View Full Version : LT1-LT4 Modifications
- Need Help!!!
- coil to opti wire
- Help please! I need computer files
- broken valve spring
- Emergency, help me please.
- NEW to LT1 scene and want to know what cam/ mods to go with.
- pinging noise when not warmed up
- Fuel Pump install ???
- 1st Thought on MSD Opti
- 12 bolt ABS question?
- head swap gaskets...
- School me about heads!
- Ordering a cam?
- idle hesitation
- 3.73 ?
- First time on the dyno and the last time for a while
- New to LT1 Group! Some questions if I may (Yes I read the stickied)
- ss dash plaque
- 97 Ws6 Into 93 T/a
- Rocker arm stud and head bolt questions
- exhaust question
- Best Header Gasket for LT1
- code 36 high resulotion
- having problems with the crankshaft pulley?
- Exhaust Poping
- Poll: If your Opti went, what would you do?
- LT1 forged?..
- 96 lt1 camaro tune need help!!
- Hey Guys Will This....
- ARP head bolts
- Catted 3" y-pipe for LT's?
- Tps
- what is this?
- What Cam for my rebuild?
- DTC P0300 Random Multiple Cylinder Misfire Detected
- Stage 8 Header Bolts for an LT1?
- Stage 1
- Who has the best price on ATI Super Dampers
- header Qs
- anyone w/ aeromotive FPR? & coolant sensor ?
- Ok, my car sucks right now.
- lean= Runing Hot? and some other Q's
- What Pistons for Eagle 383 Stroker Kit???
- fuel PSI problem
- LT1 Formy/Z28/TransAm Weight Differences?
- Drag Radials Slowwing Me Down??
- smog legal cam!
- F'in security light
- reliability suggestions?
- ignition problem pissing me off. HELP!
- Z06 Brakes
- AFR 195s
- procharger
- got my z28 DYNOED today!
- Changing plugs on the #2 and #8 cylinders
- Pinion seal replacement..Help!
- K-Frame replacement
- le2 track times
- LT1- How much power and track time will i gain
- Too good to be true..LT1's suck balls.
- Does anyone know if the new LS7 race lifter from SDPC will work on LTx engines????
- 383 N/A Plugs
- Heating problem fixed..
- 252.3 Rwhp
- Double roller guys come on in...
- Traction???
- car no start/ fuel related
- Help me with a few questions(ignition coil, and exhaust)
- Idle help
- SS Cold Air Intake
- need some flow numbers????
- need a pic of the plug for the alternator
- IntakeElbows.com
- how much does the LT1 weigh??
- LT1 !Wire Mod question
- How much wheel hp, will a k and n intake give an lt1
- Wheel
- Whats the Part #???
- Freshly painted 95Z
- exhaust question
- Engine Wiring Harness Question
- Cheapest place to buy a TF elbow?
- lt1 valve springs
- what is the best CAI for LT1
- opti install ? 94 opti to a 95 block? change cam gear?
- Port-Matching Heads and Intake
- How much $$$????
- Car dies at start up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
- VFN pic on car
- Lt1 Cam Bearings Help Please
- what kind of increase on power
- tuning a LT4 conversion....
- Were can I find a LT4 intake??
- Optispark question
- Some recent photos
- Pacesetter Ceramic Coating
- Want mild street/strip setup
- Actron Autoscanner
- Lt1 bucking
- HELP P1441 Powertrain Code
- FS: Comp Cams XE 224/230 cam (CC 503) and FREE 987 springs
- Full Exhaust Question
- LS1 Brake Conversion
- Fast Xfi?
- LT1 Alternator Question??
- Error codes
- did our cars come with vette servos
- LT1 main caps
- Help. Need links
- Wrapping Headers
- RR and springs
- LT1 pull from top
- Anybody running an aftermarket tranny cooler?
- cc306 or gm847
- Were To buy LT1 SS Hood?
- torque converter
- Keep Emissions?
- OBDII Data cable
- opti spark question
- My plan...need your advice
- oxygen sensors
- maf sensor throwing code, replaced,still not working?
