View Full Version : LT1-LT4 Modifications
- pics of hood
- lt1 crank,rods in 1gen 350?
- 3.73's Guys!
- Those with AS&M or Rk Sport headers, I need your help.
- Progress pictures of my LT1. (at last).
- Need a 95 Impala tune.
- some updated progress pics
- LT1 Part Sale!
- help my dream
- big cam and valve springs
- Back from Iraq, and the Car is back together
- 95 Vs 97
- Gm847...
- what size injectors do you have?
- Temp problem
- Crankshaft and Connecting rod endplay
- question about timing marks on a lt1
- motor mounts
- Cam for bolt on LT1
- Car Using Oil
- Help Something wrong w/ car not sure what??
- Hey Should I Just Rebuild The Lt1 Out........
- Help people.....opti other options?????????
- delteq swap has anyone done it
- alarm acting crazy
- Rough Idle
- Fuel Line Mod???
- Advice needed on EGR removal.....
- Best sounding _____ Mouth.
- need help to pass emissions LE2 or LE1?
- Intake Manifolds
- installing weld in subframes..
- Hey Anybody Know ????
- performance button
- opti related?
- Weird problem
- Do these numbers look right?
- 5 pin 700r4 plug
- Weird fuse issue
- EVAP code??
- What should my oil psi be?
- Gas fumes wont quit!
- hp gain ??
- Safe or Not safe AFR hydra rev kit
- just thought that i should post this up
- Walbro pump fitmennt
- Wire Mod
- wierd..
- Adjusting rockers-valves??
- Dynosim advanced
- V6 for LT1 SWAP
- mods and high dyno numbers
- oil
- Will These Fit?
- Turbo application
- Has anyone tried the accel opti yet??
- carburated crate motor?
- Fuel Pump Fuse
- Problem at 5200 rpm
- why wont she shift?????
- What is the proper intake manifold leak cure or method??
- how to swithc out pcm's
- best build for LT1???
- My Pacesetter y pipe is touching one of the brake lines
- valvetrain question (pushrods)
- Wow, what a pain
- Maf?
- FOG lights
- Finnaly after 2 years of being down and out !! shes alive
- My track times
- Xtreme Blazer w/LT1...need advice
- New AI H/C 355 Lives, but Pig Rich
- Cam=Slower low end torque?
- ? about valve covers and pcv system
- ABS Inop after longtube install
- Best ECU for LTx?
- best y-pipe for jet hot LT's
- Wierd pops from rear hatch/suspension
- Dynoed my 383
- Can ABS be disabled by tuning?
- Change an LT1 from a Impala
- Another questions about after market heads...
- hot weather problems
- cant anybody explain this optis**t
- Turn Signal question
- Gears....
- LT1 OBDII Tunercats
- Why cant I just Delete my ac compressor without adding a pully?
- oil woooows
- 87-90 iroc z ?
- Wrecked the TA
- Ever Seen One Of These Intakes
- LT1 purchase advice
- injector size??
- Lt1 Intake
- Needed: 94-95 LT1 Vette or Ram Air TA Bin File needed
- Boosted LT1 ????'s
- Anyone here know a thing or two about T/A headlight adjustment?
- a4 to t56 conversion
- LT1 Wiring Help!!
- Do I need to replace my wires/optispark?
- 110* or 90* Elbow?
- Need help with random misfiring
- 383 running rich
- here is my problem
- Having problems starting new motor.
- 315s on a '93
- The good news and the bad news.
- removing intake
- Removing cat
- lt4 module
- LE2 Dyno. What's Wrong??
- Tuning help
- power results from headers
- lt1 longtube header question
- Yet ANOTHER header thread!inside please!
- Opti Going Bad?
- Dyno Tuning around Northwest Ohio...
- turbo cam ?s
- were to buy fiber glass hoods?
- Nice to meet you, opinions needed
- Front mounted Turbo or Rear Mounted
- Next mod?
- What do you guys think? 12.9xs?
- finally got my dyno numbers (dissapointed)
- what does this mean
- 700r swap
- Can't read codes any ideas?
