93. 1994 z28 camaro exhaust backfire
  94. 2019 LTX Shootout
  95. Has anyone bought this engine??
  96. Another "Rich at Idle" thread
  97. Optispark rebuild?
  98. Very lazy noid light
  99. Looking for some help .
  100. Is this bad?
  101. Cam Swap
  102. Want input on build path
  103. Lt1 NA 383 build. Opinions welcome
  104. Egr and air delete
  105. 93 TA, 700R4 to M28 swap help
  106. no o2 readings
  107. Transmission issues.
  108. 2 step and clutch switch wire?
  109. Is rebuilding a high mileage LT1 worth the cost?
  110. Pulling out motor with basic hand tools...
  111. Fuel pressure issues
  112. Part number for A/C cap?
  113. Little Help... 94 vs 95 LT1
  114. T56 Leak
  115. Help with Tuning 94 Z28 LT1
  116. Fuel System Troubles
  117. 97 LT1 Inconsistent Idle post Hotcam/Rebuild
  118. 1995 z28 questions and value.
  119. LT1 idles issues
  120. LS1 Lid and CHRS1313!
  121. Lean after changing injectors
  122. Swap T56 to A4
  123. Is this MAF bigger or just aftermarket?
  124. O2 Sensor Recommendations for Long-Tube Headers?
  125. Found a defect in one of my cylinders. How big of a deal is this?
  126. What is this sensor?
  127. Converting to electric water pump.
  128. Scan9495 Log
  129. DO NOT BUY Gates radiator hoses
  130. Opinion on lt1 block
  131. Installed new fuel cooler
  132. 4l60e
  133. Fuel pump died, replaced it with a new one, now engine won't stay running
  134. Lt1 firebird formula fog lights ?
  135. Looking for ECM Tune
  136. Camshaft selection
  137. 4l60e stuck in limp mode/no speedo...
  138. LS1 Lid conversion and Ram air?
  139. Tach dead
  140. What brand header is this?
  141. First time doing a clutch, does this look ok?
  142. ABS Nightmare, maybe?
  143. Flex Fuel line, replace or use something else?
  144. Brand new engine has 2x oil pressure. Any concern?
  145. PCM tuning help
  146. I did a thing...
  147. Fuel Smell
  148. 1997 trans am lt1 exhaust
  149. Lightweight crankshaft and reciprocating components question.
  150. Forward lamp relay harness??
  151. Caught in the rain
  152. Brand new engine has 6K RPM miss.
  153. A.I.R. Delete
  154. How Much Heat Mitigation Can I Expect from an Electric Water Pump?
  155. 1996 firebird ground location
  156. 1997 Pontiac Firebird Trans Am/Formula
  157. WS6/SS ram air intake parts
  158. Is this a stock GM LT1 piston?
  159. LT1 reliability vs 3V
  160. Opinions on a retune?
  161. 95 z28 pilot bearing crank bore damaged? (See pictures below)
  162. 1995 OBD2 connector
  163. 1995 LT1 wont start.
  164. Distraught cry for help with a random misfire in my 1997 lt1
  165. 93 LT1. Carb intake manifold
  166. 93 lt1. How do I tune this thing
  167. Lt1 rebuild. Need a list.
  168. Serious Vibration at 4500k
  169. Intermittent dead car
  170. Anyone install a universal throttle cable?
  171. Picking Up My SS Hood & Spoiler, Few Questions
  172. Boosted LT1’s show your piping & turbo routes
  173. Code P1351 96 Formula
  174. LT1 PCM only getting positive trims after a restart. Bizzare!
  175. 1le AC Delete pulley.
  176. Going to one CAT
  177. Summer mods Monoblade and stepped headers
  178. AFR 227's on stock short block?
  179. Mild build lt1 boost recommendations
  180. 94 formula firebird over heating in traffic please help?
  181. Urgent!! LT1/ LT4 throw out bearing differences
  182. How to identify oem ram air hood 93-97
  183. Are header gaskets generic?
  184. 1996 z28 overheats while sitting
  185. LT-4, motor and trans out, what now?
  186. 1997 Trans Am Will NOT Spark.
  187. 93 Gauge Cluster Swap
  188. T56 problem - found these pieces , what are they?
  189. Lt1 to ls1 spindle/knuckle question
  190. Anyone selling a Suncoast creations ram air box
  191. Car died suddenly without warning, tach bouncing around like crazy
  192. Instantaneous Optispark Failure?
  193. 1995 T/A LS swap won't start
  194. Hesitating and sputtering lower RPM - Solved
  195. Dual exhaust on a lt1
  196. Ignition Testing 1997 Trans Am
  197. Turbo on a daily driven cammed 383 LT1?
  198. LT-4 Vette Cam questions
  199. Billet oil pump drive gear?
  200. Cam Dowel Pin. Can it be Removed With Cam In Car?
  201. o-rings for GM Optispark
  202. LT1 Optispark which brand?
  203. Clutch pedal "snapped" to the floor and stranded, rattling noise?
  204. What is this bracket? Rear of Driver LT1 Head
  205. Best option - 93 LT1 into 97 car
  206. Best ram air hood?
  207. What's it like being a LT-1 Owner in 2019?
  208. LT1 Red Top Fuel Injectors?
  209. aftermarket gauges.
  210. Water pump gasket issues LT1
  211. Pulling Heads
  212. Pulling Heads
  213. Lt1 Carb swap Questions
  214. Please help. Need early model optispark spline shaft.
  215. 92 Corvette drivetrain removal questions...
  216. PLEASE HELP! 95 z28 motor into 96 z28 chassis
  217. 94 Formula
  218. Rough Idle in gear on brakes
  219. 96 Formula, Won't Start Unless Gas Pedal Is Floored
  220. 0411 PCM Swap/Opti Delete... Nothing Else Needed! Video inside.
  221. 94 Firehawk, miss/bucking at WOT
  222. 97 T/A - The moving misfire... dun dun dunnnnnn
  223. Sup peeps, have a question
  224. Head Gasket question
  225. Which MAF with 24x?
  226. 1997 ws6 suspension parts
  227. 1997 ss/ws6 suspension parts
  228. HELP Messed up transmission I’m pretty sure.
  229. Opti going out ? Please help
  230. Torqhead 24x Conversion 96’ Camaro
  231. lt1 cranks, wont start
  232. ScannerDanner troubleshoots an LT1 ignition issue...
  233. 96 Formula Throwing P0154 Code
  234. Opti or other problem?
  235. 1996 Camaro SS-Mcleod Street Twin Install Issues
  236. 1997 Trans-Am Head Light Issue
  237. Will 10308-1 crane valve springs fit on stock lt1 heads with no machining?
  238. Lt1 383 stroker
  239. Lt1 engine
  240. Installing rockers on new short-block. Vaves hitting the pistons
  241. Lt1 engine
  242. Need write up to replace heater hose assembly GM# 10261147 on 97 Firehawk LT1 M6
  243. Will a torque converter from a 200 4R fit an LT1?
  244. Advanced Induction?
  245. LT1 fuel mileage question
  246. T56 trans reverse issue while idling
  247. Logging AEM UEGO wideband on a OBD2 LT1
  248. 95 lt1 dtc 15 & 48
  249. Lt1 head advise
  250. Exhaust leak or?
