PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Percy's header gaskets
  2. Forged vs Hypereutectic
  3. need help with initial tune
  4. Throttle sticking?
  5. 80MPH, rumble strip sound when barely on/off the gas.
  6. problem with roadmaster pcm.
  7. no fire
  8. lt1 coil -- which side is positive and negative
  9. ?How to, Figuring out what the guy(s) did to this car before I got it.
  10. ? about lt1 intake and modding it to have a dizzy
  11. 95 LT1/T56 new Flywheel install
  12. quick '93 chip question
  13. Drag Bar
  14. How much WHP would u guys guess?
  15. Injectors?
  16. too high of stall??
  17. anybody know how to tune?
  18. SLP Loudmouth for lt1 good sound?
  19. Trans swap question!
  20. shock suggestions?
  21. crank case pressure
  22. Will this Cam work?
  23. Gen V LT1
  24. LT1 lives on!
  25. those who are good with hooking up aftermarket ignitions crane?? PLEASE PLEASE HELP
  26. Just Installed LE Custom Cam and Have a Few Issues
  27. No more Ebay headers?
  28. Charging one minute not charging the next
  29. Polished LT1 intake manifold
  30. Cutting out, need help!
  31. engine died
  32. PCV - Use stock fresh air line or breathers on high rpm motor?
  33. Tuning
  34. 94 z28 new to the muscle car thing
  35. Dynaspark
  36. 396 crank and stroke
  37. To Set Ther Record Straight
  38. Weather Theory
  39. Intake question
  40. Stock LT1 car....this about average times?
  41. Finally Sprayed it *track results and pictures*
  42. Need help on LT1 crane fireball ignition hook up -- please help
  43. Power advantages with EWP
  44. Need LT1 Genius! 95 Trans Am Backfire then No Start
  45. Please help with bolt sizes
  46. header gaskets problems
  47. car leaking gas and rear end fluid.
  48. Opti LT1 timing issue?
  49. We need a "hardcore" lt1 forum...
  50. Volant on 97 ws6
  51. Aem wideband
  52. Plug gap - tr55s & msd
  53. 95 z28?
  54. 3:23 to 4:10 wow
  55. TCS/ASR/4 channel ABS/Cruise questions
  56. Where can i get a water pump drive coupler?
  57. pushrod length?
  58. lt1 swap problems. oil pressure
  59. Stay with cc503 or go with LE h/c?
  60. IAC gasket
  61. New lt1 owner wanting ideas
  62. Complete fuel system overhaul - advice/opinions?
  63. New Delco opti DEAD!
  64. bad fuel mileage
  65. Walbro 255 max with h/c/i and N2O?
  66. dissapointing dyno results...
  67. Thinking about going through my 383 and upgrading
  68. Car showing -18* timing...
  69. Twisted Axle Splines
  70. Emailed Lloyd last night
  71. Budget LT1 11:1 355 w/ LE1 heads, what pistons??
  72. high rpm power loss/ steering column questions
  73. What is the Lt1 version of the MS3 cam?
  74. How do you full polish an lt1 intake manifold?
  75. what all is needed for a camshaft swap?
  76. Heads and Cam for 400+Hp 350 LT1, Please advice
  77. Spark plug wire length for coil packs
  78. 4000rpm hesitation
  79. How much play...
  80. Knock retard
  81. Was cutting out. Tried to diagnose ignition and now it wont even turn over.
  82. Need your suggestions for intake/valve cover paint
  83. No mods left to do but rockers.... Need advice!
  84. guy selling a cam, what type of setup is it for?
  85. turbo ltx help!!!
  86. Yes another exhaust debate
  87. Exhaust..Trying to come up with what I am going to buy, no tune.
  88. opti problem or what?
  89. knockin out of alternator?
  90. Karl Ellwein 383 may be letting this go =(
  91. looking for a procharger for a 00 Trans Am
  92. Heater hose size?
  93. LT1 Dyno Tune
  94. LT tuners in DFW or Texas
  95. One Mean Green Z
  96. Got the old thing out again.
  97. 2012 concept TA
  98. What headers on 396 lt1
  99. 3000 stall???
  100. 1997 z28
  101. LS1 steering shaft = loose(r) steering?
  102. optispark question
  103. looking to change up my exhaust
  104. My 97 is @ Tick for a build. Few pics inside.
  105. SLP Header question and header questions in general
  106. Fuel Pressure
  107. Edelbrock intake
  108. Easiest Shorties
  109. #5 Cylinder NOT Firing
  110. Head assembly question
  111. New PB et/60ft LE2 383
  112. Clutch or tranny vibration?? Suddenly started doing it..
  113. My 398 Stroker Video
  114. couple of issues need advice
  115. lt1 problems continue.. multiple misfires
  116. fuel gauge help
  117. LT1 Ram Air Bumper?
  118. lt1, no spark, no 5 volt from computer
  119. Flexplate - Need a new one?
  120. Electric Water Pump Question
  121. CF sail panel installed
  122. It starts, it runs....but doesn't sound right
  123. fun times
  124. Need better acceleration
  125. Lt1 Hp questions
  126. two stages?
