PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 [229] 230 231 232 233 234 235
  1. will this computer work?
  2. Solid Roller Help
  3. a few small problems with headers
  4. Kooks LT1 headers are here!!!
  5. just bought the third 4th gen in my house hold
  6. exaust leak SES light?
  7. High end studder/power loss.. I need help... countdown to thunder shootout.
  8. Does Anyone need stock crank or pistons or anything?
  9. Meziere Wiring
  10. Any interest in a Bolt On LT1 car
  11. 1.7 Scorpions are in
  12. Throttle Body for supercharged motor
  13. Interest on CNC ported LT1 heads or Aftermarket heads
  14. Fastest LT1?
  15. LT4 heads??
  16. What Cam For New 383??
  17. how is compression checked? please read
  18. lt4 km and nitrous
  19. Car Problems.. same old shit.
  20. Intake Flow Tests
  21. FIPK retrofit
  22. head spring pressure questions.
  23. need help with a cam question???
  24. LT4 with stroker kit... possible?
  25. Who makes hot parts for an LT1 turbo?
  26. injector decisions
  27. Dual exhaust with dual cats?
  28. Strength of the stock bottom end of an LT1?
  29. Spec clutches... good or bad??
  30. lt1 assembly pics?
  31. LT1 clutch fork help!
  32. Congrats Jim (from Speed Inc)
  33. I run pretty rich.
  34. Ran an 05 Mustang GT last night at Atlanta Dragway
  35. Please help a new owner with a lt1 heads questions
  36. 2.59 Final Drive
  37. How Do I Set The Valves?
  38. any good recommended header and exhaust combos?
  39. 200 DP on LT1
  40. Air Bag Suspension
  41. Stock LT1 lifters w/ aftermarket cam
  42. Any Interest On A Lt1 Shortblock Gp??
  43. Lt5 Top End On Lt1 Block?
  44. TSP Rumbler for LT1
  45. 4.10 or 4.56
  46. Head/cam swap, car wont start now...
  47. LT4 Cam kit with stock intake/heads
  48. Quick question about my ws6
  49. New Throttle Body
  50. Help! Vacuum Lines 96' LT1
  51. looking for a big header for an LT1fbody
  52. LT1s
  53. What ya think about this TC?
  54. Found this while searching on Google...
  55. LT4 Hot Cam timing
  56. help help lt4 guys
  57. Need some throttle body help...
  58. Buying Another Lt1!!!
  59. my car is running like shit
  60. Maybe an LT1 is in my future
  61. BMR bolt-on LCA relocation brackets
  62. Someone help
  63. Zex kit
  64. Carbon fiber Drive shaft
  65. LT1 More Power
  66. LT1 With Vortech Supercharger
  67. Lookin at 96 TA ws6 6 speed what times?
  68. torque converter or hotcam?
  69. LT1 rocker arms
  70. Header Question
  71. Trickflows are going on
  72. What sensor is this?
  73. What do you think it would run?
  74. What to do now???
  75. air fuel gauge install instructions for 94/95
  76. ATTENTION: Membership Requirements to Post a For Sale ad
  77. loading pcmforless without floppy
  78. Rear Suspension Question
  79. picking up my lt's friday
  80. no2 maximum
  81. Is it worth 6.5k?
  82. Best Mod
  83. Mid 12 all motor LT1??
  84. Lingenfelter specials
  85. Lingenfelter specials
  86. Clutch issues...
  87. Pacesetter Headers
  88. Translater Plus?
  89. Question about OBD connectors.
  90. How Hard To Change Optispark??
  91. Need Help! Optispark problem or not?
  92. clutch suggestions??
  93. two high flow cats VS no cats
  94. LT4 Hotcam
  95. lt1 clutch help!
  96. Santa Came early :)
  97. Car not working... Shelf Life for an LT1?
  98. Delteq install, having trouble with #8 plug wire
  99. Finally getting some good trap speeds
  100. SLP Loudmouth
  101. ARP Headstuds, do they need any type of sealant
  102. MSD 6AL box burning out opti?
  103. LT1 Weaknesses
  104. 9" rear
  105. would this Formula be worth the cost of rebuilding the motor?
  106. Madz28 or PCMforless??
  107. nitrous fuel plumbing
  108. rear lower control arms setting?
  109. heated o2 sensor questions?
  110. how much of a pick up is boring .030 and will boring his crank do anything?
  111. delteq questions
  112. LT1 edit
  113. air/fuel ratio?
  114. Another A4 question
  115. A4 question
  116. Msd
  117. Start up problems with an MSD6AL ignition box
  118. Scanned the car...
  119. LT1/4 Buildup
  120. Shim kits??
  121. what gears
  122. LT4 heads
  123. who can take a set of smb chevy heads and reverse cool them to work on an LT1 motor?
  124. valve guide clearance problems?
