View Full Version : LT1-LT4 Modifications
- Air pump for engine?!?!?!
- What's the fastest you've gone?
- OK I found out whats wrong with my car but how to fix??? EGR
- Brake Kits
- Help! I need to beat a supercharged 99 Vette!
- got a couple questions im new
- Nos
- mods for my 95 ta
- Swap A4 to M6
- What should I get from these mods @ 1/4?
- pistions at 30 pounds
- crane valve springs
- Can someone explain?
- what do i need for lt4 hotcam?
- LT1 Newbie....
- LT4 Knock Module
- Many LT1 Hypertech Power Programmers in stock $275.00 ea
- whats wrong??
- dash swap
- Its been beat to death.. but still
- Pacesetter headers
- headers choices
- Power Programmer Plus for '95 LT-1
- Comp "R" lifters yay or nay
- Changed out my comp R's to Morels....What do I do about Pushrods????
- Stall
- Rocker Arms
- meziere
- 190,000, rebuilding question
- different lt1 intakes
- cam
- Head studs on a '94 LT Formula
- will no rear o2s plugged in cause bad missing??
- A cool cruiser for you LT1 guys - LT1 Jag XJ6
- cant find the thread
- Cam research/question
- Questions about running a single plane intake with EFI
- Pics of Any 96-97 WS6's???
- running with open headers
- camshaft media
- Afr heads
- Another stumbling block with the Pacesetter install
- 52MM Throttle Body- Worth $$$?
- Big Problem
- white faced gauges
- Magnamouth
- 90K on engine, LE1 or LE2 still possible?
- 4.10 Gears good, bad?
- Block off plates
- Some LT1 problems resolved
- Replacing Opti-Spark, Cap & Rotor - Advice?
- SB2.2 progrees update, pics..fuel cell, NX,
- GM847 vs LT4 HotCam
- 2 - Obd II Code
- New to site, new to F-body,...yeah...just...new!
- 1996 WS.6 w/ sportline springs (pics inside)
- Getting head (another head thread)
- afrs or lloyd elliots
- running rich
- 94 formula project car for sale
- Difference in Nitrous kits
- O2 Extensions
- Who Converts to Rev. flow cooling?
- lt1 starter replacement
- car is still sputtering need help
- Newbie here
- LT1 bogging in high RPMS
- hp gain on lt1 with electronic water pump ?
- LT1 Cubes?
- Balancing Question
- aftermarket coils, which is the best???
- Sugg. springs on a LT1
- Loudmouth/lt1
- Pics of modified stock LT1 maf
- Largest cam to past smog in Cali??
- stock replacement lifters and spring pressure
- bosch 13111's LT1
- Lt4 compression ratio
- Bolt-on's & NOS or sts turbo...
- A4 Z vs M5 'Stang?????????
- Oil sending unit location?
- bought me a lil bottle today heheh, goin to the strip the 13th :-)
- underdrive pulley problem
- took new motor pics today
- Shorties or mids?
- loss of power?????
- GM847 cam
- cc305 and 1:5 or 1:6 rockers?
- 300Rwhp?
- LT4 Hot Cam
- LT headers will they fit?
- routing sprak plug wires on a 93
- big problem please help
- Cooling system and ABS questions.
- Code 22- TPS Low Voltage
- Need Help, Whats Wrong This Car?!?!?
- 1.6 roller rockers
- any ideas on a cam for heads that flow these numbers?
- need short header pics
- wanting boost????
- custom valvecovers for lt-1/lt-4
- O'2s sensors
- where can i buy o2 sims??
- how much hp can our bottom end really handle?
- 4l60-e problems
- different lt1's ?
- high rpm miss
- oil cooler sandwich adapter for sale also
- nexts mod on???
- How much is this worth??
- Slight Tapping Noise, Please help!
- Any LT1 guys gone to fully manual A4?
- mileage on your LT1
- copper LT1 exhaust gaskets for sale
- which setup
- need some suggestions
- Pics of the new heads
- Cutout question.
