View Full Version : LT1-LT4 Modifications
- Lloyd Elliot LE1 Heads any good?
- Intake
- leaking oil
- powerdyne
- Limitations on the Stock PCM?
- cam
- .600+ Lift on a DD?
- Wut happened to my fans?
- mods for a hotcam
- For My Houston Ppl!!
- exhaust
- Need help deciding on a paint scheme
- Is a Single Plain Intake Streetable?
- Hi fron the new guy, Some advice cat back?
- opinions on solid roller vs hydrualic roller
- Borla + LT = :)
- ****need Help On Cam****
- MSD LT1 Pro-Billet Distributor (Optispark) Group Purchase!
- Best Suspension upgrades for your dollar?
- LT1 motor plates
- Relocation Brackets
- Good Place to Mount A Tach?
- car shutting off???? need help
- YES!!! My pretty much stock lt1 beat an ls1!
- New Strano bars front 35mm & rear 22mm swaybars, Pics !
- true duals too loud for a DD???
- Crane quick lift rockers
- Stall for my 396?
- Car still over heating
- Pacesetter LT's installed, need help!
- whats wrong? do i need high torque starter?
- cutouts
- best way
- Noob needs help, What to do with $7500
- throttle response
- Great Having a Buddy in the Biz
- My Car
- Spark Plug Wires
- stock lt1 head flow?
- i simply need a list of tuners
- Car idleling really weird
- Pacesetter Vs. Hooker Headers
- What numbers will it put out?
- Dyno'd the car
- cleaning the maf
- warm cockpit
- Primer
- F/S P&P Heads
- clear lights size?
- heads sale
- exhaust leak
- Anybody got a clue to why my car is running very very rich (datalog inside)..
- does anyone know?
- need info on heads for my car
- Carbureting the LT1
- lt1 cam
- speculations on setup please
- TB bypass
- Anyone running Electric Cutouts?
- Cam Help
- very unique opti problem...bad oscillation destroying bearings?
- Will I benefit from a 2 1/2 y pipe with high flow cats?
- fs: chrome zo6 wheels
- Need a little help
- exhaust leak
- free tb mods
- LOOK...going to look at a car tomorrow
- Emissions?
- WTB: lt1 long tube headers
- Thinking of swapping M6 in for the A4
- Hypertech Power Programmer?
- Replacing wheel stud....Having a hard time putting new one in!
- Rear valence off of a 95z
- Bilstein Heavy Duty Shocks, how good?
- Need an OPTISPARK!
- Do I need a tune for a big cam? Not newb situo...
- A Good Undercoating?
- Help.....
- Head And Cam Help!!
- 93-97 ss hood straight from slp nice deal on z28.com
- how do i pull drivers side airbag?
- blowing out tranny pan gasket
- Oil pan Question?!?!?!?!?!?
- really weird a/c problem
- cheap juice?
- Muffler eliminator pipe
- ready to burn it down!!!!
- Help? Intake Q
- Loudmouth question
- Error code 16-Low resolution error.
- electric water pump.
- My LT1 vs stockish LS1's.
- Will this Intake work for my Ram Air Hood?
- hot cam help
- Backfiring
- Finished Turn-one PS unit, Pics
- Problems amung problems
- Stock LT1 Fuel Mileage?
- LT4 Hot Cam Kit... best place to buy?
- Formula overheated
- New best......
- spyder gears help
- Vortech S-trim kit for sale
- Whats the best Lt1 Cam
- Hooker gave cruise cable burns in a bad way
- dynomax catback, anyone running it?
- Retrofit 700r4 lockup question
- How bad is gas mileage with a TC?
- Question on 986 springs w/ cc306
- Thinking of getting headers.
- Help me out: Full Boltons
- Pinging??
- LT Header clearance
- tensenior pulley....
- a push in the right direction.
- ****Need a HP est. plz****
- front end conversion
- 02 sensor ?
