PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. 95 5.7 ls1 to 95 Chevy 1500 pickup with 4l60e
  2. Drivers side lt1 alternator relocate????
  3. Engine knock - 96 Firebird Formula
  4. Boosted LT1 runs hot
  5. No injector pulse
  6. I think I may have spun a bearing. Please tell me why I'm wrong.
  7. LT1 steam pipe
  8. LS1 brake upgrade
  9. Tunerpro guys come in lt1
  10. Timing Chain
  11. Best Shocks for Impala SS
  12. Getting ERR98 at startup
  13. Lt1 conversion in 79 z28 first time
  14. Lt1 intake swap to carb
  15. Xfi280 vs 503 cam
  16. Reusing lifters?
  17. Whats my next step?
  18. Wagon - V3.0 - next steps. Ideas?
  19. HP difference between 280xfi and LE3 cam with LE3 Heads
  20. Skip White LT1 383 Kit?
  21. Trouble with rocker/stud
  22. Looking for Lt1 alternator relocation bracket
  23. Parts store optisparks
  24. Roadmaster issue
  25. lt4 hot cam install troubleshooting
  26. I’m looking for a LT1 Caprice wagon, end goal is 350-400whp. What should I know now?
  27. Opti or Fuel Pump
  28. 1994 Lt1 Fuel gauge not working right
  29. Lt4 to 383 swap cam options...
  30. Wiring Diagram for Delteq Opti-Direct
  31. Clutch
  32. Best Throw out bearing Lt4 Vette?
  33. Replacing Rods and Crank. A few questions.
  34. Dipstick interchange
  35. OPTI spark problem
  36. ECU/Trans controller with available tuning software
  37. Alternator/ A/C mounting
  38. Anybody running Trick Flow heads? I'm having valve train geometry issues!
  39. Rough idle, lights dimmed and almost died
  40. High idle
  41. Part Throttle Misfire Help
  42. Guess what the connector is?
  43. 96 ss dash harness swap to 96 trans am
  44. Needing to find 94 Camaro harness
  45. Can Feel Pro 1406 Header gaskets be reused
  46. Over axle pipe availability
  47. Cylinder Head ID - AFR?
  48. Few LT1 Part for sale
  49. No codes and car feels gutless
  50. Will not crank, will not start
  51. Attention LT1 gurus! Need help with 383 lt1 build
  52. ‘94 lt1
  53. Testing ICM & Coil
  54. Need spark plug wire suggestions?
  55. 1994 exhaust manifold id at collector
  56. Thoughts on LS7 lifters?
  57. Vats Bypass Module Help
  58. 1994 f-body air intake MODS !
  59. Fuel Pressure / No Start. LT1
  60. Boost - NA - Trying to bring up compression.
  61. LT1 head identification.
  62. Who wants a corner carver?
  63. Lt1 383 stroker dying at wot.
  64. After market gauges for 94 LT1
  65. Help tuning obd1 with $EEHACK problems
  66. someone help me please
  67. STS Turbo Oil Return Pump Keeps Blowing Fuses
  68. No coil poer
  69. BBK 58mm ported Tb.
  70. Project LT1 back from the dead. Got a few questions.
  71. Weird Dyno numbers on 383 lt1
  72. Afr 245 on lt1
  73. Need advice from pros on valvetrain parts & pistons & rods
  74. Rhetorical Question
  75. Innercool install help
  76. Lt1 Closed Loop issues
  77. Lt1 on my 97 camaro z28 distributor problem
  78. Anyone left that does the 24X/411 conversion?
  79. 94' LT1 loss of performance and car won't shift
  80. 75 shot on TR6's only..?
