View Full Version : LT1-LT4 Modifications
- code 36?
- help
- H/C Numbers
- Is This A Cam?
- plug wires
- Timing gear question
- Lt 1 Remova
- LT1 Vacuum ?
- accelarator cable bracket
- droppedm6z getting called out....
- CAI install with traction control?
- 355ci question
- Thinking of going 383. Is a stall change necessary?
- What does this code mean??????
- 1.6 rocker help
- cam question
- what rpm do you launch an (M6) lt1
- got my n20 kit:) but still a question or 2;)
- Timing Chain Help
- Gas Leak?
- can i keep the 93 tranny when switching to a 94 pcm?
- Anyone Anywhere ever measured a stock LT1 Piston ?!?
- what is the best engine setup N/A
- Any tuners, need help
- O2 simulators
- lifters
- what should i expect (hp) wise w/new engine
- 94 formula m6 vs. 99 lightning
- Digital 6 mounting
- need website for caddy lifters
- ARCHING AGAIN:( GRRR need help AGAIN!
- Good Stage 1 ?
- my car starting up...
- Fuel Pressure Regulator..
- Hello again to all the brotheren!
- yay or nay?
- anyone have
- Is this the opti?
- optimal engine temperture
- car cuts up after engine warms up
- flowmaster 80's
- car running bad
- Belt part number needed
- Engine missing. Help?
- How do you guys think this sounds?
- plugs and wires
- Fuel pump
- Head gasket Question.HELP
- cut out
- 4.10s revs
- i need an LT1 Dyontuned in Georgia
- Hooker LT's + Mufflex ORY = Clearance issues?
- LT1 Coil Pack Conversion, modifications
- Has anybody done a vertical radiator mount?
- Cam Question
- changing plugs..
- Internal balancing?
- S-K Tools
- 93-97 V6 replacing radiator
- REBUILD KIT + CAM KIT!!!! I need your opinion
- Griffin or Be Cool?
- lower ilde?
- Going true duals ... which mufflers to pick?
- aftermarket accessory bracket
- supercharging a LT1.
- Procharger and heads..
- Exhaust ideas
- lt1 headers & dual cat y-pipe
- car over heating!!! input needed
- Help Help Help!!!
- What do you guys think i could make parting out my car?
- LS1 pacesetter Y-pipe works with LT1 pacesetter longtubes?
- how much stall?
- Pacesetter ORY work for Hooker LT
- pressure plate bolts
- Converter
- Old Vids
- Oil Pan Gaskets
- LT1 Engine Swap Sites, Post yours
- ACCEL GEN 7 and Intake
- 1st Time at Track in 2 years...
- LT1 Stalling please help
- DIY tips for pop-up headlights (pics)
- O2 help please!!
- Beat by a BMW???
- Car dies
- Hooker Comp Headers???
- Modifying the radiator fan shroud?
- stock cranck
- Should i get a tune???
- hesitation
- Anyone running Bassani exhaust on a lt1???
- Highest lift cam for a stock motor lt1??????
- Help! Good LT1 Shops in NJ?
- IF I pull out stock exhaust system to pipe will it give HP or just make noise?
- I did'nt know 99's came with the LT1 option
- hello need help
- Fuel pressure
- LE2 Build completed... (will not start help needed)
- Thinking of buying an lt1, question about cam
- popping from intake?
- Problem sputtering and hesitation after longtube install and tuneup
- cams
- Starting and hesitation problems
- wat times
- Pro Products TB
- installing moroso cai
- trans am help
- Pro Gear Timing Chain and Electric Water Pump, Reccomendations?
- Cat Conv Recommendation
- 11.41@118.49
- opti help
- exhaust leak
- Opti removeall question
- L/E H/C prices?
- what clutch....
- is this the right cat??
- Which muffler is better for power and is loud???
- Roller Rockers
- Test drove a H/C 383 LT1 Z
- What weight oil to use in 97 camaro z28?
- Exhaust help
- Bucking and not idling
- 38lb Injector?
- idle issues
- Terrible track times tonight
- lt1 dart heads
- ~7mpg= WTF?!
