View Full Version : LT1-LT4 Modifications
- spark advance data logging
- LE2 Dyno Results.....
- 96+ coil conversion
- can an ignition coil be tested with out being bolted down??
- operating temp
- cheap Ltcc or Delteq
- cam duration
- o2's read low on scanmaster
- Battery Relocation Help (starts, then doesn't)
- Looking for LT1 MAF Coupler - Pic
- 383 stroker ?
- getting my engine rebuilt, what mods should I do while its apart?
- Polished Throttle Body
- What Engine would you get?
- ltcc no start
- I need car advice
- quick o2 sensor question
- 383 Stroker Kit
- Is anybody running a ProCharger on their 355 Set-up.
- Smells like chicken..
- Need some blinker assembly's front/rear
- question 'bout racing a c5 convertible
- how much power and torque should i be putting to the wheels
- New H/C 355 LE times: 11.37 @ 118.90
- Nitrous on stock LT1
- true duals
- Edelbrock LT1 intake pics
- it died any ideas
- polished, ported, coated heads
- Max safe LT1 CUI
- what do i need to tune my car
- Heaglight motor noise? PLEASE HELP!
- LT1 fuel pump installation trap door method
- Ever had your e-water pump rebuilt?
- Gunna have about $1300..what to buy
- small cam
- small cam
- Opti Question
- Aftermarket Overflow Tank
- manual fan and 160 thermo
- Need help from the Pro's
- electric problems
- video of the LT1 falcon
- C4 in car 1/4 mile video!
- Lt1 rebuild question
- cam on budget
- is there any reason my trap speed is so low
- Impala LT1 questions
- oil pressure drops to zero when i brake
- help me on choosing my mods
- Anybody using the 26120 Beehive w/ hydraulic rollers?
- Re-wiring the starter?
- Anyone Know this Dealer
- Front End Conversion
- re-routed plug wires??
- Engine shutoff at 100mph! LT1 experts help!
- Procharger/Supercharger
- Have you seen this hood!!!!!
- LT1 x pipe help!! People with experience
- Sensor HELP! *pics*
- 93 Z28
- cam question
- ALDL cable & laptop problems
- Cooling Fans
- LT1 Single Plane: Underhood Modifications
- Howdy, come see my car
- What do you think?
- Cowl Hoods
- another whatdo you think she"ll do thread
- LT1 and LS1 cooling fan question
- 4l60-e Trans pump seal
- What is cheaper?
- So i bought an OBD1 PCM....how do i tell if its for an M6 or A4?
- Mondblade
- 160°F thermostat
- gunnin' for 11's
- Which O2's to use?
- Situation...try and figure this one out
- Plug wire runners
- LT1 Solenoid Brackets
- tire recomendations
- Manifold bolts...
- little help please
- Need help finding LT1 WS6 part!
- Driver side temp sensor?
- Water pump
- True Duals video/sound clip FINALLY!
- Harlan shift light wiring...
- still no fix
- I just had too...
- i need help with shifter in 96 trans am
- Finally!!
- 96-97 LT1 Question
- stock thermostate temperature setting ?
- Turn One Pulley?
- cable for C.A.T.S.?
- lt4 springs stock hardware?
- choosing headers
- Edelbrock LT1 intake on ebay
- my lt4 build up. lots of pics
- Progress/ Things changing
- how much nitrous
- need some numbers (918s)
- Lingenfelter Valve springs any good?
- Steering shaft does not fit with headers. WTF!!!
- I know that this is a really stupid question
- Fuel Pump
- Need cam suggestions!
- pretty new to LT1 engines, SCHOOL ME!
- Header bolts....
- comp cams
- Reasonably priced mail order tune.
- OVERHEATING (and p%$$!n me off)
- O2 Sensors
- lt4 hot cam and heads kit F/S
- Waterpump bolts
- video of my 97ss at track last year
- ebay
- I got NOS
- MSD Opti Write Up and Comparison
- 383 SR or 383 HR FI
- Radiator woes- NEED HELP PLEASE!
- Where to get SBC heads converted?
- handheld tuner?
