View Full Version : LT1-LT4 Modifications
- crank hub sleeve
- Does anyone know how to use mr gasket rocker arm oil deflectors for rocker adj
- used clutch and flywheel
- Need help
- Please help diagnose my LT1!!
- Exhaust shop screwed up catback install....need options
- why is the temp reading different?
- locks and retainers
- new longblock
- Autolite 104's
- supercharger crank pulley????
- chandler ebay opti
- wanted: 94 harness and ecu
- What bearing clearances for 400rwhp + 250 shot, recommended oil weight?
- opti stabbing
- 2 bolt mains
- Why do I keep trashing oil pressure senders?
- 4L60 Problems
- Classic. One of the best commericals ever...
- surging at start up
- Who is running Dynaspark ? Opinions ?
- Chasing no spark @ coil or plug
- 93 camaro code 42
- What Converter?
- will this dry kit work ?
- how much power and/or rpm have you thrown at your forged eagle crank?
- lifter question? roller rocker adjustment?
- acceleration problems
- MLS Cometic Gasket. What size bore gasket for a 4.030 bore engine?
- What plugs for a dry nos kit
- Whats the difference in alternators for 93-97 z28s?
- Electric Water pump install??
- Blown 355 or 383??
- metal in motor, carbon on pistons
- Post Up Your Single Plane PICS!
- Misterious Oil leak...Update please help.
- Engine Removal!
- How much spring pressure can hydraulic lifters take?
- 1994 Z28 PCM Question???
- Questions about gauges.
- Coolant cross over
- Idle problem - URGENT
- backfire through cold air intake
- help with headlights and starter
- svo red tops?
- Dyno's in Texas?
- Head casting#
- Setting the TPS
- need help. where to get a computer tune?
- Pcm tune after headers?
- WTF! $550.00 Opti......
- neutral balanced flywheel
- new motor mounts??
- LT1 Not Starting. .
- Warm start lt1 issues
- cut my muffler off
- piston recomendations
- Spark Plug Wires
- Need help with an oil leak!
- 3.4 to lt1 swap harness help
- Pacesetter off road Y
- EGR delete?
- JBA Headers
- what color caps are on stock injectors
- ebrake problem
- Oil inside the intake manifold issue...
- Is it normal to get random knock retard counts on cold startup?
- do i need a computer tune after header install?
- lt1 stock injectors vs. 24lb ford svo injectors
- Another rocker question.
- Oil Leak From Valve Cover - Help Please!
- ECM question
- Fuel injector ground wire location?
- What size injectors for 396cid LT-1 on E-85
- please help, rough running 94 trans am
- proform valve covers
- Optispark Check Valve Help
- LT1 Header Question
- rod bearing replacement
- Proform Rockers
- Scratched side windows, can I remove this safely?
- knock sensor part number what year is this?
- Volt Gauge Problem Please Help
- 1993 camaro z28
- Opti replacement
- still alive!!
- How many hood pins do you pin on guys have?
- 95 4l60e speed sensor?
- Edelbrock ProFlo XT on an LT1?
- TEASER: BLS 93-97 True Bi-Xenon Retrofit --PICS
- rear susp
- More problems...
- Magnaflow compared to GMMG im torn between the two.
- LT1 Burning Lots Of Oil
- Question about o-ringing my block and using copper gaskets. Also are hellfire rings..
- help add some input to my build
- Ongoing problem need some help!!
- 2010 Build: 3.4 to LT1
- MSD Optispark Help..
- about to pull the trigger on the S60....
- LM1 vs. LM2 bullet muffler
- URGENT - Powersteering pump fastening bolts
- Belt Slip
- wheel wobbling
- 1997 Camaro urgent please help
- Going to dyno on June 9th
- How much strain on the engine by running the AC in 100+ weather?
- Frustrated- MSD Opti…
- 97 fans aint kickn on
- Cracked radiator
- lookin for exhaust clip
- Dyno Numbers/Misfire Help
- It lives and breathes!!!
- lt4 camaro computer problem please help!!!!!!!!!!!
- LT1 Electrical Concern
- Anybody running Kooks LT headers
- Gearing question.
- Supercharge Or Turbo Lt1
- Over size filter for 93-97 lt1 ?
- LT1 fuel pumps
- need help setting WOT tune.
- Piston to valve clearence.
