PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. bad idea
  2. Spark plug's
  3. LT1 turns over, but doesn't sound like it's cranking
  4. Need help locating some parts pls!
  5. Fuel pump relay
  6. urgent I need this part number please!!
  7. Buzz
  8. easiest way to take off balancer without using puller?
  9. Ls7 Lifters
  10. 4L60E to T400 swap
  11. Another LT4 Hotcam Question :D
  12. where to get optispark harness connector?
  13. New C6 Wheels on My 94 Camaro SS
  14. car spontaneously die's..any suggestions??
  15. new oil pressure sending unit =
  16. coolant disappearing?
  17. any need for cutouts still?
  18. I've been called out...
  19. Compressor
  20. Cooling fan CFM
  21. im really sorry for the newb question...
  22. Cams!!
  23. LT'x Showdown or test & tune track rental with some heads up racing
  24. low vacuum
  25. One Wheel Peel?
  26. got 2 ?s
  27. Testing waters! Strange S60 for sale.
  28. What is this ticking noise?
  29. What The HELL Is Wrong With My Car!?! I Need Help Severely
  30. What next????
  31. I finally ran my Car
  32. Do i really need to rebuild my engine?
  33. lt1 intake manifold
  34. True dual h-pipe
  35. Motor out the top
  36. Car stalled what the hell
  37. mail order tune
  38. Rebuild a 4l60e or Buy?
  39. Rocker Question
  40. New car--figuring some things out
  41. ohhh please not again (head gasket)
  42. RTV for intake manifold?
  43. LT1 Headgasket?Opti? HELP
  44. Took some pics of the 95 formula ;)
  45. akron hp
  46. Two short in-car videos of my 355 w/ 847 cam + true duals
  47. Advanced Induction 185cc/190cc pkgs
  48. Starter ?
  49. cooling problems
  50. Sheet Metal Intakes
  51. No spark and no fuel on first startup... wtf
  52. Can the Crank position sensor cuz stalling?
  53. few questions after pacesetter lt install
  54. just got back from my first car show
  55. timing chain///opti???
  56. mysterious leak
  57. timing chain///opti???
  58. AC Compressor "delete" bypass pulley
  59. HC too high, RX7 LT1, need to fix ASAP
  60. What is this problem??????
  61. fuel tank skid plate???
  62. Fuel Issue?
  63. Just finished P.S LT header install, couple Q's
  64. stock lt1 nitrus
  65. keep hitting the rev limiter shifting into 4th? wth?..
  66. is it the opti
  67. Goals for my car, reasonable?
  68. battery relocation?
  69. went to the track friday
  70. lt1 dual fogger 300shot
  71. how important is matching piston to rings Brand names
  72. 97 WS6 with a stalling problem
  73. Oil pump distributor gear
  74. low fuel pressure, cant figure out why
  75. OBDI to OBDII Swap
  76. t56
  77. Any differences between the 96 & 97 Engine harness/PCM
  78. Motor Rebuild for more RPM
  79. The Cam Is Picked For The 383
  80. 3k lbs. Street car. How would you do it?
  81. 97 Camaro Ss Motor Build
  82. LTCC install ?
  83. Vaccum Hose
  84. What's the best Flywheel for hight HP?
  85. well i found my exhaust leak...
  86. Strange headlight issue
  87. Rod swap/install writeup?
  88. Dynaspark vs MSD Opti... which one?
  89. MR2 vs LT1
  90. Help with pushrod lengths
  91. Stock 10bolt with 4.10s T-56???
  92. It Runs
  93. Building an Lt1?
  94. Question about ceramic coated headers?
  95. gap for TR-6s
  96. smell coolant & low coolant light ON
  97. stock rods?
  98. weird problem? any help?
  99. Injectors for a 396
  100. new opti $?
  101. Hotcam Springs?
  102. So heres my bolton plans for the shoot out
  103. NE1 know where to get stock throttle cable for 97 LT1???
  104. more firebird headlight problems
  105. antifreeze agian dam it and low rpm idle
  106. flex plate torque???
  107. crank bearing help do i need my pistons reconditioned and rods
  108. 30# Injectors
  109. Coil?
  110. LTx Shoot out in GMHTP!
  111. Is the CC306 holding me back?
  112. Port the stocks or buy new????
  113. stall?
  114. voltage problem
  115. Please Help!!!!!
  116. 96 WS6 cut hole in front bumper/ hp estimate
  117. Car Starts, but then stalls STRANGE
  118. lt1 to ls1 swap
  119. True Duals WTF!!!
  120. Cam for 385 LT4?
  121. Help me choose, ET streets or Hoosier DRs..
  122. Keep factory ws6 ram air or?????
  123. AIR Delete Question
  124. Auxillary oil pressure port
  125. Clutter
  126. Another Header Question?
  127. 1 5/8 or 1 3/4 which headers best suite me??
