View Full Version : LT1-LT4 Modifications
- Lt4?
- best intake elbow
- Can I use this flpro gasket with ported stock LT1 castings
- dumb iat question??
- gonna have $3,000 to spend
- PO0410-Secondary AIR Injection system failure.
- LT1 Short Block GP!
- back when lt1 was the king
- I dont get it??
- Header Install
- New SS times
- LT1 distributor cap?
- Need LT1 Supercharging advice
- Spark Advance
- Moser 9'' or Moser 12 bolt??
- finally ran at baytown... bad results.
- How much would my rolling chassis be worth?
- jethot header problem, need help
- help installing headers
- 400 HP Goal
- Need Wiring Diagram For Z06 MAF!
- pcmforless tuning?
- Fuel injectors, Fuel pressure?
- Which cam is better?
- Dragstrip tomorrow night!
- RWHP out of the EX 224/230
- CC306 vs. GM 847
- STS rear mounted turbo.
- Opinions please
- jerking
- A4 to TH-400 to A4
- Pics of my new exhaust before installation
- 1le AC delete pulley?
- '96 LT1 Impala, stutters at very light throttle, what's wrong?
- installing LT headers and optispark on a 96 Impala SS?
- Ok now that I got the $$$ what do I buy?
- PCV?
- do Jet-Hot LTs come with header bolts?
- SS airbox
- Kenny Browne DD SFC's and x-pipe question.
- Spark Plugs for Supercharged LT1?
- X-stream Air lid from K&N
- New exhaust set-up, opinions?
- what does it take
- what oil pump do i have?
- LT1 Crank trigger
- LT4 383 vs LT1 383?
- X-Pipe...
- O2 sensor
- What's wrong?
- LT1 Editing Software
- Anyone have the 227/233/112 cam?
- Horsepower question!!
- LT1 1/4 Miles Times?
- Buying an LT1 - tranny swap?
- 355 or 383 Stroker?
- where to get get gm gears
- 355 lt1 build
- Well i got my catback installed
- what is the fastest lt1??
- Coils, Plugs, and Wires - what kind of difference in performance?
- Free Mods For The LT1
- cutouts harm the engine?!
- Miss after cam swap
- Anyone with PCM Tuning experience?
- question bout cutout, before or after cat??
- meizer ewp question?
- Y-pipe for 97 LT1
- LT1 cam swap?
- Traction control
- C4 Vette getting up to 230 oil temp.
- My Ignition Problem...
- Heater core bypass?
- low end stumble and big loss in power
- Opti
- putting on rear end gears!?
- header install??
- how to make the gmmg sound best??
- a4 to m6 conversion
- great sounding Z28 (93) without spending tons?
- what to buy for a little rumble in the engine??
- difference in gears?
- Pushrod/guideplate wear and pushrod length question
- Anyone running QA1's...
- descreen my MAF?
- ERRRR, car is STILL missing!!!
- How much power does Air foils give?
- What kinda power would i make?
- How to hit mid 12s?
- Where Can I Find Some Big Fuel Injectors
- 1993 camaro lt1 5.7, backfiring through intake
- Anyone running LS1 injectors on their LT1's?
- LT1 Starter upgrades?
- What Headers To Get?
- more help on accel dfi
- Bolt on LT1 times
- high end miss...
- LT1 with GMMG
- LT1 Edit or Tunercat
- Guide me to 370+rwhp mark! :)
- misfiring lt1
- 95 vette and CAGS
- FYI: do not get poly motor mounts!
- tranny/clutch/shifter problems?
- Valvetrain mod questions
- CNC'd LT4 head flow numbers inside.
- Milled Lt1 heads
- New Moderator
- Basic LT1 Specifications
- lt1 ignition issue
- Impy rebuild update w/pics
- Manual Fans wiring?; reflash computer?
- what kind of power do you think my 383 LT1 will make?
- are all Lt1 blocks the same?
- misfire or hitting rev limiter?
- Stock times!
- opinions on mods
- What should my car idle at?
- Looks like my optispark is dead again!!!
- lt1 gas mileage?
- What gain power out of pulleys?
- Anyone change pistons??
- GM 847 & CC306
- how hard is it to pull the motor out the top?
