PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. LT1 96/97 Ram Air intake
  2. 396 t trim
  3. Help!! Car won't pass smog for the 3rd time
  4. New 383...working the bugs out
  5. Single 3" or 4"?
  6. cai flow diff+93 lt1 cars vs 94-up
  7. Quick easy valve cover question :)
  8. Long tubes and lowered
  9. Nitrous Help needed
  10. Oil pressure??
  11. Nitrous Advice Needed
  12. stock parts worth??
  13. Strut tower brace
  14. FRACK!!!! did i just kill the PCM?
  15. lt1 Cranks
  16. transmission mount
  17. should I get a new radiator?
  18. Is there a reverse lockout on an M6?
  19. How to determine if programmer tuning is installed? (or not)
  20. Random 3rd gen question
  21. trans am front bumper?
  22. Need help with 97 Z28
  23. how to figure out the cam specs
  24. Cam selection help
  25. SS strut brace
  26. which camaro headlights are h4351 and h4352 hi and lows
  27. headlight troubles
  28. LT1 stumbles after it gets warm
  29. how much to mill heads
  30. LT1 build help
  31. LT1 Build suggestions/help
  32. Biggest rear tire on stock wheel with stock wheel wells???
  33. Newly Built LT1
  34. idle
  35. Tuner Cat vs ???
  36. Northern Auto Parts
  37. Quick, Still Street Legal LT1's
  38. which ati dampener?
  39. cats tuning software question
  40. Traction Control/Cruise Control question.
  41. Vacuum pump lt1s
  42. '97 PCM issue
  43. Scorpion rockers problem
  44. Need new spark plug wires 97 Trans Am WS6
  45. tunercat - idle afr is pretty much set but have a few questions.
  46. Pulled the intake and found some milky oil
  47. Hows my cam parts list look?
  48. Shimmed hydraulic lifters??
  49. Can I hook wideband to speed sensor instead of a/c pressure sensor for datamaster?
  50. need lt1 help
  51. Oil pan gasket replacement
  52. @#@$^ optispark?
  53. unusual vibration
  54. Heads
  55. What to look for in a coil? milliamps? peak voltage?
  56. Gas Mileage
  57. 1993 camaro...buy it or not? List of issues...
  58. Head gasket part # please.
  59. 1994-1993 swap..need input
  60. Gettin Back In The Game - Cam Choice
  61. Pinging or Knocking
  62. TunerCat free trial help!
  63. lt1 oils
  64. cam lift question
  65. Break in oil and new motors, relevant for LT1 cars??
  66. LE 232/240 cam
  67. Thunderchicken w/ Advanced Induction 21deg CNC'd TFS Heads & HR Dyno Results
  68. Truck 12 Bolt
  69. 89 Camaro RS 173i v6 swap with a LT1 please help
  70. Ok I-R-Slow
  71. msd coil worth it
  72. School me on speed density tuning
  73. LQ4 manifold bolt thread size?
  74. Torque Arm Brackets on 9 Inch
  75. Exhaust
  76. New Headers
  77. Are Sway bars worth it??
  78. 9" For b body
  79. Hp goal!!! Around 450!!!
  80. Oil Filters with Long Tube Headers
  81. Line Loc Not Working
  82. Dipstick tube, LT1 same as LS1
  83. What next on my lt1
  84. Pacesetter install help?
  85. We need more "Write-Ups" for LTx stuff!
  86. Yet Another Opti thread....
  87. Fidanza flywheels worth it??
  88. Recommendations for cc503
  89. Intake gasket PN ?.. 4 Ported heads..
  90. Speed density my only option with my setup?
  91. car reving when pulled out of gear at stops
  92. deciding to buy a book or not
  93. 95 lt1 computer in 93
  94. getting too much fuel?
  95. Gears
  96. cowl hood vert?
  97. 93 z28 m6
  98. EGR block off plate, gasket or RTV???
  99. oil pump drive stub pic
  100. In need of a tune for lt1
  101. ECU's Knock Retard value PID?
  102. 11 second cam only lt1 HELP!!!
  103. Block Strength?
  104. Optispark options??
  105. Rear end/gearing question
  106. Do 3rd gen seats bolt into 4th gens?
  107. DataMaster/Tuning question
  108. How much is a 93 Red Z28 worth? 113k auto..
  109. Any good LT1 engine build threads?
  110. LT1 Intake Upgrade Question/Options...
  111. heater not working?
  112. Dyno Tune
  113. SBC 355 swap
  114. translator plus?? WTH is it and what does it do
  115. MSD Ignition box with boost control need help understanding
  116. Are LT1 starters universal?
  117. 94 Stock LT1: Nitrous & Cam Questions
  118. Heater A/C Delete, what all do I delete? with pics!
  119. Knocking around an idea, what you guys think?
  120. Comp cam 503
  121. LT1 Ticking noise w/ Video
  122. prob with surging.... at a dead end i need help
  123. ls1 muffler (exhaust) on lt1
  124. 1994 z28 auto i have no1st gear option y??
