PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 [135] 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. ex. manifold gaskets
  2. Are They Really ALL the Valeo Pressure Plate?
  3. Proper way to bleed 94 LT1 coolant system
  4. LT1 Manual
  5. Whos running TR6 NGKs...
  6. limited slip posi and locker
  7. 93 lt1 with newer 24lb injectors
  8. What mufflers to go with.
  9. straight or angled main caps
  10. Injector Wiring Harness
  11. do i have a posi?
  12. Why would you use 1-7/8" Primaries?
  13. My winter work thread (continued) 95 turbo TA build
  14. Does anyone know where to get a car cover ?
  15. Got my Pacesetter LT's and True Duals on finally!!!
  16. Vortec V1 supercharger
  17. removing alternator
  18. lt4 knock module
  19. My new toy
  20. Need some advice on the new setup
  21. Any suggestions?
  22. Motor Mount Write-up?
  23. Should be making some shakedown passes Friday.
  24. Best Plug Wires?
  25. 52mm or 58mm TB?
  26. Header Question
  27. LPP Headers installed *PICS*
  28. 383 help
  29. Little Ram Air Scoop I Made...
  30. finally doing headers, questions, HELP.
  31. How much will my RPMs increase...
  32. any one with weld rims
  33. had a weird problem?!
  34. splyed 4 bolt VS Studs
  35. part numbers for LT1 front oil galley plugs?
  36. Electronic spark failure?
  37. Opti help!
  38. Blown head gasket
  39. will it store a code?
  40. auto trans help
  41. does anyone sell a kit like this?
  42. Dyno Tune nitrous systems?
  43. How can I get about 400 H.P. out of a TPI 350
  44. car still runs BAD. 100miles/15gallons
  45. need new engine 355 or 383??
  46. Ported Maf ends
  47. The OFFICIAL LTX Shootout 09 smack talkin thread
  48. Need advice:Installing my GMMG
  49. Difference between 93 LT1's & 94-97 LT1's
  50. Is Power Shifting Bad For Your Clutch/Flywheel?
  51. Best Sound Duals Setup ?
  52. Funny video with C Sikora in it....
  53. optispark question
  54. Help!! High and Rough Idle!!
  55. RaceTronix Fuel Pump
  56. loss of power
  57. dyno numbers and ETs in the same day
  58. LT1 tick
  59. High Res track pics 8-08-08
  60. alcohol rated fuel pump
  61. finally going to do headers, which gaskets?
  62. Ok what next??? Suggestions.
  63. need tranny help!!!!!
  64. Copper header gaskets
  65. Help me
  66. a little update....
  67. Spark Plug Torque specs?
  68. CNC-Motorsports Roller rockers
  69. Help me match an off the shelf cam to the converter I want to use...
  70. Running a 100 shot on a stock tune & 91 octane?
  71. AI gave me estimate...wow. Help!
  72. Cam upgrade from a CC306????
  73. 94 Lt1
  74. Buick Roadmaster; Texas Vehicle...spline drive opti?
  75. Weird misfire down low \=
  76. Intake leak?!
  77. How to make a 355?
  78. 95+ Opti harness
  79. arp torque settings ?
  80. Ported Aftermarket Castings
  81. Launch Delay
  82. a.i 224 cam
  83. Fuel pressure regulator for eaton s/c setup?
  84. Slow Crank at Hot Starts
  85. Common Engine Reassembly Mistakes
  86. Stock 03 cobra 39lb injectors in LT1?
  87. $2,000 what should I do?
  88. Lt1 intake question
  89. MAP unplugged ?
  90. Backfiring? and i know it is not my optispark
  91. my 97 camaro SS vid with CC503 & TSP Rumbler
  92. Gonna pull my Z28 out of storage.... Here is the performance plan..
  93. LT1 Street/Strip Motor Build ?s
  94. Handheld Tuner
  95. $150 .040 over shortblock. Should I?
  96. help, engine running like shit.
  97. same exhaust, but one is ALOT louder..
  98. Dyno Predictions!?
  99. couple questions on my 97Z28 guys..anything will be great
  100. enggine knock/low idle
  101. LT1 oil pumps ? 10552/10555
  102. LE 383 LT4 Dyno Results
  103. Couple string pipe questions
  104. Dragbag assist?
  105. Another misfire, opti or coil or o2's??
  106. 383 lifespan
  107. Torquing Sequence on a 94 LT1?
  108. no rpo codes ? wtf!!!!!!!
  109. headers and rocker arms
  110. racing shifter
  111. Where You On Top Or Bottom??
  112. Borla vs Corsa for a 95 z28
  113. PCM .bin file needed
  114. hp range??
  115. Help me prove then wrong...
  116. bigger injectors or possible bad fuel pump
  117. wrecked camaro
  118. Plastic Shield Inside the Door
  119. headers??
  120. Why was my thread deleted?
  121. 94 Z28 overheating....................