  127. Car suddenly does not want to crank?? Ive tried everything.
  128. Does anyone know where the clutch lockout switch is at?
  129. Flushed radiator and the car wont crank now?
  130. Thinking of goin the efi 24x way.
  131. LT1 H/P Question
  132. FAST Injector Offests (Tunercat)
  133. Suggestions for minor issues?
  134. Sorting out minor issues
  135. My front right turn signal won't function right, Opti??
  136. Lt1 ram air help-connecting box to maf
  137. I dont understand how to remove the knock sensors.
  138. Solid Roller Lifters
  139. tpi head vs lt1 head
  140. New exhaust set up ( Video inside )
  141. Dyno time, What number should I expect?
  142. On the verge of driving this f body in the lake
  143. Coupler/Bellows for WS6 intake?
  144. 10.24 @ 132.3
  145. cam swap and my problems
  146. Guys with converted single planes ..
  147. Best Rod for 600hp
  148. need ideas- 350lt1 build
  149. I should use walbroo255 fuel pump can uo help me
  150. Should have my car back together today
  151. A/C Compressor question
  152. fuel pump ???
  153. About to take a BFH to my car!
  154. Stupid question
  155. 95 lt1 making LOUD screech noise and trouble going into gear..
  156. 3.23 to 4.10 10 bolt a4 with shift kit what to expect
  157. Broken valve spring dampers
  158. Attempt at cooler IAT's (pics)
  159. long tube headers to x pipe muffler then dumps? Anyone use something like this
  160. New Unexpected Personal Best
  161. AFR square exhaust port to Pacesetter header
  162. Lt headers and deletes
  163. Anyone run non resistor plugs?
  164. MSD 8.5mm Plug Wires
  165. harmonic balancer/crank pulley. what to buy or avoid?
  166. wow - 34k dollars for a 95z28 with 87k miles
  167. how to gain speed past 1/8 mile mark
  168. towing with lt1
  169. MSD Optispark
  170. Having some serious tram lining issues
  171. 4l80e Conversion 1/4 mile Results
  172. Headers question..
  173. What is infront of my crank timing gear?
  174. What is infront of my crank timing gear?
  175. 97 SS Exhaust Run (Video)
  176. Does 15.28 MPG's sound ok?
  177. Need help!! 95lt1 weird issues can't figure out!!
  178. 355 build
  179. Any st.louis gurus??
  180. which sounds better
  181. Comp rockers making noise, anyone else having this?
  182. Car was running now won't start
  183. NewTurbo LT1 Z28 hotside...
  184. Who has a rail mounted fuel pressure gauge?
  185. car vibrates at about 75+ mph
  186. Keep killing 02 sensors every 1-2 years
  187. Got my car painted blah,blah,blah
  188. My 10 second '95 Camaro Build
  189. black puff of smoke from the exhaust
  190. Bad waterpump.
  191. my lt1build thread
  192. Factory alarm problems on 97 Trans-Am
  193. Should I buy an LT1 Camaro?? Optispark
  194. It's getting to be that time of year.
  195. B-Body Mods
  196. Alot of fuel smell at idle!!
  197. No spark/ stalls when it warms up help
  198. High idle (STILL)
  199. how do you guys change valve springs?
  200. Engine wiring harness help
  201. Odd vibration.
  202. Quick optispark question.. Installing right now, help
  203. 94 z28 surges/bucks when warm; acceleration and WOT ONLY
  204. Motor build setup
  205. best way to pull my motor?
  206. No start soon after MSD cap and rotor?
  207. Hid lights
  208. 800hp SC LT1
  209. huh. interesting.
  210. clogged lifters rocker arms push rods idk????
  211. What valve springs are you running with your lt4 hotcam
  212. Fuel pressure regulator or fuel pump?
  213. First time to the track after 24x
  214. 95 Lt1 Intake Manifold Gasket Replacing
  215. It's been a while
  216. Need a tachometer/shift. What do you guys recommend?
  217. Stock exhaust
  218. what I need to change my cam to solid
  219. what would be the ultimate n/a lt1 build?
  220. Door spring clip and cluster
  221. It's alive!!!!
  222. So, on a long shot..
  223. WTH! Two Oil Pump Drive Gears Toast!
  224. Help again...please
  225. ulta z hood
  226. Which valvetrain components to go with?
  227. fuel pump went out; which brand to buy?
  228. New member Needs Help With LT1 mods
  229. 95 z28 stalling until it warms up? High Idle. Ses/cabin/gauge lights flickering?!
  230. Scoggin Dickey CNC Ported Heads
  231. Transmission? ECM? Something Else?
  232. What Heads?
  233. s60 questions
  234. fuel gauage question
  235. Stock 70K mile LT1 Longblock, what is it worth?
  236. Fitting headers
  237. Low fuel pressure?
  238. cam install help PLUS HEADERS NOW TOO
  239. Ls1 Slp Air intake box in a lt1
  240. want to switch cams
  241. 95 Z-28 and Pacesetter LT's hitting the passenger floorpans, ughhh help!
  242. Best Radiator for 650+HP street/ strip motor
  243. Need some advice on a header choice
  244. 402 lt1
  245. Track advice needed!!
  246. 1994 firebird rebuild.
  247. LT1 no spark
  248. 94 starting issues
  249. oil pan help
  250. LT1 intake manifold swap
