View Full Version : LT1-LT4 Modifications
- things to replace with lt4 hot cam
- Got WS6 Style Ram Air Hood.
- new pb times
- 987 valvesprings?
- lt1 headers vs 350 headers
- 1993 vs 1994-97
- Need Stock Tune ASAP
- weird startup question...
- big prob!!!wt rr's
- Random & multiple missfires
- 94-95 code reader?
- Engine Codes...any advice?
- write up on lt1 header install?
- Engine Rebuild (pics)
- what are signs of your opti going out or is out
- VATS Problem
- what is the lift limit without PTV contact on stock bottom end?
- Rockland "no walk" tailshaft bushing
- is there a muffler instead of magnaflow that would fit w/ magnaflow catback?
- OTV plug wire kit???????
- ordered 1.6 rockers do i need to up stock springs?
- need some help
- 383 Internally balanced, will stock fly wheel work
- Crank Bolt stuck
- Spun a bearing...
- How to install the Hub
- New Cam, New Tune - qestions???
- High idle on LT1
- dynomax ultra flow #17536
- Which FPR for non-stock rail????
- Just Got tuned. Check it out
- LT1 Camshaft/Valvetrain Selection Guide by Matt
- wtf felpro!
- 300 RWHP w bolt ons
- new dyno numbers
- need some help
- Hotcam is installed!!!!!!!!
- Changing Blocks???
- oil pan gasket busted?
- how to go vented
- deleting air box?
- Ported Maf
- Is this normal?
- Engine knocking...I am positive it is........
- tuner/Progammer?!
- Refresh
- gears
- BBK 58mm sticking at idle. Did the drill mod and IAC is 50.
- lookin 4 lt1 used motor
- Rocker Arms
- what cam should theSS get?
- How do I remove my airbags?
- XFI Install... How to keep factory cluster ??
- Oil Level Sensor
- HELP! Need link to fuel pump trap door mod!!! ASAP!
- LT1 guys - Eliminate Your OptiSpark!
- 52mm vs 58mm throttle body
- Fuel line relocation mod
- New opti Already?
- Changing back to summer tires...(vid)
- Why is my timing -30?
- heading up to the track
- Wtf???????????????????????
- What do you guys think? Polylock clearance. pics
- what series
- fuel pump wires... help!!!!
- Is catback exhausts illegal to have on cars?
- Oil dilemma - calling all oil gurus!!
- custom exhaust
- Electrical Connectors for A/C, EGR, AIR
- LS1 Fuel Pump?
- cam?
- LT1 B-Body Injectors
- lt1 longtube q?
- alt. and crank pulley v.s alt. and underdrive pulley
- best fuel pump?
- 846 on lt4 valve springs stock rockers HP estimates
- Free modz
- How will this stall converter work out for me???
- Need help converter selection
- Ls1 Lid Or Ram Air Box Which to Choose?
- lower alt. bracket
- Sputtering and backfiring after big install
- which y-pipe?
- Cutting out at idle and all the time basically
- Custom cams and Cam only sticky!Dyno Numbers! Track Times!
- installing autometer oil pressure guage, quick question
- We suspected it, but this solidifies it... Edel's Air Gap sucks!
- A.I.R delete question....
- Am i in denial
- alternator
- Finally started my Diet For the LTX Shootout
- Track times: M6 + cc306 + full bolt-ons!
- Dyno numbers 396LT1
- Stock Crankshaft?
- ORY vs Catted Y
- what convertor
- Motor Mount/Trans Mount
- Engine Build -Help-
- Head Gasket???
- Ran Out Of Gas, Replaced Pump, Still No Start
- Anyone running a 2 or 3 Step Rev Limiting Launch Control?
- check out my mods, what do you think about my setup?
- th350 swap
- Air Intake Question
- Water getting into oil not burning it though???
- It is now confirmed. GMHTP mag will be covering the 2009 LTX Shootout!
- Funky ass headers on my car.
- new blackbird stripes.....
- It's back. 95 Turbo Trans Am build. (My winter work thread)
- Edelbrock LT4 Kit - 406 HP & 390 Ft. Lbs
- LE heads and cam?
- Milodon or Lokar engine dipstick with longtubes?
- LT1 Left Bank Running Lean and More
- 7 Second C4 Lt1????
- New LT1 HSR intake
- Delteq/Ignition problems?
- Help which posi locks for stock heads & rockers?
- Soaking header bolts w/ PB Blaster. HOW?
- EWP, what wire under fuse box?
