View Full Version : LT1-LT4 Modifications
- Coolant Temperature Sensor
- EGR Block off plates
- I Need Help
- Fuel Pump trapdoor 96 fbody vert
- EGR block-off?
- this head gasket fits weird
- valve train upgrades
- brakes
- power steering
- 97-02 rear tillights
- HELP! Lock nuts!
- What are splines
- 30lbs injectors
- TCI Breakaway Torque Converters Any Good??
- Catalytic Converter
- Project: Full wire tuck on engine bay
- '96 LT1 Bolt-On Questions
- gasket paper
- Code P1441, SES Light
- High idle at start up???
- check out this 99 lt1 vette
- 3/4 longtube pacesetters - too much for a stock motor?
- LT1 383 questions.
- Workin on the TA a little lately... (T56 rebuild, True Duals, 9 inch rebuild, etc)
- a4 guys- trans cooler lines
- lt1 tails and markers VHT'd!
- How To Remove Pass. Side Air Bag
- how hight do you rev the stock bottom end?
- i cant get my car to shift when running!!
- Need...help!!!!!!
- Aeromotive Lt1 FPR Help?
- need help with these headers...
- who makes these???
- how should i go about doing this??
- Coolant Temp Sensor
- changing non vented opti to vented
- Oil press gauge/cooler lines Q?
- Intake Gasket Questions
- 96 z with this cam
- LT1 Racing Videos??
- Can I use gears from an ls1?
- please help me with this cam
- Help!
- what should be repaleced when chaning optis
- Low voltage when idling
- 383 flywheel question?
- Intake question, I'm sure someone has thought of this...
- Magnaflow mufflers???
- Double Roller Timing Chain
- Changing Alternater
- got a t56
- if LT1 350 is 5.7L , what's a 383?
- Camaro's down..
- Kooks or Pacesetter LT's ?
- Went to track
- Need a clutch
- need help with fuel
- What Could Be Causing This!!!
- Do I need LS1 brake lines to swap LS1 Front Brakes onto my LT1?
- Pictures of the Formula pulled apart
- lt1 engine for sale lol
- lt1 head chamber
- New Seats Installed!!~PICS~
- ground wire
- header install q's
- OMG it's green ;)
- Port & Polish TB
- Engine seal and front end bushing kit
- Non-LT1 O2 sensor problem
- subframe connectors?
- replaced opti big problems need help
- 500 HP setup . T56 or Th400 transmission???
- Help!!
- Anyone using nitrous express maf system?
- elbow
- Back from dyno tune at Ed Wright's, numbers inside
- Lean in Open Loop, need help
- Anyone ever relocate the ABS Module in the engine bay?
- Opti Spark
- Took My T/A To Tha Tracks Lastnight...
- need help with long tubes for 93
- what's the difference between 93-94 opti and 95-97
- datalog..... can someone take a look?
- got damned this car
- 383 strokers with cc306 inside please
- yes or no?
- stock gas mileage
- Need help fast!
- Track Ready..
- LT-1 Valve cover bolts
- Wth??
- I need some help
- how do i find out what carrier i have ?????
- Dropping K frame NEED HELP ASAP!!!!
- hit a curb today, ruined everything
- Tr55 Gap?
- this should help!!
- C5 Stall fit LT1?
- Best Shorty headers
- Finally some 12s
- Lingenfelter cams?
- Going to the track today...FINALLY!!!
- First header install
- 1994 Z-28 progress...
- Autometer Speedo install....no shift!!!
- Vortec Distributor instead of Opti ??
- help me out......spark plug diagnostic
- 58mm throttle body questions
- LS1 Kills
- GAy lt1 lol
- LT1 Bin File
- Need a part number
- Any way to seal exhaust manifold w/broken bolts?
- Spark plug help
- Gas
- o2s cauding bad missing? Corvette o2 p/n
- how fast is 550rwhp
- no help yet
- Guys Running 15x10x7.5 BS prostars!!!! Please look
- Plug wire to cylinder 7 behind stock manifold?
- 1.6 rr's and springs question
- Idiot Lights
- guys with LT's is it easier to change sparkplugs?