  125. Some horrible 60' times...
  126. What mods next??
  127. Well... dang it. Progress Lacking. Odd lifter question.
  128. new owner, 95Z shutting off at 115
  129. Formulafire's '00 572cid ZL1
  130. I've heard of Cam surge.. but this is nuts
  131. head porting, what gaskets to give to the shop?
  132. How about....
  133. hey, im trying...
  134. Will 94 shorty headers work on a 93?
  135. LT1 Borla Blowout
  136. How to check A/F ratio?
  137. Air inlet hose part number??
  138. Not always the opti
  139. Lifter question
  140. Anyone have this problem with Hooker LTs?
  141. Need to lose the opti, what are my options??
  142. Knock Retard?
  143. LT4 HotCam Springs
  144. need help with supercharger and new injectors
  145. exhaust and intake in
  146. New gears are in!
  147. best heads
  148. best heads
  149. CompR Lifter Adjustment??
  150. Maintenance for adjusting valves, rockers, etc?
  151. RK Sport Headers
  152. best ECM mail tuning?
  153. NOS sistem??
  154. dyno
  155. Long tube or shorties?
  156. Lt4 Conversion
  157. tune with ls1 injectors
  158. SES on 94 A4
  159. What Exhaust should I buy for a LT1?
  160. need some help!
  161. 1993 Injector Schematic
  162. What Kind Of Cam Should I Get??
  163. gears gears
  164. GM 847 cam questions
  165. Paxton supercharger on an LT1
  166. Should I hotcam my 96 lt1??
  167. What catback exhaust to Buy?
  168. How do you tune a 1996 LT1?
  169. gear info
  170. Will LT1 Heads Work On '97-98 Vortec Engines?
  171. strictly track car
  172. Afr 227
  173. New TY TECH LT4 is in!
  174. jet hot LT's vs. pacesetter LT's
  175. Closed Loop = Slow car
  176. Good info for most
  177. Couple of problems
  178. F Body Engine Removal
  179. Do o2 sensors go bad from sitting, and can you clean them?
  180. Question for you b-body (Caprice) folks
  181. Just Sent Off Pcm To Pcmforless (idle Problems)
  182. Supercharged 383 short block... need advice.
  183. Cam with stock heads....
  184. convert a 400 block to lt1?
  185. H/C or NO2
  186. Guess my numbers and times
  187. LS1 Performance VS LT1 Performance
  188. Fired the motor up today
  189. 2 bolt Main, 4 Bolt Main... what is this?
  190. Lt1 HotCam
  191. stk injector size on a 97
  192. little help with a 383
  193. Lt1 Cam Identification?
  194. Difference between Corvette LT1 and F-body LT1?
  195. k & n air intake worth it?
  196. Help Tracking Down Problem
  197. hi, anyone running large cam in excess of 250@.050 through cats?
  198. Balancer/oil problems
  199. 1996 Impala SS resources?
  200. Motor and Trans.
  201. Heads/cam
  202. Moroso Cold Air For sale
  203. Wouldnt mind this at all
  204. Coil Conversion?
  205. 150 Shot On Lt1??
  206. sheet metal style valve covers?
  207. Harden Motorsports 385 LT1
  208. Supercharging an LT1
  209. Valve Springs break-in?
  210. how to get a Soild roller cam to live on the street
  211. Spraying A Lt1
  212. lt1 slight mod vs ls1 stock how would i fair
  213. Need some B-body LT install tips
  214. Short Blocks?
  215. ASR, Other info needed
  216. How much power to break into the 11's..10s too?
  217. 200mph? Can it be done?
  218. Building a 383 stroker.
  219. 94 impala ss mods 350-400 hp
  220. grantelli maf
  221. 700rwhp?
  222. Biggest Cam?
  223. Add-on or Project
  224. engine+tranny weight?
  225. LT1 Intakes
  226. Should i Raise the Compression?
  227. 410 Stroker Motor
  228. California Lt1 owners and LT4 Hotcam owners...
  229. Weird engine over heating problems.
  230. LT1 has no compression
  231. What is the weight of an assembled LT1?
  232. LT1 cutting out and hesitating
  233. what happens with no thermostat on lt1?
  234. Emissions or non-emissions long tubes?
  235. SLP Loudmouth
  236. How many miles to the gallon are yall getting?
  237. What is the good H/C package that worth money?
  238. single cat with long tubes?
  239. lt4 hotcam cut-off
  240. what should I be looking at for HP
  241. what should I buy?
  242. New Cam/mods Suggestions???
  243. Does Nitrous make a pretty big difference on an LT1?
  244. help?!?! aftermarket valve covers
  245. A/c delete
  246. relocate alternator?
  247. installed complete exhaust, engine sputtering?
  248. LT4 Crate Motor?
  249. LT1 vs LS1
  250. How to run 12.5s N/A on street tires?
