PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Spark plugs stall converter?
  2. ~crank hub bolt backing out
  3. Why no 7 second LT1 yet?
  4. everything youve ever wanted to know about Opti!
  5. Delteq Opti Eliminator
  6. What is a good redline on a stock block
  7. Quick !AIR !EGR question...
  8. is there anywhere that sell roller rockers in sets of 4
  9. Stroker ????????
  10. Anyone work at car shop or dealership/service or experience this ??? LT4
  11. 1 to 3rd 4l60e
  12. is this right??? e.t vs mph either way nice job!
  13. gear drive timing setup for LT1's?
  14. New pics of a few nice LT1s
  15. Motor Finally Going In!!!!
  16. car hard to start but starts, runs fine
  17. Y-pipe?
  18. Removing my Delteq, need help
  19. Pulled DTC codes low TPS sensor
  20. what kind of FUEL system will i need on my 13.1 motor
  21. Head thread help
  22. if you run octane then come in here
  23. Anyone with a CRT elbow come in.
  24. injectors
  25. valve seal??s
  26. Opti vs LTCC
  27. Overheating.
  28. Bad vibration
  29. Help me choose a cam!
  30. valve spring question..
  31. new day, new problem
  32. custom intake under stock transam Hood?
  33. RockAuto 5% Discount code
  34. o2 question step inside
  35. t-56 problem.
  36. What kind of compression ratio should I expect...
  37. Ways to retard timing for nitrous
  38. Injectors
  39. quick cam question
  40. LT1 Backfires After Header Swap
  41. head and cam work
  42. What is this? And what hose connects to it?
  43. Restoring my 1995 Bird..
  44. CC503 question
  45. !Smog Pump
  46. Different oil pressure sensor positions...why?
  47. knock mod
  48. got this today!!!
  49. Question about Plugs and o2s
  50. Sold the LT1
  51. A/C Delete Question
  52. 160 temp running 210?
  53. Air Pump problems???
  54. fog light blackouts
  55. 3rd gen SC GTA vs H/C LT1?
  56. Whay do i do???????
  57. stall converter help
  58. Car running hot
  59. LT1 into a 1985 camaro
  60. pretty sweet roots blower setup
  61. stereo
  62. wwjd
  63. best place to buy catback system for out lt1 car ?
  64. No Oil Pan Baffle
  65. This squeak rises and falls with rpm, seems like its comming from front of motor?? ?
  66. LT1 wiring guru's
  67. code 63
  68. AFR heads
  69. low fuel pressure at idle
  70. Casper383/Fast93Z?383Formula!
  71. Brake hoses Braided Who sells?
  72. How does this Pressure Plate look?
  73. Can fuel pressure affect idle?
  74. bad opti = shaking?
  75. perfect ending to a not so perfect day.
  76. New here
  77. Id this motor please!!
  78. Im I using the wrong oil filter ? Mobil 1
  79. Lt1 cam & timing set in a GM Goodwrench SBC???
  80. opti help
  81. adjust idle rpm with tech II?
  82. Cracked a water jacket
  83. Instead of selling my car, im gonna change it, opinions needed
  84. seafoam???
  85. Speed Inc cadillac cam vs. lloyd elliot sleeper cam
  86. what plugs should i go with?
  87. pics of the ta
  88. 94 LT1 Blowing FUSE!
  89. LT1 Rebuilt (Emissions ?)
  90. p1sc help
  91. LT1 question on the main journals
  92. would i need a tune
  93. seats
  94. Pressurizing coolant res
  95. Going on a diet
  96. Figured out my oil leak..
  97. Custom exhaust question
  98. Acceleration
  99. LS1 Lid Guys, let's see your rad brackets
  100. Trip odometer is not working
  101. Cam Question
  102. How to change belt and fuel filter ?
  103. do you need to change pushrod lengh...
  104. Stock stall
  105. 2 more problems...ugh
  106. new setup complete!
  107. Lt4 heads
  108. o2 extension for 96 lt1. Specific Q's..
  109. Poll: Short block or machine shop.
  110. Help me out!!
  111. Finaly got some pictures taken
  112. P0300 Misrfire
  113. 383LT1 vs Supra
  114. will a 5spd from 92 iroc z28 work in a 93 z28 a4?
  115. Overheating Issues after Opti Install
  116. Dynaspark Opti Install
  117. can i reuse my cam ????
  118. Fill up , then does not start?
  119. patriot heads
  120. Cooling fans dont start!
  121. 383 13.1 what heads should i go with
  122. current pics of my project
  123. egr removal question
  124. LT1 wont start
  125. Camaro events in Pacific northwest.
  126. opti problem
  127. LT1 problems
  128. P1153 help
  129. piston rings w/ N2O
  130. finally gettin caged
  131. Tuning question
  132. what was thestock tranny in 95 z28?
