PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. 8" vs. 9.5" Converter for TH400
  2. Was looking for a name of this mod to a lt1 air filter help??
  3. Murdered out Formula.... Time for a change?
  4. Stall w/ 4.10's?
  5. Weird starting ritual. Fuel pump?
  6. Car back from the mechanic - STILL won't shift while started
  7. Smells RICH but only sitting at 42psi???? Any thoughts
  8. Clutch fork broke
  9. cranks over but wont fire up
  10. exhaust help
  11. 86 s10 blazer lt1 mod options
  12. 3.73 or 4.10s
  13. Mods for a 93 Z28
  14. what kind of trans fluid for 4l60e in my 94
  15. 383 stroker
  16. 383 stroker
  17. Whats your custom true duals setup like?
  18. cc306 install need help
  19. LT1 camaro HID's possible?
  20. '93 !egr/air checklist
  21. Hooker Aerochamber users come in.
  22. egr delete
  23. Precision industries converters
  24. Im looking to install a Hurricane intake
  25. Weird hidden switch?
  26. PICS of you guys running single plane setups
  27. Flange to Centerbolt Valve Covers adapters
  28. Motor kicks back with NGK xi55 plugs
  29. Decisions Decisions
  30. Cars New Year Resolution is to lose weight...Pics added...
  31. finally a short vid of my of my rebuild !!!
  32. 60 Times on Stock stall and suspension
  33. Merry Christmas!! What LT1 parts is Santa bringing everyone??
  34. differences between f-body and Impala LT1's?
  35. nitrous outlet
  36. 388, lt4 intake, AFR 210 heads. A nasty build on the way
  37. Got another miss
  38. Oil Pan for Road Course Application
  39. Rim size and backspacing
  40. Video Of True Duals on stock LT1
  41. LPP true duals
  42. Crank what should he do
  43. Exhaust leak egr?
  44. Mac mid length header install
  45. BAD Missfire....
  46. Loose/Hard steering wheel problems
  47. What all can cause no spark?
  48. Timing cover gasket -.-
  49. Need Some Help
  50. Volant intake system on an Lt1???
  51. So tired of opti, sell car or fix.
  52. Exhaust setup what u guys reccomend?
  53. Installing Valve Spring with heads on the car
  54. bad mass airflow sensor?
  55. Obd 2 to obd 1 ????
  56. Forgot something on cam swap
  57. Intake questions
  58. Fuel Rail Leaking.... HELP!!!
  59. How much should this cost?
  60. Clogged Exhaust? Knock Sensor?
  61. question about racing gas
  62. Stock LT1, P0336 code, flashing SES light
  63. Found out the sad truth about my car!!!
  64. Pypes Universal Xpipe
  65. More power with same camshaft?
  66. Odd "headers" on ebay.
  67. it's a long shot....but help finding an oil leak on my 94 z28
  68. next thing to do for my z28
  69. dumb question probably... about egr
  70. Help me choose my next mod?
  71. LT1 bolt sizes....
  72. LS1 lid IAT sensor and OPTI vent location
  73. What piston rings should I go with?
  74. cheep bolt ons
  75. Winter build.....sorta.
  76. AI cam and the GMMG is installed!
  77. Anyone using NGK TR55-IX Iridium Spark Plugs with CR over 11:1?
  78. Exhaust!
  79. Exhaust Set up, Do i have everything?
  80. Rich at idle
  81. SRS Codes?
  82. do iron block LS engines require a oil cooler
  83. Where to buy????
  84. I am thinking of putting a 2001 Trans Am rearend in my 1993 Firebird. Will it work.
  85. Help design my exhaust
  86. Bad Opti?
  87. Lt1-lt4 conversion ?????
  88. electric out after the cat
  89. weird tapping sound
  90. Deleting power steering
  91. Make sure your hood closed before getting on the highway...
  92. Pretend I'm NOT asking about a CAI with H/C/I in my sig...lol
  93. Need Ramair intake setup for 97 firebird!
  94. TY Ed Wright
  95. Deleting smog pump!!!!
  96. Might be gettin a Yellow '93 transam
  97. What Size DRs?
  98. 383 with Frozen water in oil pan. Suggestions?????
  99. How will a 2400 stall run on a lt1 with bolt ons?
  100. Numbers help please!
  101. Did my LS1 lid
  102. Last runs of the season
  103. Help! Broken elbow cause these???
  104. Sign of failing electric water pump?
  105. engine swap
  106. TH400 Swap
  107. Age old Question....
  108. Blew a Headgasket.... NEED OPINIONS
  109. fuel relay
  110. Good Bye LT1's
  111. Crank hub
  112. no spark?
  113. odd grinding noise when i start?
  114. Californians, did you know about these emission standards??
  115. Help!! Coolant Temp Guage Redlined 360+
  116. LT1 swap worth the effort?
  117. LT1 corvette vs camaro
  118. Any Idea how long to have the #3 spark plug wire to go over the valve cover
  119. Stand alone fuel set up
  120. Swap the hotcam for something else
  121. Deleting emissions stuff. Help!!!
  122. Help with Cam????
  123. uprgraded suspension question
  124. how would this work out?
