PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Weird fan behavior
  2. Power numbers
  3. High Idle that won't come down.
  4. After burn after MSD digital 6 install
  5. False knock
  6. Autozone optispark went out looking for oem replacement
  7. help a brother out
  8. Consistent Misfire At Idle - Any way to track down?
  9. 383 LT1 with too much crankcase pressure!
  10. Head Gasket, Dang.
  11. Surging idle
  12. Blueprint engines long block feedback?
  13. LT1 Transplant problems
  14. AFR 210 vs AI Trickflow 215
  15. 1997 trans am 4l60e questions
  16. Lt1 feels sluggish? Plus newb intro
  17. Headers?
  18. Two questions"
  19. 1996 impala crank, no start
  20. LT1 with a 700R4
  21. Bad Lifter?
  22. Is this rodnock?
  23. Reuse Felpro 1074 Head Gaskets?
  24. possible bad opti?
  25. Lt1 sbc major differences??
  26. OptiSpark vac valves part#?
  27. ARP Rocker Studs
  28. Moroso 20185 oil pan
  29. Roller Rocker
  30. Please help me!!!!!!
  31. What windage tray for stock oil pan
  32. 96 SS LT4 tune
  33. Compression question
  34. 94 LT1 In 93 Car And Accel DFI
  35. No spark
  36. Tick adjustable master adjusting
  37. Porting intake holes out to 58mm
  38. Mystery Backfire when not Under Load
  39. Loss of power, overheating, starter not functioning.
  40. Hypertech Tuner
  41. Will this cam work?
  42. 96-97 Chips
  43. LT1 Tuning
  44. Overheating! ARGH!!
  45. Potential need/value
  46. Tools We Use
  47. Always Happens
  48. Over the radiator intake help
  49. Cam thoughts
  50. Steel fuel lines
  51. New LT World Record
  52. 94 Cadillac fleetwood lt1
  53. Lt1-TPI-tbi OBD1 tuning
  54. Cam and Injection issues.
  55. NEB Historic Flood - Grundy Worldwide, What a Disappointment
  56. End Journal size for Rear Main Seal measurement
  57. Who Makes The Best Forged Pieces For 383 vs. 396
  58. LT1 383 MS Goldbox 24X Conversion-Tuners
  59. Ignition Type
  60. 383 short block, should I get it?
