PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. ExHaust shooting out black stuff
  2. whats should i be running est.
  3. 11 sec LT1 TA auction ending Easter Sunday
  4. another fuel pump question
  5. Brodix heads on my LT1
  6. Cometic head gaskets - Help quick!!!
  7. lower and upper ball joint replacment
  8. Finally out of the garage!
  9. Jsut got my Mr Gasket copperseals, couple Qs.
  10. An interesting comparison from a local shop...
  11. Powerdyne SC owners????
  12. 95 LT1. What wire is the tach lead?
  13. Comp Cams XFI 242/248
  14. header question!
  15. LT1 engine rebuild kits?
  16. Going to need new radiator hoses.....
  17. How big!
  18. How big?
  19. Has anyone heard of this modification?
  20. help with picking porting and cam combo
  21. Headers
  22. header install price
  23. What all is included in "plugs and wires"?
  24. Custom cam
  25. lt1 dropping oil (still)
  26. LT1 starter wiring
  27. Is the OPTI SARK the problem?
  28. valve cover breather
  29. **helP My car cuts on then cuts right back off**
  30. Looking for Hood
  31. Tuning
  32. Need some LT1 help here!
  33. 97 LT1 starting issues
  34. What rims are these?
  35. replacing the o2 sensors
  36. gears in my ta
  37. Intake Air Box
  38. !EGR and !AIR???
  39. What should oil pressure be?
  40. Please Help Me!
  41. Brakes, Engine Shops, and heads and cam
  42. Where to get scorpion 1:7:1 rockers?
  43. Cams, cams and more cams
  44. LT1 cam write up
  45. Valves
  46. anyone have a blower for sale?????
  47. Roller rockers
  48. LT1 Cam help (unusual application)
  49. Considering purchase of 95 Formula with LT1
  50. what can i take off
  51. would small exhaust leaks make the Knock S. pull timing?
  52. Delteq users. Anyone use a shift light with it?
  53. fastest lt1
  54. is there such a thing????
  55. a3/th-350 swap
  56. LT1 bellows
  57. Shorty Headers
  58. Need Help Power= Not There
  59. hvac delete question
  60. having a brain fart......
  61. Msd?
  62. Fans wont come on at 220+..very wierd..read
  63. fuel rail covers, polishing, ??????
  64. Loss of torque with shorties
  65. 383 Shortblock
  66. Fuel pump?
  67. Beehive Selection 918's vs big block 120's
  68. should i port my heads?????
  69. Oil Pressure Problem???
  70. Do LT1's have the 4L60E?
  71. any horsepower numbers on 383 with stock heads?
  72. what cam
  73. LT1 Granatelli 85 MAF
  74. anybody got this
  75. progress
  76. overheating question
  77. Mostly stock LT1's, TNT f1 Nitrous kit *inside*
  78. I need help!!!!!
  79. TDC issues
  80. still misfiring
  81. cc305
  82. Comp cam to small or to big?
  83. should i get the Ram AIr Hood
  84. LT1 Missing up top
  85. How to..create a manual fan switch!
  86. Went to the Track Last night.....
  87. Mallory 685 came in jsut now... couple questions...
  88. 94Z vs import
  89. What would you do?
  90. Gremlin Keeps Opening My Hatch!
  91. Relays gone bad already??
  92. Stock tach
  93. Anyone ever hear of Allen Motorsports in TX?
  94. Where to buy LT1 edit
  95. OBD 1 vs. OBD 2
  96. sooo happy
  97. Motor Mounts
  98. Will a 98 ram air hood fit on a 96?
  99. my prayers may have been answered!
  100. what numbers are you runing with Hot Cam?
  101. newbe with a big ??????
  102. Car died on me
  103. Idle RPM
  104. lt1 codes????
  105. 93 Z28 Header Options with S/C
  106. how to tell what year?
  107. Roll cage pics......what do you guys think?
  108. New LT1 Exhaust Audio File
  109. Fuel Pump
  110. weird knock / shake in new motor
  111. Looking for a used/working opti spark for a 95-96LT1.
  112. What to do, what to do?
  113. borla wide open
  114. Should I Buy 1996 6 Speed Formula?
  115. Connecting aftermarket tach....
  116. Joe O cam on the way!!!!!!
  117. Horsepower gain with small cam
  118. alternator?