  125. MSD box.... do they work
  126. Lifters?
  127. Opti, Opti No Spark
  128. Lowered suspension for track?
  129. new parts new noise
  130. lt1 injector size?
  131. Head gaskets and bolts
  132. efi connection lt1 question.
  133. Springs
  134. Can I use a 140 psi fuel pump on a 93 z28?
  135. Missing seal at Ram Airbox WS6
  136. This the reason??????
  137. LT1 to LQ4
  138. Need help on taking off the fuel regalator
  139. need crank help asap
  140. need help
  141. MTI clear lid
  142. LT1 not starting right away
  143. Electric water pump
  144. cooling system questions... and a few others
  145. LSx accel 44lb injectors?
  146. no crank sensor signal
  147. How to figure out what I have?
  148. Water Pump Drive Install. How do you do it?
  149. Picked up the missing link to my bullet proof build...
  150. Any custom front bumper work done here?
  151. Lt1 fuel pump question!
  152. No start/No electrical at all issue (sort of emergency)
  153. terrible idle and stalling
  154. name that oil leak!
  155. Little Update
  156. 2 LT1 blocks... what to do?
  157. flow booster
  158. Lowering my camaro..
  159. LS Coil Placement - Toyota 4 Runner with LT1 EFI 24x Swap
  160. 96 t/a autometer guage install, lighting wire tap
  161. Need pictures of center console lid hinge fix.
  162. At wits end...need help
  163. Timing chain options...
  164. please help! 2 questions heater and tps
  165. magnaflow exhaust hanger??
  166. 94 formula issue
  167. lt4 cam swap; what springs?
  168. $100 to spend at the Ws6store, help me spend it!
  169. Tuning
  170. did ltx crash?
  171. Are f-bodies really that bad in the snow?
  172. =D Guy makes fun of LS1
  173. Header Gaskets
  174. Where to cut Harness from My 95 Bird for my Camaro Harness?
  175. This MSD unit is pretty solid. Let's see how it holds up.
  176. Steam Pipe thread chaser, What size
  177. Obd1 lt1
  178. Borla is quiet inside cab:)
  179. Help, my car is smoking
  180. Look out, it's another exhaust thread!
  181. Considering a 94 firebird LT1
  182. PCM freaks out when i let off the gas
  183. Help me decide
  184. Cryogenic Treatment
  185. spindle bolts
  186. lt1 finding used speed parts
  187. 94-97 cai on 93
  188. New car for me!!!!
  189. Value of a stock LT4 block
  190. My personal 24x efi wiring thread
  191. Can I determine rear gears by this...
  192. Throttle Body Help!
  193. Water pump Drive seal and shaft repair?
  194. power steering is squeaking
  195. Help with mild LT1 build!
  196. Total Seal Quick Seat
  197. Fabbed Valve Covers
  198. Looking for a muffler that sounds similar to Hooker
  199. Lt1 heads
  200. Exhaust banging pulling timing cut out???
  201. Looking for a new starter, who makes the best?
  202. 1994-97 lt1 smog pump testing
  203. Just Picked Up Nitrous Works TPI Kit 13015.....
  204. 355 LT1 First Start
  205. Finished up my single plane intake tonight!!
  206. Dying battery issue
  207. Which cylinder heads do you have, Stock or Other??
  208. LS1 steering shaft
  209. TPS adjustment
  210. How to remove clutch slave studs?????
  211. lt1 intake manifold
  212. vibration under dash
  213. o2 sensor harness question
  214. Speedo Way Off
  215. Can someone please school me on the Vats system
  216. 96 z28 ideas
  217. Bigger blower or add some spray?
  218. Pushrods help again lol
  219. Mcleod clutch questions
  220. Some mods,not happy what next?
  221. fuel pump issues
  222. If I didnt do the hotwire kit with my Walbro 255...
  223. 1996 camaro z28
  224. What Else?
  225. Next mod?
  226. Head question
  227. need help with muffler
  228. LT1 to LS1 Lid, what do I need?
  229. What do I do for tail pipes?
  230. My 95 Z28
  231. LT1 problem
  232. Ok im slow but please help me understand Shbox's picture
  233. Abs inop
  234. Looking for picture of rear diffusor.
  235. Front Control Arms
  236. AC delete with engine in car
  237. rear main replacement difficulty?
  238. Baer Brakes?
  239. Question
  240. Which MAP sensor and why? 383 LT4
  241. has any one ever put mini h1 in a 93 to 97 camaro
  242. Modifying header to clear transmission brace
  243. Cam setup
  244. how can i change governor
  245. Bought a 96 SS Camaro... What to do w/ 2k
  246. Is this a lifter tick?
  247. Oil Pump Drive stub question..
  248. Bunch of issues: Can't communicate with PCM, no spark, no injector pulse
  249. Cooking with Dave...
  250. Sponsors selling Injectors?