- how do i know what gears i have
- Removing Cruise Control
- what header to get
- 355 guys post your dyno #s
- bolt-ons
- Your opinion on Trans. TH350 vs. TH400
- callin all magnaflow and dynomax videos
- airfoil
- uncoated headers
- starter question(what wire where)
- how much is it worth
- Goals, mid 12's
- 383 stroker guys... need help!
- lt1 to Ls1 conversion
- anyone have pictures of single turbo LT1 setups?
- another green 94
- SJM ABS Delete Kit
- 350/383 crank?
- tach not working after intake install?!
- Starting Suspension..
- new mod list, am I missing anything?
- Anybody know much about this 396 Package?
- What is it Worth
- leaking head studs
- finally 11s with budget 383
- car bogging?????
- Loudmouth Install
- electric waterpump
- Need Some Help with my LT1
- Our LT1s and colder weather!
- Different Intake Question. LT1 big dogs come in.
- is there a way to test a pcm to see if its fired??
- big problem, car shut off *help*
- Opinions on setup...
- Icm
- AC Removal Finished
- difference in F-body lt1 heads???
- car doesnt run, think the PCM is fried?
- LE2 vs. Portpros Stage II
- 1997 Trans Am WS.6
- Fuel Pump
- Car doesn't want to stay running
- Do you guys think this could work?
- Check out my 94 Camaro Z28!
- First impressions: GM847, stock bottom end, M6 car
- Need suggestions
- Difference between a z28 & SS
- Scanmaster locations
- Oceanside, CA?
- Horse Power?
- 383 Almost done
- Gears Question?
- Aftermarket intakes? Not LT4
- this is new....
- LT1 Died Today
- Fiberglass hood question...
- Gauge cluster bulb and socket questions, Pic
- Jet Fan Switch
- volt meter jumping around?
- 1'st day ever at the track!
- Ground Effects
- new guy
- AC System Complete Removal..
- check out my Z28
- B-Body guys, want your own section?
- Exhaust flange stud broke can i fix it?
- slp headers
- XFI cam and .026 head gasket... PTV issues?
- Patriot Gold spring kit TI retainers and Crane roller rockers don't get along
- Please see my LT4 springs in FS section
- HID foglights install for LT1 T/A's, WS6's, PICS
- 95' EGR block off plates
- broke valve spring
- SBC Heads
- Steering Disconnect - Help!!
- LT1 build
- Stuck 02 sensor...
- car runs really bad
- help running hot
- How many oxygen sensors does my single-cat '95 LT1 have?
- gas mileage
- Recent pics of the lt1!
- Quick Cam Q
- Super chargers
- Overheating
- First time out w/the 396, LE2/4 Setup
- Please Help!!
- ignition options, need help!
- Out with the old, in with the new :)
- Valve cover Help???
- installed new opti
- Need Help Fast!!!!!
- Slp Shorties
- would it be ok to put cam in 134k lt1?
- went to track today.
- lts ?
- Stock Timing Chain Play
- 96 z/28 worth, not running?
- Abs Question
- Any1 Running Oversized Radiators?
- Track time....
- What Header Bolts and Gaskets To Use?
- Valve springs too much??
- Prothane mount install?
- German Castrol Oil Question
- do you think a tune maybe threw these codes?
- My Elty is slow!?!
- LT1 HID H4 & H3 6000k daytime pics :)
- Secondary Air Injection...Where is this
- Size of our Heater hose??
- AC Delete
- Stock WS6...not for much longer
- MSD Pro-Billet users come in
- 1996 Caddilac Broughm LT1
- Local PD harassment
- HELP!! got a new cap and rotor, where do these O-RINGS go??
- Car keeps overheating
- motor mounts
- Just got 160* tstat and PCM tune
- cam trap speeds
- Bret Bruer
- Connector Adaptors for New Style Injectors
- Cat or no cat
- Setup
- which is better
- how do you clean the IAC and where is it
- what does IAC mean on an lt1
- kinda new...