- Interior swap
- Solid Motor Mounts
- vid of my new LT1 RX-7 exhaust... burnout too
- tunercat help
- Looking for Pictures of a ported LT1 chamber
- Help me decide....
- Request clearances advice
- Fuel Pressure Gauge
- Little Update
- Roller lifter advise
- Head/Cam swap prices
- 1994-95 Exhaust Manifolds
- comp beehive valve springs with this cam
- Block off plates
- Gauges
- header installation
- Lt4 dyno #'s
- 1997 Z28 Rusty oil pan
- LT4 Intakes
- What all would I need to buy to install a cc305???
- Bad valve train issues?
- Lt1 ported heads
- headers for LT1
- edlbrock mids or pacesetter mids
- new exhaust
- cc306
- who is running LE setup
- HELP! New on LT1's
- Cheapest Place to Buy Mid-length Headers
- Pain in the rear
- Nova Conversion
- cam
- SLP 2otl
- headeers
- Cost?
- LT1 --> LT4
- brand new TNT F2 kit w/ extras for sell
- header innstall
- LT1 vs LS1
- Lt1 to Ls1
- stock lifters
- shifting trouble
- Oil leak question
- Blower for LT1
- switch????
- Dangerously Close!
- Any 3-speed LT1's out there?
- Anyone else make an LT1 Carb intake...
- Comp Cams XE 230/236 Cam for LTx motors
- need pics or link to feul pump trap door
- What does it take to hit 12's??
- Will a 4L60E from a '94 truck fit my '94 Z28?
- shifter cable
- Best cam for my application?
- Door panel removal
- Vented Opti on 92...
- hot cam kit
- SUPERcharge it?
- Emission legal headers
- pcmforless vs. madz28
- Headers...(Gaskets and Bolts?)
- Idling problems with '94 camaro???!!! Much help needed!
- got the engine back in....issues
- cam?
- Cost to overhaul an LT1 short block
- WTB Kooks LT1 Race Headers
- selling lt1 interior
- a/f with big cam
- Burning Oil?
- K-Member
- mac headers
- lt4 starter price?
- Electric Waterpump
- WS6 Identification
- Motor mounts
- What are your guys thoughts on trickflow LT1 heads?
- Pulled motor
- How much powerloss?
- Opti=$$$$
- GM bow tie roller rockers?
- Rwhp to Crank HP??
- gear selection
- Fuel Pump Prob
- Dyno numbers
- Headers!!
- Fitment issue: y-pipe, cat, cut-out
- Any Borla owners with LT's and a sound/video clip?
- LT1 flywheel
- heres a video of my lt1 ta
- Clutch & FI
- Exaust suggetions
- taking apart alt???????
- better cam for barely modded heads
- lt1 edit?
- Carb intake
- Oxygen Sensors
- new times!
- Tcs Off????
- Tires
- ordering a turbo.. need your help...
- Dynomax Bullets or Sweet Thunder
- Fabbed valvecovers
- A4 to M6 swap??
- Articles?
- Sube Frame Connectors
- Complete Rebuild Virgin, need machine shop advice.
- rollor rockers
- bye bye for now
- new best and 1st to do it with all motor lt-1
- i need loyd elliots number...thanks
- Car spits, sputters, and shakes in lower RPM's
- Recipe for the ultimate LT1 sleeper?
- Connecting rod length
- ok, I am confused, and need a quick answer
- transmissions.....
- Egr And A.i.r?
- LT1 roots blower intake
- If you have an aftermarket K member, tell me about motor mounts.
- fuel system help
- Tune or no tune???
- Gutted Converter
- An early LT-4 383 Ported Head Cousin shot
- F/S Arizona Speed and Marine 58mm Lt1 Throttle body
- dome pistons for LT1
- le1 package installed
- LT1Edit files
- how much HP do stock injectors handle?
- Man, I am thirsty
- Camaro Project Progress!!
- Favorite True Dual setup...
- New To The Club