- emissions and ignition timing
- Heater Hose Assembly....
- why dont the lt1 guys get as many forums as lt1 guys?
- Need help BAD
- 5 car beat down?
- lt1edit or dynotune?
- how long does it take to install heads and cam lt1
- Heads and cam
- Pictures from LT1 cam [and head] swaps?
- Parts for TB Bypass
- Poor mans cam swap
- high flow cat?
- What does an EGR and AIR delete do for an LT1
- Timing Chain.
- Temp Gauage question
- Do i have everything for my header install?
- 3/4 inch Header bolts work for install?
- V6 to LT1
- rear O2 sensor question
- Plugs and Wires FTL
- dont no what to do
- Rocker Problem?
- le1 h/c
- is this the opti (please help)
- backfire problems
- Guys with over 800rwhp whats your fuel system
- Whats 96 T/A Vert worth
- O2 Sensor eliminator
- heads cam headers setup help
- GM847 and similar
- couple of sensor questions
- Confused
- 1 LE H/C come in
- 97 Ta ws6 swaybar
- which muffler flows the best?
- prostar size
- Cleaning Moroso CAI
- obd2 96 z and torque management
- Weird scanmaster readings sometimes.
- What kind of tuning?
- Fuel Upgrades
- Backfire threw exhaust!
- exhaust straight pipe damage question
- I want to get some headers, which one?
- LT-1 Ignition timing
- "3 bar map sensor" will it work on my lt1?
- does someone who knows their stuff want to answer some questions??
- Lt1 T56 Bellhousing
- cheap easy way to make
- proper fuel system upgrades
- Air Tunnel From Fog Light to K&N?
- Oil pressure question
- how to install 150 speedo
- Need some help!!!
- Header Installation... Need Some Advice...
- Lamest question of the month: Corvette Servo
- Need help wont rev past 4 grand
- Something You Might Enjoy
- fuel pressure regulator opinions
- Harlan shift light LT1, DELTEQ & MSD DIS-4
- With some "finesse" could these work? (lrg images)
- opti's suck
- 383 build up
- No signel to the coil = bad opti?
- big opti/cam swap dilemma
- Cut Out installed
- what gaskets do i need for a cam and heads setup lt1
- lt1 in nissan 240sx
- what should i do???
- 93 firebird wont start.. HELP!
- What Slicks Yall Runnin???
- Lamp Circuit Failure code B1061
- What type of driveshaft??
- Planned LT1 mods. Suggestions?
- now what the hell
- 2 questions about recently installed gears
- Traction problems
- changed opti but car still runs rough from time to time
- High Flow cats?
- steam tube- routing?
- egr troubleshooting
- car stumbles randomly and tach goes crazy
- Edelbrock Dry nitrous for lt-1
- Shocks and springs NEED SOME GOOD INFO
- ?'s after stall install
- blown clutch- help!
- Need Some Help
- Need your opinion on this exhaust FAST
- sickest lt1 iv ever seen/heard
- LTCC Owners...
- Should I waste my time against this GTO?
- '95 LT1 Charging problem.... HELP!!
- Need help with injector size for boost!!!
- Help with my 60fts they seem weak.
- LT1 Piston to deck clearance vs. deck height?
- Dynoed
- LT1 383 1/8th mile results
- tranny issue???
- New Best and some video
- Problem with plugs???
- Delco R44TS, fine for a DD?
- Header bolt Q's
- Vids of a few fast LS1 tech members at the drags this weekend
- two new bests
- Looking for some advice on first mods!
- Help me pick my license plate
- How to replace the trans mount
- Shiftpoint Logging
- Pics of your HARWOOD hoods....!!
- Need help on replacing valve seals...
- timing
- How wide can I go?
- new steering wheel pics
- Cast vs Forged crank
- Rebuild?
- knock sensor
- rhino ramps
- do the 95z28 have the 4L60E or 4L80E?
- Fuel system for signal planes need ideas
- lets see some lt1's.
- Stall converter suggestions?
- i hate lt1 cooling systems!!!!
- No Coolant Gauge
- Steering Vibration
- FASTFATBOY Idle Video!
- What Size stall