- Bleed brakes when disconnecting brake master cylinder?
- crap , starts idles runs fine til it gets hot
- 4l60e swap
- What to do next....
- Can you put EGR on OFF road headers??
- Thinking about buying an LT355 Motor, Thoughts on it?
- Plastigage accurate?
- Studdering under light throttle
- New Idle vid. LE2 TDs
- Which build to go with?
- a4 ,410 gear guys here
- 74 c10 project
- Timing advance readings in Datamaster vs. actual timing advance.
- 97' Formula LT1 car. Parting out. Many H.P. parts.
- Mr Gasket #5716 - embossing up or down???
- Getting wheel locks off with out the key
- need some cam help.
- 95 LT1 with 86 style balancer?
- more fuel problems
- How much does a LT1 and t56 weigh?
- 1800 lbs with a stock Lt1?
- gear ?
- Need some opinions...
- Stock AMP bypass? 96ws6
- Top Speed Calculator Accurate?
- Need help choosing pistons
- 95 LT1 383 to 97 Lt1 Timing cover
- Has anyone ever modified their loudmouth exhaust to support a CME?
- For The Peep's With Lots Of Oil Leaks
- Quick question
- shift light
- Whats better
- LPP Headers
- injector wiring??
- water pump drive gear broke need help
- SLP speedo recalibrator.. NEED HELP!!
- fans arent coming on
- Exaust system?
- Cammed cars with stock exhaust
- Opti Questions?
- Exhaust Gasket Leak?
- My New Pit Crew
- ls1 pcm controlling lt1/4 motor
- plug wire part number?
- Wtf?
- headers
- Help
- Aeromotive Fuel system
- Stock Y-Pipe Clearance From The Ground?
- Stock Pistons & Rods
- Delete rear 02s?
- Well I have some mod money now....
- About to drop engine/trans - What size platform on the cart?
- Is the head worth repairing?
- Rant about AC Delco plugs LOL!!!!
- Need Help Finding Connectors
- car shuts off while driving.
- Header Vs. Steering linkage
- 109lsa w/ DMH Electric Cutout
- LT1 Catch Can Setup
- advantage of 6" rods?
- ses light trouble
- header flow ?
- Anybody seen the new stainless headers out?
- Firebird CME Photoshop :)
- Dynaspark Opti Install Tips?
- Newbie just got first camaro.
- Comparing head gaskets.
- Afew Quick Questions
- What timing chain? Non Vented w/ EWP
- Cruise control in the way of cold air intake?
- What do you think of this size slick?
- LT1 vs. LS1 steel fuel lines
- Help with Tuninggg!!!
- bolt on A4 95 z28 8.93@80 1/8th
- new eficonnections ls1 pcm conversion?
- fired it up !!!
- Pulling the motor, need some advice on internals
- Impala SS head gasket
- 97 camaro vert weight
- stumbling, running poorly, code 44
- Car running like poo
- New Opti-Wont Start
- Time for some new heads
- Quick timing cover help (plugging top hole)
- tb plate seal
- Engine help?
- air problems
- water pump shaft seal
- HCK with 100 shot
- 2.02/1.56 on stock heads?
- ac dryer to condesor line
- Stock Oil Cooler
- SLP MAF on LT1
- cap bolt questions
- Overheating...
- by-passing oil level sensor
- hose question...
- Pics Of Engine
- A Stupid Motor Mount ? i Need Help With
- Car hiccupped, then quit running, help!!!!!
- LT rebuild, performance part advice..
- HELP! car dies below 1000rpms
- New pictures of the T/A
- Stuck injector
- Ceramic Coated Headers and O2 Sensors
- where does it go ???
- Diagnostic Port
- Engine out the bottom ?
- Need help trouble shooting... Car dies after starting
- Bye Bye Throwout Bearing
- 28x11.5x16" ET streets (will they fit?)..
- opti tool
- Jet hot lt's
- Best price on the Harwood?
- Updated Pix of the Formula
- [F/S] 94 Camaro Z-28 with alot of parts.......
- Cammed LT1 running Lein?
- catback exhaust
- OBD I on 96 Z28
- Thought some of you might find this interesting...
- Best Replacement Engine For 95 Impala SS
- Questions About Rocker Arms
- who had LT1's new on the crate for around 15-1700?
- updated pics...
- where to find single wire o2 extensions?
- cant find it
- Service Engine Soon DTC's Listed!
- too much stall?
- Overall mod/suggestion thread