- looking for good headers
- 355 LE running...Got a few problems.
- Need help ASAP
- exhaust question
- Lt1 main cap order?
- Thinking about an LT1
- What is this? *PIX*
- 94 Check valve, what is this?
- gen1 head swap
- stock lt1 flywheel
- Anyone running a vacum pump?
- How long can you let a fresh motor sit after oil pump prime and still be safe
- 160 degree hypertech stat and jet fan switch?
- 30# injectors enough?
- Shop says i dont need to break it in...
- 370-400 hp.......
- stock hub on 3.75 crank
- LT1 forged connecting rods
- sea foam
- LT4 Knock mod&sensor???
- ScanmasterLT1
- Function of the downstream o2's?
- Dual exhaust question ?????????
- Question for you LT1 guys....
- best cam help
- help what temp are cooking fans to turn on
- need pictures of line lock install
- bigger injectors mean lower fuel press???
- I need advice
- Trans Am startup*vid*
- How much is this worth??
- High Flow Cats
- Exhaust tips to close rear bumper?
- How do you remove steering elbow?
- GM Hot Cam
- adjusting the tps??
- Canton Valve Covers!
- valve cover gaskets
- Ultra noob doing the TB bypass
- Sollid roller???
- Valve spring question
- Should I consider a colder plug/change of gap?
- 96 lt1 4L60E pcm part number
- Car shut off and won't start back up.
- header question???
- 4" exhaust tips
- How hard to rebuild motor?
- Help Please!
- Pepe Is Alive Again!!!
- Car Pops out the Intake in only 1 way, real little miss..
- 93 MAF possible?
- 1.6 rr and valve covers
- I need a used clutch set/slave 93-97
- whats the differance open or closed loop
- 93 lt1
- LE2 Bulid pics and sound clip!!!
- 1.6 Rockers question
- Two LT1 ram air questions!!
- Best place to order PS longtubes
- LE2 Head/GM-847 Idle Vid.
- Ls1 guy needs lt1 help
- I have a simple question
- track times and Dyno #'s
- 96Z28 Died on me..........HELP!
- no maf?
- 93 LT1 Questions (harness/chip content)
- STS on a 94 Z28 A4
- Reaching 1000 mile break in
- What does the TB bypass do?
- Replace Opti a good idea if working?
- 1.6 Roller Rockers
- LT-4 Springs?
- Newly Assembled LT1 w/Solid Roller cam
- Urethan Motor mounts
- How do you put tranny fluid in these cars?
- Trade my LS1 for your LT1?
- Jet Hot long tubes
- CAI install questions...
- Making sure i got the Rockers Parts list right?
- just installed h/c package runnuning rich
- Video Of My Car
- Max safe compression
- do you think this is a good price to sell my car for
- engine acting weird??
- how hard is a wiper motor install?
- Nitrous...Wet or Dry???
- My LT1 has a mind of its own?
- need help PLEASE
- power increase from ported tb
- Bolt pattern on stock lt1 flexplate
- What Intake?
- LT1 Head ?
- Pics from the other day...
- 97z cluster fit 96z???
- Nitrous questions?????????
- which pulley?
- dyno day 3-31-07!
- bbk headers help
- strut tower brace
- Smog Legal Cam?
- LT1 head gasket
- why not 1.5rr instead of 1.6 for gm847
- Headlight motor
- What fuel injectors to run?
- Nitrous tuned question--- LS1 race
- Street tires
- suncoast ram air hood F/S for lt1 trans am
- balancing a fidanza aluminum flywheel
- Help with build direction
- Rebuild the engine or not?
- Optispark
- Anyone have the LT1 motor mount schematic?
- 224/236 .538/.542 114 lsa???
- LE2 heads and cam finally installed!
- Seeking Tuner Around Austin,tx Area
- 90k mile shortblock + H/C and a 100 shot??
- need your opinion... on my 94 LT1
- i need help in ga
- New headers New problems
- Ran the caprice the other night
- Just went thru high water, car is running bad
- completeley and uttereley stumped!!
- water pump change
- new best time
- Problem with LE2 TA
- 96-97 ss
