PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. header install q's
  2. OMG it's green ;)
  3. Port & Polish TB
  4. Engine seal and front end bushing kit
  5. Non-LT1 O2 sensor problem
  6. subframe connectors?
  7. replaced opti big problems need help
  8. 500 HP setup . T56 or Th400 transmission???
  9. Help!!
  10. Anyone using nitrous express maf system?
  11. elbow
  12. Back from dyno tune at Ed Wright's, numbers inside
  13. Lean in Open Loop, need help
  14. Anyone ever relocate the ABS Module in the engine bay?
  15. Opti Spark
  16. Took My T/A To Tha Tracks Lastnight...
  17. need help with long tubes for 93
  18. what's the difference between 93-94 opti and 95-97
  19. datalog..... can someone take a look?
  20. got damned this car
  21. 383 strokers with cc306 inside please
  22. yes or no?
  23. stock gas mileage
  24. Need help fast!
  25. Track Ready..
  26. LT-1 Valve cover bolts
  27. Wth??
  28. I need some help
  29. how do i find out what carrier i have ?????
  30. Dropping K frame NEED HELP ASAP!!!!
  31. hit a curb today, ruined everything
  32. Tr55 Gap?
  33. this should help!!
  34. C5 Stall fit LT1?
  35. Best Shorty headers
  36. Finally some 12s
  37. Lingenfelter cams?
  38. Going to the track today...FINALLY!!!
  39. First header install
  40. 1994 Z-28 progress...
  41. Autometer Speedo install....no shift!!!
  42. Vortec Distributor instead of Opti ??
  43. help me out......spark plug diagnostic
  44. 58mm throttle body questions
  45. LS1 Kills
  46. GAy lt1 lol
  47. LT1 Bin File
  48. Need a part number
  49. Any way to seal exhaust manifold w/broken bolts?
  50. Spark plug help
  51. Gas
  52. o2s cauding bad missing? Corvette o2 p/n
  53. how fast is 550rwhp
  54. no help yet
  55. Guys Running 15x10x7.5 BS prostars!!!! Please look
  56. Plug wire to cylinder 7 behind stock manifold?
  57. 1.6 rr's and springs question
  58. Idiot Lights
  59. guys with LT's is it easier to change sparkplugs?
  60. emissions and ignition timing
  61. Heater Hose Assembly....
  62. why dont the lt1 guys get as many forums as lt1 guys?
  63. Need help BAD
  64. 5 car beat down?
  65. lt1edit or dynotune?
  66. how long does it take to install heads and cam lt1
  67. Heads and cam
  68. Pictures from LT1 cam [and head] swaps?
  69. Parts for TB Bypass
  70. Poor mans cam swap
  71. high flow cat?
  72. What does an EGR and AIR delete do for an LT1
  73. Timing Chain.
  74. Temp Gauage question
  75. Do i have everything for my header install?
  76. 3/4 inch Header bolts work for install?
  77. V6 to LT1
  78. rear O2 sensor question
  79. Plugs and Wires FTL
  80. dont no what to do
  81. Rocker Problem?
  82. le1 h/c
  83. is this the opti (please help)
  84. backfire problems
  85. Guys with over 800rwhp whats your fuel system
  86. Whats 96 T/A Vert worth
  87. O2 Sensor eliminator
  88. heads cam headers setup help
  89. GM847 and similar
  90. couple of sensor questions
  91. Confused
  92. 1 LE H/C come in
  93. 97 Ta ws6 swaybar
  94. which muffler flows the best?
  95. prostar size
  96. Cleaning Moroso CAI
  97. obd2 96 z and torque management
  98. Weird scanmaster readings sometimes.
  99. What kind of tuning?
  100. Fuel Upgrades
  101. Backfire threw exhaust!
  102. exhaust straight pipe damage question
  103. I want to get some headers, which one?
  104. LT-1 Ignition timing
  105. "3 bar map sensor" will it work on my lt1?
  106. does someone who knows their stuff want to answer some questions??
  107. Lt1 T56 Bellhousing
  108. cheap easy way to make
  109. proper fuel system upgrades
  110. Air Tunnel From Fog Light to K&N?
  111. Oil pressure question
  112. how to install 150 speedo
  113. Need some help!!!
  114. Header Installation... Need Some Advice...
  115. Lamest question of the month: Corvette Servo
  116. Need help wont rev past 4 grand
  117. Something You Might Enjoy
  118. fuel pressure regulator opinions
  119. Harlan shift light LT1, DELTEQ & MSD DIS-4
  120. With some "finesse" could these work? (lrg images)
  121. opti's suck
  122. 383 build up
  123. No signel to the coil = bad opti?
  124. big opti/cam swap dilemma
  125. Cut Out installed
  126. what gaskets do i need for a cam and heads setup lt1
  127. lt1 in nissan 240sx
  128. what should i do???