  61. Rear Main Seal - Teflon or Rubber
  62. Total Suspension Overhaul List + Custom Mounted Power Steering Cooler (Ton of Pics)
  63. Torqhead conversion
  64. Wiring question
  65. Looking To Build Motor (Few Years), Let's Say Budget Wasn't An Issue..Wheel HP 500+
  66. Mail order tune suggestions
  67. Kinda Down About My Dyno Numbers
  68. Owner of a new 2018 silverado 6.2
  69. Replaced OptiSpark - Ran twice, now no start
  70. Sitting 17 yrs...
  71. Stalled and won't start
  72. Need help FI O-RINGS LEAK EVERYTIME!
  73. LT1 No Start
  74. LT4 carburetor Intake manifold
  75. I can not get the transmission removed
  76. True duels or stock single pipe into a flow master
  77. Injectors
  78. cylinder 2 and 4... Nothing... Pulled injector plugs
  79. Overheating Issue with Interesting Find
  80. Need Some Help, Made A Stupid Mistake
  81. What's the trick to removing the top two bellhousing bolts?
  82. 2019: Best LT1 Head Choices
  83. Head porting and 280xfi hp numbers on 383 lt1
  84. Im BACK!!! For good this time.
  85. Lt1 exhaust
  86. Brand new centerforce dual friction disk
  87. Sloppy Steering
  88. Who has swapped a LT1 into a (67-72) C10?
  89. Lt1/383 motor was flooding out on start up, now will no longer start
  90. What can I delete off an LT1 Intake ?
  91. Can anyone help my security light came on today in my 94 formula ?
  92. Leaky injectors
  93. Bolt size, help needed!
  94. Removing HVAC box from engine bay while keeping heat
  95. Lt1 to vortec 350 swap
  96. Long Tubes touching brake lines.
  97. Heads Up on Finding NOS and Hard To Find Parts
  98. Tuner in Southern Ontario, Canada
  99. Looking for Tuner for 95 lt1 mesa az
  100. 3/8 vs 7/16 rocker stud info
  101. Tuners for LT1
  102. My fun volvo 760 383 =D
  103. Is it possible to swap a ls1 ram air intake on lt1
  104. Is it possible to swap a ls1 ram air intake on lt1
  105. Individually Disabling Injectors?
  106. Flashing CEL, code P0301.
  107. Lt1 coming out
  108. Lt1 coming out
  109. Project basket case 94 Z28, racing wheel/ 3rd brake light/ body/ audio/and lots more!
  110. Did stock head gaskets have built-in pushrod guides?
  111. N/A 500 rwhp LT1 Set ups
  112. Best Intake Elbow (Removed Opti Vent Line and Did 24X)
  113. Twin Turbo Set Up
  114. Ignition switch and connector
  115. 94 Engine and PCM in 96 F-Body
  116. Best fuel pump inline
  117. Confused By Catch Can Setup
  118. Aluminum 'plugs' to mod LT-1 aluminum heads for gen 1 chevy's
  119. Mighty Mouse Catch Can Plus TorqHead 24X, Where to Move ICM / Coil
  120. 1994 roadmaster cranks and will not start. Is not the opti
  121. Narrow Band 02's- 1 wire versus 3 or 4 wire?
  122. Airbag arming sensor under center console?
  123. Wiring question for aftermarket harness
  124. Help me pass California smog, high NOx with a bolt on LT1
  125. Hesitating and sputtering lower RPM (datalog)
  126. LT1 with a 700R4
  127. Over 3 years later
  128. How am I supposed to remove these header bolts?
  129. Best Catch Can For LT1, Is It Worth It?
  130. LT1 injector upgrades
  131. Looking for a Stock Tune
  132. Pre 24X Conversion Car Ran Bad, Have Questions
  133. Stepper Motors for my cluster.
  134. LT1 PCM, Codes and Tuning For 24x
  135. Throttle response problem after k&n install
  136. PCM Tuning Question
  137. Lt1 Swap almost finished(closed loop issues)
  138. Anyone Know Where to Get This Fuel Pump Relay Clip
  139. Removed my valve covers and found....
  140. Harland sharp S1001 full roller rockers
  141. 24X with upgrades, need injector sizing help.