  122. high compression LT1 guys
  123. car doesnt hold an idle
  124. LT1 Valve Springs
  125. 4l60e aftermarket shifter
  126. Mustang owner coming over to the LTx side
  127. transgo kit for 95 camaro 4l60e
  128. LT1 With New Shoes
  129. A few pics of my LT1 at my sponsor's car show
  130. msd opti....
  131. Damn You Radiator!!
  132. LT4 Hotcam Kit HP Gains?
  133. 918 spring pressure loss?
  134. porting my heads
  135. i need some help with changing spark plug wires
  136. High Performance Poniac Article!!!
  137. Tall Valve Covers
  138. 17 year old needing advice or ideas
  139. hesitation and wierd idle
  140. gen 1 to lt1 swap
  141. which opti
  142. cc306 vs. AI 226/234
  143. Msd6al
  144. track times
  145. power locks starting to not work??
  146. strong 4l60's?
  147. le2 heads /le1 billet cam/ le intake
  148. high revving ?
  149. header install help!
  150. front air dam
  151. LPP LT1 headers and Y now on SALE
  152. High RPM 'hitch'
  153. What is this solenoid?
  154. lt1 or lt4
  155. LT1 w/ Eaton M112 supercharged!
  156. t56 trans
  157. New Track Times!!
  158. AFR rev kit?
  159. lt1 daily driver ?
  160. would it make a differance moding my Mids?
  161. starter sparked and went dead
  162. help! will not turn over
  163. I need height measurements on electric water pumps
  164. Keeps blowing inj fuses
  165. mids 2 LT what do I need ?
  166. A little getto But it runs
  167. Who's got a Glasstek Cowl Hood??
  168. 355 (LE1 cam/LE2 heads) LT1 is complete. Final dyno numbers inside
  169. crazy vibration
  170. One way hose? (pics)
  171. cam lock rockers
  172. Motor issues
  173. Walbro pump bad after 40 miles.
  174. My 67 SS getting a Nitrous Outlet treatment...
  175. ok i know its been beaten to death
  176. Who uses block/ valvetrain girdles
  177. car wont idle
  178. Please explain why MY car won't 60ft...
  179. True Duals
  180. ICM / coil assembly cooling solution?
  181. would these fit
  182. The numbers are in! Dynoed FINALLY!
  183. dodge forum
  184. What cam for stock heads?
  185. Tranny problem?
  186. Hold up. (has pictures)
  187. 39x LTx - Year casting to use?
  188. Oil change?
  189. 94 Camaro Z28 Gear Swap!!
  190. Open Header Guys - - Come In Here!!
  191. Ac
  192. D.S Saftey Loop
  193. Trick Flow Makes a Cold Air Intake for LT1's
  194. What Lifters and gasket set for Hotcam Kit?
  195. 4.10 daily drivers?
  196. AI 226/234 first impressions
  197. Lingenfelter CAI
  198. sealant for sensors
  199. Help on cam choice
  200. How to tell the difference from nsa and sa rockers
  201. LPP lt1 headers
  202. installing engine..HELP!
  203. valve covers
  204. exhaust
  205. Out of the blue, DTC16, DTC18, DTC51
  206. Water Pump Q's on 94 Z28
  207. Thoughts on cam
  208. Stock Shift Point
  209. Power steering problem...
  210. Does the Canton oil pan require the Canton gasket?
  211. 1 3/4 Headers??
  212. LT1 Over-heating
  213. 1994 Corvette part #s needed please!
  214. Summit Electric Cutouts
  215. Slp Loud Mouth
  216. E Brake Woahs!
  217. Rev Limiter for a CC503
  218. wagon LT1
  219. A/C woes!!
  220. is machine work needed for rod bolt swap???
  221. Windage tray and stud kit questions
  222. Cam Swap Nightmare!
  223. Need pic of something
  224. fuel pump question
  225. Is 210 or more coolant gauge normal or it should always stay 160?
  226. Headers ?'s
  227. Great Deal
  228. LT1 O2 Sensors (searched...)
  229. My LPE headed 383 --- 56k? probably not
  230. Tuning advice
  231. Thinking it may be time for a "Tune".
  232. Couple of Questions about 93's
  233. Finished installing my LS1 Borla exhaust on my LT1
  234. HP/TQ predictions...
  235. Huge LT1 part out
  236. My T56 Conversion..
  237. backfire question
  238. Please help me diagnose my dieseling problem
  239. ode to my LT's
  240. What is this cut/port on the bottom of the LT4 Manifold
  241. Carbed LT1?
  242. LT1 Hooker Super Comp LT vs. Pacesetter LT's
  243. Still chasing this oil problem...
  244. Got me a LS1 Alum DS...... Questions?
  245. 350 to 396 questions ???
  246. New build
  247. Testing Plug Wires
  248. 94 3.4 firebird to 1994 corvette LT1 swap
  249. help with meziere e water pump.
  250. Best fuel pump for my setup