- looking to buy a Remanufactured engine
- Injector??
- At what point should u have an LT4 KM
- 4.6L = Bye Bye
- So I put my LT in
- Engine Progress
- 02 sensor ?
- running cold
- new camaro problems
- where to buy lt4 km?
- It finally lives
- Will I need new motor mounts when putting in mid-length headers?
- Its In!!!!!!
- What Mods Does This have???
- going from lt1 to ls1
- CC306 Cam
- Dyno Numbers
- soft clutch
- car stumbles after hard right turn.
- I purchased the LTCC
- IAT relocation after a speed density conversion
- GM847 Cam Driveability
- Heads and Cam Packages
- Next upgrade
- 94 4L60E trans interchanges to 95 4L60E?
- power steering probs? plz advise!
- FS: LT1 Hooker LT Headers
- secret borla exhaust???
- Buncha LT1 problems
- stall
- morel lifters
- my project, oh boy this is great
- Help Needed
- throttle body question.
- LT1 Cam 4 sale
- i have some money and i want..
- Car dies in rain??
- Programmer.....
- Anyone ever COMPLETELY bypassed VATS?
- Tb idle
- MSD Blaster Coil?
- Just when my car is running great..
- sts turbo system
- need torquing specs for pacesetter headers
- How much hp could this setup have???
- hesitation under partial throttle
- LT1 install in third gen camaro queston
- For Sale Built T56
- SFC's, need some advice.
- fuel rail
- Favorite parts sites?
- rev limiter
- ADVICE!!!! please
- Collector Gaskets and Bolts
- My new ET Performance heads
- guide plate help????!?!?!?!?!
- Ignition box mount location
- LT1 guys with 97+ tailights COme in!
- Help out PCV or brake booster lt1
- PCV or brakeline
- Smoked him!
- spun bearing?
- P0336 code
- FS: 96 LT1 Trans Am Ws6
- TB Bypass 5 minute install my ass.
- non self adjusting rockers/giudplate questions
- starter relay help>>>>
- Which headers????
- MSD retard
- port job
- dissapointing LT1 dyno #'s ... come and read
- Will This Fit? *link inside*
- LT-1 Hesitation question?
- Knock knock knocking on heavens door.
- What do you think about this cam???
- Fluidamr?
- 383 up and running few problems...
- 1/4 mile gains from Lts and 373s??
- Header Help, 911!!!!!!!!!!!
- Need a complete list for cam swap, please
- crankcase pressure
- Volt Drop On De-acceleration
- LT1 PCM reprogramming
- What should I gap my Tr-55's?
- Tranny mount
- Have 2 Ignitions, which one is BEST.
- Accel super ram intake
- Illinois Emissions Guys in here!
- what the fuck!
- How do I get this bitch off
- Driveshaft?
- How To Keep Heat After AC Delete?
- Haunted Formula please help
- Removing LT1 EGR etc.
- Another Opti ?
- Wtf No Brakes
- 10psi on stock lt1??
- not so good vibrations!
- brake rotors
- SHort vs. Long headers????
- Problem
- Roller Rockers on my LT
- Trickflow Head Q's????
- Does this sound like a faulty ignition switch?
- Nitrous Install Questions
- Water Pump Problem
- Decoding RPO's?
- Sugesstions on plugs and wires?
- Lt1 Edit
- Gears Next, Tough Call.
- which chip
- maintaince day
- need help with my water pump hoses
- air removal question
- just a advice
- cooling fans wont come on
- 58mm TB
- Crankwalk ????
- 3.73 or 4.11
- differential question
- help car won't start.
- Coolant level light stays on...
- Damnit, need some answers
- F/Y-body MAF differences?
- my car is all f-ed up...help!!
- detent cable (kick down cable)
- Single cat costs?
- WS9 rpo?????
- help start my car....
- Need cam advice for LT1 intake application on an L98
- lt1 electrical / stereo
- Edelbrock Intake Manifolds For LT1's
