PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 [181] 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Another exhaust question...
  2. Looking for ing box that will work up in the 800rwhp range
  3. Protecting the Opti from water
  4. Anyone have Comp Cams XFI 230 / 236, .576 / .570 113 LSA?
  5. P0420 Catalyst Below Efficiency... But which?
  6. Those w/ AFR 190,195,210 heads AND T&D Shaft rockers, inside!
  7. De-screening MAF, good or bad?
  8. True Duals by.... ME! - PIXXXX
  9. Compucar bottle in a bag kit
  10. Look at this..
  11. Aftermarket Hoods
  12. Coolant flush
  13. If you have a set of 1993 Fuel rails and lines come in!
  14. Help LT-1 bros, my starter will not spin the motor
  15. Lt1 on the rag...UE Rag Joint elim
  16. ? about heads
  17. Wtf Is Wrong With My Car
  18. Connecting Rods
  19. Header poll
  20. I need torque specs...
  21. idling rough after rain?
  22. knock problems?
  23. overheating
  24. Is this right??
  25. 93 lt1
  26. Wheel stud length
  27. ?????? what is this ????????
  28. 97 ws6 help
  29. WEIRD LT1 Problem, please help.
  30. Rings
  31. pulley/accessory setup ?
  32. Still working on a bad idle...
  33. Low Coolant Light??
  34. low RPM hesitation...
  35. Car Trouble
  36. Cam Swap
  37. Borla Adjustable plates
  38. collector bolt help please
  39. valve spring question
  40. Sqeeking coming from my car
  41. Rw Hp???????????
  42. trick flow
  43. Machine shop questions
  44. Extra Money What Should I Do? (94 Z28)
  45. New Dyno results!!!
  46. o2 sensor slow response
  47. Crank, and rod ID for LT-1 383???? & a few other questions.....
  48. Bout to burn my power steering Res
  49. Need help ASAP!! Thanks
  50. Absolutely craziest optispark question ever...
  51. Code help plz!!!
  52. Is my fuel pump bad?
  53. Fresh Engine Start Up Problem
  54. cam kit itstall problem
  55. looking for 500 rwhp N/A
  56. Problem
  57. Egr Frustration
  58. Putting Lt1 in my s10 have a few quesitons...
  59. new mustangs
  60. LT1 Plate Setup for MONOBLADE
  61. MAF Questions
  62. Popping on the big end around 5,000rpm...
  63. LT1 Start up help....
  64. Wtf?!?!?
  65. Rod and main bearing help!
  66. i'm stumped. HELP!
  67. 1st time to the track
  68. couple of questions
  69. ls1 engine swap
  70. CC306 cam and CC986 springs
  71. Timing chain for 94 z28?
  72. Cruise controll hits revlimiter!!!!! Help
  73. storker motor?
  74. Question on cams
  75. Lt-1 Dud.
  76. hard clunk on 1st to 2nd shift (auto)
  77. 355 installed...Wont start!!!
  78. changed to 2.0 valves,now have to replace springs
  79. I Need Tune
  80. off idle stutter 96 LT1
  81. Programer, Good or Bad?
  82. 96t/a Whats The Biggist Tire I Can Fit In Wheel Wells
  83. Blackbird stripes on LT1 WS6 hood???
  84. Sound clip of ghetto fab. exhaust...
  85. Stall Size
  86. 97 LT1 Open Loop
  87. Sensor
  88. BMR K-member??
  89. plug gap with msd igniton?
  90. parking lights
  91. People with SLP CAI, come in!
  92. Student Loan Fixing My Camaro Up =]
  93. Oh my F-ing god i cant take it anymore
  94. New Stocker (Part Two)
  95. key stuck in ignition
  96. Grinding in the Intake...no good
  97. Help me decide.
  98. New to LT1s
  99. head and stall question
  100. Write up on optispark?
  101. A/C doesnt work...never has....possibly compressor?
  102. Stripped bellhousing bolt A4 HELP !!!
  103. my vid
  104. Dog House intake manifold?
  105. Not an LT1 mod question, but I need help from an LT1 guy
  106. COil ? for my '96 Z!
  107. Help find safety equipment
  108. What #? will i get?!?!?!
  109. finnaly got an idle vid
  110. what gear is this
  111. What exactly is a beehive spring?
  112. 11.9s or faster, Cam only! Whos doing it?
  113. Ghetto fabulous hack job with Flows...
  114. LT1 fire a no go? help
  115. Is this what I need??
  116. Fog Lights Not Working
  117. need #s of a 97 lt1 main caps
  118. Turbo help needed!!!
  119. anyone running an m9??
