View Full Version : LT1-LT4 Modifications
- Exhaust decision
- my cc 306 video
- Better Sound
- WTB LT4 intake
- Cheap stroker for a Jeep
- header gasket question...
- Backyard exhaust swap
- LS1 Lid Conversion
- Just returned from Iraq...time to spend some $$$..but need info...
- Power steering reservior relocation???
- Problem with my TA
- Strange starting prob?
- Dynoed my car today
- help with engine leaks and headers
- Custom Cam Sound Clip
- car is "bucking" and dying/stalling on me randomly
- I need roller rocker suggestions please.
- opinions on this cam?
- Pulley doesn't fit easy, why?
- Looking for advice on Cam and Head set up for my 95 Z28 A4
- why me?
- Just finished dynoing our H/C Impala....
- Getting oil pressure in new motor
- Tsp Rumbler
- Loudmouth II on an LT1
- Custom fabricated head plate for Delteq & LTCC users
- ring & pinion question
- Interesting little tidbit
- Please help with a few quick questions.
- Fluid Danmpener
- Cam=bad things
- Getting ready for the track
- Car wont start
- Trad. dist. setup
- C1242: Rear ESB does not hold motor
- LT1 pistons
- GM847 cam tune help
- WTB: LT4 CAM & 1.8
- Anyone using K-Motion k-700 valve springs
- Hi, new to the forums
- Delteq Opti-Direct??
- car wont start,need help quick
- stock deck hight
- How much?
- Is a 150k mile lt1 old??
- A few questions?
- Pushrod Lenght for Trick Flow Heads
- im new here just saying hi
- A/F issue
- suspension
- WATER PUMPS for dummies
- Wheel Hub Help !!!!!!
- Code help!
- what is needed to get rid of the opti?
- Ram Powergrip users inside please
- Opti/not starting update
- Anyone used this elbow?
- overheating problems
- Exhaust manifold collector bolts?
- 64' GTO EnGInE OR ExHaust SOUND SWITCH... HOW?
- Hot Cam Advice !!!!
- Idle issues is it my PCM?
- Thermostat Question
- Searched the Newbie FAQ, could use some quick help...
- Thoughts on the COMP XFI 230/236
- Fuel Pump
- no injector pulse
- The Whore Runs
- headers help
- ls1 y-pipe on lt1 headers
- anyone using valve cover adapters?
- dyna spark daed?
- What do you guys think?
- Fuel Limitations of a H/C Z
- top end
- New best for 396 LT1 - 11.7 @ 118.8
- Please help diagnose some problems
- Wiper arms
- Replace water pump and timing set w/Cam?
- help my car is messed up
- founf this chart, are these good guid lines????
- Im at the point...
- LT1 Headers & Dual-Cat Y-pipe Package
- not sure if this is the right place to post
- H/C swap Help!!
- Best rockers for stock LT1 heads?
- 94 lt1 drops out under heavy throttle
- Timing
- longtubes
- Need GM part #
- Engine price..
- 4:10's...are they woth it to put on my car?
- How hard is it to replace the opti?
- What heads are these?
- actual compression help!
- Y-pipe..LS1 to LT1??
- ebay deals for throttle bodies
- LT1 removal
- Pix of new 3" Stainless True Duals...
- help asap!
- ok, so i want a louder muffler.
- what do you guys think of these heads?
- What Is The Best Cam Setup For My LT1
- 383 stroker
- Locate THIS part!
- Rod knock
- Mahle manufacturers of stock LT1 pistons?
- Nos For My Lt383?
- Just wasted $300 on a Opti that didnt fix my problem, now what?
- DYNO Results in
- What can the stock Timing chain handle??
- Melling oil pump users may want to look at this
- bottom end kit
- engine is bouncing off idle when revved
- cat question...
- All coming together
- how much boost will my t/a hold??
- Jacking points on my 1997 camaro z28?
- SS spoiler coming in, what else should I do?
- Traction
- Removing Cat?
- How can i make my car like "horse runnin" sound :P LT1 T/A??
- best traction device for my setup???
