PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 [228] 229 230 231 232 233 234 235
  1. Why LS1 can do it but Lt1 can't??
  2. Is there kit to convert Delco to Coil?
  3. what suspension brands youd recommend
  4. Question about automatic transmission programing
  5. WHere to get some Nice SS Headers for my LT1?
  6. Who Makes The Best Flowing Lt1 Heads?
  7. Converter?
  8. What do u think about this mods?? seeeeeeeee it
  9. Help on making my own catted y-pipe
  10. TB bypass?
  11. Will carbed LT1 with cats pass emissions?
  12. LME Dart heads for LT1/LT4
  13. double checking the functionality of my opti
  14. Balanced LT1
  15. LT4 Hotcam kit Question.
  16. Times with the 224-230
  17. Question about LT1 crate motors
  18. Is there package better than LT4?
  19. Thinking about buying another car
  20. how different are LT1 and L99?
  21. O2 on a catted y
  22. y pipe for Dynotech headers?
  23. Does anyone make an off-road y-pipe for manifolds?
  24. 383 stroker kit is this good?
  25. How many of you get low 11's?
  26. Is there a package for ZR1?
  27. Will 233/239 fit on LT1
  28. dumb question about borla!!
  29. Stainless Header Coating?
  30. How 96-97 SS compare to LS1?
  31. LT1 aluminum carburator intake?
  32. 94-96 Impala Websites and Forums
  33. Where can I buy an alternator relocation bracket for my LT1??
  34. Detonation! :bang:
  35. LT Header install questions
  36. Just got LT1, what comes first??
  37. LT1 Fuel Pressure regulator
  38. TEA stage 2 LT1 heads
  39. Impala SS / LT1 caprice owners
  40. which pins do I use on OBD2 connector??
  41. need help & knowledge please :)
  42. Vortex S/C on bolt-on LT1s
  43. LT1 durablity?
  44. Who has experienced converter lockup at WOT in 3rd?
  45. lt4 knock sensor
  46. Thread Cleaner for O2 Sensor Nut
  47. Cut-out - Now running rich? Need O2 sim?
  48. fabbed valve covers
  49. Anyone Running the new STS Turbo Setup?
  50. Whats The Whole TPI/Intake/Wiring Harness Worth Off A 94 Formula?
  51. new mods and going to the track
  52. What do you think?
  53. For $14, 6 hp... is this legit?
  54. LT4 Hotcam kit on 97z?
  55. Fastest LT4 hotcam car?
  56. LT1 removal, top or bottom???
  57. 410 here now what?
  58. LT1 Canton "T" Oil Pan - (Picture's inside)
  59. Quarter mile guesses
  60. Please look at this autotap log...
  61. top speed with 3.73?
  62. Roots Blower Intake For Lt1?
  63. Stroker Question
  64. anyone got a GOOD diagram of an Opti as its taken apart?
  65. 96 z28 a4 convertible times?
  66. Which cold air intake
  67. 11lbs of STS Boost + New OPTI = COil Over system I guess?
  68. GMMG & LTs
  69. Bearing questions
  70. cam dilemma...
  71. Procharged 383 In The Making!!!!
  72. installing harmonic balancer hub??
  73. Can LT4 rockers be modified?!
  74. Valve cover clearance
  75. Would an LS1 intake ducting fit...
  76. Any recommended places to get some larger valves?
  77. LT4 AFR heads
  78. LS1 coil conversion for LT1
  79. Kook's LT1 headers installation
  80. Crane vavlesprings 10308-1
  81. Dual cutouts on LT1 2.5in ory?
  82. 383 LT1 with Nitrous
  83. Whats the best header for the price?
  84. LT1 Block
  85. Air Intake
  86. Is it normal to pick up 40 rwhp when the converter locks?
  87. Smog Pump Delete on a 94 Formula
  88. New 383 stroker
  89. Educated guess anyone?
  90. LT1/LT4 hp/tq numbers?
  91. 'My engine's toast' update - December
  92. valve question
  93. Got my cats deleted today...
  94. Tsp Ms3 Vs. Gm 847
  95. Gas mileage problem.
  96. Another pleased Delteq customer!
  97. Shift Point On Stock Lt1???
  98. Question on Cold Fusion Direct port nozzles!
  99. Who tuned your ltx car?
  100. Hotcam advice?
  101. Hooker LT's
  102. The 383 Stroker...
  103. torque specs and sequence for heads on a 94-96 LT1?
  104. To The People Running The "GM847" Cam....
  105. Tune Problem
  106. best cam to make 475-500rwhp on an N/A LT1 ??
  107. Who makes Solid roller cam for LT1?
  108. Any LT1 get low 11's?
  109. Dyno results of power steering removal.
  110. Help Me Guess On My 1/4 Before Spring
  111. throttlebody?
  112. Front Crank Pulley
  113. thermal coating
  114. problems with my 97z
  115. How Many O2s Behind The Y-pipe On A 94 Formula?
  116. Who sell pacestter headers???
  117. How do you make a bad-ass heads and cam combo for a 383 when you already have a cam??
  118. First flow numbers (new port job)
  119. Delete O2's With LT1Edit?
  120. Pulling The LT1 A Must For Changing Cam?
  121. What Would You Spray? 94 LT1 91K Miles Babied
  122. Lt1 racetronix fuel pump
  123. Ls1 Ram Air on a Lt1, pics inside
  124. anyone running TPIS ZZ-409 cam?