  125. Iron or aluminum heads?
  126. Head gasket and Timing Set
  127. EWP and 160* ppl come in
  128. Your little tips and tricks?
  129. jegs screwed me over? or no
  130. squeaking problems?
  131. 98-02 front clip
  132. LT1 Swap
  133. Cam with great drivability
  134. What happens if the back of the intake mani isn't properly sealed?
  135. finally found the oil leak!!
  136. ARP Ultra torque Lube torque head studs to 80ft lbs?
  137. Need Dynatech LT Collector Part #!!
  138. What happened to the For Sale section?
  139. vacuum ports on the throttle body
  140. LT1's and Nitrous
  141. new opti didnt fix misfire... whats next?
  142. Could an exhaust leak cause a P0300 code at idle?
  143. Gains from CAI to Lid?
  144. what kind of oil should i use
  145. What would you pay for a forged 383??
  146. heater issue
  147. Aftermarket Fog Lights
  148. Possible Opti problems.
  149. WTF! Stupid bov! Or stupid me?
  150. smog and other bullshit
  151. Will i see gains with this setup?
  152. Guage Cluster???
  153. Possible Head Gasket
  154. opinions on a cam
  155. build ???
  156. Damn exhaust leaks
  157. Exhaust ?????????????
  158. how big of a block?
  159. h/c lt1 low fuel pressure?
  160. So, I need help..
  161. Cam Install Questions...
  162. pursuade me, to buy this car
  163. Have to remove heads, so can I reuse new head gaskets after I just torqued them down
  164. (need help!) Anyone here use Proscan?
  165. Paint???
  166. Who owns the Black 4th Gen Z28 on Cape Cod?
  167. Steam pipe/flow question
  168. fuel line disconnect
  169. Starting issues
  170. Crap, should I be worried that heads may leak.
  171. Are motive gears GM 3.73 Ratio.....good??????
  172. 10.82 @ 124.25!!!!!! It's about DAMN time.
  173. magnaflow cat back.......good or bad???
  174. Change Of Plans
  175. 6.0 lt1?
  176. need help with oil pressure gauge
  177. VSS wire spliced to wheel sensor, what numbers needed for accurate speedometer?
  178. 383 oil pan/pump suggestions
  179. I need some help deciding
  180. Moroso cold air with K&N?
  181. Scanning a 94 lt1 for DTC etc
  182. Grant GT adapter question
  183. lightweight flywheel recommendation
  184. Pass time
  185. Question About headers
  186. oops! over reved!
  187. Radiator Problems....someone shed some light on this for me
  188. Anyone need a set of coated pacesetter longtubes?
  189. 3" Under the axle duals
  190. 93 Z vacuum help???
  191. 93 vats module location
  192. OMG RPM Stage 5 T56
  193. Valve cover wont clear RR
  194. What # Injectors?
  195. which cam would this be?
  196. NOS Timing Retard...Mallory or MSD...whats the Difference?
  197. code 18 on 95 T/A??
  198. Daily Driver Camshaft: Hotcam vs XE502
  199. How much can you spray on a stock LT1 and how much gain.
  200. What brand is mostly used?
  201. a/c delete question
  202. Strange issue with my car?
  203. what bulb # for HIDs
  204. Afr vs ai&le
  205. You have got to be kidding me.....
  206. What to do?
  207. Wiring problems..
  208. Anybody looking for a 97SS with 19k??
  209. LT1 Fuel Line Relocation
  210. Name this noise!
  211. Throwing Code 26
  212. NITROUS advise
  213. Free Scanning vs Code Scanner?
  214. LT1 PCM gurus?
  215. Safety Testers in STL?
  216. Track outing: 1/8th mile bolt on LT1, times seem fair?
  217. Give me an idea of...
  218. Why hasn't somebody done SB2 heads?
  219. 4L60E - Trans Preform Button
  220. Thoughts On New 383 Combination
  221. Using non-arp moly lube for head studs?
  222. LE2 Vs LE1
  223. TCC not locking
  224. miss fire troubles
  225. clutch master cylinder????
  226. 1994 camaro z28 idle clip
  227. Another LT1 cam swap
  228. 7/16-20x6 (full thread)
  229. T-56 max hp
  230. O2 sensor hole/bung size????
  231. Looking for my long lost love my 1997 Red LT1 SS Camaro.
  232. LS1 Throttle body on a LT1?
  233. True Duals: 2.5" TOTL
  234. LT1's were underrated by GM???
  235. 94 lt1 ported heads/cam bolt on's tune and no power!! HELP
  236. How do I prevent water from coming in while parked with a aftermarket Ram Air hood.
  237. tuning in florida
  238. 383 ?
  239. Trans Am Headlight Mod
  240. Heads/Cam Impala goes 10's on Motor
  241. SS replacement filter?
  242. spark, fuel, compression still wont start
  243. New 95 LT1 z28, need some help
  244. Project "Fix that damn 5th/6th gear high speed vibration".
  245. Maf
  246. DLC Issues.
  247. Piston R&R cost?
  248. Radiator Install
  249. Considering Different Piston Rings
  250. Trading a 96 Formula for a 96 formula? opinions?
