View Full Version : LT1-LT4 Modifications
- Help me with these numbers guys.
- Window tint
- orings for the back of the heads
- converter tune question
- New lt1 alt. Relocation kit
- fuel pressure
- Porting
- 96 ta fuel question
- Check engine light
- A/C Delete, what size belt?
- what shocks and struts to get
- whats nomal compression numbers?
- Auto Tranny Rev Limiter?
- Ok, lt1 lovers i need help!
- Bad Oil leak, need help!
- What is factory Idle rpm on lt1 ?
- ls1 alternator on a lt1
- Cam Driveability question
- BMR kmember anyone experience this problem?
- lt1 motor and t56 FOR SALE
- Why are we still holding on to these dinosaurs?
- Excessive gas tank sweating
- LT1 on engine dyno
- Electric Water pump install
- Fel-Pro Z1094 Head Gaskets
- Idle/cutting out problem.
- Yet another new best
- Opti spark
- Oil dip stick tube holder ?
- New Persnal Best! Going Underwear Shopping Tomorrow!
- Got my 8 sec pass! 8.97 @ 151.05 mph
- Broke down yesterday.. need help
- D1SC , bottom end help
- What fuel pump
- wtf i need help
- I think my passenger side header is hitting some thing
- power steering pump go out?
- is this okay? i need to know!!
- anything else I'd need? (cam install/gaskets)
- Do greg welds fit on ls1 front brakes
- recent info about LPP headers?
- where can i get a good cheap opti?
- questions on lyod elliot packages
- LT1 Carb conversion questions...
- what do you guys think of these ???
- This what happent when you dont check the weather before wash your car.
- Do I need to Balance my short block....
- what needed for 50#ers
- idling problem
- has anyone heard of this head porter
- Help! Sputtering almost stalls?
- LT1 sludge, suggestions?
- stock short block 350 vs. 383???
- Convince me, please
- Loss of power
- Where can i find one of these in Texas?
- Open headers?
- Steering wheel removal ?
- Stock Bottom Ends?
- need some opinions
- Help 383 stroker or 396 stroker
- LT1 engine harness????
- Exhaust Questions.
- Security light lockout?
- what would it take?
- tci 3500 super street fighter stall + cam question
- What method to adjust rockers?
- head gasket blues...
- should i rebuild the engine?
- Does anyone make o2 simulators for LT1's?
- I need a little imput here folks...
- Evap Elbow
- Adv. auto Fuuuuuukkkkk uuuuuu...wifes starter went out
- trying out the wifes new camera...lt1 vette
- Who still sells ultra z or similar hoods?
- Mystery knocking sound only while accelerating
- I may be getting rid of the trans am :(
- darnit!! Lt1
- Best place to buy FAST XFI
- New Paint,Suspen,Trans,Rearend,Wire Mod & Engine Clean Up will be going to SPEEDINC.
- Muffler Question
- lt1 build questions
- PCM Failures
- driver side window fell!!!
- Break in new motor with new stall
- Super slow lt1 14.75 e.t
- 383 LT1 Engine bay pictures
- how can i make my lt1 faster with out breaking the bank
- 383 almost done - How to properly break it in?
- Motor or driveline problem???
- PCM not reading? how can i fix this?
- speed pro's vs Mahle
- Received this email for LT1 parts
- how much power do headers add?
- Finally figured out the "squeek!"
- I believe my opti is dying
- 10 Year Old Crate Motor. What Inspections Are Needed?
- Pop/backfire from pass side exhaust...new engine
- Rubber hose busted now car won't start!
- cam dowel pin broke!!
- misfire when warm
- depressing...
- quick question about roller rockers
- Question about Borla Exhaust
- Grounded out positive terminal, now zero power???
- lt1 motor woes
- tune?
- Idle too low?
- 94 lt1 running rought HELP!!
- new sneakers on the slomaro ,,before and after pics
- need help on my 95 formula
- Stepped vs Full 1 7/8 headers for my engine?
- 94 lt1 help plz
- N20 tuning help?
- Aftermarket HVAC Setup?
- Got my trick flows... uhh
- opti question about ordering
- question about checking oil psi gauge
- LT1 oil level sensor in pan gasket/o-ring part number?
- got a Random shutoff problem
- Anyone here have a tune by Solomon?
- holley blue pump/reg?
- might be getting rid of the lt1
- Multiple problems after install, coolant leak, stumbling, possibly water in oil...