- Having access to a lift is sooooo nice!
- HELP w/Pushrod length
- lt1 headers
- 93 computer redline
- after pacesetter instalation?
- cam question
- can a 96+ steering column fit a 94
- how does the fuse box work, im confused
- nitrous ????????
- Header and emissions help...
- Missing out problem need help!!!
- New pics of my LT1!
- LT1 Plug Change Help
- radar systems
- Rounded vale stem tip...Do I need to yank the head?
- how would i fare against this?
- Pushrods too long? Picture inside........
- i need a bigger cam
- Want to hit the 12's with this mod. Need your opinions
- Starting Problem
- Checking interest: Z28 200mph Overlay with Speedo Corrector Kit
- Delteq/LTCC and big cam..WTF!
- got my baby out tonight..finally
- Sibling Rivalry.
- Help with DTC PO300 code
- Destroked LT1
- whats wrong with my Formula?
- Starting issue question
- leak wont seal!!
- Is nitrous good for me and car
- ***Urgent*** help plz. Old starter has 9 teeth new has 12...
- Best cam for a 120k Stock motor
- Any difference in elbow's for 93-97 LT1 Camaro's?
- Questions on cam experience
- i think im sad
- Sb1:
- quick question
- weird shit
- Crank sensor problem
- Optispark problems inside!!!
- AZM Monoblade question?
- Any dragstrip numbers with a HOT CAM and stock heads?
- opinions inside please
- Noob here with a newb question
- Direct Port Nitrous Users???
- Small part, big problem. Knock Sensor plug is missing. Help.
- Timing and Cam????
- What are some signs/symptoms of your opti about to go out?
- lt1 mods
- SLP exhaust question
- 1LE elbow
- machine work
- headers for lt1 ?
- Electric water pumps
- whats the deal with steering wheels, need one and dont know about um
- Video of roots blower setup on F-Body
- LT-1 cutting at 5000 rpm!!??
- dyno - 1/4 mile sadness
- Good or Bad DYNO #?? And E.T prediction??
- Fuel pressure
- SLP Loudmouth 2
- Would it hurt to remove my condensor and lines? But leave the compressor?
- Headlight upgrade.......
- piston rings
- Good Head/Cam Combo
- Please help with my lt1!
- Mono bladeThrottle bodoy
- What Should i Get next
- i hate punk ass kids!my poor baby!!!
- I HATE my Lt1!
- Group buys on...about anything
- 97 SS T-56 Tranny Removal
- cams
- medim quasar blue metallic TA*Pics Inside*
- Camaro's running rough
- Best way to do a huge burnout M6?
- Edelbrock exhaust...
- cam brand/type/specs
- street/strip car ?'s
- Size (Stall)??
- What kind of gas mileage would I get with this setup?
- How much for an LT4 HCC
- Motor NOISE
- wont start help??
- whats is this sound?
- lt1 engine bay pics
- Are my fans bad?
- Get ur done! New dyno #'s
- Still overheating problems....
- ET Performance LT1 Heads (PICS)
- need pics of your intakes, not the manifold but the actual intake tube
- finally finished with alt. mounting *pics inside*
- LT header install?
- running car with out thermastat
- LT1 runs rough in Closed Loop
- Say Hello to my new car!
- 11/32 Valve with Gen III Spring
- arcing problem
- What will the order of procedure be for this quasi-massive undertaking?
- HELP PLEASE!!!!!! water pump problem
- let me know what you think
- stumbles at high rpm's
- best intake for single plain?
- Spy photos: Single Plane, NX, Crank trigger,Low profile dist>
- LT-1 in a street rod, hot cam worth it?
- H/C plan. thoughts?
- piston rings
- Choice in new coil?
- Which springs/locks/retainers with the CC306???
- README: Change with posting F/S threads in this forum...
- Up top
- Weight of stock hood?
- engine woes....
- swap or buy?
- brakes!!!!!!!!!!!
- Harmonic Balancer Recommendation
- Help with injector selection LT-1
- Collapsed lifters...
- 100* Elbow and 90MM Accufab Tb For Sale!!
- swaybar
- Help please