- Jasper Performance Products
- Guess I got luck
- After Cam install Help
- LT1 guys running Juice:) got a couple questions?
- lt's vs. mid's on a daily driver, what do you think?
- 93(94?) Firebird owners: I need to eBorrow your owners manual!
- If you've installed SVO injectors, I could use your help!
- Anybody know of a good DIY ECU tuning site for the LT1
- Found a good deal on intake elbows.
- Need info on LT1's
- Can a vacuum leak cause Code 34?
- slp driveshaft loop
- valvetrain questions for 918 springs
- TPS upgrade?
- fuel question...
- heat range question spark plugs
- Camshaft help, Im with the 10000 others!
- 58mm holley throttle body not closing
- some pics
- question on my trans
- LT1 fuel pressure regulator...
- C4 Brake Conversion
- junk opti or rotor
- OBD I conversion questions
- Help with shift light installation
- The best CAI for LT1
- High mileage LT1
- Rpm Drop
- Best next mod after full exhaust
- Headers w/o EGR???
- engine bay
- car wont start.... need help fast!!!
- spark plugs
- Fuel Tank Help
- vibration after LT install.
- Strange object found in LT1 oil pan
- Fuel pressure
- LT4 Front Cover Plug, wtf?
- aftermarket harmonic balancer
- Highest spinning LT1
- anyone with 1 chambers
- Valve lash question
- RPM's surge when cold start
- Shooting for 10.90's Heres a picture of the changes
- question about a cutout without headers, please help
- new guy :)
- knock retard help
- DAAAAAAAM I NEED A CAAAAAAAM lol
- code 32 egr recirculation
- black 93 Lt1 with friends
- MSD Opti vs. GM opti
- I can't find passenger side o2 wire (1-wire)
- Need Help Choosing Rotating Assembly
- WOT lag?
- Head Bolt Torque
- Baffled! Need help from the LT1 bretheren!
- Starting issues, need help
- 1996 Z28 SS from Lexington, NC...
- INjector problem
- EWP Roll Call!
- pics of some custom work on my LT1
- all parts for a cam swap....
- Question!!!!!
- just wondering
- Mr. Gasket MLS
- Right STerm High, Left STerm Low
- Porting a stock intake on the car?
- Some go 5.0 vs Z28
- Need help with this code... 44
- Wish me luck! Going to the track on new setup
- Does anyone know the part # for k/n>>
- Stupid question of the day/week!!!
- lt4 hot with ported heads
- LT1 might be LTjunk
- Oil Pan and roll bar Question
- A couple cylinders fire, then nothing...
- Ignition upgrade for 97 camaro z28?
- Engine Block Identification..Help Needed!!!
- Idle Hang ????
- Anyone replace LT1 Alternator fan with a better looking one?
- Header question
- OTVC kit with factory exhaust?
- thermostat question...
- help
- another what will I run thread
- 94 Vette M6... Dana 36 or 44 from the factory?
- turbo lt1? or procharger?
- valves help..... please!!!!
- Rear O2 sensor delete
- Will 98-02 tail lights fit a 96?
- piston compression height
- how do i remove this
- One way to get more air flow to the LT1 intake without adding a larger throttle body.
- Who should I go through for a custom cam??
- Really want to CAM, help on what to do.
- ls1tech stickers
- HotCam Indentification??
- new guy here, and results from last weekend racing
- 6A or 6AL?
- stuck engine
- Blown Head Gasket Repair
- air foils and pulleys...
- L98 Performance Help
- Formula not starting...Opti problem?
- Catback question...
- 94Z Project
- Keyed hub?
- Do I need a stall w/cc503
- oil pump change
- Radiator Gunk
- radiator cap question
- Going to look at an LT1 TA tomorrow!
- Here are some pics of my LT4 Formula, whatcha think???
- oil spray on valvetrain
- LT1 Engine Work
- Just got my car back after 5 weeks...
- New 355, is the Split BLM's or do I have a problem?
- engine breaks up at high rpm when warmed up
- Building a 94 lt1 camaro
- Please Help!! Lets see how smart you guys are...
- first time at the track
- Twin Turbo Teaser