  120. LT4 rockers on stock springs
  121. OBD1/OBD2 question
  122. How fast do you think i'll go in a 1/4
  123. Functional 97 SS hood on 97 Z28?
  124. LT1 Corvette fuel rail cover mod for Camaro!
  125. tuning problems
  126. tuning an lt1
  127. Datamaster Credits
  128. Cruise Control cable got some slack?
  129. header bolts/gaskets for pacesetter lts
  130. HELP!!!!!2 jolts when i reach maz torq
  131. Going a different route,
  132. Strange claims check it out
  133. LS1 Pacesetter Y fit an LT1?
  134. reset odometer
  135. Big tune up
  136. Boost + XFI Cam?
  137. Need a little Help
  138. Need a little help
  139. what kinda lifters???
  140. Why does my heat smell like gas...
  141. Used Converter ??
  142. can a bad o2 extension cause bad mpg
  143. opti plug not going in
  144. Questions on LT4
  145. Help!!!
  146. reverse cooling?
  147. injector identification
  148. Got the new stuff in..
  149. finallly got my longtubes (pics)
  150. Car Just Dieing?
  151. stock build and a mod build
  152. 300 dollars burning a hole in my hand
  153. need help with exhaust
  154. Lt1 Camaro headers on a caprice??
  155. optispark
  156. bigger injectors
  157. fuel level sender
  158. Transmission problem?
  159. NO oil pressure, please help
  160. 12's with a LT1
  161. heating up on the highway
  162. lt4 hotcam
  163. NEW AFR heads in new Hot Rod, 615CHP!!
  164. Any LT1s looking to trade?
  165. Changing throttle body?
  166. First time at the track
  167. 97 T/A Cluster in a 95 T/A
  168. removing the front struts
  169. Fuel Pump Instructions?????
  170. New Cam Help Please!!!!
  171. Busted a oil pan bolts...
  172. Ram Air or CAI ?
  173. Spark Plugs
  174. Which do you prefer?
  175. TH400 speedo/pcm question
  176. Fuel Pump Install soon...quick ?
  177. Any way to adjust shift points on a 700R4?
  178. hey I have a simple quick question about the LT1
  179. Dyno tune
  180. Computer Problems
  181. Any numbers for edelbrocks lt1 manifold yet?
  182. tailshaft seal?
  183. How your supposed todo your PCV system
  184. hypercrap
  185. idle problem/low end miss
  186. M6 guys with nitrous
  187. CC306 cam and springs
  188. Needed: A picture of the rear of the LT1, with no bell housing.
  189. I need help with the timing chain cover
  190. CA People
  191. New H/C LT1 DYNO numbers!!
  192. Which PCMs are interchangable???
  193. Opinions about comp cams 986 springs please!
  194. Need some help with LT4
  195. I need help!!!
  196. Need Recommendation For A Lt1 6-speed
  197. Any1 buy just the MSD CAP/ROTOR
  198. shift light questions
  199. i think i hurt my motor!!!
  200. Stock oil pump shaft?
  201. Trick Flow heads??
  202. What in the bottom end of the LT1 makes it not want to spin high?
  203. Any EGR delete guids?
  204. new engine break in
  205. LT1 belt tensioner
  206. HELP!!....with an LT1 motor
  207. Will a t/a speedo fit a camaro?
  208. leaky fuel rail
  209. coolant crossover pipe on backorder? wtf
  210. Anybody running an XFI cam with less than 113 LCA?
  211. 12499225 lifters and LT1
  212. Oil pan gasket
  213. New Bests for the ol LT1 That Could
  214. Good gains
  215. hot cam kit numbers
  216. will this fit??
  217. cam decisions
  218. CC306 guys what is your idle set at? Video inside.
  219. injector removal
  220. Was thinking about deleting AC?
  221. Can someone check my tune?
  222. Opinions on this cam
  223. Is this normal?
  224. water pump replacement
  225. lt1 valve covers
  226. gauge problems
  227. Largest tire on the ws6 wheel?
  228. yes i'm in idoit, need help install opti
  229. What's it worth...
  230. Exhaust with no rasp?
  231. anyone got a Lt1 Timng cover laying around?
  232. hub,dampener,balancing,keyed?
  233. intake
  234. what do you guys think of this cam
  235. car wont run right
  236. check out my vid..
  237. Horsepower differences.. GM847 vs. hotccam
  238. o yea new opti
  239. Weird exhaust problem
  240. bent pushrod/broken valvespring..need help?
  241. rims
  242. how rare is my car?
  243. NEW WS6 HOOD Need opinions/help!!!
  244. water pump
  245. can u tell me wat kind of cam this is? video inside
  246. flashing an LT1 with a vortech
  247. Short Block
  248. next possible upgrades
  249. Need input on 383/396 and cam selection
  250. Which valve springs?