- track results
- cam bearing
- I searched for days. Please help (carb conversion)
- knock module issues
- Finishing up 383 A1 21*Build
- Help Needed!
- Found an antifreeze leak...How to fix?
- catted y-pipe that works with LPP longtubes?
- Optispark question
- Shorty Headers owners, come in
- Help! my walet and my sanity can't take anymore.
- trade me cams
- --> water pump drive seal
- Gatorback Serp Belt...anyone? anyone?
- mods advise?
- I need a piston for a 388
- Question
- Throttle follower IAC offset vs MPH
- nos plate can only handle a 200 shot but I herd people boring it out for 250
- Oil pressure
- new build
- 93 lt1 auto shifting at 5500 rpms at WOT??
- looking at a 94 procharged camaro.
- What spark plugs to run?
- Guys with Ai(advanced induction) heads please state your....
- Window issue....
- Replacing my IAC valve, anything I need to do once its installed?
- changing spark plugs, need advice
- cam specs of a 305
- mail order tune
- 1 otl exhaust?
- New 3.90 gear set...do i need to break them in
- if you had to pick one of these headers which would you get
- LSx or stay with the LT1
- Do MSD wires fit in the stock looms?
- Will a Ls1 computer work in a LT1?
- Anyone else order Pacesetter's and still havent got them?
- weird LT problems need help!
- HOw do I make a solid lifter?
- Any Solid Roller Guys Daily Drive?
- Meziere HD water pump install issues
- Just checking a part
- Whats the thinnest head gasket for 4.030 bore
- how much nitrous did you shoot at your 306cc cam? Will 200-250 be to much since....
- Push rods?
- msd digital 6
- Lt1 brake bleeding
- 335 tires on 17x9.5 rim
- Wtb
- cam swap noob ?
- Need some help!
- Having an issue with traction control activating.
- LT1 Problem. Please help.
- Are TR55's ever too hot for NA?
- new opti... pre install maintinence?
- LT1 383 staged build. Need some advice please.
- major problems
- LT1 Problem
- BLower motor resistor location
- 95 lt1 problem
- need help with part #
- fuel pump wire kit, where to get?
- Lunati Voodoo camshaft 60122... anyone running it?
- Guys with Lokar throttle cables in here please
- 350 / CC503 / AI 200cc
- MadHammer?
- What Converter is everyone running??
- Arp head studs
- Is this cam too small for my build?
- biggest tire on stock rims?
- Low Oil Sensor
- Can you adjust lash with solid cam while engine is running?
- coil per cylinder?
- Engine bay is done! A few issues with first startup...
- OBDI INjector Fault Code Switches
- Major Car Trouble
- piston and head question
- 94 z28 help
- Car wont start out of nowhere, fuel pump runs but starter wont turn
- Grinding Noise
- stressed cracked timing cover
- Electric Water Pump 101
- Shorty/Mid length questions
- EGR Blockoff Bolt Sizes?
- GM847 + home ported heads dyno results
- 95-97 MSD cap fit my 93 original non vented unit?
- Cooling system problems....
- Timing set?!
- would this help my sound?
- 94 lt1 from Caprice
- misfire
- GIZMO do you know this car?
- Traction control/Brake bleeding T-100 tool?
- Tranny Cooler several questions
- wiring help?
- SES after Header install
- lt1 running issues
- thinking of going single plane intake carburator setup. help needed.
- Washed motor, now shift prob.
- low oil pressure
- Help with LT1 build?
- My purchase 95 383 LT1 T/A, 406 RWP for $3100? Killer deal or crap? Video inside
- Cam only dyno numbers.
- compcam 503, 1.7 rr,s
- Converter Doesn't Stall Like It Should
- Ai 383
- Car Ran Slower After Gear Swap
- lt1 355 BUDGET build, HELP PLEASE...
- Head Gasket Help??
- Went to the track - Results
- LT-1 vs LT1 article
- Motor out the bottom question
- LT1 vette...whats wrong???
- cutouts?
- need help... LT1 loading up
- Sleeper LT1 - best set up?
- Optispark install/internals question
- quick bit o advice please
- Can this be welded??
- Help LT1 knowlege come in....
- Getting my Magnaflow tomorrow.... =)
- died in mid route
- nsa rocker which ones work
- what spark plugs?
- Tach or Injector Signal help
- brainstorming cooler mount idea
- Header Recommendations...
- Would you 175 it on pump gas