  125. AFR 210 flow #'s from lloyd Elliott's porting
  126. suggestions on next mods
  127. Cats or Borla XR-1 with GMMG???
  128. 302 Lt1
  129. Advice On ECU?
  130. suggestions for Lt1 rebuild w/supercharger?
  131. 847 Cam and stock heads
  132. LT1s and Underdrive...
  133. rear end size?
  134. Pacesetter LT Problems
  135. Clutch problems
  136. New Best 12/5/04
  137. PCM question
  138. Pacesetter LTs on LT1
  139. This Could Come in Handy at 1500rwhp!
  140. LT1 Vs. SBC whats the difference
  141. suspension help!
  142. Why do you guys keep holding on to your lt1s?
  143. lt1 top end
  144. Hooker Longtubes
  145. what springs for 847 cam?
  146. Just got a 95z for $4500
  147. ARP Studs
  148. Procharger on stock bottom end
  149. worth the money?
  150. a/c delete pulley
  151. Guessing times for the 1/4
  152. Stock ride height?
  153. Opti-Direct Ignition System for the 93-97 LT1/LT4
  154. obd1, 4l60e/high stall, fix works
  155. Head Help!!
  156. Flexplate Question
  157. LT1 Heads : Iron Vs Aluminum
  158. Installing NX Wet kit on LT1, have questions!!
  159. exhaust and flow.
  160. stock injectors strong enough to support a Comp cam's 305 cam?
  161. Throttle Body Bypass - Advanced Question
  162. Surge at cold idle?
  163. Vette TPS Sensor Adjustment
  164. need tuning help
  165. Cam Question
  166. LT4 Max ported/ plumbed with Pro Shot Fogger Solenoids and stainless lines w/ nozzles
  167. GM 14 Bolt Rear Swap?
  168. Delteq Opti-Direct Series II
  169. Should I feel it??
  170. Question about the SLP Loudmouth LT1 exhaust kit.
  171. fuel pump ground wire
  172. Decent Deal on ebay
  173. LT1 Engine Questions
  174. GM "847" Cam RPM Range?
  175. LT1 intake question
  176. Finally got into the 11s
  177. LT4 HotCam Kit Emissions
  178. LT1/LT4 Mods - Is it worthwhile
  179. What year/models 4L60e will fit?
  180. Got some shakedown passes on the 383
  181. 383 stroker questions
  182. How much power can the stock rear end on a 95 Z28 A4 handle?
  183. Kook's LT1 feedback?
  184. New Pacesetter Longtube Install
  185. Pro-Fab question
  186. what do I need (header install)
  187. a bottom end rebuild question
  188. Could $5000 mods get me on 10's?
  189. Tubular Suspension
  190. off road y pipe
  191. Free shipping on LT1 Kooks Headers!!!
  192. LT1, LT4 heads/headers
  193. 96 vortec rods??
  194. short video of my car today
  195. Help me find a replacement for my lil Hot Cam!
  196. How many hp does 97 SS have?
  197. lt1 help
  198. is my tps voltage right?
  199. Which k-member for LT1
  200. 94 Z28
  201. OBD1 conversion
  202. Rocker Arm Ratio?
  203. anyone with the CC230/236 got track times yet?
  204. How are you new Kooks?
  205. Cam question
  206. 10 second N/A LT1 combo's???
  207. What all do i need to replace?
  208. lt4 conversion kit hp?
  209. What are the highest cam only LT1 dyno numbers?
  210. 150 shot or not
  211. fastest lt1 n/a with ac delco pcm?
  212. Timing set choices
  213. LT1 EGR Block off Plate
  214. Spark plugs with headers, More difficult or not?
  215. gmmg
  216. 383 Short block questions
  217. where to get gm gears?
  218. Dropping K-Member
  219. how quick are these cars stock?
  220. 1995 Formula Help!
  221. First modifications...
  222. Cam Install
  223. Fastest LT4 Hot Kit
  224. LT1 Rockers
  225. Jet Stage 2 PCM, Worth Buying for LT1?
  226. Springs for Comp Cams 306 cam
  227. Letting you guys know... the new fastest LT1 record
  228. Jet Hot LT's or Hooker LT's?
  229. What exactly is the Optispark?
  230. 96 vortec block two piece rear main???
  231. Valve relief Questions for stock LT1 w/ BIG CAM...
  232. LT1Edit
  233. MSD now makes a Opti crap replacement... HAIL
  234. website to listen to header/exhaust combos for lt1?
  235. CAN you do this to an OBD I '95 Z?
  236. new Lt1 why does my car shake??
  237. and you wonder why the masses view the LT1 as being weak
  238. LT1 nitrous?
  239. question about k member
  240. LT1 vs LS1 - weight, power, cost?
  241. New Trick Flow Heads flow what?!
  242. What About The Rear
  243. LT4 Hotcam
  244. what kind of times and hp should i expect
  245. LT4 HotCam work with gear drive?
  246. LT4 knock module
  247. wuts my HP?!
  248. manual rack ?
  249. free mods?
  250. Is it possible to convert a twin blade TB to a monoblade
