PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 [232] 233 234 235
  1. Upgrade clutch,flywheel or Keep it???
  2. Summits ZZ4 Motor?
  3. AFR Heads on a 396
  4. LT-4 Knock module
  5. Advice on heads and cam in a 383!!!
  6. Cooling Problems
  7. Is anyone making reproduction lt5 blocks?
  8. MSD Questions
  9. What is needed to hang Borla?
  10. How much power do you think I'll get out of this?
  11. Whos the man or place to talk to for a 10 second NA LT1 6 speed
  12. LT1-4 Inch Mufflex Cat Back For Sale!!!
  13. Dynoed the Purple Car today....
  14. lt1 differences thru the years
  15. Anyone using a "Direct Hits Ignition"?
  16. Idler pulley - A/C delete
  17. Mirror image pistons
  18. What woudl you have done differently?
  19. 52mm Throttle Body for sale
  20. Removing ABS
  21. #7 won't fire
  22. Lt4 Heads Healp
  23. Building a LT1 for a turbo. HELP
  24. LT1 vs GT
  25. LT1 road racing ability
  26. FAST (EFI HELP) users inside please--->
  27. Good Clutch???? What Kind????
  28. Cam for 383?
  29. What next?
  30. NX Install pics for LT1
  31. LT1 Solid Roller Cams
  32. Windo motors
  33. MSD What exactly does it do?
  34. lt1 set ups
  35. LT1 valve springs
  36. Borla on LT1
  37. Good LT1 Dyno Results?? Good or so-so?
  38. buddy needs help
  39. Basic LT1 Specifications
  40. speed density to mass air conversion?
  41. What is the stock LT1 bottom end true HP limit??
  42. Fly cutting cast pistons???
  43. Ideas on a rebuild?
  44. 4.6L Mustang vs LT1 F-Body
  45. True Duals
  46. Throttle body coolant hose bypass: LT1??
  47. How to remove the Clutch Master Cylinder
  48. 97 Cluster swap?
  49. lt1 to lt4 425hp?
  50. Hooking up Tach to coil?
  51. Typical cost of a turbo setup?
  52. LT Headers install on an LT1???
  53. question on header purchase
  54. Clutch or Hydraulic?
  55. GMMG On LT-1?
  56. Dyno Results are in for Mild Budget 383
  57. Not quite tech, but snapped some shots today.
  58. Turbo on a stock LT1?
  59. need some info on strokers
  60. Help me make this car badass ...
  61. 1.6 rollers and LT4 Intake: Do Both or just RR
  62. Quick Question
  63. Forced Induction or a Stroker with nitrous?
  64. lt4 question
  65. 9C1 Caprice
  66. Ls1 injectors
  67. Trick Flow LT1 heads from summit???
  68. weight reduction tips for a vert?
  69. Ran like shit tonight...
  70. Corsa cat back
  71. Cracked Head or NOT
  72. Help on next mod?
  73. Fastest bolt-on lt1's?
  74. Can anyone answer this??
  75. Cam for my t/a
  76. Almost 10s on the first trip
  77. Swaping V6 for LT1???????
  78. FMS LT1 Results
  79. dyna tech ong tubes??
  80. Can we swap out our stock LT1 rocker arms for 7/16 studs without machining??
  81. Curious how This 94 Z will run....
  82. 96 T/a Ws-6
  83. 97 LT1/4L60E in a 94 Silverado..........
  84. Formula Stalling When Taking Left hand Turns
  85. Making a carburated LT1 fuel injected?
  86. Heads and Cam combo question
  87. AutoTap or LT1 Edit??
  88. LT1/LT4? and Heads?
  89. Just got a 96 Z-28! couple of questions
  90. i want a 450rwhp 383 lt1 can anyone give me a list of combos to do this..
  91. A&SM mono Blade Question
  92. 6.0 block in LT1 Fbody??
  93. Can't steer unless pressing gas to the floor, or when moving at road speed-20-25+mph
  94. Anyone using a sheetmetal intake on their LT1?
  95. LT4 Knock Module
  96. best LT's for LT1??
  97. HP numbers with CC305?
  98. C5 Intake Update pic
  99. How to get shorties to mate up with a catback??
  100. new 350... will it work?
  101. Oil leaking after doing IM Leak fix
  102. What can I expect with these mods.
  103. 9C1 Caprice LT1 Vs. Fbody LT1
  104. What vert for a bolt on LT1 car?
  105. HELP..LT1 high temp at idle, normal when driving, low oil pressure too at idle
  106. Pcm Programming
  107. 2 Stage Nitrous
  108. Lt1 Head Flow
  109. changing valve springs..need some help
  110. my brakes are not working right, would a big cam have something to do withe it
  111. what is the power band for a cc306 cam specs on stock bottom end lt1
  112. do i need tuning on my heads and cam lt1? it is running like crap.please Help!
  113. LT1 coil conversons kits?
  114. Just Joined
  115. 383 or paxton supercharger?
