PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 [139] 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. 96 LT1 computer/flywheel Q's
  2. Rear main observation
  3. Cam Help
  4. 94 block heads into 95 car
  5. hypertech
  6. Few pics of my car from a local show.
  7. Header Installation Question
  8. Pulling my Motor and Tranny out of my OBDII 96 & going to an OBDI 95 TA, Knock Sen. ?
  9. BCM is making a clicking noise
  10. whats my motor/trans/ecm worth?
  11. LT4 Hot Cam Kit What Should I Expect??
  12. Ladies and Gentlemen, my nitrous is now.......
  13. Fuel pump/regulator?
  14. Strange Misfire
  15. Bad O2 making me lose?..
  16. does anyone on here have this setup?
  17. 94-96 camaro gauge cluster in 93?
  18. Wanting To Run Nitrous On Hyper Slugs
  19. help!!!!
  20. '93 LT1 T56 Better Gear Ratio?
  21. camaros in idaho!!!
  22. Head bolts. Thread sealer
  23. 1/4 mile
  24. bmr vs hotchkis
  25. 1500$ what to do
  26. How do u put fluid in a six speed tranny??
  27. o2's?
  28. switched to RP, lost some oil pres.
  29. E.W.P And Heating up?
  30. Tag lights
  31. Need injectors
  32. Ideas on cams?
  33. detail my car today got some pics...
  34. cam dowel pin
  35. 4th of july fun!
  36. My first LT1 rebuild and I need some help.
  37. what cam?
  38. Optima battery problems! Need Help!
  39. MSD Blaster coil... Opinions?
  40. How Hard To Change Injectors LT1
  41. affordable water pump
  42. Manual fan turn on switch is it worth it
  43. post slp loudmouth vids if you got em ...
  44. Next bolt on opinion
  45. need lots of help! opti install issues
  46. single plane intake worth it on my setup?
  47. Any performance advantage w/EGR Delete
  48. ASR Delete
  49. what does it do ?
  50. lt4 hot package
  51. Need help with Cam swap.
  52. wanting pacestter headers
  53. How much ET gain removing the catback
  54. msd ignition
  55. Which Brand Injectors
  56. SES light flashes on and off???
  57. LT1 Valve Covers
  58. Odd offering at Autozone for 96 Camaro...
  59. How hard is it to over heat o2 sensors?
  60. check this cam out;something different
  61. Piston hunt.
  62. Cam Questions
  63. Opinion on which 1.6 RR
  64. Anybyody seen or heard from TurboBob?
  65. ENGINE REBUILD.. help
  66. LIght weight flywheel questions.
  67. does anyone know what this is?
  68. 1/4 times
  69. replacement EGR tube
  70. 93 LT1 Z28 overheating?
  71. top to bottom
  72. slp fan over ride switch
  73. how many miles to break-in magnaflow catback?
  74. coolant light!!!
  75. Intake leak causing oil pressure to be low?
  76. Whats up with lloyd elliot?
  77. Croosed drilled vs. stock...
  78. 4L60E's weight comparison
  79. Engine Balancing
  80. Need suggestions!!
  81. A couple issues after longtube installation and EGR/AIR removal
  82. injectors?
  83. LT1 controlled shut down
  84. spring question
  85. Stall and Longtubes
  86. need help please, where to find these for cheap?
  87. Summit opti
  88. Injector help please
  89. 3" collector to a 2.5" x pipe?
  90. open borla vs. open cutout?
  91. Spintech
  92. lt1 question need answers
  93. which torque converter?
  94. What Is The Correct Torque For 97 LT1 Head Bolts?
  95. Low oil pressure?
  96. opinions on exhaust for my LT1 magnaflow/SLP/rumbler with LT's
  97. do i need a monoblade?
  98. 488 LT1 at KC LT1 Shootout
  99. Need M6 Part..
  100. LS1 vs LT1
  101. tracking a miss/ plug wires are crap
  102. Next bolt on?
  103. Header Gasket Help
  104. ?? Will these rotors fit on my 95??
  105. O2 Extensions for the 93 1 wire?..
  106. Lt1
  107. What auto trans used in 93 Z28s?
  108. ltcc guy's in here please!
  109. need help on were the wires go on the starter
  110. tune question
  111. went junkyard hopping!!!!!
  112. Tuning software?
  113. Car died, now wont start.
  114. engine/trans mount
  115. Wiring harness for a M6 96 Z28. Where to buy?
  116. hot cam question
  117. i just got fucke.d my pacesetter lt's are for a 94 not 93,what to do?
  118. Backfiring motor
  119. Running Megasquirt on your LT1? Post your setup!
  120. steering shaft help
  121. Stock to Ram Air Hood swap?
  122. Got my cam yesterday!!
  123. A few photos of the car
  124. Deciding on Exhaust
  125. Nitrous LT1's come in!!
  126. thinking about swapping to M6
  127. HELP! car wont start :(
  128. Headers
  129. 58mm Arizona Speed & Marine throttle body, how much can I sell it for???