- Engine noise...please help
- What to change when putting 93 engine in 95 chassis
- Knock sensor byspass switch.
- Installing headers
- timing chain and oil pump
- Two pictures from yesterday..
- low speed stumble issues
- how the F do i get this oil pan back on
- madz28 tune
- Engine vacuum question
- Brakes suck. Its the camshaft robbing vacuum.
- Question!!!!
- Fan troubles
- cam/rebuilt lt1 or crate engine?
- Someone with a stock cammed LT1 and a Scanmaster
- Timing cover questions
- Cleaning injectors
- no start possible wiring. someone help
- Idle adjustment after ls1 lid
- Vented Gas Cap
- Reasonable lightweight flywheel? Just order new clutch
- Anyone ever use these drag wheels
- pcv valve elbow???
- Largest aftermarket heads that still keep the LT1 intake?
- Which way is up for pushrods???
- Bare heads - Trickflow
- bleeder screw broke.
- Delteq ignition users, what wires etc are you using/recommend
- Still a little un easy when i come to a redlight.
- Heads for 97 350
- NGK TR55GP good spark plug for LT1?
- Problem getting my motor onto a BMR k-member
- light up dash!?
- Please share your tips for checking out a 95 LT1 Z28
- LT1 tuner in south east Michigan ??
- crank hub bolt?
- Have an LS1 car and a LT1 car, how hard is it to swap brakes from each other?
- need help please havin problems again
- Speed Density High-Flow Intake Setup
- Header bolts
- Is it true E85 octane is not 105, it is 94-96(R+M)/2?
- are bassani true duals worth the money
- quick overheating ?
- When to replace O2 sensors.
- Changing the belt - Question(s)
- 160 thermostat question/discussion
- Serious LT1 guys... input please!
- hello cc306 help
- vacuum leak
- pickup tube fell off now i have a question
- ***BLS 93-97 Firebird True Bi-Xenon Projector Retrofit GP #2***
- check engine
- Extremely High Fuel Pressure
- fuel lines
- rear end gears broken affecting my mph
- need some advice
- 97 WS6 runs rich and rough
- Thinking of going back to stock...
- Possible to put opti in wrong?
- low voltage/idle.. & hesitates
- Destroyed heater core cover!
- coolant crossover passenger leak
- guide boss clearance?
- some bolt on help plz for a newbie plz?
- bench dyno results- ai,le,afr w/ gm846(7),cc503,280xfi
- Cat on 97 TA
- exhaust question
- Error Code 18 What Is it ?? How Do I Fix It ??
- When deleting air
- What part is this
- What kinda of power?
- Starting issue
- " 2010 UPDATE " What oil filter on your LT1 now ?
- Tuning
- Valvetrain help?
- Powermaster starters
- What to expect from the cc503...
- m.s.d coils
- question about electrical
- svo injector question
- vaccum test
- Cant pick, spec 3/4 or ram pwr HD??
- PLEASE HELP!! z28 falling on its face!
- head gaskets/milling heads
- Aftermarket LT1 Fuel rails
- Clutch Problem
- LSx coil packs VS MSD/6AL Optispark combo
- new!here and 2 lt1's
- Looking to rebuild my LT1 Bottom END Any Advice
- Gear Install kit?
- My valve covers fix
- Forward headers for turbo
- ABS Inop
- stall question
- Finally recieved My McLeod Twin disc set up. Have a Question before Install.
- flywheel balanced
- Finely. My new motor is coming together
- part number for auto shifter cable
- my 95 lt-1 camaro is busting my balls
- ls maf on lt?
- 95 lt1 weird issue!!!
- 383 w/ shorty headers?
- help
- What are LT4 heads and intake worth?
- Head Discussion 396 LT1
- Glasstek 4" pin on owners come in!
- Made a custom Air Dam
- Header too close to AC line?
- any thing I can buy at part store to prevent rust ?
- Car feel loosing power.
- help, where can I get a heavy duty 5 under timing chain/timing chain set
- help!!! gettin tired of this problem
- Tunercat question
- Rotating assembly question...
- 94 body, 97 lt1 engine
- Need advice please!!!
- Cooling ?
- quest for 12.99
- Sunken Gas Pedal?
- LT1 + Muncie 4spd
- Radiator question. Car almost running!
- xfi 280 cam on stock heads?
- flew to phoenix sunday and bought...
- 383 Stroker question
- decisions and knowledge are lacking
- 383 lt1 + spray limits