- Tuning
- Crane High Six ignition problems?
- header gaskets?
- Compression ratio and cams
- i need more power... a lot more
- does MTI still work on LT1s?
- will Corvette LT1 fit?
- 150 shot on stock fuel pump
- rear end
- Maximum bore LT1.
- headers and gears
- Latest track results within
- 93 a4 vs 93 m6
- what are a good set of heads
- New Mods
- exhaust cut-out causing misfire?
- argh What have I done?!?!
- Dyno'd the Z
- my new motor
- Correct oil pressure??
- Any tips on installing Pulleys?
- LT4s vs AFRs
- whats wrong with my car??
- What brands do you prefer when it comes to ignition gear?
- Stainless longtube headers.
- msd 6al question
- o2 sim question
- Anyone know if the LT1 and the LS1 mass air meters are interchangeable?
- Backfire
- 94 camaro running shitty
- Selling the car, here's the plan...
- lt1 emissions-legal headers?
- Any 93-94 owners with vented optis?
- Installed Jet Hot LT's on my '93. Picture's inside.
- Jay from Speed Inc at Byron on opening weekend (4/4/04)
- Sputter at low RPM's
- obdII cam selection
- 1.7rr question
- Help me find an LT4 block?
- 94 Caprice
- need some detailed pics of a 95 Camaro LT1 engine bay
- 96 Chevy Impala SS Problem
- Why do YOU love the LT1?
- To coat... or not to coat
- How big of a stall?
- How are the Lt1's?
- lt1 fel-pro fast system?
- about to install headers
- Jethots
- 94Z28..changed to 52mm tb..vaccum lines shot
- 94 Z28... put on 52mm throttle body.. tb vaccum lines shot
- ignition upgrade?
- What kind of power could you make?????
- Ok....help me decide
- Hooker Super comp shorties???!!!
- Need a Nitrous Cam
- tell me what you think about this TA
- what is the firing order?
- 383 vortech LT1 - now it puked coolant everywhere! help!
- Help with Cam recommendation
- BBK 52MM Throttle Body = Garbage
- MAX Horsepwer from an LS1?
- Clutch and Drag Racing
- What should I be trapping?
- Need some help here!
- Buying a LT1, What to look for?
- Why CAI
- Need a cam, comments?
- Best place to buy short block???
- 94 z28 needs help
- Golen engine service???
- LT1 nitrous recommendations
- Weekend Mod Update
- 69 camaro 4.10 gears??
- Autometer elec F/P guage stoped working! HELP
- Is a 95 formula obd1 or obd2?
- My Next Buy???
- best place to buy LT4 heads...
- Problems With 00 Impala/93 Z
- Another Problem!!!
- what was the LT-5 rated at from the factory
- Mechanical Oil Guage
- Finally breaking into some potential...
- 100k Mile stock Bottom end 122mph
- What was the LT-5 rated at from the factory
- Any experience with cc306?
- Blown 396 LT1...
- harmonic damper
- 350-400hp? lt1
- this a problem???
- whats an lt-4,lt-5 and which is dual overhead 350 that was in the ZR-1
- Who sales LT1 edit
- Cam choice in a 396...cc306? , GM847?
- need info on the 94 vette??
- LT1/LT4 vs. LS1
- Alright, prove this guy wrong.
- Help with MSD window switch
- Vented opti swap
- SES light comes on and temp gauge doesn't move intermittently
- Who owns the record for TOTALLY stock internal NA LT1
- Headers
- LT5 or LS1
- Need help deciding for performance, and in which order
- LT5 block?
- HOW CAN I BEAT A EVO ttt
- cc306 and GM847 cam?
- 98' T/a
- Injector swap
- HELP! Tryning to remove fuel line Schrader valve core pin
- Cam advice
- Any Cali People Live In Bakersfield Or In Between Visalia?
- accel gen 6 issues
- Changed the Optispark.....
- GM 847 Cam
- Help!!
- Took a few pics of my car today, with new parts installed
- BMR/Spohn parts install
- any guess on horsepower?
- General Info Request...
- what is this?
- LT1 Porting DIY
- Haltech
- Meziere EWP users.......
- Opinions??
- TPiS ZZX CAM IN STROKER
- adapting stainless braided to stock rails