  81. 4160E trans question (neutral safety switch) new install
  82. Ebay headers fitment
  83. Valvetrain noise concern
  84. Engine slowly coming together .. what will hp be
  85. Good budget headers and recommended tube size
  86. Polylocks And Valve Covers
  87. Cooling Fans won't turn on. Completely stumped.
  88. Putting a 94 lt1 in a 97 trans am
  89. 96 SS - High RPM (under load) Flutter/Missed
  90. How to build a high rpm 400hp lt1 road racer??
  91. Do they make 1.7 ratio shaft mount afr 227 before I buy 1.65 yells
  92. Gremlin just infested my LT-1
  93. Does anyone have suggestions on a reliable aftermarket optispark?
  94. Those who deleted power steering and looped lines
  95. Anyone have a video on changing plug wires on 1997 5.7 liter firebird
  96. A little help with oil pumps
  97. Need help resolving optispark codes P1371 and P0336.
  98. Full exhaust suggestions?
  99. Vacuum 7 lbs/inch??
  100. Knock sensor location on 95 lt1
  101. 1994 Z28 LT1 dies when warm
  102. abs and brake cluster light
  103. What type of coolant for my 383 lt1 ?
  104. Autometer Cobalt Boost Gauge ??
  105. Severly overheated engine! What can I expect during teardown?
  106. 4.8 Water Pump. Question?
  107. Lost every key I had. Now what?
  108. Mystery PCM Notice
  109. motor in through top or bottom?
  110. CC503 issues. High o2 volts after warmup, fuel trims disappear
  111. 97 SS Aeromotive AFPR 13301 question
  112. Driveshift spins by hand and not when it’s in gear. I just swapped the transmission
  113. IAT location?
  114. Help lt1 was running fine. No start
  115. Very odd blown headgasket
  116. Corvette LT1 Accessory Drive Questions
  117. iam looking at the cc503 cam what mods do i need to go with it
  118. How should I connect my opti vent hoses?
  119. Tuning help
  120. Fuel pump can't hang
  121. Do I need to replace my fuel pump?
  122. air injection
  123. 1997 lt1 Camaro no spark
  124. Upgrades to help LT4 live a long life
  125. Can’t put on schrader valve
  126. How does the PE system in OEM LT computers work/
  127. Nitrous
  128. data log review
  129. Pushrod length opinions?
  130. hard start problem
  131. Are LT1 and LS1 brake hoses interchangeable?
  132. Valve cover on AFR heads
  133. New Times for the LT!
  134. Remote mount turbo?
  135. Engine wants to die under extended load
  136. Converting lt1 over to ls1 brakes front and rear
  137. 97 Firebird Lt1 Running Rough
  138. 1997 Trans-Am LT1 Engine Build Fuel Injectors Question
  139. The 1997 F-body LT1 can't be swapped with other year LT1s?
  140. My stock lt1 live run file
  141. LT headers and y pipe help for a 95 Fbody
  142. 67 Camaro Chokes and Stalls
  143. Long Tube Headers and Blower Cam for LT4
  144. 383 with CC306 dies at idle
  145. Rebuild of "The Turd"
  146. Thoughts on 280xfi cam only HP numbers
  147. High Idol, terrible gas milage and power loss
  148. Can you tune these LT1s to chop at idle?
  149. Engine missing
  150. Slightly Rough Idol after Fuel Pump Replacement
  151. headers
  152. Fuel Pump Relay (How to Disconnect)
  153. 1995 trans am and harrness with 95 Camaro lt1?
  154. 87 monto Carlo with an LT1
  155. Rack and pinion
  156. LT1 mechanic/shop recommendation in Metro Detroit Area
  157. Highest rpm and horsepower with lt1 distributor
  158. misfire codes after cam install/car runs great.