  130. Slight irregular tap at idle
  131. Which wheels? Telstar's or Convo Pro's?? WITH PICS!
  132. ? About Timing
  133. cam decision
  134. LT1 blocks
  135. Cheap effective mods?
  136. non emissions exhaust question
  137. Iac?
  138. LT1 intake leak??? HELP!!!
  139. I want 350 hp
  140. Raced my buddies fully built procharged 306!!
  141. Maybe I'm out of touch?
  142. Funny Idle, Falling on Face
  143. Finding your calling insight needed
  144. Lt1 head removal guide
  145. LE1 LE2 How to tell them apart by looking at them HELP.
  146. 383 stroker kits
  147. electrical issue
  148. Eh.. bent/roughed up the headgasket..
  149. New LTs
  150. TSP Rumbler LT1 exhaust clip
  151. best in ontrio
  152. cam install questions please help!
  153. Question about LT1 SLP Air INTAKE KIT
  154. i need a new crank pulley, how about an underdrive?
  155. ignition problems
  156. Locked keys in, opend door with no key
  157. car problem
  158. Mid range Stumble???
  159. AT IDLE WHEN I HIT GAS TIGHT CAR Knocks and ENGINE STOPS
  160. Got some parts in..
  161. random cylinder missfire 97 TA
  162. convert to a single plane intake?
  163. What Header gaskets
  164. Gen I/ Gen II Differences
  165. Camaro Window Parts
  166. alternator relocation brackets.
  167. a/c compressor removal
  168. What happens when you burn the clutch instead of the wheels?!?! (PIX)
  169. LT Headers WITH EGR/AIR
  170. Optispark Options For My 93 Lt1
  171. Trans....????
  172. LT1 bird body parts
  173. could yall check this stuff out???
  174. cc503 or Ai grind?
  175. true dauls give me the opionins
  176. Formula Guys Come Inside!
  177. The Problem
  178. got the y-pipe welded...
  179. Gas mileage?
  180. What size Dynomax Bullet
  181. burning plug wires need help!
  182. power steering pump
  183. wanted: 95 impala pinouts
  184. Dtc-13
  185. Quick ?: Front O2 sensors.
  186. WOW wtf. I just got beat by a freaking 300c ??
  187. Think I've Decided On My Combo....
  188. CC306 + stock pushrods
  189. Quick question on installing Pacesetter LT's
  190. Lloyd Elliot or Advanced Inductions
  191. FIDANZA flywheels,any good...thoughts?
  192. Never heard of this. PLEASE HELP
  193. One Screwed up Bird
  194. crank pulley
  195. exhaust?
  196. THE BEST BOLT ON's FOR THE BUCK FOR A LT1????
  197. 383 cam with ported heads
  198. Is anyone going to the LTx race in Sept.?
  199. Where can I get two of these cheap?...
  200. LT headers on a 94?
  201. Exhaust ?
  202. ASM monoblade TB, truely how good are they compared to a 58mm BBK???
  203. check light on VAF code?
  204. 97 Formula/ Trans Am Ram air problems.....
  205. lt1/lt4 conversion
  206. what to do about the rebuild?
  207. underdrive pulleys and other bolt on questions
  208. A/c delete pulley with march pulleys what belt size?
  209. Gtech
  210. Injector questions
  211. LT's install, easier from top or bottom?
  212. 383 Specification Questions...
  213. What brand 42lb injectors?
  214. what are the differences in the engine harnesses.
  215. Golen motors
  216. Is a stall converter bad?
  217. acorn taillights
  218. Starting Problem
  219. Cam, Nitrous Noob question...
  220. How quick can I go for $3,000?
  221. Back after 3 years
  222. Hoping to get a loan soon
  223. Can You Bore a LT1 .60
  224. pushrods?
  225. Does anyone know what pulse generator failure means
  226. I got my opti problen taken care of!
  227. O2 extentions
  228. Rod Balancing Question
  229. looking for part
  230. Inst cluster lights + radio wire = ?
  231. Another 383 stroker thread!
  232. header install problem
  233. 1000hp combo parting out...
  234. Color change: What do you think
  235. What is this part? and how do i get it unplugged?
  236. 383 stroker crankshaft question
  237. lake wood traction bars
  238. Head and Cam opinion please
  239. What's up guys
  240. awsome cc503 dyno today
  241. 94 TA- Dallas Inspection Help!! ? Please !!
  242. Head Suggestions
  243. LPP Stainless Headers and Y Now on Sale
  244. Tapered Deck
  245. Heads???
  246. Is Vht Ok To Put On The Tires Or Better To Put On The Street
  247. pcv valve
  248. Quieten the loud suction of a BBK throttle body
  249. 160 Degree Thermostat
  250. What Rpm Do U Launch Your Stall At