  133. cam selection help
  134. Anyone care about MPG?
  135. Vacuum pump
  136. head and cam
  137. Any one here running spark plug wire over vavle cover ?
  138. First cam swap and have questons.....?
  139. Optispark tune-up? or Replacement
  140. Help! Installing Opti and want to delete AIR
  141. RIP Ponitac
  142. Disappointed after modifications!
  143. Aftermarket steering wheel
  144. TH400 in my car (will this one work?)
  145. Headers, Cat backs? What should I do??
  146. Where to buy oil pumps
  147. LT1 vette heads
  148. Question about cc503 and stock heads
  149. What size is this plug?
  150. cooling problems
  151. MSD-6AL worth it?
  152. want to rebulid but dont know what to do.
  153. needing part# for xe230/236
  154. Whats the difference between the two motors
  155. Crank hub removal
  156. Questions.....
  157. what y pipe for jethots?
  158. Best DD Heads for 383
  159. I went over to the dark side... kinda
  160. A/C Diagram HELP!! ASAP
  161. Header Question
  162. Biggest Stall on Stock Rear
  163. What mod next?
  164. stock windage tray
  165. LT-1...Internal balance, or external?
  166. Thinking about getting this filter...what do you think?
  167. Lots of questions...maybe one problem?
  168. Where is this oil coming from!?!
  169. Comp full aluminum rockers
  170. HELP throwout bearing #
  171. Fel-Pro 1406 Header Gaskets
  172. Cam?
  173. Starter has passed away
  174. Wow!!
  175. starter headache?
  176. ?'s about deleting A.I.R.
  177. start up smoke need help
  178. Codes for my LT4
  179. Comp 26918-16 or pac 1218-16
  180. Just got my Lloyd Elliot Trickflows and intake VERY impressed!!
  181. Need FPR and Vacuum line P/N's
  182. Need help: Engine on stand leaks oil from..
  183. top speed
  184. Headers mid or long lt1
  185. Bad vibration at 130+
  186. what kind of power
  187. HELP asap!
  188. Surging Idle
  189. Manifold/Valve Cover Paint Job
  190. need yor opinions
  191. LT1 swap question
  192. What Do You Think
  193. how do i lift the front wheels
  194. lpp
  195. Motor mounts question...
  196. spun rod bearing
  197. Potential New Owner, Quick Issues Before Sale, HELP
  198. crane 10308-1 retainers, k800 spring
  199. how to bore the throttle body to 52 mm?
  200. 93 to 94-95 PCM and Harness??
  201. New Engine & Clutch Break In
  202. suggestions
  203. K&N cai, SLP cai, or other?
  204. So what would you do to finish off this build?
  205. sbc truck headers for turbo setup?
  206. Wtf...idle /start up issues help
  207. Quick disconnect
  208. Shaking problem...
  209. Jegster Tq arm
  210. lt1 head gasket blown????
  211. LT1 heads (minor porting)
  212. Spark plug gap with 6AL BOX...?
  213. 2 Bar MAP
  214. LT1 diagnostic help
  215. Peculiar problem, rear hatch button does not work ?
  216. If you live in or around houston TX and you like crusing come in
  217. car's running rich
  218. Comp. port not working...
  219. Computer question
  220. what blower kits are out there for lt1's?
  221. stock injector tune
  222. Edelbrock Shorties Flange Issue???
  223. The Firechicken Project
  224. otvc plug wires with aftermarket valve covers
  225. Superdamper necessary for brand new LT1?
  226. What do I change in the computer after doing gears?
  227. fuel system problems?
  228. WTF is wikipedia talking about
  229. Header Install light smoke after
  230. Exhaust help please
  231. fans wont work???
  232. are 6's possible
  233. What if header install Q
  234. Running like a beast
  235. Whats the going rate for LT1/T56 combo?
  236. radio, dome light, & trunk button ont working
  237. Changing oil sensor
  238. Anyone doing their own tuning...questions.
  239. Worst Part/ Aftermarket component Experiences
  240. She is ALIVE once again!
  241. Borlamouth on a mostly stock LT1?
  242. horrible noise
  243. Head light covers
  244. Pacesetter longtube headers
  245. Help wiring a LT1 in street rod
  246. stock lt1 a4 60ft times
  247. Car not running after rebuild
  248. clutch fork
  249. New rebuild i smell fluid occasionaly
  250. Wanted to share some new pics!