  128. Heres some Numbers for my Lt1 owners
  129. Newer GTOs, how fast are they?
  130. need complete lt1 engine
  131. head porting
  132. LT1 Engine Build, Exhaust Ques.
  133. true duals
  134. HEI on LT1?
  135. dumdumdumdum
  136. dumdumdumdum vs. LT1
  137. I neeed help
  138. 93 Z28 M6 to TH
  139. Got the WS6 to the 1/4 not impressed
  140. Added LT4 Knock Module = Knock Count Increased
  141. Went to the track in the SS
  142. Drag radial on Stock rear with 4.10??
  143. Quick question?
  144. something that i do not understand...
  145. well guys my lt1 modding is done got another lsx car
  146. cc503,306,Gm847...Best Dyno #s
  147. how do you drop the stock oil pan
  148. new dyno #s
  149. LT1 stuck
  150. Need stock LT1 Rack & Pinon...help
  151. Help I'm Lost!
  152. Is my machine shop right??
  153. cc503
  154. Left-side Rich Condition - Please Help!!!
  155. Oil Change Causing Higher Engine Temps??
  156. Building my LT1, heads/internals ques.
  157. Putting my LT1 back together, couple Q's on where sh!t goes!!!
  158. tuning out the c@ts
  159. LPP LT1 stainless headers advertising
  160. Ls1 lid and airbox on lt1
  161. Why Is My Longterm Fuel Trim +50???
  162. Lloyd Elliot website not working
  163. Help for a newb on Lt1's
  164. John Deere @ the track
  165. how much is my 396 lt1 worth?
  166. Crank Sensor Problems??
  167. tired of finding "friendly" inspectors, how to pass emissions
  168. okay, i got a question and need some help
  169. LT1 Twin Turbo Kit?
  170. shifter problems
  171. pics of duals with cats?
  172. Video of my true duals and GM847
  173. 400sbc ARP Main Cap Stud part number for stock windage tray?
  174. know anyone wanting trade there 6 speed for my fully built 4L60E?
  175. Let me know what you guys think of this LT1 Camaro I might buy!
  176. I Need a opti spark!!!
  177. if i would have only known then what i know now....
  178. 9" or 12 bolt???
  179. thinking of trying something with my exhaust. tell me your opinion.
  180. 97 TA lt1 head question
  181. high rpm miss
  182. Fuel pump relay
  183. I Need My New Lt4 Programmed And Tuned On Dyno.
  184. She fired after 7 months!!
  185. Part of the AIR system?
  186. MSD box getting too hot?
  187. Difference in LT1s?
  188. Guidplates with SA rockers
  189. wat times for new setup
  190. Southern California Dyno and Tuning???
  191. Headers, What brand?
  192. Where to find a good tuner?
  193. Fuel pressure issues. LT1
  194. Unknown problem LT1
  195. Anywhere to grab the air/fuel
  196. Chassis Dyno
  197. stuck in open loop - all sensors check out OK
  198. best buy? 383 stroker shortblock
  199. Please help me find this heater hose
  200. In central jersey, need help.
  201. RTV for Intake?
  202. 2-Step for LT1?
  203. Very little weight reduction / cleanness
  204. Build up or Trade up
  205. LT1 M6 guys with 4.11s..
  206. Old waterpump is out, new E-wp going in, questions on opti and timing cover.
  207. Found my missing power!!!
  208. code p1371 opti help
  209. lt1 lean ?
  210. Switch faceplate?
  211. Gear Install??
  212. radiator choices
  213. puttin in a tranny cooler
  214. Just dyno'd
  215. newb question
  216. security light
  217. My first ever run in the new T/A
  218. does any one know if this will fit?
  219. Help after PS install with pics
  220. Your thoughts & input on my future mods..
  221. Went to the track tonight on new motor!!
  222. LT1 in 3rd gen help please
  223. crankshaft front oil seal replacment
  224. Low compression
  225. Reman Injectors
  226. leak
  227. help! need sb info
  228. opti rotor problem
  229. Galley Plugs
  230. I Found The Leak ;)
  231. car won't start?
  232. internal external leak
  233. OK, I have an oil pressure issue???
  234. Install wideband with long tube.
  235. lt1 Intake
  236. Lt1 Guys I need help.
  237. Throttle bodies
  238. Runs Like Shit In Closed Loop!! Help !!
  239. headers and tires!
  240. coil pack conversion? or way toget rid of opti ?
  241. True Duals Part 2.
  242. Overheating blues
  243. Quick A/C Question
  244. LF:a good place to have a LT1 motor rebuilt at
  245. clutch for cc305?
  246. There fixed those nasty plug wires
  247. Lt1 Problem, Please help.. Stalls out/loses power
  248. BAD Vibration!
  249. Chrome Alternator
  250. Engine gasket set
