PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. How important it the air dam?
  2. What do you think broke?
  3. oil pressure problems and possibly fuel pressure problem??
  4. Vortec Distributor in an LT1?
  5. traction problems
  6. LT1 WS6 Airbox owners come in
  7. Fuel rail help
  8. New track times!!!
  9. Fuel pump prob!?!?
  10. Any IDEAS???
  11. Which Fuel Pump For Caprice?
  12. Anyone notice this behavior with the LT4 knock module?
  13. whats the next mod for a 94 LT1 ?
  14. The factory tach must be off at high rpms...
  15. Guys I need injector sizing.
  16. What could be wrong??
  17. wheel bearing install
  18. fuel pressure
  19. Idle vid with open headers lol.
  20. dart platinum 200cc lt1/lt4 heads?
  21. LS1 head conversion
  22. Parts from BMR Showed up!
  23. What is this/where does it go?
  24. What are these springs?
  25. Put my new exhaust on!
  26. New drag set up.
  27. Fiberglass Center Console??? Feeler...
  28. WTH is C.A.R.S. ?
  29. Deleting the charcoal canister?? who has pics?
  30. GMMG + Mid headers?
  31. Radiator Cover??
  32. Over vavle cover plugs
  33. Easiest way to check for fuel, and spark?
  34. Does your car smoke on the dyno?
  35. MSD 6AL Mounting
  36. Wiring a Moroso switch panel
  37. Spark Plug Hole Fix
  38. Vented Opti...come on in!
  39. making room for true duels over the axle
  40. found some pretty rare parts
  41. Which tps sensor?
  42. Help! Idle missfire
  43. ported throttle body, tune for it?
  44. fuel pressure ?
  45. What header gaskets are you using for the LPP headers?
  46. click but no start
  47. help me out pushrod and chit getting on my nerves
  48. after market tach
  49. A/C delete plate for firewall, templete somewhere to make your own?
  50. machining question
  51. Valve cover bolt size
  52. Valve float?
  53. code 16...please help
  54. K&N filter for Trans Am Ram Air Box
  55. Cheapest place to get an ACDelco opti?
  56. crank reluctor?
  57. new cam coming for 383
  58. My 1st 4th Gen - 97 SS - What perf. should I expect?
  59. new setup help
  60. GMMG vs Borla XR-1
  61. Any advantages of having car speed density tuned?
  62. Lil help please
  63. LT1 Opti SUCKS!!!!!!!!!!!
  64. picking out a bullet muffler for now
  65. car shaking at idle? Please help
  66. Got car back together, timing off after a week of driving??
  67. cruise control fail after T56 swap. need help ASAP!
  68. Lt1 headed victor jr efi
  69. Need a little Help with my re-build.
  70. Injector ? for stockish build
  71. Does anybody know what connection this is?
  72. broke bolt in intake manifold, need suggestions
  73. Timing chain choices
  74. Newish Clutch, 2k Miles ~Problem~
  75. Failing Oil Pump?
  76. LT1 fuel line connector locking plastic clip. Available seperatly ?
  77. Watts link, LT1, polished aluminum, red powder-coat, updated pics (9-14-10)
  78. problem with head installation.
  79. A new GMMG clip... for those of you who are still 2nd guessing GMMG...
  80. Another fun what will it dyno thread!!!
  81. Intake manifold questions
  82. Turbo'd 383 build thread
  83. Oil starvation Issues? Help
  84. Anyone familiar with real 96/97 SS please help.
  85. HELP! what can cause water to mix with oil
  86. nsa roller rockers
  87. Alternator Exlopded View
  88. Wiper Problem
  89. Header install problem.
  90. How do I fix this?
  91. Center Console swaparoo
  92. lt1 optispark!
  93. What application is this water pump for?
  94. 93 camaro Lt1 - headers
  95. 1.6 nsa rockers+guide plates
  96. LT1 WS6 airbox sells for $382 on ebay! Pontiac parts getting scarce?
  97. Ignition Module Help
  98. 94 PCM on a 93 Z28
  99. cracked oil pan
  100. coated rod bearings
  101. Car is running rough
  102. Nitrous Question
  103. Need help with TB plz
  104. Just picked up a 2002 WS6!
  105. What Wires to use for Long Tube Headers?
  106. Won't start
  107. 11's Cam Only Finally
  108. I hope I'm not an ebay idiot....
  109. BCM question
  110. Electrical Guru's Unite.
  111. Canton valve cover owners
  112. Disabling EVAP and EGR in TUNERCAT
  113. ? Replacing roller lifters
  114. Tb appearance plate
  115. Questions on a timing set
  116. LT4 hotcam users, what springs?
  117. Camaro problems...............
  118. LS1 Center Console
  119. Need to know how to send car in open loop? Help !!!
  120. Knocking..middle motor/lower motor
  121. obd1/2 diagnostic scanners ?
  122. Is it ok to use these head gaskets?
  123. Opti, tune, or something else?
  124. you guys were right about the headers...
  125. getting alot of water in pass. valve cover.need help?