  129. 93 firebird wont start.. HELP!
  130. What Slicks Yall Runnin???
  131. Lamp Circuit Failure code B1061
  132. What type of driveshaft??
  133. Planned LT1 mods. Suggestions?
  134. now what the hell
  135. 2 questions about recently installed gears
  136. Traction problems
  137. changed opti but car still runs rough from time to time
  138. High Flow cats?
  139. steam tube- routing?
  140. egr troubleshooting
  141. car stumbles randomly and tach goes crazy
  142. Edelbrock Dry nitrous for lt-1
  143. Shocks and springs NEED SOME GOOD INFO
  144. ?'s after stall install
  145. blown clutch- help!
  146. Need Some Help
  147. Need your opinion on this exhaust FAST
  148. sickest lt1 iv ever seen/heard
  149. LTCC Owners...
  150. Should I waste my time against this GTO?
  151. '95 LT1 Charging problem.... HELP!!
  152. Need help with injector size for boost!!!
  153. Help with my 60fts they seem weak.
  154. LT1 Piston to deck clearance vs. deck height?
  155. Dynoed
  156. LT1 383 1/8th mile results
  157. tranny issue???
  158. New Best and some video
  159. Problem with plugs???
  160. Delco R44TS, fine for a DD?
  161. Header bolt Q's
  162. Vids of a few fast LS1 tech members at the drags this weekend
  163. two new bests
  164. Looking for some advice on first mods!
  165. Help me pick my license plate
  166. How to replace the trans mount
  167. Shiftpoint Logging
  168. Pics of your HARWOOD hoods....!!
  169. Need help on replacing valve seals...
  170. timing
  171. How wide can I go?
  172. new steering wheel pics
  173. Cast vs Forged crank
  174. Rebuild?
  175. knock sensor
  176. rhino ramps
  177. do the 95z28 have the 4L60E or 4L80E?
  178. Fuel system for signal planes need ideas
  179. lets see some lt1's.
  180. Stall converter suggestions?
  181. i hate lt1 cooling systems!!!!
  182. No Coolant Gauge
  183. Steering Vibration
  184. FASTFATBOY Idle Video!
  185. What Size stall
  186. Major oil leak from Oil Level Sensor on Oil Pan
  187. 3200 stall to big
  188. take a look spark plug
  189. Looking at a 93 z28
  190. Transmission Help
  191. weld rims question
  192. Head gaskets
  193. How to race?
  194. need help with my heads
  195. Project is getting closer :) have a few questions
  196. coolant
  197. Fastest (mostly) stock LT1 ive ever seen
  198. 383 Supercharged. Ur Opinion on Gears plz
  199. Issues with putting a carbed 383 in a LT1 Camaro?
  200. Another one bites the dust....
  201. My new exhaust dyno numbers
  202. LE Edelbrock LT4 intake/Custom Rad setup
  203. Pulley Question
  204. Just got my Cut Our installed, got a ?
  205. Cheapest place to buy gm or crane 847 cam?
  206. 93 Knock Problem
  207. Problem with Dyno Jet
  208. steering question
  209. Fuel pressure Drops?!?!?!
  210. How Much Hp From This Combo
  211. LE3 Question/stock block
  212. leaky power steering fluid box
  213. My Custom Exhaust Set-Up...
  214. msd cap and rotor question
  215. Pretty much finished, or close to it
  216. Advice For Shift Points W/cc503
  217. For us LTx guys
  218. i help mail order help haha
  219. What Throttle Body should i get?
  220. first mod lol
  221. Can't get valve lash right...
  222. Computer Tuning
  223. oil pressure sinding unit
  224. lt1 t56 spec stage 1 clutch shakes
  225. My Plug Gap?
  226. What would cause it to bog when given throttle?
  227. Need advice on what bolt ons to do first???
  228. help with brainstorming...
  229. what do you do at work
  230. my setup
  231. random stumble. help me out.
  232. motor mounts for LT1
  233. IAC valve
  234. Rear LT1 Brakes
  235. delete oil cooler- oil filter adapter?
  236. I Am In Desperate Need Of Help
  237. $5k to burn
  238. can you beef up the 10 bolt??
  239. plugs 5,6,7,8 slightly fouling. 1,2,3,4 look great WTF??
  240. Singal plane help need guys..
  241. it nvr fails!!!(fuel rail prob)
  242. Screwin around..
  243. Piston guys come in.....
  244. gas and oil
  245. **PICS** grand sport stripes
  246. How to replace oil pressure sending unit
  247. MAF Ends
  248. is deltec ign. good for h/c cars
  249. what oil filter are you using
  250. Entry level Mods to 96 TA