  142. LT1 ECM Connectors
  143. C5 Corvette Brake Conversion
  144. Verifying LT1 SS Hood Pics Inside
  145. Opinions on Speed Engineering headers for '97 TA?
  146. 24x LT1 not starting
  147. 1967 camaro brake rod
  148. 10 Bolt axle bearing and seals part numbers
  149. What kind of window switch should I buy for my zex nitrous kit
  150. Looking to ditch my stock tempature gauge.
  151. LT1 not starting!
  152. Intake manifold/ opti vacuum nipple
  153. Lt1 Motor Mount
  154. LT1 intermittent bucking, overheated converter
  155. LT1 Clutch Disengageent Issues! Please Help!
  156. Part Numbers for LH and RH LT1 Engine Cradle (Connects to Engine Mounts and K-Member)
  157. Crank position sensor location in 1996 Impala SS?
  158. Can or should I do anything else to a transmission when installing a new clutch?
  159. LT1 24x RH bank too rich, fuel plugs 6,8 and 7!
  160. Went TorqHead 24x Need Tuning Help (LT! PCM to GEN III LS!
  161. Swapping From 97 ASR/TCS to 97 Non ASR/TCS
  162. Trying to Find My Nemesis (96-97 SLP OEM SS Hood) Prefer 97 Model
  163. 1994 z28 Camaro lt1 choke out or trouble switching gears when flooring it
  164. Stripped header bolts
  165. Balancer Bolt question
  166. Plastic in oil pickup screen
  167. Gen V coils on 24x setup
  168. Oil Filter relocation and stand alone oil cooler install
  169. Need serious help with lt1 emissions!!!!!!
  170. Upgrade Balancer?
  171. Zex nitrous on a 95 z28
  172. Headers
  173. Junkyard Engine questions
  174. PN for the PS pump pulley 93-97 LT1?
  175. TorqHead/E85/UMI/Watts Link+more up for grabs!
  176. can any one tell me where starter relay is on 92 vet
  177. LT1 specific year model?
  178. 1997 Camaro digital odometer not working
  179. Cleaning fuel pressure regulator with injector cleaner spray?
  180. Swapping an LT1 into a box B-body
  181. Opinion on build.
  182. Cam/Valve Spring Replacement
  183. Best place for the MAF
  184. Fuel Pressure Question??? PLEASE HELP!!
  185. High idle hard shift
  186. Lt1 383 stroker
  187. 1996 Impala SS engine is not turning on?!
  188. Soft Clutch Pedal
  189. Best bang for buck coilovers for 93'-97' f body
  190. Is this a case of a bad optispark?
  191. Replaced Fuel Pump Relay (No Clip how to hold in place)?
  192. Anyone run E85 in a N/A LT1 or LT4? What was the gains? Is it possible?
  193. fixing a corrupted 1996 Impala SS OBD2 PCM because of bad programming
  194. Painless Harness, need ECM 16188051, what VIN?
  195. Harmonic Balancer Install Question (pin)
  196. Found Car With Same Interior (I Believe), Dealer Can't Decode
  197. How to Install VATS Bypass Module?
  198. Removing ASR / TCS Found Cables Will These Work (Pics Inside)?
  199. Cam Only Firehawk Question???????
  200. how many licenses I have in my JET tuning software?
  201. Air pump shut off valve?
  202. Cam specs help
  203. OEM part numbers for 1997 WS6 shocks and struts
  204. Please firebird 1994 3.4l VATS disarm
  205. Oil pan and valve cover oil leaks
  206. No rear breaks on my 96SS
  207. Lokar Dipstick & Splayed Caps
  208. Distributor gear vs camshaft ? LT1 opti-delete
  209. LT1 died while driving
  210. What does 400 wheel hp feel like in an F body
  211. Possible rod knock or something else..Pllease help me identify this!
  212. looking for a tuner for my 24x conversion having no luck
  213. Tuning software
  214. AC system
  215. More cubes for me :-)
  216. Efi throttle body Lt1
  217. Replacement Injectors for Stock LT1
  218. Hypertech Power Programmer 111 & 160 stat
  219. Fuel pressure
  220. Cooling fans not working
  221. OBD 1.5 Cable - can I use an OBD2 cable?
  222. LT1 383 Stroker Set Up
  223. Project car build looking for knowledge and input
  224. Valves Springs for 280XFI Cam LT1
  225. Low oil and raising engine temps at Idle
  226. Anyone have a lt4 head flow chart from the now defunct CNC Cylinder Heads in FL?
  227. Single plane intake Lt1 efi
  228. low rpm miss under load
  229. Anyone with first-run, LPP headers. Need help.
  230. Stumped... Fuel pump works out of car, but not in the tank?
  231. Valve springs - Boosted
  232. Smoke at wot
  233. ARP pressure plate bolt torque?
  234. LS1 traction control on LT1 rear HELP
  235. Long tube header gaskets
  236. Need opinions for LT1 Boosted Heads/Cam combo
  237. TNT nitrous install
  238. Conflicted on Car's Future (Mod or Sell?), Going Price?
  239. 1995 chevy camaro Z28 overheating
  240. Lt1/383 Vibration
  241. Bye Bye Opti Going TorqHead 24x Conversion
  242. 97 Z28, Removing TCS but Keeping ABS?
  243. Ditching the Opti with LS computer
  244. 97 Camaro Z28, Is The TH24x Conversion Worth It?
  245. removal of the black battery cable bolt of my1996 Impala SS
  246. 1996 Impala SS old style hood struts removal?
  247. Cowl plastic and weather stripping
  248. 1997 Z28 Need Tuning, Running Out of Options. Lost Hope
  249. CC503 M6 bin file.
  250. E85 on NA 383 lt1