  119. Light Shut Off
  120. Car not running right, need help!
  121. hotcam install misfire codes
  122. Some thoughts on what mycombo might make
  123. Morel lifter adjustment?
  124. Maf Q
  125. Heads & Cam installed
  126. Changing Gaskets: Best way to clean head surface on block
  127. Stock bottom end
  128. LT1 true duals
  129. max hp on stock crank and rods
  130. Got my MegaSquirt ..Now a Few Questions.
  131. 383 power
  132. fuel rail schrader valve
  133. new 1995 z28 F1
  134. Lt1 Swap into LT1 car
  135. VE tables
  136. runs better when cold
  137. Just bought a 94 Z, need your thoughts on something
  138. LT4 vs. LT1
  139. balancer hub ??
  140. is high mileage a problem?
  141. New cam
  142. need help plz.. alt. relocation bracket
  143. What Am I Gonna Do?
  144. finally got the gears in!
  145. Smog legal shorties with ORY...
  146. Lets see your LT1 intake!!!
  147. grrrr...low rpm mis and rough idle in warm weather
  148. 00 Trans am WS6?
  149. T-56 M6 Conversion
  150. pics
  151. need seriuos help
  152. Post header install probs.
  153. 97' camaro needs some muscle
  154. 93 injector issue maybe?
  155. Overheatinga at idle, please help
  156. Blown Head Gasket or cracked Head
  157. 383 coming along... few questions...
  158. Borla plates
  159. Reflash Back To Stock
  160. ohlt1 gods
  161. what to buy next
  162. When is it time to get a bigger TB
  163. getting new ecu
  164. LT4 High RPM Miss - Help!
  165. Anyone using Pacesetter Mid-Lengths?
  166. shakin shifter knob
  167. crazy high idle, WTF?
  168. I'm stumped
  169. who tunes lt1's?????
  170. New dyno numbers smoggable setup
  171. shorty headers sound clips please!!!
  172. looking for headers
  173. 94 T/A questions
  174. cutouts
  175. Did a little turbo fabbing last night...
  176. opti problem "i know your tired of these questions"
  177. "Tipical" times of...
  178. Are heads necessary with a cam swap?
  179. Help with estimating my hp
  180. finally some dyno numbers!
  181. Forum Guidelines - Read Before Posting
  182. Anyone running JOE O. cams?
  183. turbo heads
  184. Aluminum Flywheel- pros and cons
  185. rocker question
  186. Cheapest place to get an Opti-spark?
  187. LE3 cam & LE2 heads .......
  188. Problems w/ my 93 formula
  189. what cam? yes this thread again!lol
  190. what cam is this?
  191. need to pass emissions
  192. LT4 HOTCAM w/o NEW SPRINGS?
  193. What Cam For My Forged 383??
  194. fried lt1
  195. More LT1 issues ! Please help.
  196. SLP Intake
  197. :HELP: Looking to purchase 396 short block
  198. newbe ? about valve covers
  199. LS1 Magnaflow catback
  200. Someone in need of info
  201. P&P heads and intake on a stock engine
  202. Rebuilt water pump?
  203. How strong are the blocks?
  204. 1/8 mile
  205. Removing passenger side header, crossthreaded bolt hole help!
  206. Need help with Spark
  207. H/C,stock shortblock,daily driver should run?
  208. LE3 383 runs again! (videos)
  209. my posi is shot
  210. need help asap...car died and now its smoking
  211. '95 Formula vs. '01 GT
  212. How fast are WRX STI's? Cause I raped one yesterday!
  213. anyone got any LT1 heads they wanna get rid of?
  214. Igntion ??
  215. more fuel system pics (installed)
  216. '99+ fuel tank in '94?
  217. Engine surge
  218. 95 Firehawk hood- Confused???
  219. 355 LT1 block
  220. Theres a new beast on the street
  221. Rhoads lifters
  222. Running Temp.
  223. how fast are the srt4's?
  224. I need help from anyone!!!! My 383 won't start :(
  225. Msd Digital Window Switch Wiring
  226. The best ways to lighten a 4th gen F body.
  227. Oil Pressure Problem
  228. Almost Failed smog
  229. Oil pan & baffle ?
  230. First Time G-Tech: Are these numbers right?
  231. Pacesetter LT's
  232. How good of a deal is this???????
  233. Show the Zo6's
  234. squeeky aS HELL
  235. installed ATR catback on LT1 caprice
  236. Curious...
  237. Passing emissions with cams. Who has? What size?
  238. Surging @ Idle after installing NGK TR6 plugs
  239. The little triangle or arrow on the H/B
  240. Optispark Install!?!?!?
  241. corvette waterpump in f-body
  242. O2 Extentions
  243. 500hp
  244. new 383 is slow
  245. Question about high milage cars(looking for lt1)
  246. IS this a good buy??
  247. Exhaust question
  248. Coolin problems
  249. What year is this tranny?
  250. How much of a difference do DR's actually make?