  159. How to prime engine after H/C swap?
  160. What Optispark are people having best luck with?
  161. 1997 camaro clutch size
  162. Timing with boost on bad gas vs. bad gas w/ meth vs. decent gas with meth w/ 14 psi
  163. Cc305 vs cc503
  164. How to "lean out" A/F - only on cold startup
  165. Corvette Procharger Guys... belt issues?
  166. Overheated and threw all kinds of problems
  167. New drivetrain parts - Big boy T56+Monster Triple Disc Clutch
  168. LT1 Intake bolts question
  169. Cranking with No Plugs
  170. '93 LT1 5.7L Strange periodic no start issue
  171. 90’s LT1 and LT4 differences
  172. LT1 .026" head gasket Victor Reinz = MAHLE?
  173. 95 lt1 cold air intake
  174. 93 lt1 pm pin out
  175. 95'lt1 going into a 97' M6 ?
  176. LT1 open loop problems
  177. Random question about exhaust fitment
  178. Plug Gap
  179. Should my rockers have play in them?
  180. Plastic Replacement Oil Level Sensor broke off...
  181. New LT1 project
  182. 67 Camaro - LT1/TH350 Swap Speedometer Not Working
  183. Msd chevy sb/bb cam sync plug
  184. Hood to Cowl Seal
  185. Slave Cylinder Replacement!
  186. Radiator Fans Won't Turn On
  187. rebuild or swap
  188. Pushrod Measurement Question
  189. cracking in the valve tip?
  190. A/C trouble
  191. Oil Pressure Drops
  192. Isky Adj Guide Plates
  193. Lt1 94 firebird help me please!
  194. I have a 94 firebird lt1 with some problems
  195. 4.30 for 10 bolts
  196. 100% throttle but no PE mode???
  197. lt4 oem knock module
  198. Catch can routing
  199. Taking Intake Off
  200. New engine build.
  201. Optispark possibly ruined ?
  202. Paranoia?
  203. LT1 iron cylinder block bores resleeving?
  204. SBC Head Conversion
  205. LE2, Trickflow, AFR HEAD choices
  206. Timing Chain Seals for water pump/ O-ring placement Questions
  207. Stock piston replacement opinion please!
  208. TR55 Heat Range ?
  209. How does this long block sound???
  210. 97 camaro LT1 long block swapping to corvette accessory drive?
  211. CAM/HEADS Top end shopping list. How does it look????!!!!
  212. Rust
  213. HELP identifying LT1 aluminum heads?
  214. throttle cable
  215. P&P throttle body and intake
  216. How do I find the proper length pushrods with hydraulic lifters and roller rockers?
  217. Tires
  218. Thoughts on this nitrous system for my 383
  219. Engine is coming out, head gaskets, cam swap, opinions/tips please!
  220. LT1 swap questions ???????
  221. Got motor put together tonight. Have BIG problem
  222. Iac delete question
  223. Dtc 36
  224. Lt1 performance shops?
  225. New forum top and bottom bars....
  226. Can you modify L31 Vortec heads to work on an second-gen LT1?
  227. LT4 Edlebrock intake HELP
  228. Heads
  229. Optispark reluctor wheel. Are there aftermarket ones?
  230. Lt1. Intake manifold leak? Mabey a fitting?
  231. That Exhaust thread again lol.....
  232. Need help with 95 lt1 camaro.
  233. Im in need of 4l60E seattle
  234. HELP me out
  235. 94 camaro undrivable
  236. Fuel line upgrade or replace
  237. Optispark? PCM? Need Some Help!
  238. Is this cam bearing good?
  239. can 1994 4L60E transmission be made to work with a 2004 PCM?
  240. Hugger Headers for 383 lt1
  241. Investigated noisy valvetrain, valve covers the culprit?
  242. 1.5 rr vs 1.6 rr's on 280xfi 383 lt1...
  243. just how hard is a cam install?
  244. Lloyd Elliot top end dyno results!
  245. Lt1 McLeod Twin clutch - PB Blaster?
  246. just bought 47 chev. hot rod,has engine #39700100
  247. Loud squealing from starter
  248. My 1994 Z28
  249. AFPR With Speed Density Turbo Tune
  250. Rev limit on ARP rod bolts?