  126. I need some quick advice!!!!
  127. Good places for 1 week on jacks? (pics inside)
  128. Car wont start, see what you guys think of this.
  129. Ride height change, what do you think ? PIC
  130. corvette AC compressor top plate
  131. How to set the oil pickup tube height?
  132. newby to ltq... opti.... never messed with one, need advice
  133. SES light on at idle at lower than 1500 RPM and off at above that RPM
  134. Vehicle Speed Sensor concern 4L60E
  135. Motor Mount replacement help PT.3
  136. Injector Question?
  137. should i keep my ZO6 Wheels? help im undicided.
  138. Help Finding Cam.
  139. Where and how much can I buy a camaro SS hood for?
  140. Best Fuel Pump To Buy???
  141. Put coilovers on the LT1 yesterday...
  142. 383 LT1 SR cam 88mm turbo HD VIDEO part 5 Test Drive
  143. Needing some help finding a bellhousing
  144. abs light on
  145. gettin dyno tuned april19th
  146. concerned about 383 build
  147. lost power with exhaust? help
  148. EFI 24X LS1 pcm conversion
  149. My Spring Break "Build"
  150. help help help!!!!
  151. About to start my build
  152. 1995 Pontiac Firebird Formula - Console Options
  153. LT4 388 ci low number at dyno
  154. Quickest Fix for MAIN SEAL Oil Leak?
  155. What Is The Thickest Header Gasket ???
  156. No Start After Wire Change
  157. SES lights on...
  158. 130MPH and counting...
  159. Slowly getting there!!! Found a few problems on the way...
  160. FUel Questions??
  161. Apperance mod for my black LT1
  162. Motor Mount replacement help PT.2
  163. What can ya tell me?
  164. do i need a S-pipe
  165. Where are you guys shifting the lt4 hot cam?
  166. Exhaust question
  167. Damn my luck. Oil pressure drops during hard braking.
  168. spark plug ?
  169. LT1 Stockers At Rockingham
  170. Opti Vent?
  171. Need a wire harness number and help
  172. Block Filling
  173. Keyless FOB Programming
  174. Any advantage using LS1 injectors?
  175. Motor Mount replacement help
  176. Any Ideas???
  177. Everyone that put GMMG on yout LT1
  178. Anyone having problems with oil pressure sensors when using the white spring?
  179. GU6 non locker?
  180. Lt1 Newbie P0300 code
  181. help with moroso 7 qt oil pan
  182. Im bored and was just wondering since I see so much of these question?
  183. Lets see how good you guys are 1/4 challenge
  184. Did I put my clutch DISC in backwards?
  185. LT1 tune?
  186. My first mod
  187. newby to lt1 got some questions
  188. Where does this hose go!?!?
  189. 93 Camaro LT1
  190. colder pluggs??
  191. Arp rocker arm studs?
  192. dash connector and power steering questions
  193. 96 Firebird Formula pt 2 video
  194. Cranking compression, what is average for a LT1
  195. My 570zx build
  196. School me on Nitrous!?
  197. Forged crank 3.48 stroke
  198. What race weight are you guys able to reach?
  199. 94z egr delete
  200. Questions about FAST XFI
  201. need help
  202. Tempeture sensor doesn't work
  203. harlan shift light rocks
  204. lt1 nitrous
  205. motor issues update:
  206. Want an x pipe but know what to get need help
  207. lt1 bare minimum's
  208. lt4 pushrod length?
  209. Best Header Gaskets
  210. Rocker Stud Questions
  211. speedometer off
  212. Breakdown of a previously supercharged engine reveals.....
  213. TB Bypass Question and ABS Delete
  214. TB bypass and hypertech
  215. driving the car with open headers reply!!!!
  216. Dyno'd Lean as Hell
  217. Motor mount bolts
  218. lt1 383 is shutting off at wot
  219. LT1 Alternator Relocation Bracket Problem
  220. Lt 1 IAC Removal
  221. i need ram air box dimensions
  222. How do you clean a MAF
  223. New Best 60ft
  224. oil pump rebuild/relief valve
  225. Help Please! Engine electrically died on return road after run
  226. vacuum hose diagram
  227. Anything else while I'm in there??
  228. 58mm throttle body
  229. Head bolt size?
  230. 04-06 GTO fuel pump into LT1 F-body???
  231. Safe CR with E85 on TC78 383.
  232. ECU Code: Low-Res Failure?
  233. Oil Pressure problem???
  234. Fog light socket
  235. Fuel economy sucks.
  236. should i be worried?
  237. valve spring/roller rocker install
  238. GM white spring/ Weld pickup on?
  239. Harness Question
  240. If the 7.09 made you mad you will love this!
  241. New build & OBD1 LT1 PCM won't turn on??
  242. Light weight battery
  243. missing
  244. Low Trac Light
  245. just installed an SLP loudmouth 1
  246. MAF electrical problem please help.
  247. fluctuating tps voltage + %, coolant temp and iac
  248. 97 Z28! ABS & Coolant light.
  249. Fuel Pump Trap Door Mod---PICS!
  250. fuel filter