  116. If anyone has a car close to mine, I would love to have your LT1 Edit file.
  117. Pacesetter Headers
  118. Hitting 400rwhp in an LT1
  119. What are the biggest valves to fit LT1 heads??
  120. Where to find?
  121. OBD-II PCM Tuning??
  122. what it takes to run 10's
  123. 94 Formula cutout problems
  124. Midwest Converter?
  125. Engine swap tips needed
  126. Wester's computer programming
  127. Horsepower Engineerings LT1 Packages
  128. carbureted LT1
  129. EVO 8 need help
  130. Lift with 1.6RR
  131. All we really need is LS1 styled heads to match their power levels...
  132. New intake idea within
  133. coolant temp sensor
  134. Headers of 1.6 RR
  135. Weight of LT-5
  136. Got a ?
  137. long tube headers??
  138. what cars came with the lt-5?
  139. 1.7 rr with a cc305
  140. true duals
  141. Rearends
  142. LT4 hotcam?
  143. AFR Heads
  144. whats it worth....
  145. Cam
  146. Good Tire?
  147. how much with these mods help?
  148. Anyone using Dynatech race headers?
  149. Ignition Control Module
  150. Fuel pump install question!!!???
  151. What's the best ypipe for my new Jet Hot LT's? (for an LT1)
  152. 600 bones...
  153. LT1 cam gear
  154. Does anyone know the stock LT1 waterpump flow rate specs?
  155. Does anyone know the stock LT1 waterpump flow rate specs?
  156. Need LT5 education!
  157. Need LT5 education!
  158. Car not Starting
  159. LT1 Hooker LTs, ceramic coated - anyone have them?
  160. Clutch
  161. who makes a nice LT1 tall valve cover???
  162. A.I.R. question on manifolds
  163. Spark plug gap
  164. Dynaspark?
  165. NOS vs NX
  166. Any Ideas?
  167. Headers and Y-Pipe
  168. I hit 11 psi tonight
  169. how do i launch at 3k rpm ?? without spinning
  170. .bin file for a 95 6spd LT1
  171. New Dyno Numbers
  172. L31 Vortec 330.5 HP 381.1 TQ
  173. LT1 4.0 stroke?
  174. Dumb ??? But Need Help!!!
  175. what cam should I get?
  176. Re-ringing from underneath the car, is it possible???in our Lt1z?
  177. Carb Vrs Efi
  178. Lt1 Tunning
  179. MSD blaster coil pack
  180. Bore Tolerence(sp?)
  181. New numbers!!!!!!!!!
  182. Fuel Injectors for LT1
  183. LT1/Jeep Wrangler fuel rail issue
  184. Mabye this will work better?
  185. loud rattling
  186. LT1 Fuel Injectors.
  187. LT1 guru's...In here!!
  188. Underdrive pulleys
  189. 1.6 RR and CC 305 Cam
  190. need opinions on this setup
  191. Does this sound like a bad wire or plug?
  192. Fouled Plugs
  193. durability of lt-1 engine ?
  194. Lt1 Intakes
  195. Supercharger on LT1
  196. would this work
  197. What are T/a's going for....
  198. Cam question.
  199. Spark plug wire problems
  200. Cam Question
  201. Is upgrading from shorties to long tubes worth the money?
  202. DAMN SES Light
  203. horsepower question
  204. Board Name Changed
  205. 160 Degree Thermostat
  206. NON-LS1 454 Cam Help Please!!!!
  207. Ported Heads
  208. will the lt1 carb. fite under slp hood
  209. Lowering question
  210. CC306 Stock headed auto
  211. Looking for SFI approved HB...
  212. too much money invested
  213. Nocking sound
  214. Performance Question
  215. Moser 9" on LT1?
  216. EGR Valve Blockoff
  217. 2 vids of my LT1...
  218. LT1 Surging ... what do you guys think?
  219. Swapping my Vortech for N2O...
  220. need a website!!!!
  221. oppinions needed (NEW SETUP)
  222. Which heads and cam
  223. Can I Change The Lt1 Induction
  224. Car wont Start
  225. LT1's and turbo's
  226. LT4 Knock Module
  227. How high brake stall??
  228. Tunercat vs LTedit
  229. 97 SS compression Q
  230. Distributor
  231. 224/230 XE 112lsa Idle video
  232. whats needed for the intake manifold leak fix
  233. Granatelli MAF causing bad gas mileage
  234. BBK Shorties or Hooker LT's 96 trans am
  235. 96 T/a
  236. Suspension
  237. 355??
  238. This may be a dumbass questionbut..........
  239. 94 Z
  240. LT1 Swap into an 88 Camaro
  241. Power/Time guesses
  242. Help
  243. 320RWHP ok with my mods?
  244. times
  245. Tunercat?
  246. carburated motor swap...???
  247. My Harderst Bolt On To Get A Hold OF.....
  248. Coil Packs
  249. Computer problems
  250. problems at higher speeds