- Z06 maf
- Forged or Bare LT1 block
- Overheating question
- What to do first?
- M6/ A4
- GT42-76 Forged LT1 on F.A.S.T
- 94-96 Caprice9C1/Impala 1/4 mile times?
- Annoying Cam Question
- Fuel injector swap. Nitrous and larger cam. What flow?
- vortec rocker arms
- Quick HP mods?
- electric WP
- Do i have to Have this?
- lt1 block in the oklahoma area?
- cc306 with ported heads
- high compression or turbo ?
- problem
- c6 front brakes
- Getting rid of the OPTI
- whats the point of the air pump?
- Temp guage?
- a 307?? whats the thoughts?
- Should LT1s have a forsale section?
- Please post pics of F bodies with 325/50-15 rear tires!
- Pics of my new motor!!
- Pics of the new setup with single plane.
- are they the same
- SBC heads on an LT1 - Who?
- LOW OIL light
- free ram air mod?
- Oil pump Part number??
- Convert to synthetic?
- LT1 Water pump Help!
- is my trap speed low?
- lt1 balancer question
- LT1 Guru's, take a peak
- what spark plugs are good?
- Need help/advice.
- Want to Hear a 305 114 LSA idling low..
- tap tap tap..
- My cammed LT1: cc503
- OBD2 KS compatible with a OBD1 Swap?
- Hot Cam Costs
- LS1 airbox
- Exhaust Leak
- Lt1 1/4 mile times
- k member removal questions
- Bleeding the clutch??
- Looking for emissions legal headers and y-pipe
- cam for a 396!!!!
- need advice on building this LT1
- Ordered some new parts
- Lt4 Km
- Lt-1 ?
- No muffler?
- Anyone have problems with 1.6 S/A rr's and a big cam?
- Effects of different 02 sensors
- High temp spark plug wires?
- Oil pan?
- Emissions
- Replacing the stock muffler (not catback)
- Quick Q about Cam Lube
- 355 Pistons?
- 383CI LT1 How much power?
- Ah F*** - RANT Time
- high performance oil pump
- 94 LT1 5.7 chevy block?
- Anybody think this intake could be converted to fit an LT1?
- painless hi-rpm kit
- Main stud torque spec
- Cam & valvetrain guys - couple questions
- Max Rpm
- SA or NSA RR's? Help
- Rocker Adjustment
- Where to buy LT1 shortblocks or cores?
- engine bay color change
- Headers, Y-Pipe, Rocker Arm questions
- Pistons rings
- Need photoshop help please! =)
- I cant figure it out!!
- simptoms of arcing in the distributer
- Body control module?
- Best was to get a 305 long block into the back of a truck
- LT Headers w/ Emissions...other parts?
- LS1 Lid under Stock Camaro Hood
- $ for new head gaskets?
- Head Gaskets?
- 4:10 gears
- Anyone need a long block. (affordable)
- Needle Roller Cam Bearings: what are the downsides?
- 99 LS1 over my LT1?
- A bad night...
- Comp cams 292XFI
- Ss Hood Shocks
- Delteq on the way
- Its DEAD!
- Intake elbow/nitrous questions
- F1A on the way for the LT4. have Q's?
- Finally Time for a Cam! Which one?
- Spark plugs
- What plugs should I use???
- lt1 OTVC spark wires problem
- all you 396 lt1 guys
- type of water
- Quick, anyone have the link for going from non vented to vented opti?
- D1SC guys come on in!
- Need some LT1 tuning help
- HP tuners?
- TH350 ?..... on 383 lt1
- Going Rate
- Timing Chain....
- R & R fuel pump questions?? Need Help!!
- opinions on which tranny to run...
- T-56 Clutch problem......
- Posi locks grrr..
- Help a long time lurkers idle
- Where to buy a bare block?
- LT4 Knock Module on '93?
- Destroyed it
- Headlight Conversion??
- Edelbrock LT4 Heads
- reomve oil pan with motor in car
- alternator relocate?
- Finally ordered my 355 rotating assembly
- Injectors?
- I need part number for the Comp Pro Magnum 1.6's
- Ticking noise
